    4. ZigBee neue Version 1.8.x
      earl80 last edited by earl80
      Moin! Bei der Version 1.8.24 habe ich das Problem, dass sich der Adapter manchmal mit folgender Fehlermeldung verabschiedet:
      -bei 1.8.23 geht alles...
      code_text
      ```host.raspberrypi
      2023-10-16 05:19:22.595	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspberrypi
      2023-10-16 05:19:22.595	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:591:22)
      host.raspberrypi
      2023-10-16 05:19:22.594	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:244:54)
      host.raspberrypi
      2023-10-16 05:19:22.594	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:25:18)
      host.raspberrypi
      2023-10-16 05:19:22.594	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:43:26)
      host.raspberrypi
      2023-10-16 05:19:22.594	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/devices/ikea.ts:41:36)
      host.raspberrypi
      2023-10-16 05:19:22.594	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'color_options')
      host.raspberrypi
      2023-10-16 05:19:22.593	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      2023-10-16 05:19:21.338	error	Cannot read properties of undefined (reading 'color_options')
      zigbee.0
      2023-10-16 05:19:21.338	error	TypeError: Cannot read properties of undefined (reading 'color_options') at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/devices/ikea.ts:41:36) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:43:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:25:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:244:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:591:22)
      zigbee.0
      2023-10-16 05:19:21.215	error	unhandled promise rejection: Cannot read properties of undefined (reading 'color_options')
      zigbee.0
      2023-10-16 05:19:21.214	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        @earl80 sagte in ZigBee neue Version 1.8.x:
        weil es aus dem konverter kommt und der wird in der ist in der Version 1.8.24 neuer.. und hat bestimmt an der stelle ein Bug
        • Xsev
          Xsev @arteck last edited by Xsev
          @arteck sagte in ZigBee neue Version 1.8.x:
          @xsev 9999 heisst das Gerät antwortet nicht.. ist die Batterie leer ??
          @arteck Nein Batterien sind neu, allerdings hab ich die Batterien jetzt nochmal raus und wieder rein und siehe da, Meldung ist weg und das Thermostat arbeitet wieder. Werd´s mal beobachten. Danke!
          • MyzerAT
            MyzerAT @Guest last edited by
            @dp20eic sagte in ZigBee neue Version 1.8.x:
            Ja und danach hätte/könnte man das machen.
            Anhand der Beschreibung auf https://www.zigbee2mqtt.io/supported-devices/ sind die click veraltet, daher sind die wohl in der neuen Zigbee Adapter Version herausgeflogen.
            Wenn Du zurückgehst, sollten die auch wieder funktionieren.
            servus
            Ich habe das selbe Problem, seit Zigbee Version 1.8.23 löst eine Betätigung bei meinen "WXKG01LM" keine klicks mehr aus in den Objekten! Bei der Zigbee Version 1.8.22 funktionieren aber noch alle "alten" zuvor eingerichteten "WXKG01LM" "neue" spinnen ebenfalls rum!
            Was wäre die Lösung damit die wieder laufen , habe extrem viele dieser Taster, das Ausschließen habe ich ebenfalls schon mehrfach probiert, keine Ahnung was da der Sinn dahinter sein soll, ich komme auf keinen Lösung!
            bin echt am verzweifeln, seit gut 2 Jahren lief alles paletti und nun das!
            MyzerAT ? 2 Replies Last reply Reply Quote 0
            • MyzerAT
              MyzerAT @MyzerAT last edited by
              @lls
              habe aber noch ein 2. Problem!
              wollte gestern weitere innr LED Lampen (RB 251 C) zu meiner zigbee Instanz hinzufügen, leider kein Erfolg! Egal was ich mache, sie werden nicht erkannt! Andere Zigbee Devices kann ich hinzufügen! bei mir läuft zur Zeit Zigbee 1.8.22
                A Former User @MyzerAT last edited by
                @myzerat
                Haste das gemacht?
                MyzerAT 1 Reply Last reply Reply Quote 0
                  @myzerat sagte in ZigBee neue Version 1.8.x:
                  Moin,
                  Probleme gibt es nicht, das sind nur Herausforderungen 🙂
                  Aber zu jeder Herausforderung, gibt es auch passende Log Files, ansonsten wird es ein Glaskugeldesaster.
