Iobroker Absturz - Ursache?
nodejs müsste upgedated sein...
an den ports bin ich gerade dran.
Gibt es ein Auflistung welche ports in Benutzung sind?
Ich würde shelly ändern.
Kann ich sie beliebig ändern?Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 5.10.103-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : armv7l Userland : armhf Systemuptime and Load: 20:42:26 up 1:35, 1 user, load average: 0.58, 1.87, 2.04 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Fri 2023-10-20 20:42:26 CEST Universal time: Fri 2023-10-20 18:42:26 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.4G 817M 0.0K 1.5G 2.2G Swap: 99M 0B 99M Total: 3.9G 1.4G 917M 3786 M total memory 1421 M used memory 514 M active memory 2301 M inactive memory 817 M free memory 435 M buffer memory 1112 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 117G 19G 92G 17% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 758M 868K 757M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sdb1 ext4 113G 79G 29G 74% /backup /dev/sda1 vfat 253M 49M 204M 20% /boot tmpfs tmpfs 379M 16K 379M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Oct 20 19:07:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Fri Oct 20 19:07:28 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [Fri Oct 20 19:07:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Fri Oct 20 19:07:29 2023] EXT4-fs (sda2): re-mounted. Opts: (null) [Fri Oct 20 19:07:31 2023] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null) [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 9962198: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 9962197: comm find: unable to read itable block [Fri Oct 20 20:20:42 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 9962197: comm find: unable to read itable block [Fri Oct 20 20:20:43 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 9962197: comm find: unable to read itable block [Fri Oct 20 20:20:43 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 9962197: comm find: unable to read itable block [Fri Oct 20 20:20:47 2023] EXT4-fs error: 33 callbacks suppressed [Fri Oct 20 20:20:47 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501456: block 9962196: comm find: unable to read itable block [Fri Oct 20 20:31:14 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212836: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:15 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #1578762: block 6291856: comm find: unable to read itable block [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213028: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213014: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213020: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:15 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213018: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:16 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212436: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum invalid [Fri Oct 20 20:31:17 2023] EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578923: comm find: iget: checksum invalid [Fri Oct 20 20:31:18 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212254: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:18 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212241: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212155: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212151: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:20 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361724: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212356: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212340: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212936: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361429: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:22 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361425: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:24 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212632: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212634: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:25 2023] EXT4-fs warning: 1 callbacks suppressed [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212643: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212649: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212645: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:25 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816144: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816543: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816384: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:26 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816546: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:37 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816868: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:37 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816874: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:39 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295018: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:39 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294294: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6293930: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295038: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295036: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294560: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:40 