    4. Test Adapter OpenDTU
      schoeppi_1 @Codierknecht last edited by schoeppi_1
      @codierknecht
        <variables>
          <variable id="BN!a@q$SEAU4^)xo:SRJ">max_WR_Leistung</variable>
          <variable id="AcYpB0Ty+wVObL7=Y.a.">saldierte_Leistung</variable>
          <variable id="1}Q0686mMw0ZGk)e+r?(">IST-Wert_WR</variable>
          <variable id="le#}gR{6G.yhW=x|6pS8">SOLL-Wert_WR</variable>
          <variable id="av^_6@}eU-gIk%dJ,!,}">Stellwert_WR</variable>
        </variables>
        <block type="schedule" id="OO@|Rtoh_rlRKcPbfGAo" x="-1862" y="-1263">
          <field name="SCHEDULE">0,10,20,30,40,50 * * * * *</field>
            <block type="comment" id="!%pL=9LkG.9?H[$qx2YI">
              <field name="COMMENT">wenn Nachteinspeisung aktiv</field>
                <block type="controls_if" id="7T?Z|?Y5.p-:678Tx$Ti">
                    <block type="get_value" id=")N-S8Ay5cnSc#BmbZ.=w">
                      <field name="OID">sonoff.0.Steckdose_2.POWER</field>
                    <block type="comment" id="un41CmgNYK(Y]/a|36h]">
                      <field name="COMMENT">Variablen beschreiben</field>
                        <block type="variables_set" id="EqaM{MYS7M6`-h;!zF93">
                          <field name="VAR" id="BN!a@q$SEAU4^)xo:SRJ">max_WR_Leistung</field>
                            <block type="math_number" id="^w]xAxYJ7wN]m6;vk(fV">
                              <field name="NUM">200</field>
                            <block type="variables_set" id="wR,+k_F;sMBf]aAYh+~t">
                              <field name="VAR" id="AcYpB0Ty+wVObL7=Y.a.">saldierte_Leistung</field>
                                <block type="get_value" id="RX$n4zq((b9U%h@.fnK,">
                                  <field name="OID">0_userdata.0.Stromverbrauch.var_Bezug_Summe_Leistung_saldiert</field>
                                <block type="variables_set" id="~RRNE/ol!3MoTz;#)`PK">
                                  <field name="VAR" id="1}Q0686mMw0ZGk)e+r?(">IST-Wert_WR</field>
                                    <block type="get_value" id="5CvJRCtL/p)gjkP2,A%K">
                                      <field name="OID">opendtu.0.112184710720.ac.phase_1.power</field>
                                    <block type="variables_set" id="mZ+[ru,M.bbbDx$!%cbd">
                                      <field name="VAR" id="le#}gR{6G.yhW=x|6pS8">SOLL-Wert_WR</field>
                                        <block type="math_arithmetic" id="rv08p$|]!!eg`$;G4?[t">
                                          <field name="OP">ADD</field>
                                            <shadow type="math_number" id="n}1O70OfJnrAub1M8c[r">
                                              <field name="NUM">1</field>
                                            <block type="math_arithmetic" id="3y=~@f2Qw!_YiJJ7yyxq">
                                                <shadow type="math_number" id="qLf/8W@9:(9C9tZ0)%zs">
                                                <block type="variables_get" id="0N8%)B@Js@QKG(.|9C;/">
                                                <shadow type="math_number" id="N@J09x*NDsor:$]CWIb)">
                                                <block type="variables_get" id="k8CjoP?zy$q5sYiz|fp`">
                                            <shadow type="math_number" id="RrKwrA08I}5~xOXJTY=l">
                                              <field name="NUM">0</field>
                                        <block type="comment" id="%`DgcG;amO_v`JekW7X#">
                                          <field name="COMMENT">maximal WR Leistung einstellen</field>
                                            <block type="controls_if" id="X.V3jJA5CZkZQUc%Yn{;">
                                              <mutation elseif="3"></mutation>
                                                <block type="logic_compare" id="TKLqCZMY~Wns-BS@K,K2">
                                                  <field name="OP">GTE</field>
                                                    <block type="variables_get" id="?B6HLx3_C%j{i`W3_h~4">
                                                    <block type="variables_get" id="=j*pkdNV[O*7=,LmG^hL">
                                                <block type="variables_set" id="T{[2|VMAG8kqI|/hwnX.">
                                                  <field name="VAR" id="av^_6@}eU-gIk%dJ,!,}">Stellwert_WR</field>
                                                    <block type="variables_get" id="YULaab+c`U9LO`fH91iU">
                                                    <block type="comment" id="EK7aa~/95cKP_*9jtj~u">
                                                      <field name="COMMENT">Vermeidung W Änderungen &gt; 10W wegen Schwingen</field>
                                              <value name="IF1">
                                                <block type="logic_compare" id="gVY;LPML8z$4uv`|Pif0">
                                                    <block type="variables_get" id="(@i,:QFP%Ui#$Qc#}9zK">
                                                    <block type="math_arithmetic" id="qS;D4lv4a]J5@{4bq}}[">
                                                        <shadow type="math_number" id="I_UEM;1#-apn7r1ubP.Q">
                                                        <block type="variables_get" id="E`wS@czP,1f}|UDsLxWy">
                                                        <shadow type="math_number" id="vc]UO5xK#u/;a[$nc{7L">
                                                        <block type="math_number" id="=1.lbX$$-%3|HK%5O1s6">
                                                          <field name="NUM">10</field>
                                              <statement name="DO1">
                                                <block type="variables_set" id="2hh%7nQbUqWU/c/oD;1]">
                                                    <block type="math_arithmetic" id="B0B7N@oj(qhgq.[CfLrm">
                                                        <block type="variables_get" id="~U[j;IW!IuC97gq%wTiT">
                                                        <block type="math_number" id="npdn`ZMsF.UU%sumAg]f">
                                                    <block type="comment" id="+52id[cI4NLN3rH@}5+9">
