    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Mephisto090 @SKB last edited by
      • DJMarc75
        DJMarc75 @Mephisto090 last edited by
        @mephisto090 Konsolentexte nicht als Bild sondern kopieren und in Codetags hier einsetzen 😉
        • SKB
          SKB Developer Most Active @Mephisto090 last edited by
          @mephisto090 Dann wird es laufen 🙂
            Mephisto090 @DJMarc75 last edited by Mephisto090
            @DJMarc75
            root@iobroker:/opt/iobroker# /usr/bin/speedtest --json
                "bytes_received": 111995656,
                "bytes_sent": 43466752,
                "client": {
                    "country": "DE",
                    "ip": "???????",
                    "isp": "Vodafone Germany DSL",
                    "ispdlavg": "0",
                    "isprating": "3.7",
                    "ispulavg": "0",
                    "lat": "11.111",
                    "loggedin": "0",
                    "lon": "22.222",
                    "rating": "0"
                "download": 89252315.3942659,
                "ping": 26.842,
                "server": {
                    "cc": "DE",
                    "country": "Germany",
                    "d": 5.1528760454098,
                    "host": "speedeu.akesacloud.co.za:8080",
                    "id": "60714",
                    "lat": "52.5167",
                    "latency": 26.842,
                    "lon": "13.3833",
                    "name": "Berlin",
                    "sponsor": "Akesa IT - Europe",
                    "url": "http://speedeu.akesacloud.co.za:8080/speedtest/upload.php"
                "share": null,
                "timestamp": "2023-10-20T14:47:20.708905Z",
                "upload": 34704998.6338473
            root@iobroker:/opt/iobroker# /usr/bin/speedtest -h
            usage: speedtest [-h] [--no-download] [--no-upload] [--single] [--bytes] [--share] [--simple] [--csv] [--csv-delimiter CSV_DELIMITER] [--csv-header] [--json] [--list] [--server SERVER] [--exclude EXCLUDE] [--mini MINI]
                             [--source SOURCE] [--timeout TIMEOUT] [--secure] [--no-pre-allocate] [--version]
            Command line interface for testing internet bandwidth using speedtest.net. -------------------------------------------------------------------------- https://github.com/sivel/speedtest-cli
            options:
              -h, --help            show this help message and exit
              --no-download         Do not perform download test
              --no-upload           Do not perform upload test
              --single              Only use a single connection instead of multiple. This simulates a typical file transfer.
              --bytes               Display values in bytes instead of bits. Does not affect the image generated by --share, nor output from --json or --csv
              --share               Generate and provide a URL to the speedtest.net share results image, not displayed with --csv
              --simple              Suppress verbose output, only show basic information
              --csv                 Suppress verbose output, only show basic information in CSV format. Speeds listed in bit/s and not affected by --bytes
                                    Single character delimiter to use in CSV output. Default ","
              --csv-header          Print CSV headers
              --json                Suppress verbose output, only show basic information in JSON format. Speeds listed in bit/s and not affected by --bytes
              --list                Display a list of speedtest.net servers sorted by distance
              --server SERVER       Specify a server ID to test against. Can be supplied multiple times
              --exclude EXCLUDE     Exclude a server from selection. Can be supplied multiple times
              --mini MINI           URL of the Speedtest Mini server
              --source SOURCE       Source IP address to bind to
              --timeout TIMEOUT     HTTP timeout in seconds. Default 10
              --secure              Use HTTPS instead of HTTP when communicating with speedtest.net operated servers
              --no-pre-allocate     Do not pre allocate upload data. Pre allocation is enabled by default to improve upload performance. To support systems with insufficient memory, use this option to avoid a MemoryError
              --version             Show the version number and exit
            --version: Python 3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
              @skb leider nicht
              16:49:14.239	info	javascript.0 (951689) Start javascript script.js.common.Speedtest
              16:49:14.243	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
              16:49:14.244	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
              16:49:14.246	info	javascript.0 (951689) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
              16:49:44.245	info	javascript.0 (951689) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
              16:49:44.457	error	javascript.0 (951689) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input
              16:49:44.459	error	javascript.0 (951689) at generiere_array (script.js.common.Speedtest:182:18)
              16:49:44.459	error	javascript.0 (951689) at script.js.common.Speedtest:231:28
              16:49:44.570	error	host.iobroker Caught by controller[0]: at generiere_array (script.js.common.Speedtest:205:18)
              16:49:44.570	error	host.iobroker Caught by controller[0]: at script.js.common.Speedtest:254:28
                Mephisto090 @SKB last edited by Mephisto090
                @skb habe jetzt auch mal das -s durch --server ersetzt
                17:01:04.619	info	javascript.0 (954175) Stop script script.js.common.Speedtest
                17:01:06.582	info	javascript.0 (954175) Start javascript script.js.common.Speedtest
                17:01:06.595	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                17:01:06.597	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!
