    3. Einsteigerfragen
    4. FLOT Grafik-URL in Image rendern und abspeichern
      Andreas 9 @DJMarc75 last edited by
      @djmarc75
      so?
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Static hostname: IOBroker-rasi
      Icon name: computer
      Operating System: Raspbian GNU/Linux 12 (bookworm)
      Kernel: Linux 6.1.0-rpi4-rpi-v7
      Architecture: arm
      Model : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker : false
      Virtualization : none
      Kernel : armv7l
      Userland : armhf
      Systemuptime and Load:
      14:11:27 up 7 min, 4 users, load average: 1.38, 1.75, 1.08
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
      Local time: Fri 2023-10-20 14:11:27 CEST
      Universal time: Fri 2023-10-20 12:11:27 UTC
      RTC time: n/a
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      andi
      /home/andi
      andi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: true
      Desktop:
      Terminal: tty
      Boot Target: graphical.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 966M 798M 50M 9.9M 184M 168M
      Swap: 104M 104M 69K
      Total: 1.1G 903M 50M
            921 M total memory
            761 M used memory
            316 M active memory
            476 M inactive memory
             47 M free memory
              3 M buffer memory
            172 M swap cache
             99 M total swap
             99 M used swap
              0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      udev devtmpfs 325M 0 325M 0% /dev
      tmpfs tmpfs 93M 912K 92M 1% /run
      /dev/mmcblk0p2 ext4 235G 6.1G 217G 3% /
      tmpfs tmpfs 461M 8.0K 461M 1% /dev/shm
      tmpfs tmpfs 5.0M 12K 5.0M 1% /run/lock
      /dev/mmcblk0p1 vfat 510M 113M 398M 23% /boot/firmware
      tmpfs tmpfs 93M 36K 93M 1% /run/user/1000
      [Fri Oct 20 14:03:45 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=3da5620d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Fri Oct 20 14:03:52 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Oct 20 14:03:55 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/mmcblk0p2 ext4 rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      649M /var/
      225M /var/log/journal/3d6b5879ff85490ca0b4d60fb921e0ca
      225M /var/log
      178M /var/lib
      Archived and active journals take up 224.0M in the file system.
      /opt/iobroker/backups:
      29M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      175M /opt/iobroker/iobroker-data/
      116M /opt/iobroker/iobroker-data/files
      52M /opt/iobroker/iobroker-data/files/javascript.admin
      34M /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      20M /opt/iobroker/iobroker-data/objects.jsonl
      8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      7.2M /opt/iobroker/iobroker-data/states.jsonl
      7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs v18.13.0
      /usr/bin/node v18.13.0
      /usr/bin/npm 9.2.0
      /usr/bin/npx 9.2.0
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
      Installed: 18.13.0+dfsg1-1+rpi1
      Candidate: 18.13.0+dfsg1-1+rpi1
      Version table:
      *** 18.13.0+dfsg1-1+rpi1 500
      500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
      100 /var/lib/dpkg/status
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 5.0.12
      admin: 6.3.5
      javascript: 7.1.4
      Adapters from github: 0
      Adapter State
      • system.adapter.admin.0 : admin : IOBroker-rasi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      • system.adapter.backitup.0 : backitup : IOBroker-rasi - enabled
      • system.adapter.discovery.0 : discovery : IOBroker-rasi - enabled
        system.adapter.flot.0 : flot : IOBroker-rasi - enabled
        system.adapter.fritzdect.0 : fritzdect : IOBroker-rasi - disabled
      • system.adapter.hm-rega.0 : hm-rega : IOBroker-rasi - enabled
      • system.adapter.hm-rpc.0 : hm-rpc : IOBroker-rasi - enabled, port: 0
      • system.adapter.influxdb.0 : influxdb : IOBroker-rasi - enabled, port: 8086
      • system.adapter.javascript.0 : javascript : IOBroker-rasi - enabled
        system.adapter.panasonic-viera.0 : panasonic-viera : IOBroker-rasi - disabled
      • system.adapter.plenticore.0 : plenticore : IOBroker-rasi - enabled, port: 80
