    4. Umzug von Raspi auf Proxmox
      guitardoc @Guest last edited by guitardoc
      @dp20eic Hier sind die Ausgaben:
      mn@deconz:~$ sudo adduser root dialout
      [sudo] password for mn:
      Adding user `root' to group `dialout' ...
      Done.
      mn@deconz:~$ id root
      uid=0(root) gid=0(root) groups=0(root),20(dialout)
      mn@deconz:~$ sudo journalctl -g deconz
      Oct 22 16:49:44 deconz systemd[1]: Starting deconz-init.service - deCONZ: ZigBee gateway -- Initialisation...
      Oct 22 16:49:44 deconz systemd[1]: Started deconz-update.service - deCONZ: ZigBee gateway -- Update Service.
      Oct 22 16:49:44 deconz systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
      Oct 22 16:49:44 deconz deCONZ-init.sh[3353]:  stopping deconz-wifi.service
      Oct 22 16:49:45 deconz systemd[1]: deconz-init.service: Deactivated successfully.
      Oct 22 16:49:45 deconz systemd[1]: Finished deconz-init.service - deCONZ: ZigBee gateway -- Initialisation.
      Oct 22 16:49:55 deconz deCONZ-update2.sh[3354]: found deCONZ port 80
      Oct 22 16:50:05 deconz deCONZ-update2.sh[3354]: use database file /root/.local/share/dresden-elektronik/deCONZ/zll.db
      Oct 22 16:58:59 deconz systemd[1]: Stopping deconz-update.service - deCONZ: ZigBee gateway -- Update Service...
      Oct 22 16:58:59 deconz systemd[1]: Stopping deconz.service - deCONZ: ZigBee gateway -- REST API...
      Oct 22 16:58:59 deconz systemd[1]: deconz-update.service: Deactivated successfully.
      Oct 22 16:58:59 deconz systemd[1]: Stopped deconz-update.service - deCONZ: ZigBee gateway -- Update Service.
      Oct 22 16:58:59 deconz systemd[1]: deconz-update.service: Consumed 1.808s CPU time.
      Oct 22 16:58:59 deconz systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
      Oct 22 16:58:59 deconz systemd[1]: deconz.service: Failed with result 'exit-code'.
      Oct 22 16:58:59 deconz systemd[1]: Stopped deconz.service - deCONZ: ZigBee gateway -- REST API.
      Oct 22 16:58:59 deconz systemd[1]: deconz.service: Consumed 8.083s CPU time.
      -- Boot fba950f005134ee2a0ae9eb4135e1815 --
      Oct 22 16:59:02 deconz systemd[1]: Starting deconz-init.service - deCONZ: ZigBee gateway -- Initialisation...
      Oct 22 16:59:02 deconz systemd[1]: Started deconz-update.service - deCONZ: ZigBee gateway -- Update Service.
      Oct 22 16:59:03 deconz systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
      Oct 22 16:59:03 deconz deCONZ-init.sh[90]:  stopping deconz-wifi.service
      Oct 22 16:59:03 deconz systemd[1]: deconz-init.service: Deactivated successfully.
      Oct 22 16:59:03 deconz systemd[1]: Finished deconz-init.service - deCONZ: ZigBee gateway -- Initialisation.
      Oct 22 16:59:13 deconz deCONZ-update2.sh[91]: found deCONZ port 80
      Oct 22 16:59:23 deconz deCONZ-update2.sh[91]: use database file /root/.local/share/dresden-elektronik/deCONZ/zll.db
      Oct 22 17:11:20 deconz sudo[2997]:       mn : TTY=pts/3 ; PWD=/home/mn ; USER=root ; COMMAND=/usr/bin/journalctl -u deconz
      Oct 22 17:17:59 deconz systemd[1]: Stopping deconz-update.service - deCONZ: ZigBee gateway -- Update Service...
      Oct 22 17:17:59 deconz systemd[1]: Stopping deconz.service - deCONZ: ZigBee gateway -- REST API...
      Oct 22 17:17:59 deconz systemd[1]: deconz-update.service: Deactivated successfully.
