    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Mephisto090 @SKB last edited by
      @skb
      Das passt 😞
      • SKB
        SKB Developer Most Active @Mephisto090 last edited by
        @mephisto090 Und, wenn du das komplette Kommando via SSH eingibst, was passiert?
          das hier
          • SKB
            @mephisto090 Dann teste mal statt -f json --json
            Musst dann ggf. das Kommando anpassen.
              Mephisto090 @SKB last edited by Mephisto090
              @skb laut ssh geht das irgendwie auch nicht
              SKB DJMarc75 2 Replies Last reply Reply Quote 0
              • SKB
                @mephisto090 Und nur mit --json ?
                  @skb scheint zu funktionieren. Habe es jetzt mal im script so angepasst.
                    • DJMarc75
                      DJMarc75 @Mephisto090 last edited by
                      @mephisto090 Konsolentexte nicht als Bild sondern kopieren und in Codetags hier einsetzen 😉
                      • SKB
                        @mephisto090 Dann wird es laufen 🙂
                          Mephisto090 @DJMarc75 last edited by Mephisto090
                          @DJMarc75
                          root@iobroker:/opt/iobroker# /usr/bin/speedtest --json
                              "bytes_received": 111995656,
                              "bytes_sent": 43466752,
                              "client": {
                                  "country": "DE",
                                  "ip": "???????",
                                  "isp": "Vodafone Germany DSL",
                                  "ispdlavg": "0",
                                  "isprating": "3.7",
                                  "ispulavg": "0",
                                  "lat": "11.111",
                                  "loggedin": "0",
                                  "lon": "22.222",
                                  "rating": "0"
                              "download": 89252315.3942659,
                              "ping": 26.842,
                              "server": {
                                  "cc": "DE",
                                  "country": "Germany",
                                  "d": 5.1528760454098,
                                  "host": "speedeu.akesacloud.co.za:8080",
                                  "id": "60714",
                                  "lat": "52.5167",
                                  "latency": 26.842,
                                  "lon": "13.3833",
                                  "name": "Berlin",
                                  "sponsor": "Akesa IT - Europe",
                                  "url": "http://speedeu.akesacloud.co.za:8080/speedtest/upload.php"
                              "share": null,
                              "timestamp": "2023-10-20T14:47:20.708905Z",
                              "upload": 34704998.6338473
                          root@iobroker:/opt/iobroker# /usr/bin/speedtest -h
                          usage: speedtest [-h] [--no-download] [--no-upload] [--single] [--bytes] [--share] [--simple] [--csv] [--csv-delimiter CSV_DELIMITER] [--csv-header] [--json] [--list] [--server SERVER] [--exclude EXCLUDE] [--mini MINI]
                                           [--source SOURCE] [--timeout TIMEOUT] [--secure] [--no-pre-allocate] [--version]
                          Command line interface for testing internet bandwidth using speedtest.net. -------------------------------------------------------------------------- https://github.com/sivel/speedtest-cli
                          options:
                            -h, --help            show this help message and exit
                            --no-download         Do not perform download test
                            --no-upload           Do not perform upload test
                            --single              Only use a single connection instead of multiple. This simulates a typical file transfer.
                            --bytes               Display values in bytes instead of bits. Does not affect the image generated by --share, nor output from --json or --csv
                            --share               Generate and provide a URL to the speedtest.net share results image, not displayed with --csv
                            --simple              Suppress verbose output, only show basic information
                            --csv                 Suppress verbose output, only show basic information in CSV format. Speeds listed in bit/s and not affected by --bytes
                                                  Single character delimiter to use in CSV output. Default ","
                            --csv-header          Print CSV headers
                            --json                Suppress verbose output, only show basic information in JSON format. Speeds listed in bit/s and not affected by --bytes
                            --list                Display a list of speedtest.net servers sorted by distance
                            --server SERVER       Specify a server ID to test against. Can be supplied multiple times
                            --exclude EXCLUDE     Exclude a server from selection. Can be supplied multiple times
                            --mini MINI           URL of the Speedtest Mini server
                            --source SOURCE       Source IP address to bind to
                            --timeout TIMEOUT     HTTP timeout in seconds. Default 10
                            --secure              Use HTTPS instead of HTTP when communicating with speedtest.net operated servers
                            --no-pre-allocate     Do not pre allocate upload data. Pre allocation is enabled by default to improve upload performance. To support systems with insufficient memory, use this option to avoid a MemoryError
                            --version             Show the version number and exit
                          --version: Python 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
                            @skb leider nicht
                            16:49:14.239	info	javascript.0 (951689) Start javascript script.js.common.Speedtest
                            16:49:14.243	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                            16:49:14.244	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
                            16:49:14.246	info	javascript.0 (951689) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                            16:49:44.245	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                            16:49:44.457	error	javascript.0 (951689) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input
                            16:49:44.459	error	javascript.0 (951689) at generiere_array (script.js.common.Speedtest:182:18)
                            16:49:44.459	error	javascript.0 (951689) at script.js.common.Speedtest:231:28
                            16:49:44.570	error	host.iobroker Caught by controller[0]: at generiere_array (script.js.common.Speedtest:205:18)
                            16:49:44.570	error	host.iobroker Caught by controller[0]: at script.js.common.Speedtest:254:28
                              @skb habe jetzt auch mal das -s durch --server ersetzt
                              17:01:04.619	info	javascript.0 (954175) Stop script script.js.common.Speedtest
                              17:01:06.582	info	javascript.0 (954175) Start javascript script.js.common.Speedtest
                              17:01:06.595	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                              17:01:06.597	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
                              17:01:06.611	info	javascript.0 (954175) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                              17:01:36.598	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                              17:01:36.935	error	javascript.0 (954175) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest --json --server 37316 Cannot retrieve speedtest configuration ERROR: HTTP Error 403: Forbidden
                              Jetzt kommt diese Meldung
                              Edit: Habe jetzt den Server mit der ID rausgenommen und er führt auch den Speedtest aus. Leider passen wohl die Vars nicht mehr.