        system.adapter.puppeteer.0 : puppeteer : IOBroker-rasi - enabled
      • system.adapter.rpi2.0 : rpi2 : IOBroker-rasi - enabled
        system.adapter.vis-bars.0 : vis-bars : IOBroker-rasi - disabled
        system.adapter.vis.0 : vis : IOBroker-rasi - enabled
      • system.adapter.web.0 : web : IOBroker-rasi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
      • instance is alive
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.10.1 , installed 6.3.5 [Updatable]
      Adapter "backitup" : 2.8.1 , installed 2.6.23 [Updatable]
      Adapter "cul" : 2.2.0 , installed 2.2.0
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "flot" : 1.12.0 , installed 1.12.0
      Adapter "fritzdect" : 2.3.1 , installed 2.3.1
      Adapter "hm-rega" : 3.0.47 , installed 3.0.47
      Adapter "hm-rpc" : 1.15.19 , installed 1.15.19
      Adapter "influxdb" : 3.2.0 , installed 3.2.0
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "mediola-gateway": 1.0.1 , installed 1.0.1
      Adapter "panasonic-viera": 2.0.0 , installed 2.0.0
      Adapter "plenticore" : 2.2.0 , installed 2.2.0
      Adapter "puppeteer" : 0.2.7 , installed 0.2.7
      Adapter "rpi2" : 1.3.2 , installed 1.3.2
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "socketio" : 6.5.5 , installed 6.5.5
      Adapter "sql" : 2.2.0 , installed 2.2.0
      Adapter "vis" : 1.4.16 , installed 1.4.16
      Adapter "vis-bars" : 0.1.4 , installed 0.1.4
      Adapter "web" : 6.1.2 , installed 6.1.2
      Adapter "ws" : 2.5.5 , installed 2.5.5
      Objects and States
      Objects: 1220
      States: 896
      E: The repository 'https://repos.influxdata.com/debian bookworm Release' does not have a Release file.
      W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Pending Updates: 16
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 18807 688/iobroker.js-con
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 15244 688/iobroker.js-con
      tcp 0 0 127.0.0.1:41245 0.0.0.0:* LISTEN 1001 19310 1570/chromium-brows
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13884 706/sshd: /usr/sbin
      tcp 0 0 0.0.0.0:42010 0.0.0.0:* LISTEN 1001 19726 1527/io.hm-rpc.0
      tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 112 16521 686/influxd
      tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 16527 685/cupsd
      tcp6 0 0 ::1:631 :::* LISTEN 0 16526 685/cupsd
      tcp6 0 0 :::22 :::* LISTEN 0 13886 706/sshd: /usr/sbin
      tcp6 0 0 :::8086 :::* LISTEN 112 15143 686/influxd
      tcp6 0 0 :::8081 :::* LISTEN 1001 17990 1321/io.admin.0
      tcp6 0 0 :::8082 :::* LISTEN 1001 21575 1733/io.web.0
      udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14139 857/cups-browsed
      udp 0 0 0.0.0.0:39144 0.0.0.0:* 104 16120 519/avahi-daemon: r
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 16118 519/avahi-daemon: r
      udp6 0 0 fe80::892c:24f9:e72:546 :::* 0 17461 622/NetworkManager
      udp6 0 0 :::58962 :::* 104 16121 519/avahi-daemon: r
      udp6 0 0 :::5353 :::* 104 16119 519/avahi-daemon: r
      TROUBLESHOOTING: https://pptr.dev/troubleshooting
      at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:262:24)
      at ChildProcess.emit (node:events:525:35)
      at ChildProcess._handle.onexit (node:internal/child_process:291:12)
      2023-10-20 14:06:53.657 - error: puppeteer.0 (2039) Failed to launch the browser process! undefined
      2023-10-20 14:06:53.690 - info: puppeteer.0 (2039) terminating
      2023-10-20 14:06:53.693 - warn: puppeteer.0 (2039) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-10-20 14:06:54.200 - info: puppeteer.0 (2039) terminating
      2023-10-20 14:06:54.326 - error: host.IOBroker-rasi Caught by controller[0]:
      2023-10-20 14:06:54.328 - error: host.IOBroker-rasi Caught by controller[0]: Puppeteer old Headless deprecation warning:
      2023-10-20 14:06:54.329 - error: host.IOBroker-rasi Caught by controller[0]: In the near feature headless: true will default to the new Headless mode
      2023-10-20 14:06:54.331 - error: host.IOBroker-rasi Caught by controller[0]: for Chrome instead of the old Headless implementation. For more
      2023-10-20 14:06:54.332 - error: host.IOBroker-rasi Caught by controller[0]: information, please see https://developer.chrome.com/articles/new-headless/.