                                                      <field name="COMMENT">Vermeidung W Änderungen &lt; 10W wegen Schwingen</field>
                                              <value name="IF2">
                                                <block type="logic_compare" id="cp:Gbx*F@Z)|d?I_*NM[">
                                                  <field name="OP">LTE</field>
                                                    <block type="variables_get" id="!m{sPTYgujd)08}F(iiw">
                                                    <block type="math_arithmetic" id="@tgzHg%Ae%v`SEE4*4Vh">
                                                        <block type="variables_get" id="D:an~$hFrNvX$+lLY*).">
                                                        <block type="math_number" id="c;wHpOxmnU[,woPIEeV^">
                                              <statement name="DO2">
                                                <block type="variables_set" id="0K$GCJ,wp=x$|NNUk}tJ">
                                                    <block type="math_arithmetic" id="J^O#Rg+68T:Xnfp?_IAb">
                                                        <block type="variables_get" id="E@NrHLM:p${9Orq}X6^w">
                                                        <block type="math_number" id="~LDPUO1B|3*vKw~E+7Ji">
                                              <value name="IF3">
                                                <block type="logic_operation" id="P_uomd33Pm,$sKLHaK?8">
                                                  <field name="OP">OR</field>
                                                    <block type="logic_compare" id="%9^pqGFOAdF_Q4+I_kk|">
                                                        <block type="variables_get" id="3FJ;ccWjMMWY975Kj@5s">
                                                        <block type="math_number" id="3[DVAMar{wt_rK:[kRtU">
                                                    <block type="logic_compare" id="H(i+-mX%!VeQT-k-dSW~">
                                                        <block type="variables_get" id="If*V!EDhw)-mx.R1T4n|">
                                                        <block type="math_number" id="Ba7:PVdMPz2$p~*KFDnQ">
                                              <statement name="DO3">
                                                <block type="comment" id="f1T,}m=[3vLl{OBvCavV">
                                                  <field name="COMMENT">benötigte Leistung einstellen</field>
                                                    <block type="variables_set" id="N2`__2dpmt+NXIcxENW/">
                                                        <block type="variables_get" id=";3S?@Jd,;,GMMI=X8X,0">
                                                <block type="comment" id="5V:8{H(Wby#lc(I7TXo3">
                                                  <field name="COMMENT">Vermeidung das SOLL-Wert &lt; 10W wird</field>
                                                    <block type="controls_if" id="z~i9;MPg9rNBrD:.ZcHx">
                                                        <block type="logic_compare" id="#wA@uq;vFm}184]3,XTf">
                                                            <block type="variables_get" id="b~F;nG1/8mo.0J8Qo;]3">
                                                            <block type="math_number" id="1a.@~,.{Y9?msC|}i!Eh">
                                                        <block type="variables_set" id="y-1KyiEpr+hF9[GjI6yR">
                                                            <block type="math_number" id="ZCQw^kFMn*J`ypL@Xt.A">
                                                        <block type="control" id="%cOvD+Otu7dc3(7+Pt%?">
                                                          <field name="OID">opendtu.0.112184710720.power_control.limit_nonpersistent_absolute</field>
                                                            <block type="math_round" id="qp8W?7#X`RyZcY2C7b7k">
                                                              <field name="OP">ROUND</field>
                                                              <value name="NUM">
        <shadow type="math_number" id="OJ-sBUj]4[O=:~#bD`+/">
        <field name="NUM">3.1</field>
        <block type="variables_get" id="c;t^q^e_m6@Xsn@8(u`r">
        @codierknecht
        ich glaube das war genauso falsch...
        Ich habe auf "Code" gedrückt:
        code_text
        Code text war markiert und dann habe ich CTRL V für einfügen gedrückt.
        Stimmt das?
          schoeppi_1 @schoeppi_1 last edited by
          @schoeppi_1 ```
          code_text
          • Codierknecht
            Codierknecht Developer Most Active @schoeppi_1 last edited by
            @schoeppi_1
            Das muss jeweils in eigene Zeilen.
            Du hast die Markierung direkt hinter den Profillink gepackt.
            Also so:
            Und wir sprachen von "nachholen" - nicht von nochmal posten. Das macht es noch schlimmer.
            Friedhofsblond 1 Reply Last reply Reply Quote 0
            • Friedhofsblond
              Friedhofsblond @Codierknecht last edited by
              @codierknecht
              Moin,
              seit Version 1.0.0 muß ich den Adapter oft manuell starten - muß ich nach dem Update noch was tun ?
              Sonst muß ich wohl ein Backup der Vorversion zurückholen 😞
              Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Codierknecht Developer Most Active @Friedhofsblond last edited by
                @friedhofsblond
                Version 1.0.0 läuft bei mir 1a.
                Zeig mal
                iob diag
                  Thomas Braun Most Active @Friedhofsblond last edited by
                  @friedhofsblond sagte in Test Adapter OpenDTU:
                  Hier nicht. Muss was individuelles bei dir sein.
                  • Friedhofsblond
                    @codierknecht
                    Wo hack ich das ein?
                    Auf dem system selber - da kommt dann aber viel ...
                      @friedhofsblond
                      Ja, da kommt viel...
                      Alles hier rein kopieren.
                      • Friedhofsblond
                        Friedhofsblond @Thomas Braun last edited by
                        ok - das passt?
