    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      LibertyX82 @tombox last edited by
      @tombox
      Das tritt in dem Intervall auf, der als Update Intervall im Adapter eingestellt ist, da er bei jeder Abfrage auftritt.
        Lucky_ESA Developer Most Active last edited by
        So sieht es jetzt mit der 0.1.5 aus.
        parcel.0	2023-10-18 19:27:50.123	error	Error: read ETIMEDOUT
        parcel.0	2023-10-18 19:27:50.122	error	Failed to get https://www.dhl.de/int-verfolgen/data/search?noRedirect=true&language=de&cid=app
        parcel.0	2023-10-18 19:26:38.978	info	Login to Hermes successful
        parcel.0	2023-10-18 19:26:38.543	info	Login to Hermes
        parcel.0	2023-10-18 19:26:38.543	info	{"Fault":{"faultcode":"Client","faultstring":"An exception has been raised as a result of client data.","detail":{"Errors":{"ErrorDetail":{"Severity":"Authentication","PrimaryErrorCode":{"Code":"250003","Description":"Invalid Access License number"},"Location":{"LocationElementName":"p2:AccessLicenseNumber"}}}}}}
        parcel.0	2023-10-18 19:26:38.541	warn	Login to UPS failed
        parcel.0	2023-10-18 19:26:38.232	info	Login to UPS
        parcel.0	2023-10-18 19:26:38.223	info	Login to GLS successful
        parcel.0	2023-10-18 19:26:37.732	info	Login to GLS
        parcel.0	2023-10-18 19:26:37.729	info	Login to Amazon successful
        parcel.0	2023-10-18 19:26:35.641	info	Login to Amazon
        parcel.0	2023-10-18 19:26:35.632	info	Login to T17 User successful
        parcel.0	2023-10-18 19:26:35.020	info	Login to T17 User
        parcel.0	2023-10-18 19:26:34.502	info	Login to DPD successful
        parcel.0	2023-10-18 19:26:32.142	info	Login to DPD
        parcel.0	2023-10-18 19:26:32.015	info	Login to DHL successful
        parcel.0	2023-10-18 19:26:29.155	info	Login to DHL
        parcel.0	2023-10-18 19:26:29.024	info	starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.parcel, node: v18.18.0, js-controller: 5.0.14
        Gruß//Lucky
          TT-Tom last edited by
          @tombox
          Ja, es kommt im 10 Minuten Takt.
            tombox @TT-Tom last edited by
            @tt-tom bitte mal 0.1.6 testen
            O Chris76e Thomas Braun T haselchen 5 Replies Last reply Reply Quote 1
            • O
              oFbEQnpoLKKl6mbY5e13 @tombox last edited by oFbEQnpoLKKl6mbY5e13
              Kein Fehler mehr mit 0.1.6.
              • Chris76e
                Chris76e @tombox last edited by
                @tombox
                bis jetzt keine Fehler mehr bei DHL mit der 0.1.6
                  Thomas Braun Most Active @tombox last edited by Thomas Braun
                  @tombox
                  Hier ist mit der 0.1.6 auch Ruhe im Log eingekehrt.
                  TTBerlin 1 Reply Last reply Reply Quote 0
                    TT-Tom @tombox last edited by
                    @tombox
                    Bei mir auch alles okay, danke.
                    Omnedon 1 Reply Last reply Reply Quote 0
                    • Omnedon
                      Omnedon @TT-Tom last edited by
                      @tombox
                      Bei mir geht es ebenfalls. Keine Fehler im Log.
                      Vielen Dank!
                      • TTBerlin
                        TTBerlin @Thomas Braun last edited by
                        @thomas-braun kann ich nur bestätigen. Alles ruhig mit 0.1.6. Sehr schön, vielen Dank!
                        • haselchen
                          haselchen Most Active @tombox last edited by haselchen
                          @tombox
                          Bekomme immer noch (wahllos) eine Meldung
                          parcel.0	2023-10-19 14:28:05.205	info	Login to Amazon successful
                          Ob Info oder Warn oder Error, es ist halt eine Meldung, wo ich nicht weiss, warum die erscheint.
                          Den Adapter habe ich vor Stunden auf 0.1.6 upgedatet und alle Login liefen durch.
                          Jetzt kommt aufmal diese Info....
                          Edit:
                          gerade gesehen, dass passierte öfters in den letzten Stunden
                          parcel.0
                          parcel.0
                          	2023-10-19 14:01:04.711	info	Login to Amazon successful
                          parcel.0
                          	2023-10-19 13:34:04.443	info	Login to Amazon successful
                          parcel.0
                          	2023-10-19 13:07:08.256	info	Login to Amazon successful
                            Thomas Braun Most Active @haselchen last edited by Thomas Braun
                            @haselchen sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            Die kommt schon ewig. Halt bei jedem Login bei Amazon. Ich hab das LogLevel auf Warn gesetzt.
                            • haselchen
                              haselchen Most Active @Thomas Braun last edited by
                              Ich logge mich aber nicht alle 30min bei Amazon ein.
                              Muss ja nen Grund geben, warum diese Meldung ausgelöst wird.
                              Mit Warn wegsehen ist nicht die Lösung 😉
                                @haselchen
                                Du nicht. Aber der Adapter!
                                  Ist halt eine Info. Muss ich nicht sehen.
                                  Könnte der Maintainer aber auch raushalten, denke ich. Bei den anderen Diensten kommt ja auch keine Meldung dieser Art.
                                  • haselchen
                                    Auf wieviel Minuten hast Du die Update Time gestellt in den Einstellungen?
                                      @haselchen
                                      Ich glaube 25 Minuten.
                                      • haselchen
                                        Okay, ich hab 27.
                                        Deckt sich mit den Amazon Einträgen im Log.
                                        27min dazwischen.
                                        Nun die Frage, warum gibt es von DHL und DPD keine Log Info Meldung nach 27min ?
                                          tombox @haselchen last edited by
                                          @haselchen Amazon muss sich bei jeder Abfrage seit neustem neu einloggen. Das war vorher nicht der Fall. Es wäre schöner wenn das nicht notwendig wäre. Falls es doch unumgänglich ist werde ich den log wohl raus nehmen
                                          Frederik Buss 1 Reply Last reply Reply Quote 2
                                          • Frederik Buss
                                            Frederik Buss @tombox last edited by Frederik Buss
                                            @tombox Hi, ich habe eine Frage zu den json Datenpunkten der einzelnen Lieferdienste (also z.B. parcel.0.dhl.json). Ich bekomme die nicht in das normale JSON Widget eingebunden (Angezeigt wird nur object,object, usw). Gibt es da einen Trick - der allProviderJson oder auch inDelivery Datenpunkt zeigt im Widget alles tadellos an...?
                                            81.1k
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            534808
