    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
      Conector777 last edited by
      Ach befor es kommt auch mit RM4P
      	2023-08-15 13:15:20.018	info	discover [ '192.168.1.133' ] from 0.0.0.0:34452
      broadlink2.0
      	2023-08-15 13:15:20.014	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }:
      broadlink2.0
      	2023-08-15 13:15:15.607	warn	Failed to authenticate device RM4P, undefined, ec:0b:ae:84:e9:f2, 192.168.178.133 with err [object Object]
      broadlink2.0
      	2023-08-15 13:15:14.781	info	discover [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:34526
      broadlink2.0
      	2023-08-15 13:15:14.780	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }:
      broadlink2.0
      	2023-08-15 13:15:14.718	info	Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0
      	2023-08-15 13:15:14.717	info	macObjects: []
      broadlink2.0
      	2023-08-15 13:15:14.717	info	interface to be used: { netmaskBits: 24, address: '192.168.178.49/24', addrs: [ 192, 168, 178, 49 ], cidr: '192.168.178.49/24', bcaddr: '192.168.178.255' }:
      broadlink2.0
      	2023-08-15 13:15:14.715	info	broadlink2 has 0 old devices!
      broadlink2.0
      	2023-08-15 13:15:14.715	info	Devices to rename:
      broadlink2.0
      	2023-08-15 13:15:14.714	info	Devices to add: 21011=RM4P
      broadlink2.0
      	2023-08-15 13:15:14.714	info	Scanning additional IP's: 192.168.1.133
      broadlink2.0
      	2023-08-15 13:15:14.712	info	broadlink2 initialization started...
      broadlink2.0
      	2023-08-15 13:15:14.607	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.17.1, js-controller: 4.0.24
        crunchip Forum Testing Most Active @Conector777 last edited by
        @conector777 https://forum.iobroker.net/post/940424
        stett was von 27755=RM4P
          Danke aber ich habe es gerade geschafft....Fehler war ...das sich durch das Update der Box wieder die Schutzfunktion im Menü aktiviert hat. Dann kann man sie nicht Auslesen
            flipkill1985 last edited by
            ich habe ein Signal einer Fernbedienung zum drehen um damit eine Lampe aus und eine zu fahren.
            Wen ich das Signal nun ausführe geht die Lampe nur 2 cm ausgefahren, ich müsste das signal verlängern.
            mache ich es mit blockly ruckelt die Lampe beim ausfahren.
            hat jemand eine Idee? wie ich ein Signal verlängern kann?
            Grüße Jan
            padrino R 2 Replies Last reply Reply Quote 0
            • padrino
              padrino Most Active @flipkill1985 last edited by
              @flipkill1985 sagte in Adapter: broadlink2:
              Geht soweit ich weiß mit dem Broadlink leider nicht.
              • Krisiun
                Krisiun last edited by
                Hallo Leute,
                ich habe seid ein paar Tagen einen Problem. Der Broadlink schreibt eine Warnung in log.
                Error in StateChange for broadlink2.1.Scenes.Fernseher = Error: The id is empty! Please provide a valid id.at Validator.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/validator.js:113:19)at AdapterClass.setForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:6048:25)at /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2037:16at new Promise (<anonymous>)at AdapterClass.setForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2036:16)at /opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:318:6at async sendScene (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:317:3)at async A.stateChange (/opt/iobroker/node_modules/iobroker.broadlink2/broadlink2.js:182:47)
                Natürlich als Leier weiß ich nicht wirklich wie ich da vorgehen soll.
                Mag mir mal jemand helfen?
                Krisiun 1 Reply Last reply Reply Quote 0
                  flipkill1985 @padrino last edited by
                  @padrino Eine Idee was ich zur Umsetzung benötige?