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                         Static hostname: ioserver
                               Icon name: computer-desktop
                                 Chassis: desktop 🖥️
                                  Kernel: Linux 6.1.0-13-amd64
                            Architecture: x86-64
                         Hardware Vendor: Intel_R_ Client Systems
                          Hardware Model: NUC7CJYH
                        Firmware Version: JYGLKCPX.86A.0070.2023.0505.1501
                        model name      : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
                        Docker          : false
                        Virtualization  : none
                        Kernel          : x86_64
                        Userland        : amd64
                        Systemuptime and Load:
                         14:10:02 up 3 min,  2 users,  load average: 0.24, 0.36, 0.17
                        CPU threads: 2
                        *** Time and Time Zones ***
                                       Local time: Fri 2023-10-20 14:10:02 CEST
                                   Universal time: Fri 2023-10-20 12:10:02 UTC
                                         RTC time: Fri 2023-10-20 12:10:02
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        superuser
                        /home/superuser
                        superuser cdrom floppy sudo audio dip video plugdev users netdev iobroker
                        *** X-Server-Setup ***
                        X-Server:       true
                        Desktop:
                        Terminal:       web
                        *** MEMORY ***
                        Mem:            7.9G        1.3G        6.0G         27M        877M        6.6G
                        Swap:           1.0G          0B        1.0G
                        Total:          8.9G        1.3G        7.1G
                                 7556 M total memory
                                 1239 M used memory
                                  291 M active memory
                                 1299 M inactive memory
                                 5753 M free memory
                                   43 M buffer memory
                                  793 M swap cache
                                  975 M total swap
                                    0 M used swap
                                  975 M free swap
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.7G     0  3.7G   0% /dev
                        tmpfs          tmpfs     756M  1.1M  755M   1% /run
                        /dev/sda2      ext4      218G  7.9G  199G   4% /
                        tmpfs          tmpfs     3.7G     0  3.7G   0% /dev/shm
                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                        /dev/sda1      vfat      511M  9.8M  502M   2% /boot/efi
                        tmpfs          tmpfs     756M   20K  756M   1% /run/user/104
                        tmpfs          tmpfs     756M   16K  756M   1% /run/user/1000
                        [Fri Oct 20 14:06:23 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Fri Oct 20 14:06:24 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                        TARGET      SOURCE    FSTYPE OPTIONS
                        /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
                        `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                        /var:
                        2.3G    /var/
                        1.9G    /var/cache/apt
                        1.9G    /var/cache
                        1.8G    /var/cache/apt/archives
                        215M    /var/log
                        Archived and active journals take up 20.5M in the file system.
                        /opt/iobroker/backups:
                        2.4M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        70M     /opt/iobroker/iobroker-data/
                        34M     /opt/iobroker/iobroker-data/backup-objects
                        15M     /opt/iobroker/iobroker-data/files
                        13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                        5.5M    /opt/iobroker/iobroker-data/states.jsonl
                        2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                        1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /home/iobroker/.diag.sh: line 277: nodejs: command not found
                        /usr/bin/node           v18.17.1
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        /usr/bin/corepack       0.18.0
                        /home/iobroker/.diag.sh: line 288: nodejs: command not found
                        *** nodejs is NOT correctly installed ***
                        nodejs:
                          Installed: 18.17.1-deb-1nodesource1
                          Candidate: 18.17.1-deb-1nodesource1
                          Version table:
                         *** 18.17.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                                100 /var/lib/dpkg/status
                             18.13.0+dfsg1-1 500
                                500 http://debian.inf.tu-dresden.de/debian bookworm/main amd64 Packages
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.12
                        admin:          6.10.1
                        javascript:     "javascript" not found
                        Adapters from github:   1
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : ioserver                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : ioserver                                 -  enabled
                          system.adapter.discovery.0              : discovery             : ioserver                                 - disabled
                        + system.adapter.email.0                  : email                 : ioserver                                 -  enabled
                        + system.adapter.influxdb.0               : influxdb              : ioserver                                 -  enabled, port: 8086
                          system.adapter.mercedesme.0             : mercedesme            : ioserver                                 - disabled
                          system.adapter.mqtt.1                   : mqtt                  : ioserver                                 - disabled, port: 1883, bind: 0.0.0.0
                          system.adapter.oilfox.0                 : oilfox                : ioserver                                 -  enabled
                        + system.adapter.opendtu.0                : opendtu               : ioserver                                 -  enabled
                        + system.adapter.viessmannapi.0           : viessmannapi          : ioserver                                 -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Used repository: stable
                        Adapter    "admin"        : 6.10.1   , installed 6.10.1
                        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                        Adapter    "email"        : 1.2.0    , installed 1.2.0
                        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                        Controller "js-controller": 5.0.12   , installed 5.0.12
                        Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
                        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                        Adapter    "oilfox"       : 4.2.0    , installed 4.2.0
                        Adapter    "opendtu"      : 1.0.0    , installed 1.0.0
                        Adapter    "viessmannapi" : 2.0.9    , installed 2.2.1
                        Objects and States
                        Objects:        9422
                        States:         7662
                        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:2 http://debian.inf.tu-dresden.de/debian bookworm InRelease
                        Hit:3 http://debian.inf.tu-dresden.de/debian bookworm-updates InRelease
                        Hit:4 https://repos.influxdata.com/debian stable InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        Get:6 https://deb.nodesource.com/node_18.x bookworm InRelease [4586 B]
                        Fetched 4586 B in 1s (5014 B/s)
                        Reading package lists...