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294556: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:41 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295040: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:42 2023] EXT4-fs warning: 5 callbacks suppressed [Fri Oct 20 20:31:42 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6424206: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1184835: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056874: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:46 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056811: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056879: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056602: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7362338: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056607: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056903: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6951908: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821023: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:47 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821020: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:48 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6820752: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:48 2023] EXT4-fs error: 21 callbacks suppressed [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:48 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 9962193: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 9962193: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 9962193: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 9962193: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:49 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 9962194: comm find: unable to read itable block [Fri Oct 20 20:31:50 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4481932: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:50 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4482754: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:31:57 2023] EXT4-fs error: 4 callbacks suppressed [Fri Oct 20 20:31:57 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 17827376: comm find: unable to read itable block [Fri Oct 20 20:31:57 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 17827376: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 17827368: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 17827368: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 17827385: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 17827385: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 17827377: comm find: unable to read itable block [Fri Oct 20 20:31:58 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 17827377: comm find: unable to read itable block [Fri Oct 20 20:31:59 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 17827385: comm find: unable to read itable block [Fri Oct 20 20:31:59 2023] EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 17827385: comm find: unable to read itable block [Fri Oct 20 20:32:01 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893701: lblock 0: comm find: error -5 reading directory block [Fri Oct 20 20:32:01 2023] EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893470: lblock 0: comm find: error -5 reading directory block Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime,stripe=8191 |-/backup /dev/sdb1 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 6.4G /var/ 3.4G /var/cache/apt 3.4G /var/cache 3.3G /var/cache/apt/archives 2.6G /var/lib Archived and active journals take up 232.0M in the file system. /opt/iobroker/backups: 3.9G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.1G /opt/iobroker/iobroker-data/ 552M /opt/iobroker/iobroker-data/backup-objects 383M /opt/iobroker/iobroker-data/files 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png 52M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 41M /opt/iobroker/iobroker-data/states.json.old 41M /opt/iobroker/iobroker-data/states.json.bak 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 24M /opt/iobroker/iobroker-data/objects.jsonl 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03 /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00 *** NodeJS-Installation *** /usr/bin/nodejs v18.18.2 /usr/bin/node v18.18.2 /usr/bin/npm 9.8.1 /usr/bin/npx 9.8.1 /usr/bin/corepack 0.19.0 nodejs: Installed: 18.18.2-1nodesource1 Candidate: 18.18.2-1nodesource1 Version table: *** 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: redis Core adapters versions js-controller: 5.0.12 admin: 6.10.1 javascript: 7.1.4 Adapters from github: 3 Adapter State + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspi - enabled + system.adapter.backitup.0 : backitup : raspi - enabled + system.adapter.chromecast.0 : chromecast : raspi - enabled + system.adapter.cloud.0 : cloud : raspi - enabled system.adapter.deconz.0 : deconz : raspi - disabled, port: 80 system.adapter.devices.0 : devices : raspi - enabled system.adapter.feiertage.0 : feiertage : raspi - enabled system.adapter.flot.0 : flot : raspi - enabled system.adapter.fritzdect.0 : fritzdect : raspi - disabled system.adapter.hue-extended.0 : hue-extended : raspi - disabled system.adapter.hue.0 : hue : raspi - disabled, port: 443 system.adapter.ical.0 : ical : raspi - enabled system.adapter.icons-icons8.0 : icons-icons8 : raspi - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspi - enabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi - enabled system.adapter.iqontrol.0 : iqontrol : raspi - disabled + system.adapter.javascript.0 : javascript : raspi - enabled system.adapter.luftdaten.0 : luftdaten : raspi - enabled system.adapter.luftdaten.1 : luftdaten : raspi - enabled system.adapter.mqtt.0 : mqtt : raspi - disabled, port: 1884, bind: 0.0.0.0 system.adapter.net-tools.0 : net-tools : raspi - enabled system.adapter.netatmo-crawler.0 : netatmo-crawler : raspi - enabled + system.adapter.nuki.0 : nuki : raspi - enabled + system.adapter.onvif.0 : onvif : raspi - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.ping.0 : ping : raspi - enabled + system.adapter.pushover.0 : pushover : raspi - enabled + system.adapter.reolink.0 : reolink : raspi - enabled + system.adapter.reolink.1 : reolink : raspi - enabled + system.adapter.reolink.2 : reolink : raspi - enabled + system.adapter.reolink.3 : reolink : raspi - enabled system.adapter.reolink.4 : reolink : raspi - disabled system.adapter.samsung_tizen.0 : samsung_tizen : raspi - disabled, port: 8002 + system.adapter.sayit.0 : sayit : raspi - enabled + system.adapter.sayit.1 : sayit : raspi - enabled + system.adapter.sayit.2 : sayit : raspi - enabled + system.adapter.sayit.3 : sayit : raspi - enabled + system.adapter.sayit.4 : sayit : raspi - enabled + system.adapter.sayit.5 : sayit : raspi - enabled + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.smartcontrol.0 : smartcontrol : raspi - disabled + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.2 : sourceanalytix : raspi - enabled + system.adapter.spotify-premium.0 : spotify-premium : raspi - enabled + system.adapter.sql.0 : sql : raspi - enabled, port: 0 system.adapter.statistics.0 : statistics : raspi - disabled + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : raspi - disabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspi - enabled system.adapter.vis-fancyswitch.0 : vis-fancyswitch : raspi - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : raspi - enabled system.adapter.vis-history.0 : vis-history : raspi - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspi - enabled system.adapter.vis-icontwo.0 : vis-icontwo : raspi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspi - enabled system.adapter.vis-justgage.0 : vis-justgage : raspi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspi - enabled system.adapter.vis-metro.0 : vis-metro : raspi - enabled system.adapter.vis-rgraph.0 : vis-rgraph : raspi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspi - enabled system.adapter.vis.0 : vis : raspi - enabled + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspi - disabled + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : raspi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.onvif.0 : onvif : raspi - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.shelly.0 : shelly : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sql.0 : sql : raspi - enabled, port: 0 + system.adapter.telegram.0 : telegram : raspi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspi - enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.10.1 , installed 6.10.1 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "asterisk" : 1.0.6 , installed 1.0.6 Adapter "backitup" : 2.8.1 , installed 2.8.1 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "cloud" : 4.4.1 , installed 4.4.1 Adapter "countdown" : 2.2.0 , installed 2.2.0 Adapter "deconz" : 1.3.21 , installed 1.3.21 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "digitalstrom" : 2.3.0 , installed 2.3.0 Adapter "discovery" : 3.1.0 , installed 3.2.0 Adapter "fb-checkpresence": 1.2.2 , installed 1.2.2 Adapter "feiertage" : 1.1.4 , installed 1.1.4 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.3.1 , installed 2.3.1 Adapter "fullybrowser" : 2.1.2 , installed 2.1.2 Adapter "hue" : 3.10.0 , installed 3.10.0 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iqontrol" : 2.3.0 , installed 2.3.0 Adapter "javascript" : 7.1.4 , installed 7.1.4 Controller "js-controller": 5.0.12 , installed 5.0.12 Adapter "luftdaten" : 3.0.0 , installed 3.0.0 Adapter "moma" : 1.2.9 , installed 1.2.9 Adapter "mqtt" : 4.1.1 , installed 4.1.1 Adapter "mydlink" : 1.3.4 , installed 1.3.4 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "nuki" : 1.6.0 , installed 1.6.0 Adapter "nuki-extended": 2.6.5 , installed 2.6.5 Adapter "octoprint" : 4.0.0 , installed 5.0.1 Adapter "onvif" : 1.0.5 , installed 1.0.5 Adapter "owntracks" : 1.0.5 , installed 1.0.5 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ph803w" : 1.1.1 , installed 1.1.1 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pushover" : 3.0.3 , installed 3.0.4 Adapter "samsung" : 0.5.11 , installed 0.5.11 Adapter "sayit" : 3.0.5 , installed 3.0.0 [Updatable] Adapter "shelly" : 6.4.1 , installed 6.4.