    4. Zigbee Adapter startet nicht mehr
      anselra @Jaksa last edited by
      @jaksa
      leider das selbe Resultat
      zigbee.0
      2023-10-21 20:25:46.135	error	Error herdsman start
      zigbee.0
      2023-10-21 20:25:46.135	error	Failed to start Zigbee
      zigbee.0
      2023-10-21 20:25:46.134	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
      zigbee.0
      2023-10-21 20:25:45.862	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
      zigbee.0
      2023-10-21 20:25:45.817	debug	Starting zigbee-herdsman...
      zigbee.0
      2023-10-21 20:25:45.809	info	Starting Zigbee npm ...
      zigbee.0
      2023-10-21 20:25:45.807	info	Try to reconnect. 1 attempts left
      zigbee.0
      2023-10-21 20:25:35.806	error	Error herdsman start
      zigbee.0
      2023-10-21 20:25:35.806	error	Failed to start Zigbee
      zigbee.0
      2023-10-21 20:25:35.805	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
      zigbee.0
      2023-10-21 20:25:35.540	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_25_34.tar.gz success
      zigbee.0
      2023-10-21 20:25:35.537	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
      zigbee.0
      2023-10-21 20:25:35.180	debug	Starting zigbee-herdsman...
      zigbee.0
      2023-10-21 20:25:34.788	info	Starting Zigbee npm ...
      zigbee.0
      2023-10-21 20:25:34.785	info	delete old Backup files. keep only last 10
      zigbee.0
      2023-10-21 20:25:34.689	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2023-10-21 20:25:34.630	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
      zigbee.0
      2023-10-21 20:25:34.336	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      zigbee.0
      2023-10-21 20:25:34.322	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2023-10-21 20:25:33.741	debug	States connected to redis: 127.0.0.1:9000
      zigbee.0
      2023-10-21 20:25:33.479	debug	States create User PubSub Client
      zigbee.0
      2023-10-21 20:25:33.478	debug	States create System PubSub Client
      zigbee.0
      2023-10-21 20:25:33.368	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      zigbee.0
      2023-10-21 20:25:33.126	debug	Objects connected to redis: 127.0.0.1:9001
      zigbee.0
      2023-10-21 20:25:33.117	debug	Objects client initialize lua scripts
      zigbee.0
      2023-10-21 20:25:32.802	debug	Objects create User PubSub Client
      zigbee.0
      2023-10-21 20:25:32.800	debug	Objects create System PubSub Client
      zigbee.0
      2023-10-21 20:25:32.798	debug	Objects client ready ... initialize now
      zigbee.0
      2023-10-21 20:25:32.639	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        Jaksa @anselra last edited by Jaksa
        @anselra
        Naja jetzt sieht es so aus als wäre das Gerät bereits in Benutzung durch was auch immer. Das war vorhin noch nicht der Fall.
        Versuch nochmal den Stick aus und wieder einzustecken bzw. die ganze Kiste einmal neu zu starten wenn ersteres nicht hilft.
        • 1Topf
          1Topf @anselra last edited by
          @anselra sagte in Zigbee Adapter startet nicht mehr:
          @jaksa
          pi@iobroker:~ $ ls -l /dev/serial/by-id/
          total 0
          lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00 -> ../../ttyACM0
          lrwxrwxrwx 1 root root 13 Oct 21 19:34 usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if03 -> ../../ttyACM1
          bringt nur den Zigbee Chip
          Wieso bringt es den denn 2mal? Der sollte dort nur 1mal auftauchen, da er ja auch nur 1mal drin steckt.