                        Pending Updates: 1
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:53939           0.0.0.0:*               LISTEN      111        19304      1089/rpc.statd
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13972      1/init
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18510      559/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19040      984/exim4
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19952      950/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19959      950/iobroker.js-con
                        tcp6       0      0 :::3000                 :::*                    LISTEN      112        20042      948/grafana
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19041      984/exim4
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20066      998/io.admin.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        19602      590/influxd
                        tcp6       0      0 :::9090                 :::*                    LISTEN      0          18217      1/init
                        tcp6       0      0 :::50057                :::*                    LISTEN      111        19310      1089/rpc.statd
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          13974      1/init
                        udp        0      0 127.0.0.1:841           0.0.0.0:*                           0          19296      1089/rpc.statd
                        udp        0      0 0.0.0.0:42092           0.0.0.0:*                           111        19301      1089/rpc.statd
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13973      1/init
                        udp6       0      0 :::46604                :::*                                111        19307      1089/rpc.statd
                        udp6       0      0 :::111                  :::*                                0          13975      1/init
                        2023-10-20 14:06:42.384  - info: influxdb.0 (1041) enabled logging of Viessmann-Aussentemp, Alias=true, 19 points now activated
                        2023-10-20 14:06:42.385  - info: influxdb.0 (1041) enabled logging of Viessmann-Gas-Heizung-Tag, Alias=true, 20 points now activated
                        2023-10-20 14:06:42.385  - info: influxdb.0 (1041) enabled logging of Viessmann-Gas-WW-Tag, Alias=true, 21 points now activated
                        2023-10-20 14:06:42.385  - info: influxdb.0 (1041) enabled logging of Viessmann-Strom-Heizung-Tag, Alias=true, 22 points now activated
                        2023-10-20 14:06:42.385  - info: influxdb.0 (1041) enabled logging of Viessmann-WW-Temp, Alias=true, 23 points now activated
                        2023-10-20 14:06:42.386  - info: influxdb.0 (1041) enabled logging of Viessmann-VL-Temp, Alias=true, 24 points now activated
                        2023-10-20 14:06:42.386  - info: influxdb.0 (1041) enabled logging of Zisterne-Füllstand-Perc, Alias=true, 25 points now activated
                        2023-10-20 14:06:42.386  - info: influxdb.0 (1041) enabled logging of Zisterne-Füllstand-Liter, Alias=true, 26 points now activated
                        2023-10-20 14:06:42.386  - info: influxdb.0 (1041) enabled logging of B200-Letzte-Fahrt-km, Alias=true, 27 points now activated
                        2023-10-20 14:06:42.387  - info: influxdb.0 (1041) enabled logging of B200-Durchschnittsverbrauch-L, Alias=true, 28 points now activated
                        2023-10-20 14:06:42.387  - info: influxdb.0 (1041) enabled logging of B200-Durchschnittsverbrauch-letzte-Fahrt, Alias=true, 29 points now activated
                        2023-10-20 14:06:42.387  - info: influxdb.0 (1041) enabled logging of B200-KM-Stand, Alias=true, 30 points now activated
                        2023-10-20 14:06:42.455  - info: influxdb.0 (1041) Connected!
                        2023-10-20 14:06:44.858  - info: host.ioserver instance system.adapter.backitup.0 started with pid 1056
                        2023-10-20 14:06:46.078  - info: backitup.0 (1056) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.17.1, js-controller: 5.0.12
                        2023-10-20 14:06:46.124  - info: backitup.0 (1056) [iobroker] backup will be activated at 23:00 every 1 day(s)
                        2023-10-20 14:06:48.859  - info: host.ioserver instance system.adapter.opendtu.0 started with pid 1108
                        2023-10-20 14:06:49.077  - info: admin.0 (998) ==> Connected system.user.admin from ::ffff:192.168.115.175
                        2023-10-20 14:06:50.672  - info: opendtu.0 (1108) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.17.1, js-controller: 5.0.12
                        2023-10-20 14:06:51.433  - info: opendtu.0 (1108) Connect to OpenDTU over websocket connection.
                        2023-10-20 14:06:52.860  - info: host.ioserver instance system.adapter.viessmannapi.0 started with pid 1123
                        2023-10-20 14:06:54.081  - info: viessmannapi.0 (1123) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.17.1, js-controller: 5.0.12
                        2023-10-20 14:06:56.834  - info: host.ioserver instance scheduled system.adapter.oilfox.0 5 12 * * *
                        2023-10-20 14:07:05.584  - info: opendtu.0 (1108) Connect to OpenDTU over websocket connection.
                        2023-10-20 14:07:05.734  - info: viessmannapi.0 (1123) 1 installations found.
                          Thomas Braun Most Active @Friedhofsblond last edited by Thomas Braun
                          @friedhofsblond
                          X-Server: true
                          Schalt dem Desktop aus. Server werden exklusiv über die Kommandozeile administriert.
                          Setz den superuser in die Gruppe 'adm', sonst ist der nämlich nicht Super.
                          Und bring nodejs auf die aktuelle Version.
                          • Friedhofsblond
                            habe xfs installiert und Administration über Debian-Cockpit.
                            Superuser ist nicht der root sondern ein einfacher user.
                            Der Admin für IOB ist der Admin - nicht das wir uns mistverstehen. 😉
                              Was ist das? Wofür braucht man das? Ich kenne das nur als Dateisystem.
                              Das der 'superuser' nicht root ist sehe ich. Aber dem fehlt zum super sein halt die Mitgliedschaft in 'adm'
                              • Friedhofsblond
                                sorry Xfce-Desktop - bin halt alt ....
                                • Codierknecht
                                  Xfce-Desktop
                                  So ein Desktop (welcher auch immer) hat auf einem Server nix zu suchen.
                                    @friedhofsblond
                                    Joh, auf einem Server läuft halt kein Desktop. Auch kein xfce. Hat auch mit dem Alter nix zu tun.
                                    • Friedhofsblond
                                      so, fällt Euch nochwas auf (ausser dem Xfce) 😉 ?
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                               Chassis: desktop 🖥️
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : amd64
                                       14:54:52 up 2 min,  2 users,  load average: 0.19, 0.20, 0.08
                                      CPU threads: 2
                                                     Local time: Fri 2023-10-20 14:54:52 CEST
                                                 Universal time: Fri 2023-10-20 12:54:52 UTC
                                                       RTC time: Fri 2023-10-20 12:54:52
                                                    NTP service: active
                                                RTC in local TZ: no
                                      superuser
                                      /home/superuser
                                      superuser adm cdrom floppy sudo audio dip video plugdev users netdev iobroker
                                      X-Server:       true
                                      Desktop:
                                      Terminal:       web
                                      *** MEMORY ***
                                      Mem:            7.9G        1.2G        6.3G         27M        697M        6.7G
                                      Swap:           1.0G          0B        1.0G
                                      Total:          8.9G        1.2G        7.3G
                                               7556 M total memory
                                               1171 M used memory
                                                213 M active memory
                                               1162 M inactive memory
                                               5986 M free memory
                                                 34 M buffer memory
                                                630 M swap cache
                                                975 M total swap
                                                  0 M used swap
                                                975 M free swap
                                      *** FILESYSTEM ***
                                      [Fri Oct 20 14:52:44 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                      [Fri Oct 20 14:52:45 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                      /var:
                                      2.4G    /var/
                                      2.0G    /var/cache
                                      1.9G    /var/cache/apt/archives
                                      1.9G    /var/cache/apt
                                      215M    /var/log
                                      Archived and active journals take up 198.6M in the file system.