                17:01:06.611	info	javascript.0 (954175) script.js.common.Speedtest: registered 1 subscription, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                17:01:36.598	info	javascript.0 (954175) script.js.common.Speedtest: Speedtest mit Server 37316 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                17:01:36.935	error	javascript.0 (954175) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest --json --server 37316 Cannot retrieve speedtest configuration ERROR: HTTP Error 403: Forbidden
                Jetzt kommt diese Meldung
                Edit: Habe jetzt den Server mit der ID rausgenommen und er führt auch den Speedtest aus. Leider passen wohl die Vars nicht mehr.
                17:07:56.335	error	javascript.0 (954175) script.js.common.Speedtest: TypeError: Cannot read properties of undefined (reading 'externalIp')
                • DJMarc75
                  @mephisto090 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                  root@iobroker
                  da brauchen wir nicht weitermachen 😉
                  Leg Dir einen User mit Sudorechten an.
                    @djmarc75 das ist docker 😉 in diesem container läuft nur ein service und das ist iobroker. ich glaube da ist das egal 😉 außerdem ist der nach außen hin nicht offen. 😉
                      Thomas Braun Most Active @Mephisto090 last edited by
                      Das ist ja kein Grund. Angriffe können ja auch von innen heraus erfolgen. Durch heruntergeladenen Code. Und dieser Code läuft mit den Rechten des users. Bei root halt ganz schlecht.
                      Aber bei Docker soll es ja auch irgendwelchen Gründen, die mir bis heute noch niemand plausibel darlegen konnte, angeblich nicht möglich sein eine ordentliche Rechteverwaltung zu haben.
                      • SKB
                        @mephisto090 Die Variablen passen noch. Ich habe gerade die aktuelle Version des Speedtest (Speedtest by Ookla 1.2.0.84) installiert.
                        Hier werden wie erwartet alle Daten gefüllt.
                          Mephisto090 last edited by Mephisto090
                          @skb So habe mein Fehler gefunden. Irgendwie war das falsche speedtest-cli installiert. Es funktioniert jetzt und habe mal etwas das Skript angepasst. (Gerne kannst du es auf deiner Seite aktualisieren) Ich habe ein Trigger DP als Button hinzugefügt und das Skript den Button auswerten lassen. Des Weiteren ist Max. und Min. Ping dazugekommen sowie Paket Lost für Down- und Upload. Ich habe das Skript noch mit einer der letzten Statusmeldung ergänzt.
                           * @copyright 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                           * @author 2020 Stephan Kreyenborg <stephan@kreyenborg.koeln>
                           * Dieses Skript dient zur freien Verwendung in ioBroker zur Überprüfung Deiner Internetgeschwindkeit mit Hilfe von Speedtest.
                           * Jegliche Verantwortung liegt beim Benutzer. Das Skript wurde unter Berücksichtigung der bestmöglichen Nutzung
                           * und Performance entwickelt.
                           * Der Entwickler versichert, das keine böswilligen Systemeingriffe im originalen Skript vorhanden sind.
                           * Sollte das Skript wider Erwarten nicht korrekt funktionieren, so hast Du jederzeit die Möglichkeit, Dich auf
                           * https://www.kreyenborg.koeln
                           * für Unterstützung zu melden. Jedes Skript besitzt seine eigene Kommentarseite, auf der,
                           * nach zeitlicher Möglichkeit des Autors, Hilfe angeboten wird. Ein Anrecht hierauf besteht nicht!
                           * Ansprüche gegenüber Dritten bestehen nicht.
