    4. Zigbee Adapter startet nicht mehr
      A Former User @anselra last edited by
      @anselra sagte in Zigbee Adapter startet nicht mehr:
      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03
      Moin,
      ja und was habe ich geschrieben, das Du mal den 00 nehmen sollst, sogar mit Erklärung 😉
      VG
      Bernd
        anselra @Jaksa last edited by
        @jaksa
        leider das selbe Resultat
        zigbee.0
        2023-10-21 20:25:46.135	error	Error herdsman start
        zigbee.0
        2023-10-21 20:25:46.135	error	Failed to start Zigbee
        zigbee.0
        2023-10-21 20:25:46.134	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
        zigbee.0
        2023-10-21 20:25:45.862	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
        zigbee.0
        2023-10-21 20:25:45.817	debug	Starting zigbee-herdsman...
        zigbee.0
        2023-10-21 20:25:45.809	info	Starting Zigbee npm ...
        zigbee.0
        2023-10-21 20:25:45.807	info	Try to reconnect. 1 attempts left
        zigbee.0
        2023-10-21 20:25:35.806	error	Error herdsman start
        zigbee.0
        2023-10-21 20:25:35.806	error	Failed to start Zigbee
        zigbee.0
        2023-10-21 20:25:35.805	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
        zigbee.0
        2023-10-21 20:25:35.540	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_25_34.tar.gz success
        zigbee.0
        2023-10-21 20:25:35.537	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
        zigbee.0
        2023-10-21 20:25:35.180	debug	Starting zigbee-herdsman...
        zigbee.0
        2023-10-21 20:25:34.788	info	Starting Zigbee npm ...
        zigbee.0
        2023-10-21 20:25:34.785	info	delete old Backup files. keep only last 10
        zigbee.0
        2023-10-21 20:25:34.689	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
        zigbee.0
        2023-10-21 20:25:34.630	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
        zigbee.0
        2023-10-21 20:25:34.336	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        zigbee.0
        2023-10-21 20:25:34.322	debug	Plugin sentry Initialize Plugin (enabled=true)
        zigbee.0
        2023-10-21 20:25:33.741	debug	States connected to redis: 127.0.0.1:9000
        zigbee.0
        2023-10-21 20:25:33.479	debug	States create User PubSub Client
        zigbee.0
        2023-10-21 20:25:33.478	debug	States create System PubSub Client
        zigbee.0
        2023-10-21 20:25:33.368	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        zigbee.0
        2023-10-21 20:25:33.126	debug	Objects connected to redis: 127.0.0.1:9001
        zigbee.0
        2023-10-21 20:25:33.117	debug	Objects client initialize lua scripts
        zigbee.0
        2023-10-21 20:25:32.802	debug	Objects create User PubSub Client
        zigbee.0
        2023-10-21 20:25:32.800	debug	Objects create System PubSub Client
        zigbee.0
        2023-10-21 20:25:32.798	debug	Objects client ready ... initialize now
        zigbee.0
        2023-10-21 20:25:32.639	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          Jaksa @anselra last edited by Jaksa
          @anselra
          Naja jetzt sieht es so aus als wäre das Gerät bereits in Benutzung durch was auch immer. Das war vorhin noch nicht der Fall.
          Versuch nochmal den Stick aus und wieder einzustecken bzw. die ganze Kiste einmal neu zu starten wenn ersteres nicht hilft.
          • 1Topf
            1Topf @anselra last edited by
            @jaksa
            pi@iobroker:~ $ ls -l /dev/serial/by-id/
            total 0
            lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00 -> ../../ttyACM0
            lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03 -> ../../ttyACM1
            bringt nur den Zigbee Chip
            Wieso bringt es den denn 2mal? Der sollte dort nur 1mal auftauchen, da er ja auch nur 1mal drin steckt.