                                      60M     /opt/iobroker/iobroker-data/
                                      sort: fflush failed: 'standard output': Broken pipe
                                      sort: write error
                                      8.2M    /opt/iobroker/iobroker-data/objects.jsonl
                                      3.2M    /opt/iobroker/iobroker-data/states.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/nodejs         v18.18.2
                                      /usr/bin/node           v18.18.2
                                      /usr/bin/npm            9.8.1
                                      /usr/bin/npx            9.8.1
                                      /usr/bin/corepack       0.19.0
                                      nodejs:
                                        Installed: 18.18.2-1nodesource1
                                        Candidate: 18.18.2-1nodesource1
                                        Version table:
                                       *** 18.18.2-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.18.1-1nodesource1 1001
                                           18.18.0-1nodesource1 1001
                                           18.17.1-1nodesource1 1001
                                           18.17.0-1nodesource1 1001
                                           18.16.1-1nodesource1 1001
                                           18.16.0-1nodesource1 1001
                                           18.15.0-1nodesource1 1001
                                           18.14.2-1nodesource1 1001
                                           18.14.1-1nodesource1 1001
                                           18.14.0-1nodesource1 1001
                                           18.13.0+dfsg1-1 500
                                           18.13.0-1nodesource1 1001
                                           18.12.0-1nodesource1 1001
                                           18.11.0-1nodesource1 1001
                                           18.10.0-1nodesource1 1001
                                           18.9.1-1nodesource1 1001
                                           18.9.0-1nodesource1 1001
                                           18.8.0-1nodesource1 1001
                                           18.7.0-1nodesource1 1001
                                           18.6.0-1nodesource1 1001
                                           18.5.0-1nodesource1 1001
                                           18.4.0-1nodesource1 1001
                                           18.3.0-1nodesource1 1001
                                           18.2.0-1nodesource1 1001
                                           18.1.0-1nodesource1 1001
                                           18.0.0-1nodesource1 1001
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.10.1
                                      Adapter State
                                      + system.adapter.terminal.0               : terminal              : ioserver                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                      Objects and States
                                      Objects:        9445
                                      States:         7679
                                      Hit:1 http://debian.inf.tu-dresden.de/debian bookworm InRelease
                                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                      Hit:4 https://apt.grafana.com stable InRelease
                                      Hit:5 https://repos.influxdata.com/debian stable InRelease
                                      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:48497           0.0.0.0:*               LISTEN      111        22545      1091/rpc.statd
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19494      953/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20542      953/iobroker.js-con
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19488      988/exim4
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14966      1/init
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19016      567/sshd: /usr/sbin
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19489      988/exim4
                                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       21025      1156/io.terminal.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20669      1002/io.admin.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        17117      591/influxd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      112        19513      952/grafana
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          14968      1/init
                                      tcp6       0      0 :::37127                :::*                    LISTEN      111        22551      1091/rpc.statd
                                      tcp6       0      0 :::9090                 :::*                    LISTEN      0          16646      1/init
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14967      1/init
                                      udp        0      0 0.0.0.0:49340           0.0.0.0:*                           111        22542      1091/rpc.statd
                                      udp        0      0 127.0.0.1:843           0.0.0.0:*                           0          22537      1091/rpc.statd
                                      udp6       0      0 :::111                  :::*                                0          14969      1/init
                                      udp6       0      0 :::37763                :::*                                111        22548      1091/rpc.statd
                                      2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-Gas-WW-Tag, Alias=true, 21 points now activated
                                      2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-Strom-Heizung-Tag, Alias=true, 22 points now activated
                                      2023-10-20 14:53:03.484  - info: influxdb.0 (1045) enabled logging of Viessmann-WW-Temp, Alias=true, 23 points now activated
                                      2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Viessmann-VL-Temp, Alias=true, 24 points now activated
                                      2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Zisterne-Füllstand-Perc, Alias=true, 25 points now activated
                                      2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of Zisterne-Füllstand-Liter, Alias=true, 26 points now activated
                                      2023-10-20 14:53:03.485  - info: influxdb.0 (1045) enabled logging of B200-Letzte-Fahrt-km, Alias=true, 27 points now activated
                                      2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-Durchschnittsverbrauch-L, Alias=true, 28 points now activated
                                      2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-Durchschnittsverbrauch-letzte-Fahrt, Alias=true, 29 points now activated
                                      2023-10-20 14:53:03.486  - info: influxdb.0 (1045) enabled logging of B200-KM-Stand, Alias=true, 30 points now activated
                                      2023-10-20 14:53:03.490  - info: influxdb.0 (1045) Connected!
                                      2023-10-20 14:53:06.011  - info: host.ioserver instance system.adapter.backitup.0 started with pid 1060
                                      2023-10-20 14:53:07.223  - info: backitup.0 (1060) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.12
                                      2023-10-20 14:53:07.268  - info: backitup.0 (1060) [iobroker] backup will be activated at 23:00 every 1 day(s)
                                      2023-10-20 14:53:10.013  - info: host.ioserver instance system.adapter.opendtu.0 started with pid 1113
                                      2023-10-20 14:53:11.095  - info: opendtu.0 (1113) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.18.2, js-controller: 5.0.12
                                      2023-10-20 14:53:11.349  - info: opendtu.0 (1113) Connect to OpenDTU over websocket connection.
                                      2023-10-20 14:53:14.011  - info: host.ioserver instance system.adapter.viessmannapi.0 started with pid 1128
                                      2023-10-20 14:53:15.223  - info: viessmannapi.0 (1128) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.viessmannapi, node: v18.18.2, js-controller: 5.0.12
                                      2023-10-20 14:53:18.059  - info: host.ioserver instance scheduled system.adapter.oilfox.0 5 12 * * *
                                      2023-10-20 14:53:22.014  - info: host.ioserver instance system.adapter.terminal.0 started with pid 1156
                                      2023-10-20 14:53:23.447  - info: terminal.0 (1156) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v18.18.2, js-controller: 5.0.12
                                      2023-10-20 14:53:23.492  - info: terminal.0 (1156) http server listening on port 8088
                                      2023-10-20 14:53:25.953  - info: opendtu.0 (1113) Connect to OpenDTU over websocket connection.
