    3. Off Topic
    4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
      Thomas Braun Most Active @reutli last edited by Thomas Braun
      @reutli
      Influx hast du aber in (vermutlich) zwei .list files in /etc/apt/sources.list.d stehen. Lösch die mit dem release name drin.
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://repos.influxdata.com/debian bullseye InRelease
        reutli @Thomas Braun last edited by
        Dann habe ich doch noch eine Frage:
        Das heisst ich ersetze meinen Inhalt der sources.list
        # deb cdrom:[Official Debian GNU/Linux Live 10.3.0 standard 2020-02-08T12:27]/ bullseye main
        #deb cdrom:[Official Debian GNU/Linux Live 10.3.0 standard 2020-02-08T12:27]/ bullseye main
        deb http://deb.debian.org/debian/ bullseye main non-free
        deb-src http://deb.debian.org/debian/ bullseye main
        deb http://security.debian.org/debian-security bullseye-security main
        deb-src http://security.debian.org/debian-security bullseye-security main
        # bullseye-updates, previously known as 'volatile'
        deb http://deb.debian.org/debian/ bullseye-updates main
        deb-src http://deb.debian.org/debian/ bullseye-updates main
        # This system was installed using small removable media
        # (e.g. netinst, live or single CD). The matching "deb cdrom"
        # entries were disabled at the end of the installation process.
        # For information about how to configure apt package sources,
        # see the sources.list(5) manual.
        komplett mit
        deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
         deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
         deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
         # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
         deb-src http://deb.debian.org/debian bookworm main contrib non-free
         deb-src http://security.debian.org/debian-security bookworm-security main contrib non-free
         deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free
        oder nur Teile davon?
        @thomas-braun sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
        Habe nur eine influxdata.list
        admin@macmini-iobroker:/etc/apt/sources.list.d$ ls -la
        insgesamt 24
        drwxr-xr-x 2 root root 4096 15. Okt 18:40 .
        drwxr-xr-x 9 root root 4096 24. Sep 18:59 ..
        -rw-r--r-- 1 root root   84 16. Apr 2023  grafana.list
        -rw-r--r-- 1 root root  117 16. Apr 2023  influxdata.list
        -rw-r--r-- 1 root root   56 16. Apr 2023  influxdb.list
        -rw-r--r-- 1 root root  100 15. Okt 18:40 nodesource.list
        mit
        deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
        das passt dann, oder?
          @reutli sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
          influxdb.list
          Dann ist die zuviel.
          Ich sag ja, es gibt zwei Dateien mit Bezug zu influxdb.
          Hatte ich im HowTo nicht dazu geschrieben, dass die sources.list komplett mit dem neuen Inhalt versehen werden muss? Dann muss ich das noch nachtragen...
            reutli @Thomas Braun last edited by reutli
            influxdb.list
            Ok, dann wird die gelöscht, da steht tatsächlich
            admin@macmini-iobroker:/etc/apt/sources.list.d$ cat influxdb.list
            deb https://repos.influxdata.com/debian bullseye stable
            Da steht
            In die Datei /etc/apt/sources.list kopieren wir diese neuen Zeilen rein, die alten Einträge fliegen dafür raus:
            Das kann man schon so verstehen. Vielleicht einfach deutlicher "alle anderen Einträge fliegen raus"?
            Dann habe ich es (sorry) immer noch nicht kapiert, weil da steht:
            Wenn ich aber alles, also
            rein nehme, dann sind die deb-src ja eben NICHT aaskommentiert???
            Scheint ich bin zu doof das zu kapieren.
              deb-src braucht es auf einem üblichen System nicht. Die Pakete von dort werden nur für die Software-Entwicklung benötigt.
              Ist mehr oder weniger egal, ob die Zeilen aktiv sind oder nicht. Brauchen tust du die wohl eher nicht.
              un99known99 R 2 Replies Last reply Reply Quote 0
              • un99known99
                un99known99 @Thomas Braun last edited by un99known99
                Hi, what about:
                "deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi"
                is that needed for the upgrade or is it replaced by the debian entry?
                Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @un99known99 last edited by
                  @un99known99
                  Still needed for the Raspberry OS specific packages.
                  raspi-config for example.
                  • Meister Mopper
                    Meister Mopper @un99known99 last edited by
                    @un99known99
                    Here is my raspi.list for bookworm:
                    thomas@rpizigbee:~ $ cat /etc/apt/sources.list.d/raspi.list
                    deb http://archive.raspberrypi.com/debian/ bookworm main
                    un99known99 1 Reply Last reply Reply Quote 0
                    • un99known99
                      un99known99 @Meister Mopper last edited by un99known99
                      @meister-mopper @Thomas-Braun
                      I have:
                      root@pihole[/etc/apt/sources.list.d] # cat raspi.list
                      deb http://archive.raspberrypi.org/debian/ bullseye main
                      Uncomment line below then 'apt-get update' to enable 'apt-get source'
                      #deb-src http://archive.raspberrypi.org/debian/ bullseye main
                      and
                      that ok and only exchange with bookworm?
                      no entry with e.g. security ...?
                      do I need to add as well:
                      deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware?
                      Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                        @un99known99
                        Absolutely NO root shell!
                        Use your default user, not root!
                        And please use the commands in the initial posting of this thread.
                          Update erfolgt!
                          Habe folgende Warnings erhalten:
                          dpkg: Warnung: Altes Verzeichnis »/usr/lib/udev/rules.d« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          dpkg: Warnung: Altes Verzeichnis »/usr/lib/udev« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          Entpacken von dkms (3.0.10-8+deb12u1) über (2.8.4-3) ...
                          dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkdeb/debian« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkdeb« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkbmdeb/debian« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          dpkg: Warnung: Altes Verzeichnis »/etc/dkms/template-dkms-mkbmdeb« kann nicht gelöscht werden: Das Verzeichnis ist nicht leer
                          Warning: Stopping lvm2-lvmpolld.service, but it can still be activated by:
                            lvm2-lvmpolld.socket
                          Warning: os-prober will not be executed to detect other bootable partitions.
                          update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
                          rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
                          Ansonsten scheint es gut auszusehen:
                          admin@macmini-iobroker:~$ sudo apt update
                          [sudo] Passwort für admin:
                          OK:1 http://deb.debian.org/debian bookworm InRelease
                          OK:2 http://security.debian.org/debian-security bookworm-security InRelease
                          OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                          OK:4 https://repos.influxdata.com/debian stable InRelease
                          OK:5 https://apt.grafana.com stable InRelease
                          OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Holen:7 http://deb.debian.org/debian bookworm/main amd64 DEP-11 Metadata [4.492 kB]
                          Holen:8 http://deb.debian.org/debian bookworm/contrib amd64 DEP-11 Metadata [16,5 kB]
                          Holen:9 http://deb.debian.org/debian bookworm/non-free amd64 DEP-11 Metadata [4.428 B]
                          Holen:10 http://deb.debian.org/debian bookworm/non-free-firmware amd64 DEP-11 Metadata [15,5 kB]
                          Es wurden 4.529 kB in 2 s geholt (2.057 kB/s).
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Alle Pakete sind aktuell.
                          • Samson71
                            Samson71 Global Moderator @un99known99 last edited by
                            @un99known99
                            IP aus DE und wir sind im DE-Teil des Forums? Warum nicht auf Deutsch?
                            • un99known99
                              un99known99 @Samson71 last edited by
                              @samson71
                              sry, Macht der Gewohnheit
                              • U
                                UV-on-fire @Thomas Braun last edited by
                                Also hat problemlos geklapp auf meinem NUC. Container problemlos upgedatet und hochgelaufen.
                                Vielen Dank für deine Anleitung. Perfekt 👍 👏
                                lobomau 1 Reply Last reply Reply Quote 0
                                • lobomau
                                  lobomau @UV-on-fire last edited by lobomau
                                  Das Update auf dem NUC von Debian 11 auf 12 lief ohne Prpbleme durch.