      Oct 22 17:17:59 deconz systemd[1]: Stopped deconz-update.service - deCONZ: ZigBee gateway -- Update Service.
      Oct 22 17:17:59 deconz systemd[1]: deconz-update.service: Consumed 3.858s CPU time.
      Oct 22 17:17:59 deconz systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
      Oct 22 17:17:59 deconz systemd[1]: deconz.service: Failed with result 'exit-code'.
      Oct 22 17:17:59 deconz systemd[1]: Stopped deconz.service - deCONZ: ZigBee gateway -- REST API.
      Oct 22 17:17:59 deconz systemd[1]: deconz.service: Consumed 16.070s CPU time.
      -- Boot 8ee980f3991845108d7b6504542b4a9b --
      Oct 22 17:18:03 deconz systemd[1]: Starting deconz-init.service - deCONZ: ZigBee gateway -- Initialisation...
      Oct 22 17:18:03 deconz systemd[1]: Started deconz-update.service - deCONZ: ZigBee gateway -- Update Service.
      Oct 22 17:18:03 deconz systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
      Oct 22 17:18:03 deconz deCONZ-init.sh[90]:  stopping deconz-wifi.service
      Oct 22 17:18:03 deconz systemd[1]: deconz-init.service: Deactivated successfully.
      Oct 22 17:18:03 deconz systemd[1]: Finished deconz-init.service - deCONZ: ZigBee gateway -- Initialisation.
      Oct 22 17:18:13 deconz deCONZ-update2.sh[91]: found deCONZ port 80
      Oct 22 17:18:23 deconz deCONZ-update2.sh[91]: use database file /root/.local/share/dresden-elektronik/deCONZ/zll.db
      Oct 22 18:13:57 deconz sudo[13110]:       mn : TTY=pts/3 ; PWD=/home/mn ; USER=root ; COMMAND=/usr/bin/journalctl -g deconz
      mn@deconz:~$ sudo journalctl -g error
      Oct 22 18:14:41 deconz sudo[13263]:       mn : TTY=pts/3 ; PWD=/home/mn ; USER=root ; COMMAND=/usr/bin/journalctl -g error
      mn@deconz:~$ sudo systemctl status deconz.service
      * deconz.service - deCONZ: ZigBee gateway -- REST API
           Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabled)
           Active: active (running) since Sun 2023-10-22 17:18:03 CEST; 58min ago
         Main PID: 92 (deCONZ)
            Tasks: 4 (limit: 76898)
           Memory: 68.5M
              CPU: 48.493s
           CGroup: /system.slice/deconz.service
                   `-92 /usr/bin/deCONZ -platform minimal --http-port=80
      Oct 22 17:18:03 deconz deCONZ[92]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
      Oct 22 17:18:03 deconz deCONZ[92]: libpng warning: iCCP: known incorrect sRGB profile
      Oct 22 17:18:03 deconz deCONZ[92]: This plugin does not support propagateSizeHints()
      mn@deconz:~$
      Hab den Stick jetzt mal aus- und wieder eingesteckt - er verbindet sich nicht. Dafür hat er die Rechte verloren. Die sind erst nach Reboot wieder richtig.
        A Former User @guitardoc last edited by A Former User
        @guitardoc sagte in Umzug von Raspi auf Proxmox:
        Moin,
        wenn ich Dich richtig verstehe, dann ist das Verhalten im LX Container korrekt, dass Du den LX Container, entweder neu starten musst, oder udev muss neu gestartet werden.
        Edit
        Mit dem Befehl, den ich weiter oben schon einmal gezeigt habe
        # udevadm control --reload-rules && udevadm trigger
        Oder musst Du Proxmox neu booten?
        VG
        Bernd
          @dp20eic Nein, nicht Proxmox. Ich gebe als User mn sudo reboot ein, dann stimmen die Rechte wieder.
          Wenn es gar nicht klappt, dann muss ich eben den Raspi für den Stick nehmen. Das ist zwar schon irgendwie albern, aber was soll ich machen... Ärgern tut es mich aber schon.
