    4. Umzug von Raspi auf Proxmox
      A Former User @guitardoc last edited by
      @guitardoc sagte in Umzug von Raspi auf Proxmox:
      Hab ich noch was vergessen oder woran kann das liegen?
      Moin,
      nicht nacherzählen, zeigen, was Du siehst, Logs bitte als Text in Code Tags </>
      VG
      Bernd
        guitardoc @Guest last edited by guitardoc
        @dp20eic So siehts im Moment aus:
        root@deconz:~# ls -l /dev/ttyACM0
        crw-rw-rw- 1 root root 166, 0 Oct 22 11:17 /dev/ttyACM0
        root@deconz:~# lsusb
        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
        Bus 001 Device 002: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
        Bus 001 Device 003: ID 8087:0026 Intel Corp. AX201 Bluetooth
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        total 0
        crwx------ 1 root tty  136, 0 Oct 22 11:24 console
        lrwxrwxrwx 1 root root     11 Oct 22 11:24 core -> /proc/kcore
        lrwxrwxrwx 1 root root     13 Oct 22 11:24 fd -> /proc/self/fd
        crw-rw-rw- 1 root root   1, 7 Oct 22 11:24 full
        drwxr-xr-x 2 root root      0 Oct 22 11:24 hugepages
        lrwxrwxrwx 1 root root     12 Oct 22 11:24 initctl -> /run/initctl
        lrwxrwxrwx 1 root root     28 Oct 22 11:24 log -> /run/systemd/journal/dev-log
        drwxrwxrwt 2 root root     40 Oct 22 11:24 mqueue
        crw-rw-rw- 1 root root   1, 3 Oct 22 11:24 null
        crw-rw-rw- 1 root root   5, 2 Oct 22  2023 ptmx
        drwxr-xr-x 2 root root      0 Oct 22 11:24 pts
        crw-rw-rw- 1 root root   1, 8 Oct 22 11:24 random
        drwxr-xr-x 3 root root     60 Oct 22 11:24 serial
        drwxrwxrwt 2 root root     40 Oct 22 11:24 shm
        lrwxrwxrwx 1 root root     15 Oct 22 11:24 stderr -> /proc/self/fd/2
        lrwxrwxrwx 1 root root     15 Oct 22 11:24 stdin -> /proc/self/fd/0
        lrwxrwxrwx 1 root root     15 Oct 22 11:24 stdout -> /proc/self/fd/1
        crw-rw-rw- 1 root root   5, 0 Oct 22 11:24 tty
        crw------- 1 root tty  136, 1 Oct 22  2023 tty1
        crw--w---- 1 root tty  136, 2 Oct 22 11:24 tty2
        crw-rw-rw- 1 root root 166, 0 Oct 22 11:17 ttyACM0
        ---------- 1 root root      0 Oct 22 11:24 ttyACM1
        ---------- 1 root root      0 Oct 22 11:24 ttyUSB0
        ---------- 1 root root      0 Oct 22 11:24 ttyUSB1
        crw-rw-rw- 1 root root   1, 9 Oct 22 11:24 urandom
        crw-rw-rw- 1 root root   1, 5 Oct 22 11:24 zero
        root@deconz:~#
        Der Conbee II hatte auch immer die Berechtigung verloren, von daher hab ich ihn nach Anleitung mit mknod dauerhaft angebunden.
        Edith sagt:
        Der Zwischenstecker wird aber nicht gefunden - er ist zurückgesetzt und blinkt:
        Edith nochmal - der Stick scheint auch nicht verbunden zu sein - normalerweise zeigt er auch das Bild eines USB-Sticks und nicht dieses seltsame Bild:
          A Former User @guitardoc last edited by A Former User
          Moin,
          alles was ich bis jetzt über Deconz gelesen habe, oder hier im Forum, geschrieben wurde, muss der User und die Gruppe anders lauten als bei Dir
          Du
          Laut Doku
          crw-rw-rw- 1 root dialout 166, 0 Oct 22 11:17 /dev/ttyACM0
          Ich muss mal suchen, wo ich das gesehen habe.
          VG
          Bernd
          P.S.: Der User, der das später nutzt, muss in der Gruppe -> Dialout sein!
          P.P.S.: @guitardoc sagte in Umzug von Raspi auf Proxmox:
          Nach welcher?