                           * Skript Name:        Speedtest
                           * Skript Version:    1.3
                           * Erstell-Datum:    29. November 2021
                          // Datenpunkte neu erstellen
                          var ueberschreiben = false;
                          // Hauptdatenpunkt unterhalb javascript
                          var datenpunkt = "Speedtest.";
                          // Favorisierter Server
                          // Liste: https://www.speedtest.net/speedtest-servers.php
                          var fav_server = 0;
                          // Speedtest Objekte
                          var objekt = ["JSON_Output",
                              "Ergebnisse.PaketLost_Download",
                              "Ergebnisse.PaketLost_Upload",
                              "Ergebnisse.Ping",
                              "Ergebnisse.Ping_Min",
                              "Ergebnisse.Ping_Max",
                              "Ergebnisse.Jitter",
                              "Ergebnisse.Download_MBit",
                              "Ergebnisse.Upload_MBit",
                              "Ergebnisse.Download_MB",
                              "Ergebnisse.Upload_MB",
                              "Ergebnisse.OriginalDownload",
                              "Ergebnisse.OriginalUpload",
                              "ISP",
                              "IP",
                              "Ergebnisse.URL",
                              "Ergebnisse.ID",
                              "Test.Server.ServerID",
                              "Test.Server.ServerIP",
                              "Test.Server.Name",
                              "Test.Server.Stadt",
                              "Test.Server.Land",
                              "Test.Server.Adresse",
                              "Test.Daten.Download",
                              "Test.Daten.Upload",
                              "Test.Daten.OriginalDownload",
                              "Test.Daten.OriginalUpload",
                              "Test.Daten.DauerDownload",
                              "Test.Daten.DauerUpload",
                              "Test.Daten.Letzter_Speedtest",
                              "Trigger",
                              "Status"
                          // Beschreibung der Objekte
                          var beschreibung = ["JSON Ausgabe der Konsole",
                              "Paketverlust in %",
                              "Ping in ms",
                              "Min. Ping in ms",
                              "Max. Ping in ms",
                              "Jitter in ms",
                              "Download Geschwindigkeit in MBit/s",
                              "Upload Geschwindigkeit in MBit/s",
                              "Download Geschwindigkeit in MB/s",
                              "Upload Geschwindigkeit in MB/s",
                              "Download Geschwindigkeit in Byte/s",
                              "Upload Geschwindigkeit in Byte/s",
                              "Internet Service Provider",
                              "externe IP",
                              "Adresse der Ergebnisse",
                              "ID der Ergebnisse",
                              "ID des getesteten Servers",
                              "IP des getesteten Servers",
                              "Anbieter des getesteten Servers",
                              "Stadt des getesteten Servers",
                              "Land des getesteten Servers",
                              "URL des getesteten Servers",
                              "Download Daten in MB",
                              "Upload Daten in MB",
                              "Download Daten in Byte",
                              "Upload Daten in Byte",
                              "Dauer des Download Test",
                              "Dauer des Upload Test",
                              "Letzter Speedtest",
                              "Startet den Speedtest",
                              "Status vom letzten Speedtest"
                          // Einheiten der Objekte
                          var einheiten = ["",
                              "ms",
                              "ms",
                              "ms",
                              "ms",
                              "MBit/s",
                              "MBit/s",
                              "MB/s",
                              "MB/s",
                              "Byte/s",
                              "Byte/s",
                              "MB",
                              "MB",
                              "Byte",
                              "Byte",
                              "s",
                              "s",
                          // Typen der Objekte
                          var typen = ["string",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "string",
                              "string",
                              "string",
                              "string",
                              "number",
                              "string",
                              "string",
                              "string",
                              "string",
                              "string",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "number",
                              "string",
                              "boolean",
                              "string"
                          // Rollen der Objekte
                          var rolle = ["json",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "text",
                              "text",
                              "text",
                              "text",
                              "value",
                              "text",
                              "text",
                              "text",
                              "text",
                              "text",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "value",
                              "text",
                              "button",
                              "text"
                          // Schreibe Werte des JSON String in ein Array
                          function generiere_array(json_array) {
                              var j = JSON.parse(json_array);
                              var array_werte = [json_array,
                                  parseFloat((j.download.elapsed * 100 / j.download.bytes).toFixed(2)),
                                  parseFloat((j.upload.elapsed * 100 / j.upload.bytes).toFixed(2)),
                                  j.ping.latency,
                                  j.ping.low,
                                  j.ping.high,
                                  j.ping.jitter,