                              17:07:56.335	error	javascript.0 (954175) script.js.common.Speedtest: TypeError: Cannot read properties of undefined (reading 'externalIp')
                              • DJMarc75
                                @mephisto090 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                root@iobroker
                                da brauchen wir nicht weitermachen 😉
                                Leg Dir einen User mit Sudorechten an.
                                  @djmarc75 das ist docker 😉 in diesem container läuft nur ein service und das ist iobroker. ich glaube da ist das egal 😉 außerdem ist der nach außen hin nicht offen. 😉
                                    Thomas Braun Most Active @Mephisto090 last edited by
                                    Das ist ja kein Grund. Angriffe können ja auch von innen heraus erfolgen. Durch heruntergeladenen Code. Und dieser Code läuft mit den Rechten des users. Bei root halt ganz schlecht.
                                    Aber bei Docker soll es ja auch irgendwelchen Gründen, die mir bis heute noch niemand plausibel darlegen konnte, angeblich nicht möglich sein eine ordentliche Rechteverwaltung zu haben.
                                    • SKB
                                      @mephisto090 Die Variablen passen noch. Ich habe gerade die aktuelle Version des Speedtest (Speedtest by Ookla 1.2.0.84) installiert.
                                      Hier werden wie erwartet alle Daten gefüllt.
                                        Mephisto090 last edited by Mephisto090
                                        @skb So habe mein Fehler gefunden. Irgendwie war das falsche speedtest-cli installiert. Es funktioniert jetzt und habe mal etwas das Skript angepasst. (Gerne kannst du es auf deiner Seite aktualisieren) Ich habe ein Trigger DP als Button hinzugefügt und das Skript den Button auswerten lassen. Des Weiteren ist Max. und Min. Ping dazugekommen sowie Paket Lost für Down- und Upload. Ich habe das Skript noch mit einer der letzten Statusmeldung ergänzt.
                                         * @copyright 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                                         * @author 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                                         * Dieses Skript dient zur freien Verwendung in ioBroker zur Überprüfung Deiner Internetgeschwindkeit mit Hilfe von Speedtest.
                                         * Jegliche Verantwortung liegt beim Benutzer. Das Skript wurde unter Berücksichtigung der bestmöglichen Nutzung
                                         * und Performance entwickelt.
                                         * Der Entwickler versichert, das keine böswilligen Systemeingriffe im originalen Skript vorhanden sind.
                                         * Sollte das Skript wider Erwarten nicht korrekt funktionieren, so hast Du jederzeit die Möglichkeit, Dich auf
                                         * https://www.kreyenborg.koeln
                                         * für Unterstützung zu melden. Jedes Skript besitzt seine eigene Kommentarseite, auf der,
                                         * nach zeitlicher Möglichkeit des Autors, Hilfe angeboten wird. Ein Anrecht hierauf besteht nicht!
                                         * Ansprüche gegenüber Dritten bestehen nicht.