            @dp20eic Nach dieser hier:
            https://www.iobroker.net/#de/documentation/install/proxmox.md
            Aber da steht tatsächlich auch als Gruppe dialout. Hmm, warum steht da bei mir root? Möglicherweise, weil ich als root angemeldet war und nicht als Benutzer? Wie kann ich das jetzt wieder gerade biegen?
            Thomas Braun ? T 4 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @guitardoc last edited by Thomas Braun
              Jein. Aber das herumgehampel als root macht es nicht leichter...
              Das einzige was da leichter geht ist es, sein System zu verfummeln. Das geht nämlich als root superleicht.
                Nach dieser hier:
                Moin,
                es ist ja schon mal sehr gut, dass Du diese Installationsanleitung hergenommen hast und jetzt aber, das aber, das ist die Installationsanleitung für den ioBroker Du möchtest aber ein LX Container mit Deconz installieren, da sollte man sich an die Eigenheiten des Grundsystems richten.
                Ich schaue aber noch, ob ich die Anleitung wiederfinde.
                VG
                Bernd
                  ticaki Developer @guitardoc last edited by
                  sudo chown root:dialout /dev/ttyACM0
                  wenn mich nicht alles täuscht
                  ? Thomas Braun 2 Replies Last reply Reply Quote 1
                    A Former User @ticaki last edited by
                    @ticaki sagte in Umzug von Raspi auf Proxmox:
                    Moin,
                    ja, dann muss er das aber immer machen, sobald er den LX Container rebootet, wenn er das auf PVE Ebene macht, ist das auch nicht von Dauer.
                    VG
                    Bernd
                      Thomas Braun Most Active @ticaki last edited by
                      @ticaki
                      Die Dateien in /dev werden vom System verwaltet, ggfls. über udev-Regeln.
                      Da macht man als user nix direkt.
                      Ob/wie das bei Proxmox funktioniert weiß ich aber nicht. Müsste ich auch nachlesen. Aber das macht ja @dp20eic schon...
                        ticaki Developer @Thomas Braun last edited by
                        @dp20eic
                        Danke für die Korrektur/Info
                          guitardoc @ticaki last edited by guitardoc
                          Ich habe den Container jetzt fix noch mal erstellt. Hab ja nun schon Übung darin... 🙂
                          In der Deconz-Anleitung (https://tteck.github.io/Proxmox/) steht:
                          If the LXC is created Privileged, the script will automatically set up USB passthrough.
                          Weiter hab ich jetzt erst mal nichts installiert oder angepasst, auch aus der ioBroker Anleitung nicht. Es werden trotzdem keine Geräte gefunden.
                          Edith sagt dass er auch irgendwas anpasst:
                            GNU nano 7.2                                     103.conf
                          ## deCONZ LXC
                          #  ### https%3A//tteck.github.io/Proxmox/
                          #  <a href='https%3A//ko-fi.com/D1D7EP4GF'><img src='https%3A//img.shields.io/badge/%E2%98%95-Buy me a c>
                          arch: amd64
                          cores: 2
                          features: nesting=1
                          hostname: deconz
                          memory: 1024
                          net0: name=eth0,bridge=vmbr0,gw=192.168.188.1,hwaddr=56:3E:A8:E2:ED:F3,ip=192.168.188.122/24,type=veth
                          onboot: 1
                          ostype: debian
                          rootfs: local-lvm:vm-103-disk-0,size=4G
                          swap: 512
                          tags: proxmox-helper-scripts
                          lxc.cgroup2.devices.allow: a
                          lxc.cap.drop:
                          lxc.cgroup2.devices.allow: c 188:* rwm
                          lxc.cgroup2.devices.allow: c 189:* rwm
                          lxc.mount.entry: /dev/serial/by-id  dev/serial/by-id  none bind,optional,create=dir
                          lxc.mount.entry: /dev/ttyUSB0       dev/ttyUSB0       none bind,optional,create=file
                          lxc.mount.entry: /dev/ttyUSB1       dev/ttyUSB1       none bind,optional,create=file
                          lxc.mount.entry: /dev/ttyACM0       dev/ttyACM0       none bind,optional,create=file
                          lxc.mount.entry: /dev/ttyACM1       dev/ttyACM1       none bind,optional,create=file
                            Moin,
                            dass Du den LX Container mit diesem Helfer Skript installiert hast, wäre auch gut zu wissen, bevor ich wieder mal angefangen habe eine Anleitung zu schreiben 😞
                            VG
                            Bernd
                            P.S.: ich spiele das mal nach, um zu schauen was das Skript da so macht.