          Noch eine andere Frage - was muss ich im ioBroker noch anpassen? Dort ist zwar alles grün, aber z.B. meine Blocklys werden nicht ausgeführt, obwohl diese auch grün sind. Vermutlich muss irgendwo noch was angepasst werden?
          Edit:
          Vermutlich liegt das Problem an der Simple-Api. Dort lassen sich die Einstellungen nicht mehr öffnen:
          [JsonConfig] Cannot read file: Not exists
          Edit 2:
          Und Web sieht auch so seltsam aus:
          ? 2 Replies Last reply Reply Quote 0
            Moin,
            wenn es nur der LX Container ist, dann kannst Du das auch wie gezeigt machen, einfach nur den udev neu starten.
            # sudo udevadm control --reload-rules && udevadm trigger
            Da muss ich erstmal nachdenken, Du hast, das alles aus einem Backup, wieder hergestellt?
            Ich nutze BackitUp nicht, werden da nicht für die einzelnen Dienste, eigene Backupfiles angelegt, z. B. backup_iobroker, backup_javascript, backup_influxdb, usw.
            Hast Du denn auch alle Backups wieder eingespielt?
            Oder hast Du vielleicht auf dem RasPI im Backitup Adapter vergessen, die Skripte mitzusichern?
            VG
            Bernd
              Moin,
              und wo ist
              VG
              Bernd
                @dp20eic Nein, ich hatte alles richtig gesichert. Auch alles wieder hergestellt:
                • iobroker
                • Javascript
                • Yahka
                Die sind ja auch alle da - nur sie laufen nicht. Auch der Shuttercontrol funktionierte nicht, von daher denke ich, dass es ein anderes Problem ist - web und simple-api sehen nicht so aus wie sie aussehen sollten und bei simple api komme ich nicht mehr auf die Einstellungen (siehe oben).
                Javascript ist da:
                Web und simple-api neu installieren? Oder zerschieße ich da alles?
                G ? 2 Replies Last reply Reply Quote 0
                  guitardoc @guitardoc last edited by guitardoc
                  Hab mit
                  ioB upload all
                  mal alles überladen. Bei simple-api hat es geholfen, das Problem ist aber der Adapter web:
                  upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                  upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                  upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                  upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                  upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/index_m.html index_m.html text/html
                  upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/words.js words.js application/javascript
                  upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/wu.png wu.png image/png
                  upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                  /usr/bin/iob: line 12:  1093 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                  mn@iobroker:~$ iob start
                    Zeig doch mal, den Baum vom javascript
                    Sind die denn gestartet, kommt denn irgendwas im Log, von/für
                    VG
                    Bernd
                      @dp20eic Das funktioniert alles. Der Adapter Web ist das Problem - der lädt nicht richtig. Ein ähnliches Problem hatte wohl schon mal jemand, dort lag es aber an einem falschen Port. Scheint aber hier nicht der Fall zu sein:
                      mn@iobroker:~$ sudo netstat -ltp
                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                      tcp        0      0 localhost:39347         0.0.0.0:*               LISTEN      1355/io.yahka.0
                      tcp        0      0 localhost:smtp          0.0.0.0:*               LISTEN      296/master
                      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      875/go2rtc
                      tcp        0      0 0.0.0.0:8182            0.0.0.0:*               LISTEN      1340/io.wiffi-wz.0
                      tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      132/iobroker.js-con
                      tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      132/iobroker.js-con
                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      551/io.mqtt.0
                      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      551/io.mqtt.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      607/io.shelly.1
                      tcp        0      0 0.0.0.0:sunrpc          0.0.0.0:*               LISTEN      1/init
                      tcp6       0      0 localhost:smtp          [::]:*                  LISTEN      296/master
                      tcp6       0      0 [::]:8554               [::]:*                  LISTEN      875/go2rtc
                      tcp6       0      0 [::]:8087               [::]:*                  LISTEN      1310/io.simple-api.
                      tcp6       0      0 [::]:8082               [::]:*                  LISTEN      738/io.web.0
                      tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN      446/io.admin.0
                      tcp6       0      0 [::]:1984               [::]:*                  LISTEN      875/go2rtc
                      tcp6       0      0 [::]:sunrpc             [::]:*                  LISTEN      1/init
                      tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      1/init
                      tcp6       0      0 [::]:35409              [::]:*                  LISTEN      1355/io.yahka.0
                      mn@iobroker:~$
                        Der Adapter Web
                        Moin,
                        was, wie hast Du das Netzwerk des LX Containers eingestellt?