      2023-10-20 14:06:54.332 - error: host.IOBroker-rasi Caught by controller[0]: Consider opting in early by passing headless: "new" to puppeteer.launch()
      2023-10-20 14:06:54.333 - error: host.IOBroker-rasi Caught by controller[0]: If you encounter any bugs, please report them to https://github.com/puppeteer/puppeteer/issues/new/choose.
      2023-10-20 14:06:54.334 - error: host.IOBroker-rasi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-10-20 14:06:54.335 - info: host.IOBroker-rasi Restart adapter system.adapter.puppeteer.0 because enabled
      2023-10-20 14:06:54.336 - warn: host.IOBroker-rasi Do not restart adapter system.adapter.puppeteer.0 because restart loop detected
      • DJMarc75
        DJMarc75 @Andreas 9 last edited by
        @andreas-9 sagte in FLOT Grafik-URL in Image rendern und abspeichern:
        so?
        nö, sondern so:
          @djmarc75
          na hab ich doch! 😌
          • DJMarc75
            na hab ich doch
            naja 😉
            unabhängig davon:
            RPI3 hat nur 1 GB RAM - zu schwach auf der Brust
            Desktop aktiv - weg damit
            dann
            iob stop
            iob fix
            iob start
            warten !!!
            iob nodejs-update
              @djmarc75
              hat leider nichts gebracht. Im iob diag steht immer noch: *** nodejs is NOT correctly installed ***
              • DJMarc75
                bitte nichts nacherzählen sondern zeigen (Codetags) 😉
                  @djmarc75
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : armhf
                   15:20:29 up  1:16,  5 users,  load average: 1.99, 1.86, 1.23
                  CPU threads: 4
                  Current issues:
                  ~ Under-voltage detected
                                 Local time: Fri 2023-10-20 15:20:29 CEST
                             Universal time: Fri 2023-10-20 13:20:29 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  andi
                  /home/andi
                  X-Server:       true
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            966M        769M         56M        245K        199M        197M
                  Swap:           104M        104M        155K
                  Total:          1.1G        874M         56M
                            921 M total memory
                            734 M used memory
                            636 M active memory
                            145 M inactive memory
                             53 M free memory
                              7 M buffer memory
                            182 M swap cache
                             99 M total swap
                             99 M used swap
                              0 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  tmpfs          tmpfs      93M  920K   92M   1% /run
                  /var:
                  655M    /var/
                  225M    /var/log
                  183M    /var/lib
                  154M    /opt/iobroker/iobroker-data/
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  5.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/550.cfbef968.chunk.js.map
                  USB-Devices by-id:
                  /usr/bin/npm            9.2.0
                  /usr/bin/npx            9.2.0
                  nodejs:
                    Candidate: 18.18.2-1nodesource1
                    Version table:
                       18.18.2-1nodesource1 1001
                          500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                       18.18.1-1nodesource1 1001
                       18.18.0-1nodesource1 1001
                       18.17.1-1nodesource1 1001
                       18.17.0-1nodesource1 1001
                       18.16.1-1nodesource1 1001
                       18.16.0-1nodesource1 1001
                       18.15.0-1nodesource1 1001
                       18.14.2-1nodesource1 1001
                       18.14.1-1nodesource1 1001
                       18.14.0-1nodesource1 1001
                       18.13.0-1nodesource1 1001
                       18.12.0-1nodesource1 1001
                       18.11.0-1nodesource1 1001
                       18.10.0-1nodesource1 1001
                       18.9.1-1nodesource1 1001
                       18.9.0-1nodesource1 1001
                       18.8.0-1nodesource1 1001
                       18.7.0-1nodesource1 1001
                       18.6.0-1nodesource1 1001
                       18.5.0-1nodesource1 1001
                       18.4.0-1nodesource1 1001
                       18.3.0-1nodesource1 1001
                       18.2.0-1nodesource1 1001
                       18.1.0-1nodesource1 1001
                       18.0.0-1nodesource1 1001
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     7.1.4
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : IOBroker-rasi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.backitup.0               : backitup              : IOBroker-rasi                            -  enabled
                  + system.adapter.discovery.0              : discovery             : IOBroker-rasi                            -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : IOBroker-rasi                            -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker-rasi                            -  enabled, port: 0