                                         * Skript Name:        Speedtest
                                         * Skript Version:    1.3
                                         * Erstell-Datum:    29. November 2021
                                        // Datenpunkte neu erstellen
                                        var ueberschreiben = false;
                                        // Hauptdatenpunkt unterhalb javascript
                                        var datenpunkt = "Speedtest.";
                                        // Favorisierter Server
                                        // Liste: https://www.speedtest.net/speedtest-servers.php
                                        var fav_server = 0;
                                        // Speedtest Objekte
                                        var objekt = ["JSON_Output",
                                            "Ergebnisse.PaketLost_Download",
                                            "Ergebnisse.PaketLost_Upload",
                                            "Ergebnisse.Ping",
                                            "Ergebnisse.Ping_Min",
                                            "Ergebnisse.Ping_Max",
                                            "Ergebnisse.Jitter",
                                            "Ergebnisse.Download_MBit",
                                            "Ergebnisse.Upload_MBit",
                                            "Ergebnisse.Download_MB",
                                            "Ergebnisse.Upload_MB",
                                            "Ergebnisse.OriginalDownload",
                                            "Ergebnisse.OriginalUpload",
                                            "ISP",
                                            "IP",
                                            "Ergebnisse.URL",
                                            "Ergebnisse.ID",
                                            "Test.Server.ServerID",
                                            "Test.Server.ServerIP",
                                            "Test.Server.Name",
                                            "Test.Server.Stadt",
                                            "Test.Server.Land",
                                            "Test.Server.Adresse",
                                            "Test.Daten.Download",
                                            "Test.Daten.Upload",
                                            "Test.Daten.OriginalDownload",
                                            "Test.Daten.OriginalUpload",
                                            "Test.Daten.DauerDownload",
                                            "Test.Daten.DauerUpload",
                                            "Test.Daten.Letzter_Speedtest",
                                            "Trigger",
                                            "Status"
                                        // Beschreibung der Objekte
                                        var beschreibung = ["JSON Ausgabe der Konsole",
                                            "Paketverlust in %",
                                            "Ping in ms",
                                            "Min. Ping in ms",
                                            "Max. Ping in ms",
                                            "Jitter in ms",
                                            "Download Geschwindigkeit in MBit/s",
                                            "Upload Geschwindigkeit in MBit/s",
                                            "Download Geschwindigkeit in MB/s",
                                            "Upload Geschwindigkeit in MB/s",
                                            "Download Geschwindigkeit in Byte/s",
                                            "Upload Geschwindigkeit in Byte/s",
                                            "Internet Service Provider",
                                            "externe IP",
                                            "Adresse der Ergebnisse",
                                            "ID der Ergebnisse",
                                            "ID des getesteten Servers",
                                            "IP des getesteten Servers",
                                            "Anbieter des getesteten Servers",
                                            "Stadt des getesteten Servers",
                                            "Land des getesteten Servers",
                                            "URL des getesteten Servers",
                                            "Download Daten in MB",
                                            "Upload Daten in MB",
                                            "Download Daten in Byte",
                                            "Upload Daten in Byte",
                                            "Dauer des Download Test",
                                            "Dauer des Upload Test",
                                            "Letzter Speedtest",
                                            "Startet den Speedtest",
                                            "Status vom letzten Speedtest"
                                        // Einheiten der Objekte
                                        var einheiten = ["",
                                            "ms",
                                            "ms",
                                            "ms",
                                            "ms",
                                            "MBit/s",
                                            "MBit/s",
                                            "MB/s",
                                            "MB/s",
                                            "Byte/s",
                                            "Byte/s",
                                            "MB",
                                            "MB",
                                            "Byte",
                                            "Byte",
                                            "s",
                                            "s",
                                        // Typen der Objekte
                                        var typen = ["string",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "string",
                                            "string",
                                            "string",
                                            "string",
                                            "number",
                                            "string",
                                            "string",
                                            "string",
                                            "string",
                                            "string",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "number",
                                            "string",
                                            "boolean",
                                            "string"
                                        // Rollen der Objekte
                                        var rolle = ["json",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "text",
                                            "text",
                                            "text",
                                            "text",
                                            "value",
                                            "text",
                                            "text",
                                            "text",
                                            "text",
                                            "text",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "value",
                                            "text",
                                            "button",
                                            "text"
                                        // Schreibe Werte des JSON String in ein Array
                                        function generiere_array(json_array) {
                                            var j = JSON.parse(json_array);
                                            var array_werte = [json_array,
                                                parseFloat((j.download.elapsed * 100 / j.download.bytes).toFixed(2)),
                                                parseFloat((j.upload.elapsed * 100 / j.upload.bytes).toFixed(2)),
                                                j.ping.latency,
                                                j.ping.low,
                                                j.ping.high,
                                                j.ping.jitter,
                                                parseFloat((j.download.bandwidth / 125000).toFixed(2)),