                        Was sagt denn, die Diagnose dazu
                        # iob diag
                        VG
                        Bernd
                          @dp20eic Das war ja das Witzige. Ich habe als erstes den ioB diag drüberlaufen lassen, und der sagte, dass alles OK ist. Dann der guten Ordnung halber noch den ioB fix. Alles kein Problem. ioB upload all hat dann simple api gefixt, aber web nicht. Ich hab web deinstalliert und wieder installiert, dann alles neu gestartet - und Voila!! jetzt läuft es. Also zumindest die ersten Tests mit den Javascript Routinen. Puh... 🙂
                          Jetzt kann ich mich wieder dem leidigen Thema Conbee II widmen... 🙂
                            Moin,
                            ich bin dann für heute raus, Familienabend, Frauchen schaut schon etwas schräg zu mir 🙂
                            Noch viel Erfolg.
                            VG
                            Bernd
                              @dp20eic Danke danke, ganz vielen lieben Dank für die Hilfe! Und einen schönen Abend noch - ich werde berichten wenn ich etwas herausgefunden habe.
                                Ich habe es tatsächlich aufgegeben, mit dem Deconz zu arbeiten. Bin auf den Zigbee Adapter gegangen und der funktioniert einwandfrei.
                                Danke noch mal für die Hilfe!
                                  Moin,
                                  Bitte, auch wenn es nicht geklappt hat, war das, sich beschäftigen, mit der Materie, dann doch keine vergebene Liebesmüh 🙂
                                  Dann betreibst Du den Conbee II jetzt am ioBroker LX Container?
                                  Dann mach mal einen Schritt nach dem anderen, und noch viel Spaß beim Umzug, falls noch was Unerwartetes kommt, einfach melden.
                                  VG
                                  Bernd
                                    @dp20eic Ja, ich habe viel gelernt bei der Aktion. Vielen Dank noch mal bei der Hilfe!
                                    Der Conbee II läuft jetzt am ioBroker LXC, richtig. Das funktioniert ohne Probleme.
                                      Ich habe gleich noch eine Frage. Hab den iob diag mal drüber laufen lassen, weil ich Fehler im Protokoll habe. Hier die Ausgabe:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                       Static hostname: iobroker
                                             Icon name: computer-container
                                               Chassis: container ☐
                                        Virtualization: lxc
                                                Kernel: Linux 6.2.16-15-pve
                                          Architecture: x86-64
                                      model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
                                      Docker          : false
                                      Virtualization  : lxc
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Systemuptime and Load:
                                       13:49:55 up 1 day,  4:17,  3 users,  load average: 0.98, 0.47, 0.28
                                      CPU threads: 2
                                      *** Time and Time Zones ***
                                                     Local time: Tue 2023-10-24 13:49:55 CEST
                                                 Universal time: Tue 2023-10-24 11:49:55 UTC
                                                       RTC time: n/a
                                                    NTP service: inactive
                                                RTC in local TZ: no
                                      *** User and Groups ***
                                      mn
                                      /home/mn
                                      mn adm dialout sudo users iobroker
                                      *** X-Server-Setup ***
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      Boot Target: 	graphical.target
                                      *** MEMORY ***
                                      Mem:            4.3G        2.5G        1.4G        131K        398M        1.8G
                                      Swap:           536M          0B        536M
                                      Total:          4.8G        2.5G        2.0G
                                               4096 M total memory
                                               2347 M used memory
                                                170 M active memory
                                               2438 M inactive memory
                                               1367 M free memory
                                                  0 M buffer memory
                                                380 M swap cache
                                                512 M total swap
                                                  0 M used swap
                                                512 M free swap
                                      *** FAILED SERVICES ***
                                        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                      LOAD   = Reflects whether the unit definition was properly loaded.
