    5. Text in Base64 codieren und Datei von Netzlaufwerk suchen
    • Chris76e
      Chris76e @OliverIO last edited by
      @oliverio
      nginx ist installiert, komme aber mit der configuration nicht klar.
      so sieht bis jetzt die
      /etc/nginx/nginx.conf
      user  nginx;
      worker_processes  auto;
      error_log  /var/log/nginx/error.log notice;
      pid        /var/run/nginx.pid;
      events {
          worker_connections  1024;
      http {
          include       /etc/nginx/mime.types;
          default_type  application/octet-stream;
          log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                            '$status $body_bytes_sent "$http_referer" '
                            '"$http_user_agent" "$http_x_forwarded_for"';
          access_log  /var/log/nginx/access.log  main;
          sendfile        on;
          #tcp_nopush     on;
          keepalive_timeout  65;
          #gzip  on;
          include /etc/nginx/conf.d/*.conf;
      und so die
      /etc/nginx/conf.d/default.conf
      server {
          listen       80;
          server_name  localhost;
          #access_log  /var/log/nginx/host.access.log  main;
          location / {
              root   /usr/share/nginx/html;
              index  index.html index.htm;
          #error_page  404              /404.html;
          # redirect server error pages to the static page /50x.html
          error_page   500 502 503 504  /50x.html;
          location = /50x.html {
          # proxy the PHP scripts to Apache listening on 127.0.0.1:80
          #location ~ \.php$ {
          #    proxy_pass   http://127.0.0.1;
          # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
          #    root           html;
          #    fastcgi_pass   127.0.0.1:9000;
          #    fastcgi_index  index.php;
          #    fastcgi_param  SCRIPT_FILENAME  /scripts$fastcgi_script_name;
          #    include        fastcgi_params;
          # deny access to .htaccess files, if Apache's document root
          # concurs with nginx's one
          #location ~ /\.ht {
          #    deny  all;
      server {
          root /home/iobroker/vubox/AdvancedEventLibrary/poster;
          location / {
          location /images/ {
          location ~ \.(mp3|mp4) {
              root /www/media;
      aus. Verstehe die beiden Kapitel nicht so richtig.......
      • OliverIO
        OliverIO @Chris76e last edited by OliverIO
        @chris76e
        Dann musst du bis zum Wochenende warten. Kann erst da wieder was ausprobieren
        Schreib am Samstag hier nochmal eine Erinnerung rein
        Chris76e 3 Replies Last reply Reply Quote 0
        • Chris76e
          @oliverio ok
          • Chris76e
            @oliverio
            Habe es jetzt am laufen, kam mit dieser Anleitung besser klar
            http://nginx.org/en/docs/beginners_guide.html#static
            Habe aber dennoch einige fragen am Wochenede 🤔
            • Chris76e
              Chris76e last edited by Chris76e
              @ all
              habe mit diesem Befehl die Festplatte vom Linux Receiver in ioBroker gemountet.
              sudo mount -t nfs -o soft 192.168.0.90:/media/hdd /data/images
              nach einem neustart von ioBroker ist der Mount wieder weg. Was muss ich wo einstellen das der Mount auch nach einem neustart bestehen bleibt?
              • OliverIO
                @chris76e
                Man muss den Mount in die Datei fstab eintragen
                https://wiki.ubuntuusers.de/fstab/
                Bitte eine Sicherungskopie der funktionierenden fstab machen
                und sorgfältig bearbeiten.
                Bei einem Fehler wird es sonst etwas aufwändiger die Datei wieder z zurückzustzen
                Daher bitten den ganzen Artikel zuerst durchlesen.