                                      2023-10-20 14:53:27.313  - info: viessmannapi.0 (1128) 1 installations found.
                                        sort: write error
                                        Komische Meldung, sollte da nicht auftauchen.
                                        Und schalt den Desktop AUS!
                                        • Friedhofsblond
                                          OK ich schau mal nach.
                                          Ansonsten beobachte ich mal was morgen so passiert.
                                          Danke erstmal 👍
                                            knopers1 @schoeppi_1 last edited by knopers1
                                            @schoeppi_1
                                            sehr geil 👍 besten Dank! Ich musste das Script etwas anpassen, da ich dauerhaft die Grundlast einspeisen möchte. Am Tage sollte der Akku trotzdem noch voll werden, da ich noch weitere drei Module an 1300 Watt WR Leisung angeschlossen habe.
                                            ich habe jetzt dein erstes Script für meinen Zweck abgeändert, und Mal hier zur Begutachtung exportiert. Kannst Du deine 10 Watt Änderung an meinem angepassten Script noch einfügen?
                                            Komme jetzt mit den zwei Abschnitten nicht ganz klar...
                                              <variables>
                                                <variable id="BN!a@q$SEAU4^)xo:SRJ">maxSolarPower</variable>
                                                <variable id="AcYpB0Ty+wVObL7=Y.a.">measuredPower</variable>
                                                <variable id="1}Q0686mMw0ZGk)e+r?(">measuredSolarPower</variable>
                                                <variable id="le#}gR{6G.yhW=x|6pS8">neededPower</variable>
                                                <variable id="X-B3:`dA%wy5$?]at5W-">NeededPowerPercent</variable>
                                                <variable id=":U;.Z4:pYNy(TwM9X-dL">storedNeededPower</variable>
                                                <variable id="}s`y%Qd}~t2t(jU$8(ud">upperLimit</variable>
                                                <variable id="P^1|W+9iVy?PgNp}9!.S">lowerLimit</variable>
                                                <variable id="?~:J:;gqC%-pt?=zNsH:">Sunrise</variable>
                                                <variable id="UJ`JGN{Ezb$K7jJ[4P}j">Sunset</variable>
                                                <variable id=")2]D^Y|D:QS6S[A}9J=/">SolarLimit</variable>
                                              </variables>
                                              <block type="schedule" id="!P+uzJ#%y!_wHsKqo2~M" x="-769" y="-524">
                                                <field name="SCHEDULE">*/15 * * * * *</field>
                                                  <block type="controls_if" id="xaOp|xXgB@BB44iq}cJ.">
                                                      <block type="time_compare_ex" id="Y8n@Iqzd:%qZbp|#P_v^">
                                                        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                                        <value name="START_TIME">
                                                          <shadow type="text" id="]-0N3DkP*7?ghtYzXwX!">
                                                            <field name="TEXT">10:00</field>
                                                        <value name="END_TIME">
                                                          <shadow type="text" id="fBJt;J|@?8y+L|`jmRd9">
                                                            <field name="TEXT">09:00</field>
                                                      <block type="variables_set" id="~p6WKGjCNU[UXfc{|$8|">
                                                        <field name="VAR" id="BN!a@q$SEAU4^)xo:SRJ">maxSolarPower</field>
                                                          <block type="math_number" id="Z(v(#cMkS]/o.,;iyE/|">
                                                            <field name="NUM">600</field>
                                                          <block type="variables_set" id="Ih%sQzzK`!Ec=`tscEm-">
                                                            <field name="VAR" id="AcYpB0Ty+wVObL7=Y.a.">measuredPower</field>
                                                              <block type="get_value" id="E60zTd:yszZT-@pD[YB#">
        <field name="OID">hm-rega.0.10421</field>
                                                              <block type="variables_set" id=":rlAB32E^@yPP9Jh?EMO">
        <field name="VAR" id="1}Q0686mMw0ZGk)e+r?(">measuredSolarPower</field>
        <block type="get_value" id="Q8pLDlgI~N(N2-6)X@Qu">
        <field name="OID">opendtu.0.114182913679.ac.phase_1.power</field>
        <block type="variables_set" id="t8-xB+K`%rr)x]%:Q5cN">
        <field name="VAR" id="le#}gR{6G.yhW=x|6pS8">neededPower</field>
        <block type="math_arithmetic" id="2FaDMR/kS5K9d!j=`dK3">
        <shadow type="math_number" id="2FEk%?jHI2)Hvf4}p|*;">
        <block type="variables_get" id="Z`YZ!4FileGG?5VwaP-/">