                                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                      SUB    = The low-level unit activation state, values depend on unit type.
                                      2 loaded units listed.
                                      *** FILESYSTEM ***
                                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                                      /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  2.9G  4.6G  39% /
                                      none                             tmpfs     492K  4.0K  488K   1% /dev
                                      /dev/mapper/pve-root             ext4       94G  4.3G   85G   5% /dev/ttyACM0
                                      udev                             devtmpfs   32G     0   32G   0% /dev/tty
                                      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
                                      tmpfs                            tmpfs      13G  120K   13G   1% /run
                                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                      tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
                                      dmesg: read kernel buffer failed: Operation not permitted
                                      TARGET         SOURCE                                                 FSTYPE OPTIONS
                                      /              /dev/mapper/pve-vm--101--disk--0                       ext4   rw,relatime,stripe=16
                                      `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                                      /var:
                                      446M	/var/
                                      251M	/var/cache
                                      247M	/var/cache/apt
                                      172M	/var/cache/apt/archives
                                      145M	/var/lib
                                      Archived and active journals take up 48.0M in the file system.
                                      /opt/iobroker/backups:
                                      30M	/opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      291M	/opt/iobroker/iobroker-data/
                                      157M	/opt/iobroker/iobroker-data/files
                                      96M	/opt/iobroker/iobroker-data/backup-objects
                                      52M	/opt/iobroker/iobroker-data/files/javascript.admin
                                      34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                                      35M	/opt/iobroker/iobroker-data/objects.jsonl
                                      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                      8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
                                      7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                                      6.6M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs 	v18.18.2
                                      /usr/bin/node 		v18.18.2
                                      /usr/bin/npm 		9.8.1
                                      /usr/bin/npx 		9.8.1
                                      /usr/bin/corepack 	0.19.0
                                      nodejs:
                                        Installed: 18.18.2-1nodesource1
                                        Candidate: 18.18.2-1nodesource1
                                        Version table:
                                       *** 18.18.2-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                              100 /var/lib/dpkg/status
                                           18.18.1-1nodesource1 500
                                           18.18.0-1nodesource1 500
                                           18.17.1-1nodesource1 500
                                           18.17.0-1nodesource1 500
                                           18.16.1-1nodesource1 500
                                           18.16.0-1nodesource1 500
                                           18.15.0-1nodesource1 500
                                           18.14.2-1nodesource1 500
                                           18.14.1-1nodesource1 500
                                           18.14.0-1nodesource1 500
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                           18.13.0-1nodesource1 500
                                           18.12.0-1nodesource1 500
                                           18.11.0-1nodesource1 500
                                           18.10.0-1nodesource1 500
                                           18.9.1-1nodesource1 500
                                           18.9.0-1nodesource1 500
                                           18.8.0-1nodesource1 500
                                           18.7.0-1nodesource1 500
                                           18.6.0-1nodesource1 500
                                           18.5.0-1nodesource1 500
                                           18.4.0-1nodesource1 500
                                           18.3.0-1nodesource1 500
                                           18.2.0-1nodesource1 500
                                           18.1.0-1nodesource1 500
                                           18.0.0-1nodesource1 500
                                      No problems detected
                                      Errors in npm tree:
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller: 	5.0.12
                                      admin: 		6.10.1
                                      javascript: 	7.1.4
                                      Adapters from github: 	1
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                      + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
                                        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                      + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                                      + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
                                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                        system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                      + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                                      + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                      + instance is alive
                                      ioBroker-Repositories
                                      stable        : https://download.iobroker.net/sources-dist.json
                                      beta          : https://download.iobroker.net/sources-dist-latest.json
                                      live-stable   : http://iobroker.live/repo/sources-dist.json
                                      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "admin"        : 6.10.1   , installed 6.10.1
                                      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
                                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                      Adapter    "eusec"        : 1.1.2    , installed 1.1.2
                                      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                      Adapter    "followthesun" : 0.4.2    , installed 0.4.2
                                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                      Controller "js-controller": 5.0.12   , installed 5.0.12
                                      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
                                      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                                      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                      Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                      Adapter    "vw-connect"   : 0.0.67   , installed 0.1.3
                                      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                      Adapter    "web"          : 6.1.2    , installed 6.1.2
                                      Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                                      Objects and States
                                      Objects: 	10537
                                      States: 	8720
                                      Hit:2 http://security.debian.org bookworm-security InRelease
                                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       28955      132/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       19417      132/iobroker.js-con
                                      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       37990      391/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       37989      391/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34068      421/io.shelly.1
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19123      1/init
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19308      296/master
                                      tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       42087      602/go2rtc
                                      tcp        0      0 127.0.0.1:34653         0.0.0.0:*               LISTEN      1000       46256      1039/io.yahka.0
                                      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       42080      602/go2rtc
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          19125      1/init
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          26426      1/init
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       45417      1009/io.simple-api.