                                                parseFloat((j.upload.bandwidth / 125000).toFixed(2)),
                                                parseFloat((j.download.bandwidth / (1024 * 1024)).toFixed(2)),
                                                parseFloat((j.upload.bandwidth / (1024 * 1024)).toFixed(2)),
                                                j.download.bandwidth,
                                                j.upload.bandwidth,
                                                j.isp,
                                                j.interface.externalIp,
                                                j.result.url,
                                                j.result.id,
                                                j.server.id,
                                                j.server.ip,
                                                j.server.name,
                                                j.server.location,
                                                j.server.country,
                                                j.server.host,
                                                parseFloat((j.download.bytes / (1024 * 1024)).toFixed(2)),
                                                parseFloat((j.upload.bytes / (1024 * 1024)).toFixed(2)),
                                                j.download.bytes,
                                                j.upload.bytes,
                                                parseFloat((j.download.elapsed / 1000).toFixed(2)),
                                                parseFloat((j.upload.elapsed / 1000).toFixed(2)),
                                                hole_datum(),
                                                false,
                                                "Speedtest wird durchgeführt"
                                            return array_werte;
                                        function speedtest() {
                                            // temporäre Variable für das Array
                                            var tmp_json;
                                            // Kommando für den Speedtest
                                            setStatus("Speedtest wird durchgeführt");
                                            var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
                                            if (fav_server > 0) {
                                                kommando = kommando + " -s " + fav_server;
                                                log("Speedtest mit Server " + fav_server + " gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                                            } else {
                                                log("Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                                            exec(kommando,
                                                function (error, stdout) {
                                                    if (error) {
                                                        log('Speedtest konnte nicht ausgeführt werden! ' + error, 'error');
                                                        setState(datenpunkt + "Status", "Fehler", true);
                                                        setStatus("Speedtest fehlerhaft");
                                                        return;
                                                    } else {
                                                        tmp_json = generiere_array(stdout);
                                                        aktualisiere_datenpunkt(tmp_json);
                                                        setStatus("Speedtest erfolgreich durchgeführt");
                                                        log('Speedtest durchgeführt. Ergebnisse: Download: ' + tmp_json[7] + ' MBits/s | Upload: ' + tmp_json[8] + ' MBits/s | Ping: ' + tmp_json[3] + 'ms');
                                        function setStatus(text) {
                                            setState(datenpunkt + "Status", text, true);
                                        function aktualisiere_datenpunkt(werte) {
                                            for (let i = 0; i < objekt.length; i++) {
                                                setState(datenpunkt + objekt[i], werte[i], true);
                                        // Erstelle die benötigten Datenpunkte
                                        function datenpunkte_erstellen() {
                                            for (var i = 0; i < objekt.length; i++) {
                                                createState(datenpunkt + objekt[i], "", ueberschreiben, {
                                                    desc: beschreibung[i],
                                                    type: typen[i],
                                                    role: rolle[i],
                                                    unit: einheiten[i]
                                                setStatus("Datenpunkte erfolgreich erstellt");
                                            // Alle Datenpunkte erstellt. Führe ersten Speedtest aus!
                                            log('Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!');
                                            setTimeout(speedtest, 30000);
                                        // Datum
                                        function hole_datum() {
                                            let datum = new Date();
                                            let tag = '0' + datum.getDate();
                                            let monat = '0' + (datum.getMonth() + 1);
                                            let jahr = datum.getFullYear();
                                            let stunde = '0' + datum.getHours();
                                            let minute = '0' + datum.getMinutes();
                                            let sekunde = '0' + datum.getSeconds();
                                            return tag.substr(-2) + '.' + monat.substr(-2) + '.' + jahr + ' ' + stunde.substr(-2) + ':' + minute.substr(-2) + ':' + sekunde.substr(-2);
                                        function speedtest_erster_start() {
                                            log("Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!");
                                            // Datenpunkte werden erstellt
                                            datenpunkte_erstellen();
                                        // Erster Start und Initialisierung
                                        speedtest_erster_start();
                                        // Alle 60 Minuten einen Speedtest ausführen
                                        schedule('0,30 * * * *', speedtest);
                                        // Script ausführen wenn Datenpunkt "Speedtest-Trigger" = true
                                        on({ id: "javascript.0.Speedtest.Trigger", change: "any" }, function (obj) {
                                            if (obj.state.val===true) {
                                                speedtest ();
                                          PatrickFro @Mephisto090 last edited by
                                          Moin,
                                          bei mir funktioniert das Script aus welchem Grunde auch immer nicht - bin leider sonst kein Linux-Nutzer-
                                          Anzeige im Javascript-Adapter:
                                          error	javascript.1 (10238) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr /bin/sh: 1: /usr/bin/speedtest: not found
                                          /etc/speedtest# type -p speedtest
                                          /usr/bin/speedtest
                                          Gebe ich in der Konsole
                                          /usr/bin/speedtest -f json --accept-license --accept-gdpr -s 28602
                                          ein, funktioniert der Speedtest.
                                          Ich nutze Debian-Linux Bookworm und habe die automatische Installation genutzt:
                                          sudo apt-get install curl
                                          curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                                          sudo apt-get install speedtest```
                                            Thomas Braun Most Active @PatrickFro last edited by
                                            @patrickfro
                                            sudo apt update
                                            apt policy speedtest*
                                            sagt?
                                            391
                                            73773