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.5.5 , installed 6.5.5 Adapter "sonoff" : 2.5.3 , installed 2.5.7 Adapter "spotify-premium": 1.2.2 , installed 1.2.2 Adapter "sql" : 2.2.0 , installed 2.2.0 Adapter "statistics" : 2.3.0 , installed 2.3.0 Adapter "telegram" : 1.16.0 , installed 1.16.0 Adapter "text2command" : 3.0.2 , installed 3.0.2 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "vis" : 1.4.16 , installed 1.4.16 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 0.96.0 , installed 0.96.0 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 6.1.2 , installed 6.1.2 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wiobrowser" : 2.0.2 , installed 2.0.2 Adapter "ws" : 2.5.5 , installed 2.5.5 Adapter "zigbee" : 1.8.23 , installed 1.8.23 Objects and States Please stand by - This may take a while Objects: 15185 States: 11056 *** OS-Repositories and Updates *** Hit:1 http://phoscon.de/apt/deconz bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 12897 350/deCONZ tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12058 510/sshd: /usr/sbin tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 14693 459/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 458023 2123/io.sonoff.0 tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14750 350/deCONZ tcp 0 0 192.168.178.53:9092 0.0.0.0:* LISTEN 1001 460503 2779/io.nuki.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 457155 1757/iobroker.js-co tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 110 12935 586/mariadbd tcp 0 0 127.0.0.1:6379 0.0.0.0:* LISTEN 118 13918 473/redis-server 12 tcp6 0 0 :::8081 :::* LISTEN 1001 456110 1849/io.admin.1 tcp6 0 0 :::8082 :::* LISTEN 1001 460147 2534/io.web.0 tcp6 0 0 :::22 :::* LISTEN 0 12060 510/sshd: /usr/sbin tcp6 0 0 :::8087 :::* LISTEN 1001 464627 3567/io.simple-api. tcp6 0 0 ::1:631 :::* LISTEN 0 14692 459/cupsd tcp6 0 0 ::1:6379 :::* LISTEN 118 13919 473/redis-server 12 udp 0 0 0.0.0.0:59397 0.0.0.0:* 108 11914 343/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 459997 2432/io.shelly.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12999 903/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 12141 610/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 459488 2196/io.chromecast. udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11912 343/avahi-daemon: r udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14963 350/deCONZ udp6 0 0 :::546 :::* 0 13018 903/dhcpcd udp6 0 0 :::5353 :::* 108 11913 343/avahi-daemon: r udp6 0 0 :::45894 :::* 108 11915 343/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-10-20 20:41:05.366 - warn: sonoff.0 (2123) Client "TAS-2NICE-1" not connected 2023-10-20 20:43:34.170 - info: host.raspi iobroker add shelly auto --host raspi --debug 2023-10-20 20:43:38.123 - info: host.raspi iobroker host.raspi create instance shelly 2023-10-20 20:43:38.215 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.alive created 2023-10-20 20:43:38.289 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.connected created 2023-10-20 20:43:38.317 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.compactMode created 2023-10-20 20:43:38.394 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.cpu created 2023-10-20 20:43:38.435 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.cputime created 2023-10-20 20:43:38.453 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memHeapUsed created 2023-10-20 20:43:38.480 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memHeapTotal created 2023-10-20 20:43:38.496 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.memRss created 2023-10-20 20:43:38.508 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.uptime created 2023-10-20 20:43:38.519 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.inputCount created 2023-10-20 20:43:38.548 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.outputCount created 2023-10-20 20:43:38.562 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.eventLoopLag created 2023-10-20 20:43:38.573 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.sigKill created 2023-10-20 20:43:38.583 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1.logLevel created 2023-10-20 20:43:38.600 - info: host.raspi iobroker host.raspi object shelly.1 created 2023-10-20 20:43:38.644 - info: host.raspi iobroker host.raspi object shelly.1.info created 2023-10-20 20:43:38.690 - info: host.raspi iobroker host.raspi object shelly.1.info.connection created 2023-10-20 20:43:38.706 - info: host.raspi iobroker host.raspi object shelly.1.info.update created 2023-10-20 20:43:38.722 - info: host.raspi iobroker host.raspi object shelly.1.info.downloadScripts created 2023-10-20 20:43:38.728 - info: host.raspi iobroker host.raspi Set default value of shelly.1.info.connection: false 2023-10-20 20:43:38.758 - info: host.raspi iobroker host.raspi object system.adapter.shelly.1 created 2023-10-20 20:43:39.787 - info: host.raspi iobroker exit 0
nodejs ist jetzt richtig.
Aber dem Datenträger sdb1 auf /backup geht es schlecht. Ich vermute da auch den Grund für dein Problem. -
Ich nehme an, es ist dieser part:
@haselchen
woher hast du gesehen, dass shelly und sonoff den gleichen port haben?
(es stimmt wohl, beide auf 1883) -
@thomas-braun said in Iobroker Absturz - Ursache?:
Was ist da?
Das ist da:
evtl. Festplatten-Schaden? -
Ich weiß ja nicht was das da für ein Datenträger ist. Jedenfalls sind das viel zu viele Fehler da auf dem Hobel.
Es sind zwei USB Sticks dran. Aber es betrifft wohl den backup usb stick.
Denkst du das kann sich im laufenden Betrieb auswirken?pi@raspi:~ $ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 119,2G 0 disk ├─sda1 8:1 0 256M 0 part /boot └─sda2 8:2 0 119G 0 part / sdb 8:16 1 114,6G 0 disk └─sdb1 8:17 1 114,6G 0 part /backup
@brokeling sagte in Iobroker Absturz - Ursache?:
Na logisch.