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       38452      512/io.web.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       32794      319/io.admin.0
                                      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       42082      602/go2rtc
                                      tcp6       0      0 :::45545                :::*                    LISTEN      1000       46219      1039/io.yahka.0
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19309      296/master
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19124      1/init
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       46220      1039/io.yahka.0
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       38023      406/io.shelly.0
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       34086      436/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       34087      436/io.tuya.0
                                      udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       42083      602/go2rtc
                                      udp        0      0 0.0.0.0:46126           0.0.0.0:*                           1000       38911      557/io.eusec.0
                                      udp        0      0 0.0.0.0:51323           0.0.0.0:*                           1000       7820103    406/io.shelly.0
                                      udp        0      0 0.0.0.0:57687           0.0.0.0:*                           1000       38906      557/io.eusec.0
                                      udp6       0      0 :::111                  :::*                                0          19126      1/init
                                      udp6       0      0 :::8443                 :::*                                1000       42088      602/go2rtc
                                      2023-10-24 02:43:23.983  - warn: zigbee.0 (466) Device '0x54ef441000017f65' announced itself
                                      2023-10-24 03:03:23.397  - warn: eusec.0 (557) Heartbeat check failed for station T8010P2320100018. Connection seems lost. Try to reconnect...
                                      2023-10-24 03:03:23.400  - info: eusec.0 (557) Disconnected from station T8010P2320100018
                                      2023-10-24 03:03:34.281  - info: eusec.0 (557) Connected to station T8010P2320100018 on host 52.58.242.75 and port 13526
                                      2023-10-24 04:10:17.254  - warn: weatherunderground.0 (3395) get state error: Connection is closed.
                                      2023-10-24 05:04:00.015  - info: telegram.0 (361) Scheduled restart.
                                      2023-10-24 05:04:00.523  - info: telegram.0 (361) terminating
                                      2023-10-24 05:04:00.524  - info: telegram.0 (361) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      2023-10-24 05:04:02.849  - info: telegram.0 (3499) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
                                      2023-10-24 06:02:14.604  - error: modbus.0 (376) Socket Error
                                      2023-10-24 06:02:14.606  - error: modbus.0 (376) Client in error state.
                                      2023-10-24 06:02:14.606  - warn: modbus.0 (376) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                                      2023-10-24 06:02:15.607  - info: modbus.0 (376) Disconnected from slave 192.168.188.90
                                      2023-10-24 06:03:15.608  - info: modbus.0 (376) Connected to slave 192.168.188.90
                                      2023-10-24 07:31:22.086  - info: eusec.0 (557) Push notification connection closed
                                      2023-10-24 07:31:28.100  - info: eusec.0 (557) Push notification connection successfully established
                                      2023-10-24 07:49:15.504  - info: javascript.0 (346) script.js.common.Kameras.Status_Eufy_Homebase_anwesend_abwesend: Homebase Nordost und Homebase Südwest wurden auf Guard Mode Anwesend (1) gesetzt.