                                  Nur der Pi4 als slave will nicht mehr connecten. Kann es am Update auf Debian 12 liegen? Hab am Pi4 eigentlich nichts geändert, da läuft weiterhin bullseye.
                                  Beim slave kommt:
                                  pi@Pi4:~ $ sudo iobroker multihost browse
                                  No connection to states 192.168.1.19:6379[redis]
                                  Und vorher beim Host:
                                  lobomau@ioBroker:~$ sudo iobroker multihost enable
                                  [sudo] password for lobomau:
                                  Please check the binding of the configured jsonl server to allow remote connections.
                                  No configuration change needed.
                                  Multihost discovery server: enabled
                                  Discovery authentication:   enabled
                                  Persistent activation:      disabled
                                  Objects:                    jsonl on 0.0.0.0
                                  States:                     redis on 0.0.0.0
                                    Thomas Braun Most Active @lobomau last edited by Thomas Braun
                                    @lobomau sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                    sudo iobroker
                                    Wie immer: iobroker wird NICHT per sudo angepackt. Nie.
                                    Du verbiegst dir die Rechte, bis es zu genau solch merkwürdigen Meldungen wie jetzt bei dir kommt.
                                    iob fix
                                    auf allen Installationen.
                                    • lobomau
                                      lobomau @Thomas Braun last edited by lobomau
                                      @thomas-braun Danke für den Hinweis. iob fix hab ich gemacht. Hat aber erstmal nichts geändert.
                                      Weiter unten in der Beschreibung zu multihost ist nochmal der Hinweis zu Redis.
                                      Bei mir steht in der zu ändernden Zeile (hatte da aber auch nie etwas geändert):
                                      bind 127.0.0.1 -::1
                                      Hab ich angepasst auf:
                                      bind 127.0.0.1 192.168.1.19
                                      Alle Maschinen neugestartet, aber es funktioniert nicht mehr. Irgendwas mit dem "binding"?
                                      lobomau@ioBroker:~$ iobroker multihost enable
                                        reutli @lobomau last edited by
                                        @lobomau
                                        ... aber nicht dass es damit
                                        https://forum.iobroker.net/topic/69019/raspberry-pi-os-lite-bookworm-ist-da/56
                                        zusammenhängt?
                                        Kann ich nicht beurteilen aber bei mir hat es (ohne Redis) geholfen.
                                        meute lobomau 2 Replies Last reply Reply Quote 0
                                        • meute
                                          meute @reutli last edited by
                                          @Thomas-Braun
                                          Top Anleitung. 👍
                                          Ich habe meinen Test-Raspi hochgezogen.
                                          Er läuft noch, jetzt mit 12/bookworm.
                                          Du schreibst in Deiner Anleitung folgendes:
                                          "Wenn während des Upgrades Rückfragen kommen, ob eine neue Version einer Konfig-Datei eingespielt werden soll bitte immer mit yes bestätigen. Es wird von der ursprünglichen Datei eine Kopie mit der Endung .dpkg-old gespeichert, welche bei Bedarf dann zurückgespielt werden kann."
                                          Das habe ich gemacht.
                                          Bei mir gab es gesicherte Dateien mit folgenden Endungen:
                                          .dpkg-old
                                          .ucf-old
                                          .update-old
                                          Einen Vorschlag habe ich dazu.
                                          Du könntest in Deiner Anleitung als Anmerkung die Suche nach solchen Dateien hinzufügen.
                                          Danach ist es ein leichtes, alt und neu zu kontrollieren.
                                          sudo find /etc/ -iname *-old | sort
                                          • lobomau
                                            lobomau @reutli last edited by
                                            @reutli Danke für den Hinweis! "ohne Redis" war der richtige Tipp. Nun läuft alles und zwar mit jsonl. Habe auch den Pi4 auf bookworm hochgezogen.
                                            upgrade bullseye bookworm
                                            51
                                            351
                                            88686