Sonst hättest du ja nicht die ganze Latte an Fehlermeldungen. -
Na logisch.
Sonst hättest du ja nicht die ganze Latte an Fehlermeldungen.ok, danke!
Den werde ich dann austauschen.den shelly port konnte ich ändern 1883 -> 1885
jetzt aber zu den beiden anderen doppel-port-Belegungen:
0 0 0.0.0.0:5353 0.0.0.0:* 1001 283538 12415/io.chromecast udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 11912 343/avahi-daemon: r
jetzt ist die Frage wie ich da rankommen kann, die zu ändern...
Von avahi würde ich die Finger lassen. Ob und wie man den chromcast abschalten kann weiß ich nicht.
ok, ich lass das jetzt mal so. Und tausche schnellstmöglich den USB Stick.
Oder kann man da was "reparieren"?
Danke für die Hilfe!!! -
Moin,
reparieren, kann ich nicht sagen, aber bei einem korrupten Filesystem, kann man immer ein Check machen
# fsck
In Deinem Fall, so
# sudo umount /backup # sudo fsck.ext4 /dev/sdb1
Dann schauen was kommt, falls Du Dir nicht sicher bist, dann hier posten. Den Vorgang wiederholen wenn Fehler auftauchen.
VG
Bernd -
@dp20eic said in Iobroker Absturz - Ursache?:
leider ist mir iobroker heute abgestürzt, wahrscheinlich um so 18:50!?!
Moin,
schau mal nicht nur ins
Log, es kann auch ein Problem außerhalb gewesen sein.
Du könntest insjournal
schauen,# sudo journalctl --since="2023-10-20 18:45:00"
VG
BerndVielen Dank übrigens für die codes!
Ich stelle den das Resultat des letzteren hier rein, vielleicht kann der ein oder andere noch was draus lesen:pi@raspi:~ $ sudo journalctl --since="2023-10-20 18:45:00" -g 'error' -- Journal begins at Thu 2023-08-17 15:42:50 CEST, ends at Sat 2023-10-21 21:43:52 CEST. -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- Okt 20 19:32:46 raspi pipewire[18775]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 996> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501486: block 996> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 996> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501484: block 996> Okt 20 20:20:42 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 996> Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501485: block 996> Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 996> Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501468: block 996> Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 996> Okt 20 20:20:43 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501466: block 996> Okt 20 20:20:47 raspi kernel: print_req_error: 72 callbacks suppressed Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:20:47 raspi kernel: EXT4-fs error: 33 callbacks suppressed Okt 20 20:20:47 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501456: block 996> Okt 20 20:31:02 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 74160 op 0x0:(READ) flags 0x80> Okt 20 20:31:14 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767768 op 0x0:(READ) flags > Okt 20 20:31:14 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212836: lblock 0: com> Okt 20 20:31:15 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 50334880 op 0x0:(READ) flags 0> Okt 20 20:31:15 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #1578762: block 629> Okt 20 20:31:15 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768536 op 0x0:(READ) flags > Okt 20 20:31:15 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213028: lblock 0: com> Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768480 op 0x0:(READ) flags > Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213014: lblock 0: com> Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768504 op 0x0:(READ) flags > Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213020: lblock 0: com> Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768496 op 0x0:(READ) flags > Okt 20 20:31:16 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7213018: lblock 0: com> Okt 20 20:31:16 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 197141808 op 0x0:(READ) flags > Okt 20 20:31:17 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230766184 op 0x0:(READ) flags > Okt 20 20:31:17 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212436: lblock 0: com> Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578927: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578945: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578925: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578921: comm find: iget: checksum > Okt 20 20:31:17 raspi kernel: EXT4-fs error (device sdb1): ext4_lookup:1706: inode #1578923: comm find: iget: checksum > Okt 20 20:31:18 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765472 op 0x0:(READ) flags > Okt 20 20:31:18 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212254: lblock 0: com> Okt 20 20:31:18 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765424 op 0x0:(READ) flags > Okt 20 20:31:18 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212241: lblock 0: com> Okt 20 20:31:20 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765088 op 0x0:(READ) flags > Okt 20 20:31:20 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212155: lblock 0: com> Okt 20 20:31:20 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765072 op 0x0:(READ) flags > Okt 20 20:31:20 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212151: lblock 0: com> Okt 20 20:31:21 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234968984 op 0x0:(READ) flags > Okt 20 20:31:21 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361724: lblock 0: com> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 58724392 op 0x0:(READ) flags 0> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765864 op 0x0:(READ) flags > Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212356: lblock 0: com> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230765800 op 0x0:(READ) flags > Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212340: lblock 0: com> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230768168 op 0x0:(READ) flags > Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212936: lblock 0: com> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234967824 op 0x0:(READ) flags > Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361429: lblock 0: com> Okt 20 20:31:22 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234967808 op 0x0:(READ) flags > Okt 20 20:31:22 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7361425: lblock 0: com> Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230766952 op 0x0:(READ) flags > Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212632: lblock 0: com> Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212634: lblock 0: com> Okt 20 20:31:25 raspi kernel: print_req_error: 2 callbacks suppressed Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767000 op 0x0:(READ) flags > Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212643: lblock 0: com> Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767024 op 0x0:(READ) flags > Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212649: lblock 0: com> Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 230767008 op 0x0:(READ) flags > Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7212645: lblock 0: com> Okt 20 20:31:25 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218171528 op 0x0:(READ) flags > Okt 20 20:31:25 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816144: lblock 0: com> Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218173424 op 0x0:(READ) flags > Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816543: lblock 0: com> Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218172680 op 0x0:(READ) flags > Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816384: lblock 0: com> Okt 20 20:31:26 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218173440 op 0x0:(READ) flags > Okt 20 20:31:26 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816546: lblock 0: com> Okt 20 20:31:37 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218174960 op 0x0:(READ) flags > Okt 20 20:31:37 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816868: lblock 0: com> Okt 20 20:31:37 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218174984 op 0x0:(READ) flags > Okt 20 20:31:37 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6816874: lblock 0: com> Okt 20 20:31:39 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407536 op 0x0:(READ) flags > Okt 20 20:31:39 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295018: lblock 0: com> Okt 20 20:31:39 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201404528 op 0x0:(READ) flags > Okt 20 20:31:39 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294294: lblock 0: com> Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201403016 op 0x0:(READ) flags > Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6293930: lblock 0: com> Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407616 op 0x0:(READ) flags > Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295038: lblock 0: com> Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407608 op 0x0:(READ) flags > Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295036: lblock 0: com> Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201405632 op 0x0:(READ) flags > Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294560: lblock 0: com> Okt 20 20:31:40 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201405616 op 0x0:(READ) flags > Okt 20 20:31:40 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6294556: lblock 0: com> Okt 20 20:31:41 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 201407624 op 0x0:(READ) flags > Okt 20 20:31:41 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6295040: lblock 0: com> Okt 20 20:31:42 raspi kernel: print_req_error: 5 callbacks suppressed Okt 20 20:31:42 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 205593712 op 0x0:(READ) flags > Okt 20 20:31:42 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6424206: lblock 0: com> Okt 20 20:31:46 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 37835504 op 0x0:(READ) flags 0> Okt 20 20:31:46 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1184835: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648672 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056874: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648656 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056811: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648680 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056879: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648352 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056602: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 234970008 op 0x0:(READ) flags > Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #7362338: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648360 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056607: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 33648736 op 0x0:(READ) flags 0> Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #1056903: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 222384016 op 0x0:(READ) flags > Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6951908: lblock 0: com> Okt 20 20:31:47 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218190272 op 0x0:(READ) flags > Okt 20 20:31:47 