              Thomas Braun Most Active @1Topf last edited by
              @1topf sagte in Zigbee Adapter startet nicht mehr:
              Der Stick hat zwei Interfaces.
              lsof /dev/ttyACM0
              sagt? (lsof muss ggf. noch installiert werden)
                @jaksa
                Neustart erfolgt, leider immer noch nicht grün
                zigbee.0
                2023-10-21 20:47:46.819	error	Error herdsman start
                zigbee.0
                2023-10-21 20:47:46.819	error	Failed to start Zigbee
                zigbee.0
                2023-10-21 20:47:46.817	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                zigbee.0
                2023-10-21 20:47:46.274	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                zigbee.0
                2023-10-21 20:47:46.220	debug	Starting zigbee-herdsman...
                zigbee.0
                2023-10-21 20:47:39.042	info	Starting Zigbee npm ...
                zigbee.0
                2023-10-21 20:47:39.041	info	Try to reconnect. 1 attempts left
                zigbee.0
                2023-10-21 20:47:29.038	error	Error herdsman start
                zigbee.0
                2023-10-21 20:47:29.037	error	Failed to start Zigbee
                zigbee.0
                2023-10-21 20:47:29.035	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
                zigbee.0
                2023-10-21 20:47:28.177	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
                zigbee.0
                2023-10-21 20:47:27.582	debug	Starting zigbee-herdsman...
                zigbee.0
                2023-10-21 20:47:27.317	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_47_27.tar.gz success
                zigbee.0
                2023-10-21 20:47:27.253	info	Starting Zigbee npm ...
                zigbee.0
                2023-10-21 20:47:27.239	info	delete old Backup files. keep only last 10
                zigbee.0
                2023-10-21 20:47:27.126	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                zigbee.0
                2023-10-21 20:47:26.997	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                  anselra @Thomas Braun last edited by
                  es handelt sich um das dev Board CC26X2R1
                    Raspberry PI OS Lite 32
                    Moin,
                    hat jetzt nichts mit dem eigentlichen Problem zu tun, aber wieso das 32 Bit, warum nicht 64 Bit?
                    VG
                    Bernd
                      anselra @Guest last edited by
                      @dp20eic
                      meinte mich zu erinnern, dass pivccu probleme mit 64Bit hatte
                        Thomas Braun Most Active @anselra last edited by
                        Joh, un?
                          war nur als Zusatz Info gedacht bezüglich deiner Antwort an 1topf
                            @anselra
                            lsof /dev/ttyACM0
                              anselra @Thomas Braun last edited by anselra
                              ist installiert, in der Ausgabe kommt aber nichts
                                anselra @anselra last edited by
                                kurze Info,
                                Ich habe es mit Bookworm lite und:
                                pi@iobroker:~ $ apt policy udev
                                udev:
                                  Installed: 252.17-1~deb12u1
                                  Candidate: 252.17-1~deb12u1
                                  Version table:
                                 *** 252.17-1~deb12u1 500
                                        100 /var/lib/dpkg/status
                                nicht zum laufen gebracht.
                                Bin zurück auf Bullseye lite und mit der https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev läuft jetzt wieder alles.
                                Nicht ganz das gewünschte Ergebnis.
                                Thomas Braun Meister Mopper 3 Replies Last reply Reply Quote 0
                                  Das hat aber dann NICHTS mit udev zu tun, die Bookworm-Version dort hat den Fehler nicht.
                                    mag sein ich hatte aber keinen anderen Ansatz als es so zu Lösen.
                                    Falls du einen anderen Lösungsansatz hast gerne her damit habe das System auf einer anderen platte installiert und somit noch vorhanden
                                      Ohne Meldungen aus dem System natürlich nicht.
                                        waren noch welche offen die ich nicht bereitgestellt habe?
                                          ist halt keine Aussage mit der man irgendwas anfangen könnte.
                                            könntest du konkret werden? du hast davon gesprochen das es ohne Meldungen schwer ist, was vollkommen richtig ist! Allerdings hast du auch keine angefragt die ich nicht zurück gemeldet habe.
                                            Was genau ist jetzt dein Thema?
                                            3137
