    3. Einsteigerfragen
    4. FLOT Grafik-URL in Image rendern und abspeichern
    • DJMarc75
      DJMarc75 @Andreas 9 last edited by
      @andreas-9 sagte in FLOT Grafik-URL in Image rendern und abspeichern:
      Dabei hab ich mich an diese Anleitung gehalten
      Uralter Quatsch und auf Desktop basierend.
      In dem LOG (welches man eigentlich in Codetags hier rein setzt) sehe ich zudem dass Node 18.13.0 installiert ist - quasi krumm.
      Zeig mal bitte
      iob diag
      Langfassung und auch bitte in Codetags 😉
        Andreas 9 @DJMarc75 last edited by
        @djmarc75
        so?
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Static hostname: IOBroker-rasi
        Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
        Kernel: Linux 6.1.0-rpi4-rpi-v7
        Architecture: arm
        Model : Raspberry Pi 3 Model B Plus Rev 1.3
        Docker : false
        Virtualization : none
        Kernel : armv7l
        Userland : armhf
        Systemuptime and Load:
        14:11:27 up 7 min, 4 users, load average: 1.38, 1.75, 1.08
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        *** Time and Time Zones ***
        Local time: Fri 2023-10-20 14:11:27 CEST
        Universal time: Fri 2023-10-20 12:11:27 UTC
        RTC time: n/a
        NTP service: active
        RTC in local TZ: no
        *** User and Groups ***
        andi
        /home/andi
        andi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: true
        Desktop:
        Terminal: tty
        Boot Target: graphical.target
        *** MEMORY ***
        total used free shared buff/cache available
        Mem: 966M 798M 50M 9.9M 184M 168M
        Swap: 104M 104M 69K
        Total: 1.1G 903M 50M
              921 M total memory
              761 M used memory
              316 M active memory
              476 M inactive memory
               47 M free memory
                3 M buffer memory
              172 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        udev devtmpfs 325M 0 325M 0% /dev
        tmpfs tmpfs 93M 912K 92M 1% /run
        /dev/mmcblk0p2 ext4 235G 6.1G 217G 3% /
        tmpfs tmpfs 461M 8.0K 461M 1% /dev/shm
        tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock
        /dev/mmcblk0p1 vfat 510M 113M 398M 23% /boot/firmware
        tmpfs tmpfs 93M 36K 93M 1% /run/user/1000
        [Fri Oct 20 14:03:45 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=3da5620d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Fri Oct 20 14:03:52 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Oct 20 14:03:55 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET SOURCE FSTYPE OPTIONS
        / /dev/mmcblk0p2 ext4 rw,noatime
        `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        649M /var/
        225M /var/log/journal/3d6b5879ff85490ca0b4d60fb921e0ca
        225M /var/log
        178M /var/lib
        Archived and active journals take up 224.0M in the file system.
        /opt/iobroker/backups:
        29M /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        175M /opt/iobroker/iobroker-data/
        116M /opt/iobroker/iobroker-data/files
        52M /opt/iobroker/iobroker-data/files/javascript.admin
        34M /opt/iobroker/iobroker-data/files/javascript.admin/static
        33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        20M /opt/iobroker/iobroker-data/objects.jsonl
        8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        7.2M /opt/iobroker/iobroker-data/states.jsonl
        7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        *** NodeJS-Installation ***