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821023: lblock 0: com> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218190256 op 0x0:(READ) flags > Okt 20 20:31:48 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6821020: lblock 0: com> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 218189888 op 0x0:(READ) flags > Okt 20 20:31:48 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #6820752: lblock 0: com> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697448 op 0x0:(READ) flags 0> Okt 20 20:31:48 raspi kernel: EXT4-fs error: 21 callbacks suppressed Okt 20 20:31:48 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 996> Okt 20 20:31:48 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 79697440 op 0x0:(READ) flags 0> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501414: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501418: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501402: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501406: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 996> Okt 20 20:31:49 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #2501422: block 996> Okt 20 20:31:50 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4481932: lblock 0: com> Okt 20 20:31:50 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #4482754: lblock 0: com> Okt 20 20:31:57 raspi kernel: print_req_error: 26 callbacks suppressed Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags > Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags > Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags > Okt 20 20:31:57 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags > Okt 20 20:31:57 raspi kernel: EXT4-fs error: 4 callbacks suppressed Okt 20 20:31:57 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 178> Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481282: block 178> Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 178> Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618920 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: blk_update_request: critical medium error, dev sdb, sector 142618928 op 0x0:(READ) flags > Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481164: block 178> Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 178> Okt 20 20:31:58 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481439: block 178> Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 178> Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481297: block 178> Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 178> Okt 20 20:31:59 raspi kernel: EXT4-fs error (device sdb1): __ext4_get_inode_loc_noinmem:4457: inode #4481429: block 178> Okt 20 20:32:01 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893701: lblock 0: com> Okt 20 20:32:02 raspi kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:1003: inode #2893470: lblock 0: com> Okt 20 20:35:30 raspi bash[1130]: [ioredis] Unhandled error event: Error: write EPIPE Okt 20 21:10:59 raspi sshd[26773]: error: kex_exchange_identification: Connection closed by remote host Okt 20 21:58:27 raspi sshd[27425]: error: kex_exchange_identification: Connection closed by remote host Okt 20 21:58:35 raspi pipewire-media-session[18783]: error id:0 seq:293 res:-32 (Broken pipe): connection error Okt 20 21:58:36 raspi bash[1757]: This error originated either by throwing inside of an async function without a catch > Okt 20 21:58:36 raspi bash[1757]: Error: DB closed -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- -- Boot f657936a502c4d5899b0bd648d6120d7 -- -- Boot 9034ae27f1174260808e596c062cf691 -- Okt 20 21:58:46 raspi raspi-config[473]: Error opening '/dev/input/event*': No such file or directory Okt 20 22:23:56 raspi pipewire[16483]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 20 22:24:02 raspi sshd[16619]: error: kex_exchange_identification: Connection closed by remote host Okt 20 22:33:28 raspi sshd[22886]: error: kex_exchange_identification: Connection closed by remote host Okt 20 22:33:31 raspi pipewire[22918]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 20 22:33:32 raspi sshd[22979]: error: kex_exchange_identification: Connection closed by remote host Okt 21 09:29:13 raspi pipewire[11613]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 21 09:35:25 raspi pipewire-media-session[11623]: error id:0 seq:293 res:-32 (Broken pipe): connection error Okt 21 09:35:46 raspi pipewire[16025]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 21 09:36:03 raspi sudo[16220]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl --since=20> Okt 21 09:37:51 raspi pipewire-media-session[16033]: error id:0 seq:293 res:-32 (Broken pipe): connection error Okt 21 21:43:37 raspi pipewire[19010]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could n> Okt 21 21:43:52 raspi sudo[19205]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/journalctl --since=20> lines 199-227/227 (END)
Ich würde behaupten, das Ding ist fratze.
Neuinstallation (auf frischem Datenträger), Backup von vor dem Crash einspielen.
Und diesmal gleich ohne Desktop installieren. -
Aber die Haupt-SSD ist doch in Ordnung und läuft, oder wo ist das Problem?
Das Problem hat doch nur der backup-USB Stick!?!
Und die backups sind ja leider auf dem corrupten USB Stick - ob die auslesbar sind? -
pi@raspi:~ $ sudo umount /backup umount: /backup: not mounted. pi@raspi:~ $ sudo fsck.ext4 /dev/sdb1 e2fsck 1.46.2 (28-Feb-2021) /dev/sdb1 is in use. e2fsck: Cannot continue, aborting.
Kannste ja probieren. Ich würde das Dateisystem aber tunlichst 'nur-lesend'-ro einhängen. Du schrabbelst das Ding sonst nur noch weiter kaputt.
wie mache ich das?