                                  parseFloat((j.download.bandwidth / 125000).toFixed(2)),
                                  parseFloat((j.upload.bandwidth / 125000).toFixed(2)),
                                  parseFloat((j.download.bandwidth / (1024 * 1024)).toFixed(2)),
                                  parseFloat((j.upload.bandwidth / (1024 * 1024)).toFixed(2)),
                                  j.download.bandwidth,
                                  j.upload.bandwidth,
                                  j.isp,
                                  j.interface.externalIp,
                                  j.result.url,
                                  j.result.id,
                                  j.server.id,
                                  j.server.ip,
                                  j.server.name,
                                  j.server.location,
                                  j.server.country,
                                  j.server.host,
                                  parseFloat((j.download.bytes / (1024 * 1024)).toFixed(2)),
                                  parseFloat((j.upload.bytes / (1024 * 1024)).toFixed(2)),
                                  j.download.bytes,
                                  j.upload.bytes,
                                  parseFloat((j.download.elapsed / 1000).toFixed(2)),
                                  parseFloat((j.upload.elapsed / 1000).toFixed(2)),
                                  hole_datum(),
                                  false,
                                  "Speedtest wird durchgeführt"
                              return array_werte;
                          function speedtest() {
                              // temporäre Variable für das Array
                              var tmp_json;
                              // Kommando für den Speedtest
                              setStatus("Speedtest wird durchgeführt");
                              var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
                              if (fav_server > 0) {
                                  kommando = kommando + " -s " + fav_server;
                                  log("Speedtest mit Server " + fav_server + " gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                              } else {
                                  log("Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!");
                              exec(kommando,
                                  function (error, stdout) {
                                      if (error) {
                                          log('Speedtest konnte nicht ausgeführt werden! ' + error, 'error');
                                          setState(datenpunkt + "Status", "Fehler", true);
                                          setStatus("Speedtest fehlerhaft");
                                          return;
                                      } else {
                                          tmp_json = generiere_array(stdout);
                                          aktualisiere_datenpunkt(tmp_json);
                                          setStatus("Speedtest erfolgreich durchgeführt");
                                          log('Speedtest durchgeführt. Ergebnisse: Download: ' + tmp_json[7] + ' MBits/s | Upload: ' + tmp_json[8] + ' MBits/s | Ping: ' + tmp_json[3] + 'ms');
                          function setStatus(text) {
                              setState(datenpunkt + "Status", text, true);
                          function aktualisiere_datenpunkt(werte) {
                              for (let i = 0; i < objekt.length; i++) {
                                  setState(datenpunkt + objekt[i], werte[i], true);
                          // Erstelle die benötigten Datenpunkte
                          function datenpunkte_erstellen() {
                              for (var i = 0; i < objekt.length; i++) {
                                  createState(datenpunkt + objekt[i], "", ueberschreiben, {
                                      desc: beschreibung[i],
                                      type: typen[i],
                                      role: rolle[i],
                                      unit: einheiten[i]
                                  setStatus("Datenpunkte erfolgreich erstellt");
                              // Alle Datenpunkte erstellt. Führe ersten Speedtest aus!
                              log('Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 30 Sekunden ausgeführt!');
                              setTimeout(speedtest, 30000);
                          // Datum
                          function hole_datum() {
                              let datum = new Date();
                              let tag = '0' + datum.getDate();
                              let monat = '0' + (datum.getMonth() + 1);
                              let jahr = datum.getFullYear();
                              let stunde = '0' + datum.getHours();
                              let minute = '0' + datum.getMinutes();
                              let sekunde = '0' + datum.getSeconds();
                              return tag.substr(-2) + '.' + monat.substr(-2) + '.' + jahr + ' ' + stunde.substr(-2) + ':' + minute.substr(-2) + ':' + sekunde.substr(-2);
                          function speedtest_erster_start() {
                              log("Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!");
                              // Datenpunkte werden erstellt
                              datenpunkte_erstellen();
                          // Erster Start und Initialisierung
                          speedtest_erster_start();
                          // Alle 60 Minuten einen Speedtest ausführen
                          schedule('0,30 * * * *', speedtest);
                          // Script ausführen wenn Datenpunkt "Speedtest-Trigger" = true
                          on({ id: "javascript.0.Speedtest.Trigger", change: "any" }, function (obj) {
                              if (obj.state.val===true) {
                                  speedtest ();
                            PatrickFro @Mephisto090 last edited by
                            Moin,
                            bei mir funktioniert das Script aus welchem Grunde auch immer nicht - bin leider sonst kein Linux-Nutzer-
                            Anzeige im Javascript-Adapter:
                            error	javascript.1 (10238) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr /bin/sh: 1: /usr/bin/speedtest: not found
                            /etc/speedtest# type -p speedtest
                            /usr/bin/speedtest
                            Gebe ich in der Konsole
                            /usr/bin/speedtest -f json --accept-license --accept-gdpr -s 28602
                            ein, funktioniert der Speedtest.