                  • Krisiun
                    Krisiun @Krisiun last edited by
                    @krisiun sagte in Adapter: broadlink2:
                    Hallo Leute,
                    Weißt hier wirklich niemand wie ich den Fehler los werden kann?
                    padrino 1 Reply Last reply Reply Quote 0
                    • padrino
                      padrino Most Active @Krisiun last edited by
                      @krisiun
                      Sorry, der Broadlink Adapter ist ziemlich tot... 🤷
                      • Krisiun
                        Krisiun @padrino last edited by
                        @padrino sagte in Adapter: broadlink2:
                        @krisiun
                        Danke für Deine Antwort. Es ist nur der Fehler da der Broadlink funktioniert einwandfrei
                        • BananaJoe
                          BananaJoe Most Active @Krisiun last edited by
                          @krisiun vermutlich wird da mit einer neueren JavaScript-Adapter oder was auch immer Version nicht mehr passen. Wobei "nicht passen": Die neueren Versionen prüfen halt mehr Dinge. Hat halt ggf. vorher zu keiner Fehlermeldung geführt (falls noch alles funktioniert).
                          Ich habe hier auch noch diverse Broadlinks liegen, nur noch einer ist in Betrieb. Ich habe diese inzwischen mit Tasmota-IR Empfängern/Sender abgelöst.
                          angelernt habe ich diese mit dem Broadlink weil die Fernbedienung meines Beamers zum Beispiel schon seit Jahren defekt ist.
                          Gargano 1 Reply Last reply Reply Quote 0
                          • Gargano
                            Gargano @BananaJoe last edited by
                            @bananajoe welche Tasmota IR verwendest Du ? Ich hab auch noch ein Broadlink in Betrieb.
                            • Krisiun
                              Ja das möchte ich auch mal wissen?
                              aber bevor ich alles umstellen muss möchte ich wissen ob mit meinem Broadlink noch was zu machen ist?
                              Ich habe bemerkt dass der Fehler immer nur dann kommt wenn der Fernseher einen Befehl zu einschalten bekommt.
                              • BananaJoe
                                BananaJoe Most Active @Gargano last edited by
                                @gargano ich habe 2 von denen hier im Einsatz:
                                https://www.amazon.de/gp/product/B07L146TXC
                                die habe ich auf Tasmota-IR umgeflasht.
                                Und vom Preis her ist es gerade ok wie ich sehe. Ich hab zwar im Sale 7,99 bezahlt, aber die Preise ändern sich halt. Besser als die 29,99 zwischenzeitlich (regulär scheint der bei 24,99 zu liegen).
                                Hier ist die Anleitung für Tasmota: https://tasmota.github.io/docs/devices/YTF-IR-Bridge/
                                • BananaJoe
                                  @krisiun bei google gibt es Anleitung wie man die Broadlink auf Tasmota umbaut ... indem man da einen Wemos D1 Mini einbaut ...
                                  Wenn das Einschalten ansonsten geht ist doch - im Moment - noch alles gut
                                  Krisiun padrino 2 Replies Last reply Reply Quote 0
                                  • Krisiun
                                    Krisiun @BananaJoe last edited by
                                    @bananajoe
                                    Sieht ziemlich kompliziert aus
                                    • BananaJoe
                                      @krisiun Der Umbau? Jupp, deswegen habe ich es auch gelassen.
                                      Die Dinger von Amazon: pfft wenn man schon ein paar mal Tasmota geflasht hat bzw. so einen Flasher eh da hat: nein.
                                      Ich hab gerade mal geschaut, aber zum fertig kaufen habe ich es nicht gefunden
                                      • Krisiun
                                        @bananajoe
                                        OK. Vielen Dank.
                                        Ich behalte mir deine Anweisungen im Hinterkopf auf. Ich versuche immer nach dem Motto zu handeln:
                                        Dont tuch running system !!
                                        Hab schon mehrmals die Regeln gebrochen und immer bereut.
                                        • padrino
                                          padrino Most Active @BananaJoe last edited by
                                          @bananajoe sagte in Adapter: broadlink2:
                                          Also, wenn das das Projekt ist, dass ich kenne (war das nicht auch hier im Forum?), dann ist der Broadlink dabei doch nur Gehäuse- und Stromspender... 🤔
                                          BananaJoe Krisiun 2 Replies Last reply Reply Quote 0
                                          • BananaJoe
                                            BananaJoe Most Active @padrino last edited by
                                            genau!
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            620004