            Thomas Braun Most Active @1Topf last edited by
            @1topf sagte in Zigbee Adapter startet nicht mehr:
            Der Stick hat zwei Interfaces.
            lsof /dev/ttyACM0
            sagt? (lsof muss ggf. noch installiert werden)
              @jaksa
              Neustart erfolgt, leider immer noch nicht grün
              zigbee.0
              2023-10-21 20:47:46.819	error	Error herdsman start
              zigbee.0
              2023-10-21 20:47:46.819	error	Failed to start Zigbee
              zigbee.0
              2023-10-21 20:47:46.817	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
              zigbee.0
              2023-10-21 20:47:46.274	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
              zigbee.0
              2023-10-21 20:47:46.220	debug	Starting zigbee-herdsman...
              zigbee.0
              2023-10-21 20:47:39.042	info	Starting Zigbee npm ...
              zigbee.0
              2023-10-21 20:47:39.041	info	Try to reconnect. 1 attempts left
              zigbee.0
              2023-10-21 20:47:29.038	error	Error herdsman start
              zigbee.0
              2023-10-21 20:47:29.037	error	Failed to start Zigbee
              zigbee.0
              2023-10-21 20:47:29.035	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00'"
              zigbee.0
              2023-10-21 20:47:28.177	info	Installed Version: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83
              zigbee.0
              2023-10-21 20:47:27.582	debug	Starting zigbee-herdsman...
              zigbee.0
              2023-10-21 20:47:27.317	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2023_10_21-20_47_27.tar.gz success
              zigbee.0
              2023-10-21 20:47:27.253	info	Starting Zigbee npm ...
              zigbee.0
              2023-10-21 20:47:27.239	info	delete old Backup files. keep only last 10
              zigbee.0
              2023-10-21 20:47:27.126	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100GZZ-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
              zigbee.0
              2023-10-21 20:47:26.997	info	starting. Version 1.8.24 (non-npm: ioBroker/ioBroker.zigbee#e233808d509f6fc4ddb3176d79633f4492146a83) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.2, js-controller: 5.0.12
                anselra @Thomas Braun last edited by
                es handelt sich um das dev Board CC26X2R1
                  A Former User @anselra last edited by
                  Raspberry PI OS Lite 32
                  Moin,
                  hat jetzt nichts mit dem eigentlichen Problem zu tun, aber wieso das 32 Bit, warum nicht 64 Bit?
                  VG
                  Bernd
                    anselra @Guest last edited by
                    @dp20eic
                    meinte mich zu erinnern, dass pivccu probleme mit 64Bit hatte
                      Thomas Braun Most Active @anselra last edited by
                      Joh, un?
                        war nur als Zusatz Info gedacht bezüglich deiner Antwort an 1topf
                          @anselra
                          lsof /dev/ttyACM0
                            anselra @Thomas Braun last edited by anselra
                            ist installiert, in der Ausgabe kommt aber nichts
                              anselra @anselra last edited by
                              kurze Info,
                              Ich habe es mit Bookworm lite und:
                              pi@iobroker:~ $ apt policy udev
                              udev:
                                Installed: 252.17-1~deb12u1
                                Candidate: 252.17-1~deb12u1
                                Version table:
                               *** 252.17-1~deb12u1 500
                                      100 /var/lib/dpkg/status
                              nicht zum laufen gebracht.
                              Bin zurück auf Bullseye lite und mit der https://forum.iobroker.net/topic/65017/zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev läuft jetzt wieder alles.
                              Nicht ganz das gewünschte Ergebnis.
                              Thomas Braun Meister Mopper 3 Replies Last reply Reply Quote 0
                                Das hat aber dann NICHTS mit udev zu tun, die Bookworm-Version dort hat den Fehler nicht.
                                  mag sein ich hatte aber keinen anderen Ansatz als es so zu Lösen.
                                  Falls du einen anderen Lösungsansatz hast gerne her damit habe das System auf einer anderen platte installiert und somit noch vorhanden
                                    Ohne Meldungen aus dem System natürlich nicht.
                                      waren noch welche offen die ich nicht bereitgestellt habe?
                                        ist halt keine Aussage mit der man irgendwas anfangen könnte.
                                          könntest du konkret werden? du hast davon gesprochen das es ohne Meldungen schwer ist, was vollkommen richtig ist! Allerdings hast du auch keine angefragt die ich nicht zurück gemeldet habe.
                                          Was genau ist jetzt dein Thema?
                                            @anselra
                                            Gib mal die vollständige Ausgabe von
                                            iob diag
                                            zum Besten.
                                            3155
