    4. ioBroker Installer zerschießt System
      Homoran Global Moderator Administrators @antimon last edited by
      @antimon sagte in ioBroker Installer zerschießt System:
      Das Linux-Shellskript
      die von dir genannten Meldungen kommen mir total unbekannt vor 🤔
        Einstein67 @Homoran last edited by
        @homoran said in ioBroker Installer zerschießt System:
        Die kommen bei einer Installation unter Ubuntu aber tatsächlich;
        Welcome to Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-87-generic x86_64)
         * Documentation:  https://help.ubuntu.com
         * Management:     https://landscape.canonical.com
         * Support:        https://ubuntu.com/advantage
        This system has been minimized by removing packages and content that are
        not required on a system that users do not log into.
        To restore this content, you can run the 'unminimize' command.
        Last login: Sun Oct 22 07:17:43 2023 from 192.168.0.26
        ernst@ubuntu:~$ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2023-10-13
            Welcome to the ioBroker installer!
            Installer version: 2023-10-13
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        [sudo] password for ernst:
        Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
        Get:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
        Get:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease [109 kB]
        Get:4 http://at.archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
        Get:5 http://at.archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [1036 kB]
        Fetched 1374 kB in 1s (2238 kB/s)
        Reading package lists... Done
            Node.js not found. Installing...
        Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
        Hit:4 http://at.archive.ubuntu.com/ubuntu jammy-security InRelease
        Building dependency tree... Done
        ca-certificates is already the newest version (20230311ubuntu0.22.04.1).
        ca-certificates set to manually installed.
        curl is already the newest version (7.81.0-1ubuntu1.14).
        curl set to manually installed.
        gnupg is already the newest version (2.2.27-3ubuntu2.1).
        gnupg set to manually installed.
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
        debconf: delaying package configuration, since apt-utils is not installed
        debconf: unable to initialize frontend: Dialog
        debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/D                                      ebconf/FrontEnd/Dialog.pm line 78.)
        debconf: falling back to frontend: Readline
        Scanning processes...
        Scanning linux images...
        Running kernel seems to be up-to-date.
        No services need to be restarted.
        No containers need to be restarted.
        No user sessions are running outdated binaries.
        No VM guests are running outdated hypervisor (qemu) binaries on this host.
         Setting up nodejs (18.18.2-1nodesource1) ...source1_amd64.deb ...led.)
        Installed nodejs
        Node.js Installed successfully!
        Changing npm registry to https://registry.npmjs.org
         Setting up acl (2.3.1-1) ...ives/acl_2.3.1-1_amd64.deb ... installed.)
        Installed acl
         update-alternatives: warning: skip creation of /usr/share/man/man1/c++.1.gz because associated file /usr/share/man/man1                                       Processing triggers for libc-bin (2.35-0ubuntu3.4) ...
        Installed build-essential
         Processing triggers for libc-bin (2.35-0ubuntu3.4) ...untu5.1) ...5.1_amd64.deb ...
        Installed libavahi-compat-libdnssd-dev
         Setting up libudev-dev:amd64 (249.11-0ubuntu3.10) ...0_amd64.deb ....)
        Installed libudev-dev
         Setting up libpam0g-dev:amd64 (1.4.0-11ubuntu2.3) ...3_amd64.deb ....)
        Installed libpam0g-dev
         Setting up git (1:2.34.1-1ubuntu1.10) ... ...u1.10_amd64.deb .....ed.)
        Installed git
         Setting up unzip (6.0-26ubuntu3.1) ...untu3.1_amd64.deb ...installed.)
        Installed unzip
         debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/                                       Setting up libcairo2-dev:amd64 (1.16.0-5ubuntu2) .....untu2.2) ....
        Installed libcairo2-dev
        debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78.)
         Processing triggers for libc-bin (2.35-0ubuntu3.4) .........._amd64.deb .......
        Installed libpango1.0-dev
         Processing triggers for libc-bin (2.35-0ubuntu3.4) .....eb .....deb ...
        Installed libjpeg-dev
         Processing triggers for libc-bin (2.35-0ubuntu3.4) ....deb ...talled.)
        Installed libgif-dev
         Processing triggers for libgdk-pixbuf-2.0-0:amd64 (2.42.8+dfsg-1ubuntu0.2) ....eb ...