        <shadow type="math_number" id="+10nRI6/x]hugF{/lmxM">
        <block type="variables_get" id="n0BqKn~p@qPw.Jvfrj,s">
        <block type="variables_set" id="$61h{3os=)%X-VEx9M:i">
        <field name="VAR" id="X-B3:`dA%wy5$?]at5W-">NeededPowerPercent</field>
        <block type="math_round" id="3$tH.4.P)ukPPcI4xw.A">
        <value name="NUM">
        <shadow type="math_number" id="{D8W1ElJ#97Cg:]vDkM;">
        <block type="math_arithmetic" id="ju~9S8j-`0c/OF%2$7-o">
        <shadow type="math_number" id="6:p#t,*^;)z:Wb:@dc|3">
        <field name="NUM">100</field>
        <shadow type="math_number" id=".fYZ,3H9RSS}:wD=%Bvk">
        <block type="math_arithmetic" id="Z9S-r-/8^FbCeq,[{ULB">
        <field name="OP">DIVIDE</field>
        <shadow type="math_number" id="jul_lM$(9.yj`:ZH8}%@">
        <block type="variables_get" id="_mPBX.l-0%hNvWtND[z1">
        <shadow type="math_number" id="{Q+JfjzDv.)Z1KRbU*uv">
        <block type="variables_get" id="M!sN^/9!7$b}.ru.lqgC">
        <block type="variables_set" id="g3gA+F5X4*$4x2),%sJV">
        <field name="VAR" id=":U;.Z4:pYNy(TwM9X-dL">storedNeededPower</field>
        <block type="get_value" id="7wbrC,7l;@ahCGcw2/pL">
        <field name="OID">0_userdata.0.PV-Anlage.storedNeededPowerHM600.storedNeededPower</field>
        <block type="variables_set" id="2KI]WdQd`0MzEf%mOPaL">
        <field name="VAR" id="}s`y%Qd}~t2t(jU$8(ud">upperLimit</field>
        <block type="math_round" id="Ha.~N]M`[1eWboby_aYe">
        <value name="NUM">
        <shadow type="math_number" id=":C/cpWh)P`-jK9}]IN*4">
        <block type="math_arithmetic" id="v}v!|Jkv3JHVqQR7poM0">
        <shadow type="math_number" id="Nou}`9U#64_9EfeP$7E^">
        <block type="variables_get" id="{dg*rTfc(I5I1PoYYN;l">
        <shadow type="math_number" id="D`~([S!SEua]l95F+#-*">
        <block type="math_arithmetic" id="#Aa[sC!ija_TtL9Go*jl">
        <shadow type="math_number" id="GfovLR]X(6=?),|X/9K2">
        <block type="variables_get" id="?YS@_}6Hup[`ZsLR!Z45">
        <shadow type="math_number" id="YxGb?xk[MY37)!7O-Cqe">
        <field name="NUM">0.05</field>
        <block type="variables_set" id="+KJ71_Z(eLN.a(uoEuci">
        <field name="VAR" id="P^1|W+9iVy?PgNp}9!.S">lowerLimit</field>
        <block type="math_round" id="=HYNg!vGE)^Z7m{+e$cs">
        <value name="NUM">
        <shadow type="math_number" id="|d.50MyF$Zxnn(B]!gq~">
        <block type="math_arithmetic" id="?8HAOa[X,LM#h`p]lLc4">
        <shadow type="math_number" id="(8p!3BSrd)N0m`PVj}cd">
        <block type="variables_get" id="?$cU!rsg;wkU}CP.VsR.">
        <shadow type="math_number" id="@kP8*eoC!D4/Wa?%grKM">
        <block type="math_arithmetic" id="D$_kryX`Gb5eu$gnYS_q">
        <shadow type="math_number" id="MHx^YJ`[IJHske|0K5}M">
        <block type="variables_get" id="nrL6t1UCC{jy1*U[O|Xq">
        <shadow type="math_number" id="||~-FC.nb3oU=fuLJzw}">
        <field name="NUM">0.1</field>
        <block type="debug" id="8cGY=ms*^/Fbn#Cde4/e">
        <value name="TEXT">
        <shadow type="text" id="csk68CmH=pR,ptmE?y}5">
        <block type="text_join" id="QUQf.~7J|ziuD3sLdl)|">
        <value name="ADD0">
        <block type="text" id="lGPf[Ci!QdAF4j#Bn34-">
        <field name="TEXT">Sonnenaufgang; </field>
        <value name="ADD1">
        <block type="variables_get" id="kwmbl:u%6-!)]lE{Bhdj">
        <field name="VAR" id="?~:J:;gqC%-pt?=zNsH:">Sunrise</field>
        <block type="debug" id="yaFK]t~sZKg}j1WzH!TL">
        <value name="TEXT">
        <shadow type="text" id="A:^a.TTl)CuCY?K4{Z0;">
        <block type="text_join" id="g_%Dq-ksE!p;Tib-dWoB">
        <value name="ADD0">
        <block type="text" id="(bZZUaTT0bt~IQ|a~%#R">
        <field name="TEXT">Sonnenuntergang; </field>
        <value name="ADD1">
        <block type="variables_get" id="weuYcyZ5+:mfnpSK9UiP">
        <field name="VAR" id="UJ`JGN{Ezb$K7jJ[4P}j">Sunset</field>
        <block type="debug" id="1|f1K~GhCe(a;/q4o_X]">
        <value name="TEXT">
        <shadow type="text" id="WtDq6*-h|XRBClzt7C[}">
        <block type="text_join" id="2Zo2{I0w6J%`$2:qEY1l">
        <value name="ADD0">
        <block type="text" id="+YI.VRyx;em.YT$D(|bs">
        <field name="TEXT">Istwert: </field>
        <value name="ADD1">
        <block type="variables_get" id="z%3ACfZd0~)KLgj0p}%@">
        <block type="debug" id="r+xN[i`4xS-M`OYDBpb.">
        <value name="TEXT">
        <shadow type="text" id="huRV|RwGh(WJG|l-)Aw`">
        <block type="text_join" id="(f(78JM#Hy0@?Z0hJe~l">
        <value name="ADD0">
        <block type="text" id="~}`O(MW.TU:J%_oS)#Xu">
        <field name="TEXT">obere Grenze: </field>
        <value name="ADD1">
        <block type="variables_get" id=",vBoJg7x{3!@v.c5w4q]">
        <block type="debug" id="qBNh2:P3U}F#$|$6FZFn">
        <value name="TEXT">
        <shadow type="text" id="2kPK8(t-SdR9TZvb.%-l">
        <block type="text_join" id="}cq5v9RJT$55w(=?6BX)">
        <value name="ADD0">
        <block type="text" id="*q^TTVgJ+?:b!z,x/S;V">
        <field name="TEXT">untere Grenze: </field>
        <value name="ADD1">
        <block type="variables_get" id="Vh$)4$K%:ZHW:~MiMXet">
        <block type="debug" id="k}*+@}8y%^u*6nB1JGm^">
        <value name="TEXT">
