    4. Test Adapter device-reminder V 3.x
    • Xenon
      Xenon Forum Testing Developer @Rene55 last edited by Xenon
      @rene55 unter System -> Adapter -> device-reminder-> Instanz und dann auf den Stift findest du deine Config (um diese Anzeige zu erhalten muss die Expertenansicht aktiv sein)
      Magst du mir alles von "linked-devices" hier reinstellen? Auch bei mir sieht man, dass oben 6 Geräter unter ids stehen, unter final aber nur 5 auftauchen (der Trockner fehlt). Ich möchte mal sehen, ob es bei dir genauso ist
      "linkedDevice": {
            "ids": [
                "enabled": true,
                "name": "Waschmaschine",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "0"
                "enabled": true,
                "name": "Trockner",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": 6
                "enabled": true,
                "name": "Geschirrspueler",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "1"
                "enabled": true,
                "name": "Kuehlschrank",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "2"
                "enabled": true,
                "name": "Netzwerk Dachboden",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "3"
                "enabled": true,
                "name": "Heizung Dachboden",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "4"
                "enabled": true,
                "name": "Homeserver",
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "autoOff": false,
                "timer": "0",
                "abort": false,
                "id": "5"
            "finalIds": {
              "0": {
                "type": "washing-machine",
                "pathConsumption": "shelly.0.SHEM-3#485519D6A780#1.Emeter1.Power",
                "pathSwitch": "",
                "startText": "Waschmaschine started",
                "endText": "Waschmaschine finished",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "0"
              "1": {
                "type": "dishwasher",
                "pathConsumption": "shelly.0.SHEM-3#485519D6A780#1.Emeter2.Power",
                "pathSwitch": "",
                "startText": "Geschirrspueler started",
                "endText": "Geschirrspueler finished",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "1"
              "2": {
                "type": "custom1",
                "pathConsumption": "zigbee.0.a4c1385d452e7cb0.load_power",
                "pathSwitch": "",
                "startText": "Kuehlschrank started",
                "endText": "Kuehlschrank finished",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "2"
              "3": {
                "type": "custom2",
                "pathConsumption": "zigbee.0.a4c1387e45a340bf.load_power",
                "pathSwitch": "",
                "startText": "Netzwerk Dachboden started",
                "endText": "Netzwerk Dachboden ausgeschaltet",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "3"
              "4": {
                "type": "custom3",
                "pathConsumption": "zigbee.0.a4c138084249cc8f.load_power",
                "pathSwitch": "",
                "startText": "Heizung Dachboden started",
                "endText": "Heizung Dachboden ausgeschaltet",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "4"
              "5": {
                "type": "custom4",
                "pathConsumption": "zigbee.0.a4c1385ab3cc00ea.load_power",
                "pathSwitch": "",
                "startText": "Homeserver started",
                "endText": "Homeserver ausgeschaltet",
                "enabled": true,
                "alexa": [],
                "sayit": [],
                "telegram": [
                  "0"
                "whatsapp": [
                  "0",
                  "1"
                "pushover": [],
                "signal": [],
                "email": [],
                "matrix": [],
                "timer": "0",
                "autoOff": false,
                "abort": false,
                "id": "5"
      Rene55 Marko1974 2 Replies Last reply Reply Quote 0
      • Rene55
        Rene55 @Xenon last edited by Rene55
        @xenon Ja natürlich gern:
          "linkedDevice": {
             "ids": [
                 "enabled": true,
                 "name": "Trockner",
                 "telegram": [
                   "1"
                 "autoOff": false,
                 "timer": "0",
                 "abort": false,
                 "id": "1"
                 "enabled": true,
                 "name": "Waschen",
                 "telegram": [
                   "1"
                 "autoOff": false,
                 "timer": "0",
                 "abort": false,
                 "id": "2"
                 "enabled": true,
                 "name": "Geschirr",
                 "telegram": [
                   "1"
                 "autoOff": false,
                 "timer": "0",
                 "abort": false,
                 "id": "3"
             "finalIds": {
               "1": {
                 "type": "custom1",
                 "pathConsumption": "sonoff.0.DVES_DE4DE7.ENERGY_Power",
                 "pathSwitch": "sonoff.0.DVES_DE4DE7.POWER",
                 "startText": "Trockner läuft",
                 "endText": "Trockner ist fertig",
                 "enabled": true,
                 "name": "Trockner",
                 "alexa": [],
                 "sayit": [],
                 "telegram": [
                   "1"
                 "whatsapp": [],
                 "pushover": [],
                 "signal": [],
                 "email": [],
                 "matrix": [],
                 "timer": "0",
                 "autoOff": false,
                 "abort": false,
                 "id": "1"
               "2": {
                 "type": "custom2",
                 "pathConsumption": "sonoff.0.DVES_DE6C60.ENERGY_Power",
                 "pathSwitch": "sonoff.0.DVES_DE6C60.POWER",
                 "startText": "Waschmaschine läuft",
                 "endText": "Waschmaschine ist fertig",
                 "enabled": true,
                 "name": "Waschen",
                 "alexa": [],
                 "sayit": [],
                 "telegram": [
                   "1"
                 "whatsapp": [],
                 "pushover": [],
                 "signal": [],
                 "email": [],
                 "matrix": [],
                 "timer": "0",
                 "autoOff": false,
                 "abort": false,
                 "id": "2"
        Xenon 1 Reply Last reply Reply Quote 0
        • Xenon
          @rene55 danke, ich schaue heute Abend mal danach 🙂
          • Rene55
            @xenon Ich hatte jetzt nur "linkedDevice" geschickt. Brauchst du noch die "devices"?