                  + system.adapter.influxdb.0               : influxdb              : IOBroker-rasi                            -  enabled, port: 8086
                  + system.adapter.javascript.0             : javascript            : IOBroker-rasi                            -  enabled
                  + system.adapter.plenticore.0             : plenticore            : IOBroker-rasi                            -  enabled, port: 80
                  + system.adapter.rpi2.0                   : rpi2                  : IOBroker-rasi                            -  enabled
                  + system.adapter.web.0                    : web                   : IOBroker-rasi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Objects and States
                  Objects:        1221
                  States:         897
                  Pending Updates: 16
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       69852      7563/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       68817      7563/iobroker.js-co
                  tcp        0      0 0.0.0.0:42010           0.0.0.0:*               LISTEN      1001       70060      7639/io.hm-rpc.0
                  tcp        0      0 127.0.0.1:35909         0.0.0.0:*               LISTEN      1001       68049      7681/chromium-brows
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       69905      7581/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       69135      7865/io.web.0
                  2023-10-20 15:20:43.342  - error: puppeteer.0 (8088) Failed to launch the browser process! undefined
                  2023-10-20 15:20:43.363  - info: puppeteer.0 (8088) terminating
                  2023-10-20 15:20:43.367  - warn: puppeteer.0 (8088) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2023-10-20 15:20:43.874  - info: puppeteer.0 (8088) terminating
                  2023-10-20 15:20:43.984  - error: host.IOBroker-rasi Caught by controller[0]:
                  2023-10-20 15:20:43.985  - error: host.IOBroker-rasi Caught by controller[0]:   Puppeteer old Headless deprecation warning:
                  2023-10-20 15:20:43.987  - error: host.IOBroker-rasi Caught by controller[0]:     In the near feature `headless: true` will default to the new Headless mode
                  2023-10-20 15:20:43.988  - error: host.IOBroker-rasi Caught by controller[0]:     for Chrome instead of the old Headless implementation. For more
                  2023-10-20 15:20:43.989  - error: host.IOBroker-rasi Caught by controller[0]:     information, please see https://developer.chrome.com/articles/new-headless/.
                  2023-10-20 15:20:43.989  - error: host.IOBroker-rasi Caught by controller[0]:     Consider opting in early by passing `headless: "new"` to `puppeteer.launch()`
                  2023-10-20 15:20:43.990  - error: host.IOBroker-rasi Caught by controller[0]:     If you encounter any bugs, please report them to https://github.com/puppeteer/puppeteer/issues/new/choose.
                  2023-10-20 15:20:43.990  - error: host.IOBroker-rasi instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2023-10-20 15:20:43.991  - info: host.IOBroker-rasi Restart adapter system.adapter.puppeteer.0 because enabled
                  2023-10-20 15:20:43.992  - warn: host.IOBroker-rasi Do not restart adapter system.adapter.puppeteer.0 because restart loop detected
                  2023-10-20 15:21:12.465  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                  2023-10-20 15:21:12.485  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 vis.0
                  2023-10-20 15:21:12.489  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                  2023-10-20 15:21:12.493  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                  2023-10-20 15:21:12.496  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                  2023-10-20 15:21:12.499  - info: web.0 (7865) <== Disconnect system.user.admin from ::ffff:192.168.178.6 flot
                  • DJMarc75
                    @andreas-9
                    Zusammenfassend:
                    • Nimm ein anderes Netzteil welches Deinen PI versorgt
                    • schalte den Desktop aus
                    • RPI3 ist mit 1 GB RAM zu schwach
                    • iob nodejs-update nochmals ausführen und beobachten !
                    • System IMMER aktuell halten (Pending Updates: 16)
                      Thomas Braun Most Active @Andreas 9 last edited by
                      Hab ja schliesslich das ganze system letzte Woche neu aufgesetzt.
                      Wie schafft man dann so eine krumme Installation?
                      Ich würd's nochmal machen. Diesmal ohne Desktop und mit dem iob-Installer, der zieht auch das richtige nodejs mit.
                        Andreas 9 @Thomas Braun last edited by
                        @thomas-braun said in FLOT Grafik-URL in Image rendern und abspeichern:
                        😞 Echt? So ein Mist!!!
                        Aber vielen Dank für deine Mühe!
                        Wird unter "Lerneffekt" verbucht!
                          @andreas-9
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          1418