                              @dp20eic Das hatte ich doch aber geschrieben: https://forum.iobroker.net/post/1062710
                              Ich denke, dass die Rechte durch das Helperscript nicht richtig gesetzt sind:
                              mn@deconz:~$ lsusb
                              Bus 001 Device 005: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
                              mn@deconz:~$ ls -l /dev
                              total 0
                              crwx------ 1 root tty  136, 0 Oct 22 13:09 console
                              lrwxrwxrwx 1 root root     11 Oct 22 13:09 core -> /proc/kcore
                              lrwxrwxrwx 1 root root     13 Oct 22 13:09 fd -> /proc/self/fd
                              crw-rw-rw- 1 root root   1, 7 Oct 22 13:09 full
                              drwxr-xr-x 2 root root      0 Oct 22 13:09 hugepages
                              lrwxrwxrwx 1 root root     12 Oct 22 13:09 initctl -> /run/initctl
                              lrwxrwxrwx 1 root root     28 Oct 22 13:09 log -> /run/systemd/journal/dev-log
                              drwxrwxrwt 2 root root     40 Oct 22 13:09 mqueue
                              crw-rw-rw- 1 root root   1, 3 Oct 22 13:09 null
                              crw-rw-rw- 1 root root   5, 2 Oct 22 13:28 ptmx
                              drwxr-xr-x 2 root root      0 Oct 22 13:09 pts
                              crw-rw-rw- 1 root root   1, 8 Oct 22 13:09 random
                              drwxr-xr-x 3 root root     60 Oct 22 13:09 serial
                              drwxrwxrwt 2 root root     40 Oct 22 13:09 shm
                              lrwxrwxrwx 1 root root     15 Oct 22 13:09 stderr -> /proc/self/fd/2
                              lrwxrwxrwx 1 root root     15 Oct 22 13:09 stdin -> /proc/self/fd/0
                              lrwxrwxrwx 1 root root     15 Oct 22 13:09 stdout -> /proc/self/fd/1
                              crw-rw-rw- 1 root root   5, 0 Oct 22 13:09 tty
                              crw------- 1 root tty  136, 1 Oct 22 13:09 tty1
                              crw--w---- 1 root tty  136, 2 Oct 22 13:09 tty2
                              c--------- 0 root root 166, 0 Oct 22 13:09 ttyACM0
                              ---------- 1 root root      0 Oct 22 13:09 ttyACM1
                              ---------- 1 root root      0 Oct 22 13:09 ttyUSB0
                              ---------- 1 root root      0 Oct 22 13:09 ttyUSB1
                              crw-rw-rw- 1 root root   1, 9 Oct 22 13:09 urandom
                              crw-rw-rw- 1 root root   1, 5 Oct 22 13:09 zero
                              mn@deconz:~$ ls -l /dev/ttyACM0
                              c--------- 0 root root 166, 0 Oct 22 13:09 /dev/ttyACM0
                              mn@deconz:~$
                                Moin,
                                man, das war ja vor Tagen, das merke ich mir doch nicht 🙂
                                Abwarten, ich lasse das gerade mal laufen.
                                VG
                                Bernd
                                G ? 2 Replies Last reply Reply Quote 1
                                  @dp20eic OK, danke für deine Hilfe und Bemühung!
                                  Ich habe gleich noch eine Frage - ich würde zwischenzeitlich gern die ioBroker-Sicherungen in das neue ioBroker-Verzeichnis kopieren um sie von dort über den Backitup-Adapter wieder einzulesen. Ich bin aber einfach zu dämlich von meinem Mac die Dateien in das Backup-Verzeichnis des LXC-Containers zu kopieren. Vermutlich ist das wieder eine Frage der Berechtigungen...
                                    A Former User @Guest last edited by
                                    @dp20eic sagte in Umzug von Raspi auf Proxmox:
                                    Moin,
                                    zitiere mich mal selbst.