                  VG
                  Bernd
                  • MyzerAT
                    @ilovegym
                    ja habe ich gelesen und es so verstanden, das ich da jene Geräte zb ausschließen kann, die dann in Zukunft nicht mehr von einer neuen Zigbee Version (update) betroffen sind!
                    wie komme ich auf die benötigte 1.8.24 ? über :
                    • MyzerAT
                      @dp20eic
                      sorry, hast natürlich recht! musste erst wieder checken wie man das genau macht !
                      zigbee_MyzerAT.txt
                        Rudi macht doch nicht so ein Aufstand.... die Thamtik ist zig mal behandelt worden..
                        auch bei Update hast du eine Meldung bekommen, dass sich Aqara/Xiaomi Steuerung ändert
                        die Buttons unter auschliessen packen... adapter neu starten
                        dann entstehen neue Object.. die du LEIDER in deine Scripte ändern musst.
                        fettisch
                        wenn du noch aufräumen willst drückmal den hier
                        dann werden alle nicht mehr benötigten Objecte aus dem adapter gelöscht
                        p.s: das LOG kannst du dir sparenin diesem Fall...
                        und unter
                        https://github.com/ioBroker/ioBroker.zigbee
                        reinpacken..
                        aber das hast du schon zig mal gemacht..
                        • MyzerAT
                          MyzerAT last edited by MyzerAT
                          ja ich weiß, hab das im ganzen schon verstanden, habe ja vorher intensiv deine Info dazu gelesen, nur das mit der "wie komme ich auf die aktuelle Version" ist mir wieder mal entfallen! gibt ja drei Möglichkeiten!
                          ps: das mit dem Log ist ein anderes Problem, hat nichts mit dem klickverhalten der WXKG01LM zu tun! ich kann warum auch immer keine innr Lampen pairen, daher das log!
                          #Edit#
                          so, nach vielen Stunden der Suche und des Probierens, auch mit Version 1.8.24 , bin ich mit meinem Latein am Ende! Selbst im debug log von zigbee wird nicht mal angezeigt, das was fehlschlägt beim pairen der zwei innr Lampen ! Sie tun auch als ob sie sich verbinden wollten!
                          Einschalten, kurz warten "sie ändern die Farben" und dann 6x ein/aus und dann werden sie etwas dunkler, im Zigbee keine Reaktion - 0 - nichts - nada !
                          Die Lampen sind nagelneu! Lassen sich ohne Probleme mit einem Echo von Amazon einbinden! Andere Devices kann ich ohne Probleme einbinden!
                          laut QR Code an den Lampen haben sie folgende Kennung , damit finde ich sie im logfile, aber ich sehe sie nirgends im iobroker !!!
                          Z:C**498860000D9D0FA** $I:532AAF965B1237FE635ABF668DC4F1387F5D
                          Z:C**498860000DA341A** $I:DAF4DE68227C46700AA40E18F2CC76C0ADA8
                            Moin,
                            Q. Wie kann ich eine Lampe manuell zurücksetzen?
                            A. Schalten Sie die Lampe 6 mal, in Intervallen von 0,5 Sekn, aus und an. Die Lampe wird 2 mal kurz
                            aufleuchten und damit zeigen, dass sie neu koppelbar ist.
                            Falls Du das meintest, sorry, dann hab ich das falsch verstanden.
                            VG
                            Bernd
                            • MyzerAT
                              MyzerAT @Guest last edited by MyzerAT
                              @dp20eic
                              was willst du mir damit sagen ?
                              hier nochmal ein logfile, ich gehe in den paringmodus und im log erscheint die neue LED in zeile 99 "498860000DA341A" aber mehr nicht! im Kopplungsmodus ist nichts zu sehen, keine FM nichts! Eventuell liegt ja der Fehler an der Zigbee Version selbst! Bin ja nicht dumm! habe schon hunderte male was eingebunden per pairing!