            Und wie krieg ich das in den schwarzen Kasten?
            • Xenon
              @rene55
              nein, dass reicht 😉
              code_text
              • Rene55
                @xenon Danke. Jetzt hats funktioniert. Habe ich eben auch so gemacht - hat aber nicht geklappt. So siehts schön aus.
                • Xenon
                  @rene55 habe im Admin nochmals einfach auf Speichern geklickt, aufmal ist auch der Trockner angelegt worden. Merkwürdiges Verhalten, ich versuche es mal irgendwie zu reproduzieren 😕
                  • Rene55
                    @xenon Um nochmal speichern zu können muss man erstmal was verändern. Ich hab einfach ein 4. Gerät hinzugefügt und schon ist das dritte Gerät im Objektbaum. Was ich auch festgestellt habe, der Neustart danach dauert (nach meinem Gefühl) recht lang.
                    Xenon 1 Reply Last reply Reply Quote 1
                    • Xenon
                      @rene55 sagte in Test Adapter device-reminder V 2.x:
                      Aber das neue wurde nicht angelegt? Das wäre ein Ansatz....
                      • Rene55
                        @xenon So ist es.
                        ERGÄNZUNG: In der Config ist es drin. Womöglich ein Darstellungsproblem, dass irgendwo ein Index nicht sauber mitläuft.
                        • Xenon
                          @xenon So ist es.
                          Aber unter "finalIds" wirds fehlen. Und genau da stehen die Daten, aus denen der Adapter das Objekt erstellt. Aber immerhin habe ich dann nachher eine Möglichkeit, das Ganze zu reproduzieren. Danke dir !
                          • Rene55
                            @xenon Ja korrekt. Device 1 - 3 sind da, 4 fehlt. Frohes schaffen
                            • Xenon
                              Xenon Forum Testing Developer last edited by Xenon
                              Neue Version auf github (3.0.0)
                              Achtung: Alle die nicht die Version 2.1.2 installiert hatten (das sind die wenigsten), müssen den Adapter zwingend neu installieren!
                              Alle bekannten Bugs sollten behoben sein, inklusive fehlender Buttons für die Config
                              Sollte es keine großen Probleme mehr geben, kommt die Version am Wochenende in die latest. Vorher passe ich natürlich die readme noch an, da ja einige Neuerungen dazu gekommen sind. Schönen abend 😉
                              F Knallochse 2 Replies Last reply Reply Quote 2
                                flotux @Xenon last edited by
                                @Xenon
                                Folgende Warnung bekomme ich im ioBroker Log noch:
                                Ansonsten teste ich die Tage jetzt mal, ob alles soweit funktioniert und gebe Feedback.
                                • Xenon
                                  Xenon Forum Testing Developer @flotux last edited by
                                  @flotux sagte in Test Adapter device-reminder V 3.x:
                                  @Xenon
                                  Obwohl du den Adapter neu installiert hast?
                                    @xenon
                                    Exakt! Ich habe den Adapter vollständig entfernt und dann neu über die GitHub Adresse aktualisiert.
                                    • Xenon
                                      @flotux okay, das ist das Objekt welches den Adapter in den Instanzen gelb anzeigt. Brauchst du erstmal nicht weiter beachten
                                      • Rene55
                                        @xenon Version 3.0.0 drübergebügelt. Sieht gut aus: 4.Gerät ist da und Export funktioniert auch. Jetzt muss nur noch gewaschen werden.
                                          Hakemann last edited by
                                          Hallo xenon, erstmal vielen Dank für deine Arbeit und gute Besserung.
                                          Bisher scheint es bei mir zu funktionieren. Was mir aufgefallen ist, dass sich der Pfad von Alexa geändert hat. "Speak" findet sich nicht mehr unter "Announcements", sondern unter "Commands".
                                          Wo du gerade schon dran arbeitest kannst du das vielleicht auch anpassen.
                                          • Xenon
                                            Xenon Forum Testing Developer @Hakemann last edited by
                                            @hakemann das ist nur ein beispiel dafür, dass man entweder announcement oder speak auswählen muss
                                            390
                                            72222