        /usr/bin/nodejs v18.13.0
        /usr/bin/node v18.13.0
        /usr/bin/npm 9.2.0
        /usr/bin/npx 9.2.0
        /home/iobroker/.diag.sh: line 281: corepack: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
        Installed: 18.13.0+dfsg1-1+rpi1
        Candidate: 18.13.0+dfsg1-1+rpi1
        Version table:
        *** 18.13.0+dfsg1-1+rpi1 500
        500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
        100 /var/lib/dpkg/status
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Core adapters versions
        js-controller: 5.0.12
        admin: 6.3.5
        javascript: 7.1.4
        Adapters from github: 0
        Adapter State
        • system.adapter.admin.0 : admin : IOBroker-rasi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        • system.adapter.backitup.0 : backitup : IOBroker-rasi - enabled
        • system.adapter.discovery.0 : discovery : IOBroker-rasi - enabled
          system.adapter.flot.0 : flot : IOBroker-rasi - enabled
          system.adapter.fritzdect.0 : fritzdect : IOBroker-rasi - disabled
        • system.adapter.hm-rega.0 : hm-rega : IOBroker-rasi - enabled
        • system.adapter.hm-rpc.0 : hm-rpc : IOBroker-rasi - enabled, port: 0
        • system.adapter.influxdb.0 : influxdb : IOBroker-rasi - enabled, port: 8086
        • system.adapter.javascript.0 : javascript : IOBroker-rasi - enabled
          system.adapter.panasonic-viera.0 : panasonic-viera : IOBroker-rasi - disabled
        • system.adapter.plenticore.0 : plenticore : IOBroker-rasi - enabled, port: 80
          system.adapter.puppeteer.0 : puppeteer : IOBroker-rasi - enabled
        • system.adapter.rpi2.0 : rpi2 : IOBroker-rasi - enabled
          system.adapter.vis-bars.0 : vis-bars : IOBroker-rasi - disabled
          system.adapter.vis.0 : vis : IOBroker-rasi - enabled
        • system.adapter.web.0 : web : IOBroker-rasi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        • instance is alive
        ioBroker-Repositories
        stable : http://download.iobroker.net/sources-dist.json
        beta : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter "admin" : 6.10.1 , installed 6.3.5 [Updatable]
        Adapter "backitup" : 2.8.1 , installed 2.6.23 [Updatable]
        Adapter "cul" : 2.2.0 , installed 2.2.0
        Adapter "discovery" : 3.1.0 , installed 3.1.0
        Adapter "flot" : 1.12.0 , installed 1.12.0
        Adapter "fritzdect" : 2.3.1 , installed 2.3.1
        Adapter "hm-rega" : 3.0.47 , installed 3.0.47
        Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
        Adapter "influxdb" : 3.2.0 , installed 3.2.0
        Adapter "javascript" : 7.1.4 , installed 7.1.4
        Controller "js-controller": 5.0.12 , installed 5.0.12
        Adapter "mediola-gateway": 1.0.1 , installed 1.0.1
        Adapter "panasonic-viera": 2.0.0 , installed 2.0.0
        Adapter "plenticore" : 2.2.0 , installed 2.2.0
        Adapter "puppeteer" : 0.2.7 , installed 0.2.7
        Adapter "rpi2" : 1.3.2 , installed 1.3.2
        Adapter "simple-api" : 2.7.2 , installed 2.7.2
        Adapter "socketio" : 6.5.5 , installed 6.5.5
        Adapter "sql" : 2.2.0 , installed 2.2.0
        Adapter "vis" : 1.4.16 , installed 1.4.16
        Adapter "vis-bars" : 0.1.4 , installed 0.1.4
        Adapter "web" : 6.1.2 , installed 6.1.2
        Adapter "ws" : 2.5.5 , installed 2.5.5
        Objects and States
        Objects: 1220
        States: 896
        E: The repository 'https://repos.influxdata.com/debian bookworm Release' does not have a Release file.