                              2023-10-19 19:07:15.702 - debug: zigbee.0 (672) Routing for '0xc4988600004bdb43': {"neighbors":[{"linkquality":255,"networkAddress":0,"ieeeAddr":"0x00124b001940be75","relationship":2,"depth":255},{"linkquality":0,"networkAddress":8259,"ieeeAddr":"0xc498860000d9d0fa","relationship":5,"depth":255},{"linkquality":89,"networkAddress":9003,"ieeeAddr":"0x7cb03eaa00b09a56","relationship":2,"depth":255},{"linkquality":110,"networkAddress":12355,"ieeeAddr":"0x000b57fffe972bd2","relationship":2,"depth":255},{"linkquality":255,"networkAddress":16055,"ieeeAddr":"0xc4988600004bda67","relationship":2,"depth":255},{"linkquality":34,"networkAddress":18536,"ieeeAddr":"0x84182600000ff39d","relationship":2,"depth":255},{"linkquality":213,"networkAddress":19519,"ieeeAddr":"0x000d6ffffe9f907c","relationship":2,"depth":255},{"linkquality":165,"networkAddress":23639,"ieeeAddr":"0xf0d1b800001d8b83","relationship":2,"depth":255},{"linkquality":0,"networkAddress":35053,"ieeeAddr":"0xc498860000da341a","relationship":5,"depth":255},{"linkquality":75,"networkAddress":46489,"ieeeAddr":"0x000d6ffffe9c27d9","relationship":2,"depth":255},{"linkquality":103,"networkAddress":48806,"ieeeAddr":"0x000b57fffe9b4e54","relationship":2,"depth":255},{"linkquality":96,"networkAddress":55885,"ieeeAddr":"0xc498860000078314","relationship":2,"depth":255},{"linkquality":48,"networkAddress":60906,"ieeeAddr":"0x000b57fffe48a839","relationship":2,"depth":255},{"linkquality":117,"networkAddress":62541,"ieeeAddr":"0xc4988600004bda4b","relationship":2,"depth":255}]}
                              zigbee_MyzerAT.txt
                                Moin,
                                ich wollte damit nur fragen/sagen, dass Du den Reset etwas anders beschrieben hast als das, was ich im Internet gefunden habe.
                                VG
                                Bernd
                                  Moin,
                                  hast Du die da auch wieder entkoppelt?
                                  VG
                                  Bernd
                                  • MyzerAT
                                    @dp20eic ja klar, habe ja nur eine von sechs stück bei Amazon probiert und selbst alle anderen erscheinen nicht im iobroker ! Die waren noch nirgends eingebunden!
                                      arteck Developer Most Active @MyzerAT last edited by
                                      @myzerat anz sachte...
                                      zuerst adapter auf INFO.. kein debug da sind zu viele infos.
                                      also adapter stop -> auf info stellen -> coordinator rausziehen -> kurz warten -> wieder rein -> adapter starten
                                      vom start log posten
                                      dann anlernen.. und wieder log posten
                                      MyzerAT 2 Replies Last reply Reply Quote 1
                                      • MyzerAT
                                        MyzerAT @arteck last edited by
                                        @arteck
                                        mach ich am Nachmittag, thx
                                        • MyzerAT
                                          MyzerAT @arteck last edited by MyzerAT
                                          @arteck
                                          so habe es genau so gemacht wie du es oben verlangt hast!
                                          zigbee_start_pairing_log_MyzerAT.txt
                                          ps: gibt aber nur das eine log, weil nach dem pairing sich nix getan hat im log!
                                          hier nochmal das log von gestern, die zwei innr LED sind absolut neu und beim pairing erscheint keine Meldung, dennoch finde ich sie im debuglog!
                                          Z:C** 498860000D9D0FA ** $I:532AAF965B1237FE635ABF668DC4F1387F5D
                                          Z:C** 498860000DA341A ** $I:DAF4DE68227C46700AA40E18F2CC76C0ADA8
                                          beite im log_myzerAT#.txt
                                            @myzerat deie Firmware ist alt 20200211
                                            und du findest die zwar abe rmit linkquality":0 also die senden garnix..ich würde vermuten das es an der Firmware liegt..
                                            genau kann ich es dir nicht sagen
                                            81.1k
                                            385
                                            85415