                                      2023-10-24 09:32:08.877  - error: admin.0 (319) Cannot update news: TypeError: newNews.forEach is not a function
                                      2023-10-24 09:33:20.215  - info: info.0 (610) Reading/updating systemdata.
                                      2023-10-24 09:33:20.351  - info: info.0 (610) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                      2023-10-24 09:33:20.678  - info: info.0 (610) cpu Temp res = {"main":54,"cores":[56,54,52,52],"max":56,"socket":[],"chipset":null}
                                      2023-10-24 09:50:36.953  - error: weatherunderground.0 (4390) WUnderground reported an error: --/{"message":"timeout of 15000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 15000ms exceeded\n    at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/axios/lib/adapters/http.js:630:16)\n    at RedirectableRequest.emit (node:events:517:28)\n    at RedirectableRequest.emit (node:domain:489:12)\n    at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:179:12)\n    at listOnTimeout (node:internal/timers:569:17)\n    at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":15000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8","User-Agent":"Mozilla/5.0 (Windows) Gecko/20100101 Firefox/68.0","Accept-Language":"de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=e1f10a1e78da46f5b10a1e78da96f525&icaoCode=EDDP&units=m&language=de&format=json"},"code":"ECONNABORTED","status":null}
                                      2023-10-24 11:30:45.132  - warn: weatherunderground.0 (4552) get state error: Connection is closed.
                                      2023-10-24 12:20:08.446  - warn: weatherunderground.0 (4632) get state error: Connection is closed.
                                      2023-10-24 13:10:07.814  - warn: weatherunderground.0 (4755) get state error: Connection is closed.
                                      			v.2023-10-10
                                        Virtualization: lxc
                                      Installation: 		lxc
                                      Kernel: 		x86_64
                                      Userland: 		amd64
                                      Timezone: 		Europe/Berlin (CEST, +0200)
                                      User-ID: 		1001
                                      X-Server: 		false
                                      Pending OS-Updates: 	0
                                      Pending iob updates: 	0
                                      Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
                                      			/usr/bin/npm 		9.8.1
                                      			/usr/bin/npx 		9.8.1
                                      Recommended versions are nodejs 18.18.2 and npm 9.8.1
                                      MEMORY:
                                      Mem:            4.3G        2.5G        1.3G        131K        555M        1.8G
                                      Swap:           536M          0B        536M
                                      Total:          4.8G        2.5G        1.8G
                                      Active iob-Instances: 	23
                                      ioBroker Core: 		js-controller 		5.0.12
                                      			admin 			6.10.1
                                      ioBroker Status: 	iobroker is running on this host.
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects: 		10537
                                      States: 		8720
                                      Size of iob-Database:
                                      42M	/opt/iobroker/iobroker-data/objects.jsonl
                                      5.4M	/opt/iobroker/iobroker-data/states.jsonl
                                      Kann da jemand etwas damit anfangen?
                                      Insbesondere seltsam ist, dass ich Info im GUI nicht aufrufen kann (steht auch was im Protokoll).
                                      Auch zu ext4 steht da weiter oben ein Fehler und zu USB-Sticks. Oder ist das so OK?
                                        Moin,
                                        welche?
                                        Las uns das nicht suchen, sondern zeige das direkt.
                                        Edit
                                        *** FILESYSTEM ***
                                        /dev/mapper/pve-root             ext4       94G  4.3G   85G   5% /dev/ttyACM0       <- das ist Unsinn, was hast Du da gemacht????
                                        Daraus resultiert auch, dass der USB-Stick ja kein Speicher-Stick ist, somit ist da auch kein ext4 Filesystem drauf.
                                        Zeig mal, die Konfiguration
                                        # cat /etc/pve/lxc/<lxc_id>.conf
                                        Und auch
                                        VG
                                        Bernd
                                          @dp20eic Die Fehler aus dem Protokoll sind oben in meinem letzten Post mit drin. Für Weatherunderground scheint der Adapter wohl einen Fehler zu haben, da hatte ich letztens schon öfter solche Fehlermeldungen drin.