                            Ich nutze Debian-Linux Bookworm und habe die automatische Installation genutzt:
                            sudo apt-get install curl
                            curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                            sudo apt-get install speedtest```
                              Thomas Braun Most Active @PatrickFro last edited by
                              @patrickfro
                              sudo apt update
                              apt policy speedtest*
                              sagt?
                                @thomas-braun said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                Folgendes:
                                root@VM-IoBroker:/etc/speedtest# sudo apt update
                                OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                                OK:2 http://deb.debian.org/debian bookworm InRelease
                                OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                                OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                OK:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                                Paketlisten werden gelesen… Fertig
                                Abhängigkeitsbaum wird aufgebaut… Fertig
                                Statusinformationen werden eingelesen… Fertig
                                Alle Pakete sind aktuell.
                                root@VM-IoBroker:/etc/speedtest# apt policy speedtest*
                                speedtest:
                                  Installiert:           1.2.0.84-1.ea6b6773cf
                                  Installationskandidat: 1.2.0.84-1.ea6b6773cf
                                  Versionstabelle:
                                 *** 1.2.0.84-1.ea6b6773cf 500
                                        500 https://packagecloud.io/ookla/speedtest-cli/debian bookworm/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                speedtest-cli:
                                  Installiert:           (keine)
                                  Installationskandidat: 2.1.3-2
                                  Versionstabelle:
                                     2.1.3-2 500
                                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                  @patrickfro sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                                  root@
                                  KEIN root-Login!
                                  Meld dich als user an, verdammte Hacke...
                                    PatrickFro @Thomas Braun last edited by
                                    @thomas-braun Schande über mein Haupt. Ist ne neue Installation und der normale User hat noch keine sudo-Rechte. Daher der Weg. Aber nun wirds klar, root hat wohl kein usr-Verzeichnis.
                                      Und das ist das erste und letzte, was man als root in einem neuen System tut. Bzw. man installiert sein Debian gleich von vorneherein OHNE root-Passwort.
                                      usr steht NICHT für user, wenn du das vermuten solltest sondern für UnixSystemRessources. Du meinst vermultich home-Verzeichnisse. Das vom root findet sich unter /root
                                        PatrickFro @Thomas Braun last edited by PatrickFro
                                        ich habe es nun als root deinstalliert
                                        sudo apt-get update
                                        sudo apt-get remove speedtest
                                        meinem normalen user sudo gegeben, mich als normaler user angemeldet, neu installiert, selber Fehler wie oben.
                                        patrick@VM-IoBroker:~$ sudo apt update
                                        patrick@VM-IoBroker:~$ apt policy speedtest*
                                        speedtest:
                                          Versionstabelle:
                                                500 https://packagecloud.io/ookla/speedtest-cli/debian bookworm/main amd        64 Packages
                                        speedtest-cli:
                                          Versionstabelle:
                                             2.1.3-2 500
                                        Ich sehe in diesem Ergebnis leider auch keine Änderung. Du hast doch sicherlich noch eine Idee, oder?
                                          @patrickfro
                                          sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
                                            patrick@VM-IoBroker:~$ sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
                                            {"type":"result","timestamp":"2023-10-22T17:35:33Z","ping":{"jitter":0.318,"latency":1.630,"low":1.274,"high":1.954},"download":{"bandwidth":10028954,"bytes":55169840,"elapsed":5603,"latency":{"iqm":1.419,"low":0.692,"high":207.800,"jitter":18.722}},"upload":{"bandwidth":4651107,"bytes":16764520,"elapsed":3608,"latency":{"iqm":119.987,"low":0.858,"high":317.042,"jitter":40.296}},"packetLoss":0,"isp":"wilhelm.tel","interface":{"internalIp":"...7d8f:6950","name":"ens18","macAddr":"...AE","isVpn":false,"externalIp":"...4950"},"server":{"id":4087,"host":"speedtest.wtnet.de","port":8080,"name":"wilhelm.tel","location":"Norderstedt","country":"Germany","ip":"...3:2"},"result":{"id":"fea91c99-07ee-4ff1-ae4d-8cd14483123","url":"https://www.speedtest.net/result/c/fea91c99-07ee-4ff1-ae4d-8cd144333823","persisted":true}}
                                            391
                                            73599
