    4. Test Adapter Weather-Warnings
      ticaki Developer @Chris76e last edited by ticaki
      @chris76e
      Dazu gibts 2 möglichkeiten - Version 1. 01. 10. als fertiges token ... ne geht nicht für english also version 2.
      startday startmonth endday endmonth und das halt
      ${startday}. ${startmonth}.
      Sollte in 1. 10. was erster zehnter bedeutet.
        sigi234 Forum Testing Most Active @Chris76e last edited by sigi234
        @chris76e sagte in Test Adapter Weather-Warnings:
        @sigi234
        stehe gerade auf dem schlauch, mit welchem Widget und wie kann ich die icon´s mit dem DP iconurl anzeigen lassen?
        Widget:Edit
        [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/weather-warnings.admin/icons/black/storm.png","stretch":true},"style":{"left":"176px","top":"379px","z-index":"4","width":"100px","height":"100px"},"widgetSet":"basic"}]
        Chris76e 1 Reply Last reply Reply Quote 0
        • Chris76e
          Chris76e @sigi234 last edited by
          @sigi234
          aber da wird doch "per hand" ein Bild ausgesucht. Dachte das geht mit dem DP automatisch
            @sigi234
            Das war auch so gedacht, wenn das nicht geht, baue ich im Admin ein Feld ein in dem man http://ip:port / https://ip:port selbst eingeben kann.
            M sigi234 Chris76e 3 Replies Last reply Reply Quote 1
              Megawaldi @ticaki last edited by
              @ticaki
              würde denn
              http://localhost:port oder
              https://localhost:port
              nicht funktionieren?
                sigi234 Forum Testing Most Active @ticaki last edited by sigi234
                @ticaki sagte in Test Adapter Weather-Warnings:
                @sigi234
                So geht es bei mir:
                http://192.168.178.20:8082/adapter/weather-warnings/icons/black/storm.png
                Auch so:
                http://localhost:8082/adapter/weather-warnings/icons/black/storm.png
                • Chris76e
                  Chris76e @ticaki last edited by
                  @ticaki
                  keine ahnung was besser ist. Habe die Wettersymbole von Adapter "DasWetter" bis jetzt so eingebunden, dann bräuchte man noch ein DP mit warntypenummer und eine Liste welce nummer für welchen type da ist.
                  sigi234 T 2 Replies Last reply Reply Quote 0
                    @ticaki
                    Und welcher Provider
                    Ist nicht so einfach mit den Icons.
                      @chris76e
                      @sigi234
                      Also ich hab die Tokens für Alexa eingebaut und en Urlprefixfeld. Paar Übersetzungen sind auch besser. Natürlich alles nicht getestet.
                      Eine einfache Liste gibts nicht wirklich: Man sieht hier welche Zahl welche Bedeutung hat: https://github.com/ticaki/ioBroker.weather-warnings/blob/322ccd2bd7a5617bf37b479ff05e029e525b6f76/src/lib/def/messages-def.ts#L302
                          '1': { name: 'genericWarntyp.1.name', id: 'unknown', dwdService: [], uwzService: [0, 1], zamgService: [0, 8] },
                          '2': {
                              dwdService: [40, 41, 44, 45, 48, 49, 51, 52, 53, 54, 55, 56, 57, 58, 96, 79],
                              uwzService: [2],
                              zamgService: [1],
                          '3': {
                              dwdService: [70, 71, 72, 73, 74, 75, 76],
                              uwzService: [3],
                              zamgService: [3],
                          '4': {
                              dwdService: [96, 95, 66, 65, 64, 63, 62, 61, 49, 48, 46, 45, 44, 42],
                              uwzService: [4],
                              zamgService: [2],
                          '5': { name: 'genericWarntyp.5.name', id: 'cold', dwdService: [82, 22], uwzService: [10, 11, 5], zamgService: [7] },
                          '6': { name: 'genericWarntyp.6.name', id: 'forest_fire', dwdService: [], uwzService: [6], zamgService: [] },
                          '7': {
                              dwdService: [90, 91, 92, 93, 95, 96, 31, 33, 34, 36, 38, 40, 41, 42, 44, 45, 46, 48, 49],
                              uwzService: [7],
                              zamgService: [5],
                          '8': {
                              dwdService: [87, 85, 84, 24],
                              uwzService: [8],
                              zamgService: [4],
                          '9': { name: 'genericWarntyp.9.name', id: 'heat', dwdService: [247, 248], uwzService: [9], zamgService: [6] },
                          '10': {
                              dwdService: [95, 96, 46, 48, 49],
                              uwzService: [],
                              zamgService: [],
                          '11': { name: 'genericWarntyp.11.name', id: 'fog', dwdService: [59], uwzService: [], zamgService: [] },
                          '12': { name: 'genericWarntyp.12.name', id: 'thaw', dwdService: [88, 89], uwzService: [], zamgService: [] },
                      Ah gibt doch ne Liste und zwar hier:
                      https://github.com/ticaki/ioBroker.weather-warnings/blob/72408c6b62074952775d61cf162ffa211b3616e5/admin/i18n/de/translations.json#L25
                      Ich könnte es auch noch in das Object formatedKeys.xx.genericwarntype rein schreiben. ins object common, weiß gerade nicht wie das heißt das zahlen als zeichenketten anzeigt.