        W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Pending Updates: 16
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 18807 688/iobroker.js-con
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 15244 688/iobroker.js-con
        tcp 0 0 127.0.0.1:41245 0.0.0.0:* LISTEN 1001 19310 1570/chromium-brows
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13884 706/sshd: /usr/sbin
        tcp 0 0 0.0.0.0:42010 0.0.0.0:* LISTEN 1001 19726 1527/io.hm-rpc.0
        tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 112 16521 686/influxd
        tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 16527 685/cupsd
        tcp6 0 0 ::1:631 :::* LISTEN 0 16526 685/cupsd
        tcp6 0 0 :::22 :::* LISTEN 0 13886 706/sshd: /usr/sbin
        tcp6 0 0 :::8086 :::* LISTEN 112 15143 686/influxd
        tcp6 0 0 :::8081 :::* LISTEN 1001 17990 1321/io.admin.0
        tcp6 0 0 :::8082 :::* LISTEN 1001 21575 1733/io.web.0
        udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14139 857/cups-browsed
        udp 0 0 0.0.0.0:39144 0.0.0.0:* 104 16120 519/avahi-daemon: r
        udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 16118 519/avahi-daemon: r
        udp6 0 0 fe80::892c:24f9:e72:546 :::* 0 17461 622/NetworkManager
        udp6 0 0 :::58962 :::* 104 16121 519/avahi-daemon: r
        udp6 0 0 :::5353 :::* 104 16119 519/avahi-daemon: r
        TROUBLESHOOTING: https://pptr.dev/troubleshooting
        at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:262:24)
        at ChildProcess.emit (node:events:525:35)
        at ChildProcess._handle.onexit (node:internal/child_process:291:12)
        2023-10-20 14:06:53.657 - error: puppeteer.0 (2039) Failed to launch the browser process! undefined
        2023-10-20 14:06:53.690 - info: puppeteer.0 (2039) terminating
        2023-10-20 14:06:53.693 - warn: puppeteer.0 (2039) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-10-20 14:06:54.200 - info: puppeteer.0 (2039) terminating
        2023-10-20 14:06:54.326 - error: host.IOBroker-rasi Caught by controller[0]:
        2023-10-20 14:06:54.328 - error: host.IOBroker-rasi Caught by controller[0]: Puppeteer old Headless deprecation warning:
        2023-10-20 14:06:54.329 - error: host.IOBroker-rasi Caught by controller[0]: In the near feature headless: true will default to the new Headless mode
        2023-10-20 14:06:54.331 - error: host.IOBroker-rasi Caught by controller[0]: for Chrome instead of the old Headless implementation. For more
        2023-10-20 14:06:54.332 - error: host.IOBroker-rasi Caught by controller[0]: information, please see https://developer.chrome.com/articles/new-headless/.
        2023-10-20 14:06:54.332 - error: host.IOBroker-rasi Caught by controller[0]: Consider opting in early by passing headless: "new" to puppeteer.launch()
        2023-10-20 14:06:54.333 - error: host.IOBroker-rasi Caught by controller[0]: If you encounter any bugs, please report them to https://github.com/puppeteer/puppeteer/issues/new/choose.
        2023-10-20 14:06:54.334 - error: host.IOBroker-rasi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-10-20 14:06:54.335 - info: host.IOBroker-rasi Restart adapter system.adapter.puppeteer.0 because enabled
        2023-10-20 14:06:54.336 - warn: host.IOBroker-rasi Do not restart adapter system.adapter.puppeteer.0 because restart loop detected
        • DJMarc75
          so?
          nö, sondern so:
            @djmarc75
            na hab ich doch! 😌
            • DJMarc75
              na hab ich doch
              naja 😉
              unabhängig davon:
              RPI3 hat nur 1 GB RAM - zu schwach auf der Brust
              Desktop aktiv - weg damit
              dann
              iob stop
              iob fix
              iob start
              warten !!!
              iob nodejs-update
                @djmarc75
                hat leider nichts gebracht. Im iob diag steht immer noch: *** nodejs is NOT correctly installed ***
                • DJMarc75
                  bitte nichts nacherzählen sondern zeigen (Codetags) 😉
                    @djmarc75
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                     15:20:29 up  1:16,  5 users,  load average: 1.99, 1.86, 1.23
                    CPU threads: 4
                    Current issues:
                    ~ Under-voltage detected
                                   Local time: Fri 2023-10-20 15:20:29 CEST
                               Universal time: Fri 2023-10-20 13:20:29 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    andi
                    /home/andi
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            966M        769M         56M        245K        199M        197M
                    Swap:           104M        104M        155K
                    Total:          1.1G        874M         56M
                              921 M total memory
                              734 M used memory
                              636 M active memory
                              145 M inactive memory
                               53 M free memory
                                7 M buffer memory
                              182 M swap cache
                               99 M total swap
                               99 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    tmpfs          tmpfs      93M  920K   92M   1% /run
                    /var:
                    655M    /var/
                    225M    /var/log
                    183M    /var/lib
                    154M    /opt/iobroker/iobroker-data/
                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                    5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                    USB-Devices by-id:
                    /usr/bin/npm            9.2.0
                    /usr/bin/npx            9.2.0
                    nodejs:
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                         18.18.2-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    javascript:     7.1.4
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : IOBroker-rasi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.backitup.0               : backitup              : IOBroker-rasi                            -  enabled
                    + system.adapter.discovery.0              : discovery             : IOBroker-rasi                            -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : IOBroker-rasi                            -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker-rasi                            -  enabled, port: 0
                    + system.adapter.influxdb.0               : influxdb              : IOBroker-rasi                            -  enabled, port: 8086
                    + system.adapter.javascript.0             : javascript            : IOBroker-rasi                            -  enabled
                    + system.adapter.plenticore.0             : plenticore            : IOBroker-rasi                            -  enabled, port: 80
                    + system.adapter.rpi2.0                   : rpi2                  : IOBroker-rasi                            -  enabled
                    + system.adapter.web.0                    : web                   : IOBroker-rasi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + instance is alive
                    Objects and States
                    Objects:        1221
                    States:         897
                    Pending Updates: 16
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       69852      7563/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       68817      7563/iobroker.js-co
                    tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       70060      7639/io.hm-rpc.0
                    tcp        0      0 127.0.0.1:35909         0.0.0.0:*               LISTEN      1001       68049      7681/chromium-brows
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       69905      7581/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       69135      7865/io.web.0
                    2023-10-20 15:20:43.342  - error: puppeteer.0 (8088) Failed to launch the browser process! undefined
                    2023-10-20 15:20:43.363  - info: puppeteer.0 (8088) terminating
                    2023-10-20 15:20:43.367  - warn: puppeteer.0 (8088) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2023-10-20 15:20:43.874  - info: puppeteer.0 (8088) terminating
                    2023-10-20 15:20:43.984  - error: host.IOBroker-rasi Caught by controller[0]:
                    2023-10-20 15:20:43.985  - error: host.IOBroker-rasi Caught by controller[0]:   Puppeteer old Headless deprecation warning:
                    2023-10-20 15:20:43.987  - error: host.IOBroker-rasi Caught by controller[0]:     In the near feature `headless: true` will default to the new Headless mode
                    2023-10-20 15:20:43.988  - error: host.IOBroker-rasi Caught by controller[0]:     for Chrome instead of the old Headless implementation. For more
                    2023-10-20 15:20:43.989  - error: host.IOBroker-rasi Caught by controller[0]:     information, please see https://developer.chrome.com/articles/new-headless/.
                    2023-10-20 15:20:43.989  - error: host.IOBroker-rasi Caught by controller[0]:     Consider opting in early by passing `headless: "new"` to `puppeteer.launch()`
                    2023-10-20 15:20:43.990  - error: host.IOBroker-rasi Caught by controller[0]:     If you encounter any bugs, please report them to https://github.com/puppeteer/puppeteer/issues/new/choose.
                    2023-10-20 15:20:43.990  - error: host.IOBroker-rasi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2023-10-20 15:20:43.991  - info: host.IOBroker-rasi Restart adapter system.adapter.puppeteer.0 because enabled
                    2023-10-20 15:20:43.992  - warn: host.IOBroker-rasi Do not restart adapter system.adapter.puppeteer.0 because restart loop detected
                    2023-10-20 15:21:12.465  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                    2023-10-20 15:21:12.485  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 vis.0
                    2023-10-20 15:21:12.489  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                    2023-10-20 15:21:12.493  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                    2023-10-20 15:21:12.496  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                    2023-10-20 15:21:12.499  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                    • DJMarc75
                      @andreas-9
                      Zusammenfassend:
                      • Nimm ein anderes Netzteil welches Deinen PI versorgt
                      • schalte den Desktop aus
                      • RPI3 ist mit 1 GB RAM zu schwach
                      • iob nodejs-update nochmals ausführen und beobachten !
                      • System IMMER aktuell halten (Pending Updates: 16)
                        Thomas Braun Most Active @Andreas 9 last edited by
                        Hab ja schliesslich das ganze system letzte Woche neu aufgesetzt.
                        Wie schafft man dann so eine krumme Installation?
                        Ich würd's nochmal machen. Diesmal ohne Desktop und mit dem iob-Installer, der zieht auch das richtige nodejs mit.
                          Andreas 9 @Thomas Braun last edited by
                          @thomas-braun said in FLOT Grafik-URL in Image rendern und abspeichern:
                          😞 Echt? So ein Mist!!!
                          Aber vielen Dank für deine Mühe!
                          Wird unter "Lerneffekt" verbucht!
                            @andreas-9
                            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            1417