                                    So wenn ich das mittels Advance Mode installiere und mit unpreviliged durchlaufen lasse, dann
                                    root@deconz:~# ls -la /dev/ttyACM*
                                    crw-rw-rw- 1 root dialout 166, 0 Oct 22 13:38 /dev/ttyACM0
                                    crw-rw-rw- 1 root dialout 166, 1 Oct  7 12:55 /dev/ttyACM1
                                    Auf die Oberfläche komme ich auch, da ich die Hardware nicht habe, kann ich da nichts weiter testen.
                                    So und so sieht es aus, wenn ich mittel Priviliged installiere
                                    crw-rw-rw- 1 root dialout 166, 0 Oct 22 13:53 /dev/ttyACM0
                                    Bei mir wird es soweit identisch installiert, ob das dann auch funktioniert, kann ich mangels Hardware nicht testen.
                                    Dann nochmals von vorn, wie sieht es auf dem Host (PVE) aus?
                                    Schritt 1: das Device auf dem Host (PVE) identifizieren
                                    root@pve:~# lsusb
                                    Hier ist Bus u. Device relevant!
                                    root@pve:~# ls -la /dev/bus/usb/<bus>/<device>
                                    root@pve:~# ls -la /dev/serial/by-id/
                                    root@pve:~# ls -la /dev/ttyACM*
                                    VG
                                    Bernd
                                      So sieht das bei mir auf dem Host aus:
                                      root@proxmox:~# lsusb
                                      Bus 001 Device 007: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
                                      root@proxmox:~# ls -la /dev/bus/usb/001/007
                                      crw-rw-r-- 1 root root 189, 6 Oct 22 14:12 /dev/bus/usb/001/007
                                      root@proxmox:~# ls -la /dev/serial/by-id/
                                      total 0
                                      drwxr-xr-x 2 root root 60 Oct 22 14:12 .
                                      drwxr-xr-x 4 root root 80 Oct 22 14:12 ..
                                      lrwxrwxrwx 1 root root 13 Oct 22 14:12 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 -> ../../ttyACM0
                                      root@proxmox:~# ls -la /dev/ttyACM*
                                      crw-rw---- 1 root dialout 166, 0 Oct 22 14:12 /dev/ttyACM0
                                      root@proxmox:~#
                                        Moin,
                                        Du hast Dich mit Deinem User mn per sftp angemeldet?
                                        Ist der User auch in der Gruppe -> iobroker?
                                        # id mn
                                        Wie sehen die rechte des Verzeichnisses aus?
                                        # ls -la /opt/iobroker
                                        VG
                                        Bernd
                                          Vermutlich passt das nicht:
                                          mn@iobroker:~$ id mn
                                          uid=1001(mn) gid=1001(mn) groups=1001(mn),27(sudo),100(users)
                                          mn@iobroker:~$ ls -la /opt/iobroker
                                          total 296
                                          drwxrwxr-x+   6 iobroker iobroker   4096 Oct 19 11:24 .
                                          drwxr-xr-x    3 root     root       4096 Oct 19 11:22 ..
                                          -rw-rwxr--+   1 iobroker iobroker    155 Oct 19 11:22 .npmrc
                                          -rwxrwxrwx+   1 iobroker iobroker    133 Oct 19 11:24 INSTALLER_INFO.txt
                                          drwxrwxr-x+   2 iobroker iobroker   4096 Oct 22 02:40 backups
                                          lrwxrwxrwx    1 iobroker iobroker     22 Oct 19 11:24 iob -> /opt/iobroker/iobroker
                                          -rwxrwxr-x+   1 iobroker iobroker    701 Oct 19 11:24 iobroker
                                          drwxrwxr-x+   7 iobroker iobroker   4096 Oct 22 13:09 iobroker-data
                                          drwxrwxr-x+   2 iobroker iobroker   4096 Oct 22 13:09 log
                                          drwxrwxr-x+ 469 iobroker iobroker  20480 Oct 20 14:06 node_modules
                                          -rw-rwxr--+   1 iobroker iobroker 245343 Oct 20 14:06 package-lock.json
                                          -rw-rwxr--+   1 iobroker iobroker    400 Oct 20 14:06 package.json
                                          mn@iobroker:~$
                                          Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                            @guitardoc
                                            sudo usermod -a -G iobroker,dialout mn
                                            124
                                            12440