        <shadow type="text" id="p_lud?Lq-FYBOI}E.h])">
        <block type="text_join" id="9O/.cB+R0J#M=YHuIJn?">
        <value name="ADD0">
        <block type="text" id="3Uv-x,Irz%wnP{oXU!s^">
        <field name="TEXT">benötigte Power in Prozent:</field>
        <value name="ADD1">
        <block type="variables_get" id="T);Yxf;X[xS0z_7}_YkI">
        <block type="controls_if" id="//Rx),f%pyif!qW8O/?G">
        <mutation elseif="1" else="1"></mutation>
        <block type="logic_operation" id="6|n{EZ*g-L?wwMuw~`pt">
        <field name="OP">AND</field>
        <block type="logic_compare" id="@s)ep$AZC}nn4%[Y{zXv">
        <block type="variables_get" id="rLGQIwoD@(-[)i.@Gek1">
        <block type="math_number" id="i.8)/]r6EY5E@{+61}ch">
        <block type="logic_compare" id="M%7gn=%*6!Oo0Iy!N0HE">
        <field name="OP">EQ</field>
        <block type="variables_get" id="FPBUa4}8MCdw~u2(u=Z4">
        <block type="math_number" id="])#t~DUCT78?qe_~1/X)">
        <block type="debug" id="_|aD2Z`JU`?BoQCCcfTz">
        <value name="TEXT">
        <shadow type="text" id="wcNA/`cj2DUcJLr26^bd">
        <field name="TEXT">keine Änderung, Wert ist gleich gespeichertem Wert</field>
        <value name="IF1">
        <block type="logic_operation" id="4WJuW,40dOlCCnG8!=A(">
        <block type="logic_compare" id="0U*fZT58L0uKFJsD)N{;">
        <field name="OP">GT</field>
        <block type="variables_get" id="%=U`G7.6z`w:8|:XtgTI">
        <block type="variables_get" id="IE{(_NPVQP{:.^rxbG?4">
        <block type="logic_compare" id="7GGwP6lHcmy!ILxZJvYk">
        <field name="OP">LT</field>
        <block type="variables_get" id="EN^7brshgWEicI7V4)C!">
        <block type="variables_get" id="7B.88d1a^Hr`R-b6!iMZ">
        <block type="controls_if" id="P8/_4.KJ/zZ6qh9iBh+o">
        <block type="logic_compare" id="mk*xKT^,LdqKZpmRr}r4">
        <block type="variables_get" id=".d_KP;p/?wytr_{S7(db">
        <block type="variables_get" id="R!EQmKR0*lP1iR`NTG%f">
        <block type="variables_set" id="v_^pc%4YAqueF4@xp/Ph">
        <field name="VAR" id=")2]D^Y|D:QS6S[A}9J=/">SolarLimit</field>
        <block type="variables_get" id="rba!2I;EQyijkPfjo!Ze">
        <block type="update" id="E7HJvqAC,*BNAxN~e8sd">
        <block type="variables_get" id="hR1[WimPbd@1ICN+UAdn">
        <statement name="ELSE">
        <block type="variables_set" id="iqqD`P-h34,:2q7p$CH|">
        <block type="math_number" id="dowAhu.+=iz#Wc-F]p:X">
        <block type="update" id="*?5=;cANP)NJ|KuX_[PF">
        <block type="math_number" id="7vXqNl1zb}n*oh6q3:]4">
        <block type="controls_if" id="ngN)`(Ee_|WVjpbeEi,Z">
        <block type="logic_compare" id="E;jvy,d?,h~{8J-;$c#Z">
        <block type="variables_get" id="j.wG0w+y^vE]tm7AZ2SR">
        <block type="math_number" id="qmst0kfQa63`(1C?20+t">
        <field name="NUM">4</field>
        <block type="variables_set" id="eG:yr(gAO*#W@6$4I,9T">
        <block type="math_number" id="0qq=Pa2L.`pfN{/fr=|V">
        <field name="NUM">5</field>
        <block type="control" id="KN@t^0cE0k@-082b*`$}">
        <field name="OID">opendtu.0.114182913679.power_control.limit_nonpersistent_relative</field>
        <block type="variables_get" id="T,9Ms}!g05fFGlV[=97t">
        <block type="update" id="K~#2,NL{?T,t?vi8K@_K">
        <field name="OID">0_userdata.0.PV-Anlage.Solarlimit_HM600.Solarlimit_HM600</field>
        <block type="variables_get" id="obffp}fvI-w|9kbk(:D7">
        <block type="debug" id="4(mO4hae0d8|yCEDlMj~">
        <value name="TEXT">
        <shadow type="text" id="GhK9E*i9z*IoFuBKSaq1">
        <block type="text_join" id="K$7:Tw;%Pm?f$3/:xV?V">
        <value name="ADD0">
        <block type="text" id="tzX795?CuQ=.SGL`i!ns">
        <field name="TEXT">gesetztes Limit: </field>
        <value name="ADD1">
        <block type="variables_get" id="`hpd|~6gnaa1#A:#I^ku">
        <block type="debug" id="k-_yI!1YR}Cw@^zA*2By">
        <value name="TEXT">
        <shadow type="text" id="pOzzR,#7b~P,=jhm/QLz">
        <field name="TEXT">keine Änderung</field>
                                                      <block type="debug" id="6hv2w66u%V}c3Ij`Q?pi">
                                                        <value name="TEXT">
                                                          <shadow type="text" id="LmPU])Tk80,#%40`K:m4">
                                                            <field name="TEXT">Zeit ist außerhalb der Reglungszeit.</field>
                                            Ich lade mein Batterie tagsüber. Der dahinter geschaltete WR ist dann vom Netz getrennt. Wenn ich einspeise, ist das Ladegerät vom Netz getrennt. Ich weiß nicht ob man eine Batterie gleichzeitig laden und entladen kann, was Dir vermutlich vorschwebt?
                                            das Laden und Entladen parallel macht dem Akku nichts aus... Es geht und wird auch woanders genau so geregelt.
                                            31.7k
                                            79.8k
                                            dtu hoymiles opendtu solar
                                            47
                                            457
                                            79829