                                          Warum der Modbus da einen Fehler liefert weiß ich nicht - da hatte ich aber auch immer mal was drin.
                                          Mich bewegt vor allem der error. admin.0:
                                          admin.0 2023-10-24 09:32:08.877	error	Cannot update news: TypeError: newNews.forEach is not a function
                                          Ich habe einmal den Conbee II Stick dran und dann noch eine USB-SSD-Festplatte (256 GB), die verwende ich als Backup-Laufwerk für die Proxmox Container. Die habe ich ext4 formatiert.
                                          root@proxmox:~# cat /etc/pve/lxc/101.conf
                                          ## ioBroker LXC
                                          #  ### https%3A//tteck.github.io/Proxmox/
                                          #  <a href='https%3A//ko-fi.com/D1D7EP4GF'><img src='https%3A//img.shields.io/badge/%E2%98%95-Buy me a coffee-red' /></a>
                                          arch: amd64
                                          cores: 2
                                          features: keyctl=1,nesting=1
                                          hostname: iobroker
                                          memory: 4096
                                          net0: name=eth0,bridge=vmbr0,gw=192.168.188.1,hwaddr=62:41:1B:12:5C:1C,ip=192.168.188.124/24,type=veth
                                          onboot: 1
                                          ostype: debian
                                          rootfs: local-lvm:vm-101-disk-0,size=8G
                                          swap: 512
                                          tags: cli-user-mn;homeautomation;proxmox-helper-scripts
                                          unprivileged: 1
                                          lxc.cgroup2.devices.allow: c 189:* rwm
                                          lxc.mount.entry: usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 none bind,optional,create=file
                                          lxc.cgroup2.devices.allow: c 166:* rwm
                                          lxc.mount.entry: /var/lib/lxc/101/devices/ttyACM0 dev/ttyACM0 none bind,optional,create=file
                                          root@proxmox:~#
                                            Moin,
                                            ja, nur vielleicht sehe ich andere Dinge als Du, somit reden wir aneinander vorbei, ich bin dann mal in den Abschnitt mit den Logs gegangen
                                            Zu aller erst, das sind Warnungen, keine Fehler -> Warn ≠ Error!
                                            Dann, so weit mir bekannt, tauchen diese Warnungen, bei allen Zeitgesteuerten Adaptern auf und sagen nur, dass der Abruf der Daten beim Dienst abgeschlossen ist und die Verbindung geschlossen wurde. Du kannst schauen, ob sich die DP in den Zeitstempeln ändern.
                                            Es gibt ein issue -> https://github.com/iobroker-community-adapters/ioBroker.weatherunderground/issues/197
                                            Du erkennst dies zeitgesteuerten Dienste am
                                            Zum modebus.0 kann ich nichts sagen, setze diesen Adapter nicht ein, weiß auch nicht was da der Client/Slave und der Server ist, was verbirgt sich hinter der IP?
                                            Hier aus dem Forum
                                            • https://forum.iobroker.net/topic/58112/modbus-adapter-ständig-error-messages
                                              Aus dem WWW
                                            • https://noegel.io/posts/2022-10-09-sungrow/
                                              Da ich Deine Sachen nicht kenne, suche ich da mal nicht weiter.
                                            Nun zum Fehler des admin.0
                                            Da gibt es, hier im Forum schon ein Thread dazu und auch schon ein issue https://github.com/ioBroker/ioBroker.admin/issues/2163
                                            So, lange Rede, kurzer Sinn, alles erklärbar.
                                            Außer modbuss, dass nur Du lösen kannst, da Du das Wissen über Deine Komponenten und Parametrierung hast.
                                            VG
                                            Bernd
                                            BenAhrdt created this issue in iobroker-community-adapters/ioBroker.weatherunderground
                                            open Connection closed meldung seit js-controller 5.0.12 #197
                                            HGlab01 created this issue in ioBroker/ioBroker.admin
                                            closed Cannot update news: TypeError: newNews.forEach is not a function #2163
                                            124
                                            12436