                      Chris76e 2 Replies Last reply Reply Quote 0
                      • Chris76e
                        @ticaki
                        Wenn man die Symbole vom Adapternutzen will reicht es doch aus, wenn für diese
                            "genericWarntyp.1.name": "Unbekannt",
                            "genericWarntyp.10.name": "Hagel",
                            "genericWarntyp.11.name": "Nebel",
                            "genericWarntyp.12.name": "Tauwetter",
                            "genericWarntyp.2.name": "Sturm",
                            "genericWarntyp.3.name": "Schneefall",
                            "genericWarntyp.4.name": "Regen",
                            "genericWarntyp.5.name": "Kälte",
                            "genericWarntyp.6.name": "Waldbrand",
                            "genericWarntyp.7.name": "Gewitter",
                            "genericWarntyp.8.name": "Glatteis/rutschig",
                            "genericWarntyp.9.name": "Hitze",
                        die nummer ausgegeben wird. Mit den ganzen nummern von DWD wird das ja eh vielzuviel......
                          @ticaki
                          Nicht das wir an einander vorbei reden:
                          1. Es gibt im Admin ein Feld mit dem man das adapter/icons... um das fehlende http://192.168.x.x:8081 ergänzen kann (der / zwischen port und adapter wird ergänzt)
                          2. gibt es nicht... Mist, das ist nur Intern, genericwarntypenumber gibts dann demnächst auch in formatedKeys
                          • Chris76e
                            @ticaki 😊
                            • Chris76e
                              Wenn ich das so für Alexa eingebe hört es sich richtig an
                              Hallo Christian. Es gibt eine ${headline}.     Die Warnung gilt von ${startdayofweek}  ${startday}ter  ${startmonth}ter  ${starttime} bis ${enddayofweek} ${endtime}.           Die Warnstufe ist ${warnlevelcolorname}
                              musste hinter startday und month jeweils ein ter schreiben
                              • rtwl
                                rtwl last edited by
                                ich denke es reicht, wenn es einen Datenpunkt "IconURL" gibt mit dem Pfad zum Icon.
                                DasWetter hat zb diesen Pfad in einem Datenpunkt als string: /adapter/daswetter/icons/tiempo-weather/galeria5/SVG/White/2.svg
                                einbinden in die VIS geht dann ganz einfach via Binding:
                                {daswetter.0.NextHours.Location_1.Day_1.current.iconURL}
                                Wichtig wäre dabei, dass man das Bild färben kann. keine Ahnung ob es mit der PNG möglich ist.
                                  sigi234 Forum Testing Most Active @rtwl last edited by
                                  @rtwl sagte in Test Adapter Weather-Warnings:
                                  Ja
                                    ticaki Developer last edited by ticaki
                                    Dann muß ich also nur ein / noch vor den adapter setzen... mit nächsten update ist es dann /adapter/adaptername/icons und das feld für den Prefix lass ich erstmal mal drin. dann mache ich es später raus und wenn sich wer beschwert kommts wieder rein. 😉
                                    • Chris76e
                                      @ticaki kann es sein das unter command die Auslösung für Alexa nicht funktioniert? Zumindest sagt sie bei mir nichts, Telegram funktioniert. Beim neustart vom Adapter spricht Alexa mit mir
                                        Geht bei mir
                                          @chris76e
                                          guckmal ob bei Alexa auf der rechten Seite eine Vorlage ausgewählt ist.
                                          update
                                          • warntypegeneric - nummer des Warntyps und ne Liste in common.states (in Systemsprache) Ändern der Sprache von States erfordert löschen der States und restart des Adapters
                                          • / in iconurl ergänzt
                                          Und für weitere Iconsets - wenn ihr die drin haben wollt, wäre es nett wenn ihr mir die mit "warntype".png und einen Verweis auf den Urheber und die Lizenz zukommen lasst, dann sind die Fix drin - ich selbst brauch nen Abend für den Kram.
                                          Chris76e rtwl 3 Replies Last reply Reply Quote 0
                                          • Chris76e
                                            Fehler gefunden, hatte da nicht auf die Vorlage "Alexa" geändert. Da war die die Vorlage "NewMessage" drin und da das token ${description}. Das ${description} funktioniert nicht, kann es sein das es eine zeichen beschränkung für Alexa gibt?
                                            31.7k
                                            79.9k
                                            1074
                                            261487