                Das Ubuntu braucht dich nicht zu verwirren, der Text gilt für alle Debian-artigen linux
                Chris76e 1 Reply Last reply Reply Quote 0
                • Chris76e
                  @oliverio
                  Hoffe das ich es richtig verstanden habe.
                  so sieht die fstab zur Zeit aus
                  # /etc/fstab: static file system information.
                  # Use 'blkid' to print the universally unique identifier for a
                  # device; this may be used with UUID= as a more robust way to name devices
                  # that works even if disks are added and removed. See fstab(5).
                  # <file system> <mount point>   <type>  <options>       <dump>  <pass>
                  # / was on /dev/sda1 during installation
                  UUID=c96f3fd9-4fdb-4d4e-a130-745e1d6aa3d6 /               ext4    errors=remount-ro 0       1
                  # swap was on /dev/sda5 during installation
                  UUID=366f70e9-5de5-4a48-a3bb-1cc13c0e0cb6 none            swap    sw              0       0
                  /dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
                  muss ich jetzt diesen eintrag hinzufügen?
                  # NFS-Freigabe:
                  192.168.0.90:/media/hdd /data/images nfs    _netdev,rw                                       0 0
                  • OliverIO
                    @chris76e
                    Sieht gut aus.
                    Testen kannst du dann ohne Neustart mit
                    sudo mount -a
                    Da siehst du dann ob es funktioniert oder ob es Fehler gibt
                    Beide Verzeichnisse sollten existieren
                    Mountverzeichnisse sollte man besser im Ordner /mnt anlegen.
                    https://tldp.org/LDP/Linux-Filesystem-Hierarchy/html/mnt.html
                    Ist aber nur eine Konvention und keine Verpflichtung
                    • Chris76e
                      @oliverio
                      habe es jetzt eingetragen, aber wenn ich
                      sudo mount -a
                      wird nichts angezeigt
                      • Chris76e
                        so, konnte die VM wo iobroker drauf läuft gerade neustarten, mount bleibt bestehen.
                        • Chris76e
                          @oliverio sagte in Text in Base64 codieren und Datei von Netzlaufwerk suchen:
                          Funktioniert jetzt soweit bei mir
                          hier die default.conf
                          #    error_page   500 502 503 504  /50x.html;
                          #    location = /50x.html {
                          #        root   /usr/share/nginx/html;
                              #    root           html;
                              #location ~ /\.ht {
                              #    deny  all;
                               server {
                              location / {
                                  root /data/www;
                              location /images/ {
                                  root /data/;
                                  try_files $uri /images/default.jpg;
                          Ist die so OK?
                          OliverIO 2 Replies Last reply Reply Quote 0
                          • OliverIO
                            @chris76e
                            wenn es funktioniert ist es ok.
                            warum hast du 2 locations?
                            das location das auf den ordner /data/www zeigt wäre erstmal
                            nicht notwendig.
                            da du dich ja nur im lan hier bewegst ist es eigentlich egal.
                            aber dateien aus dem ordner www wären dann auch über die uri
                            /images/www/abc.xyz
                            erreichbar.
                            mit try_files versuchst du zu erreichen, das wenn du die URL in der vis falsch berechnet hast, das dann zumindest ein ersatzbild kommt?
                            • OliverIO
                              @chris76e
                              evtl nochmal zum ursprungsproblem.
                              dir liegt ja der titel der sendung/film vor und du willst daraus einen base64 string machen. dann empfehle ich dir das nicht auf dem server (also mit dem javascript-adapter mit javascript/blockly) zu machen, sondern die berechnung direkt im browser vorzunehmen.
                              ich weiß jetzt nicht in welcher form dir der titel vorliegt (in einer json-struktur, oder in einem einzelnen datenpunkt?)
                              aber im browser kannst du relativ einfach die Berechnung wie folgt vornehmen
                              btoa("punkt 12 - das rtl-mittagsjournal")
                              das ergibt dann "cHVua3QgMTIgLSBkYXMgcnRsLW1pdHRhZ3Nqb3VybmFs"
                              die umkehrfunktion im browser ist
                              atob("cHVua3QgMTIgLSBkYXMgcnRsLW1pdHRhZ3Nqb3VybmFs")
                              in einem html widgets kannst du das dann direkt in einem binding einbauen und verwenden
                              • Chris76e
                                genau, wenn es kein bild für die Sendung gibt, wird default.jpg geladen.
                                muss ich mal testen
                                2661