        Installed librsvg2-dev
         Setting up net-tools (1.60+git20181103.0eebece-1ubuntu5) ...ubuntu5_amd64.deb ...
        Installed net-tools
         Processing triggers for libc-bin (2.35-0ubuntu3.4) ...1_amd64.deb ......
        Installed cmake
            Creating ioBroker user and directory (2/4)
        User iobroker created
        Created /etc/sudoers.d/iobroker
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
            Finalizing installation (4/4)
        Enabling autostart...
        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
        Autostart enabled!
        Fixing directory permissions...
            ioBroker was installed successfully
            Open http://192.168.0.231:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        Das ist eine Installation auf ein ganz frisches Ubuntu. Installation funktioniert trotz dieser komischen Meldungen problemlos.
        Homoran ? Marc Berg 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Einstein67 last edited by Homoran
          @einstein67 sagte in ioBroker Installer zerschießt System:
          "Dienste werden neu gestartet"
          klingt für mich nach Windows.
          ich kann mich an so eine Meldung nicht erinnern
          • Dr. Bakterius
            Dr. Bakterius Most Active @antimon last edited by
            Das heisst für mich dass vielleicht in der Version 2023-10-13, die ich nutze, das Problem vorhanden ist, und nicht in anderen Versionen.
            Auch ich habe vor zwei Tagen in einem debian 12 LXC das Skript ohne Probleme eingesetzt. Daran liegt es vermutlich also nicht...
              A Former User @Einstein67 last edited by A Former User
              @antimon @einstein67 sagte in ioBroker Installer zerschießt System:
              Moin,
              ich bin ja nicht so der Debian/Ubuntu Experte, aber mir scheint es, dass ein Paket nicht installiert ist und deswegen diese Meldungen kommen.
              Ob dieses Paket unter Ubuntu genutzt/gebraucht wird, kann ich nicht sagen, oder ob das bei Debian out of the box installiert ist, keine Ahnung!
              Hier mal die Seite dazu https://installati.one/install-apt-utils-ubuntu-22-04/
              VG
              Bernd
                Möglich, auf einem Debian ist es jedenfalls 'ab Werk' installiert:
                echad@chet:~ $ apt policy apt-utils
                apt-utils:
                  Installed: 2.6.1
                  Candidate: 2.6.1
                  Version table:
                 *** 2.6.1 500
                        100 /var/lib/dpkg/status
                echad@chet:~ $
                • Marc Berg
                  Marc Berg Most Active @Einstein67 last edited by Marc Berg
                  @thomas-braun sagte in ioBroker Installer zerschießt System:
                  Die Pakete sind auf einem "normalen" Ubuntu ab Werk installiert, allerdings hat @antimon eine "minimized" Version gewählt.
                  Die Installation von ioBroker läuft aber auch auf der "minimized" Version normal ohne Probleme durch. Hier muss es noch eine andere Ursache geben.
                    Also ich vermute, dass es sich um eine saublöde Konstellation von Packages dreht... ich werd mir mal die neueste Ubuntu-ISO holen und damit testen. Wenns damit geht, betriffts vermutlich nur ganz wenige Leute und spielt demnach keine Rolle...
                    Den Windows-Installer würde ich jetzt mal ausschließen. Ich glaube nicht, dass der unter Linux weit kommen würde... auch wenn Windows da einige Befehle übernommen hat - aber es sind doch noch Welten. Und ich glaube, das wäre mir dann schon irgendwie aufgefallen 😉 Aber Windows kommt für mich nicht als Server-Plattform für ioBroker in Frage, deshalb hab ich da auch keine Erfahrungen.
                      antimon @Marc Berg last edited by
                      @marc-berg Also die Minimized-Version habe ich definitiv nicht installiert - der Beschreibung zufolge hört sich das nach einer IoT-Version ohne SSH oder so an. Meine Server installiere ich zwar grundsätzlich ohne GUI, aber zu minimalistisch dann auch wieder nicht 😉
                      • Marc Berg
                        Marc Berg Most Active @antimon last edited by
                        Das Ergebnis ist dann wohl ein ähnliches. 🙂
                        2237
