    4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
      Thomas Braun Most Active @PatrickFro last edited by
      @patrickfro
      sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
        PatrickFro @Thomas Braun last edited by
        patrick@VM-IoBroker:~$ sudo -u iobroker speedtest -f json --accept-license --accept-gdpr
        {"type":"result","timestamp":"2023-10-22T17:35:33Z","ping":{"jitter":0.318,"latency":1.630,"low":1.274,"high":1.954},"download":{"bandwidth":10028954,"bytes":55169840,"elapsed":5603,"latency":{"iqm":1.419,"low":0.692,"high":207.800,"jitter":18.722}},"upload":{"bandwidth":4651107,"bytes":16764520,"elapsed":3608,"latency":{"iqm":119.987,"low":0.858,"high":317.042,"jitter":40.296}},"packetLoss":0,"isp":"wilhelm.tel","interface":{"internalIp":"...7d8f:6950","name":"ens18","macAddr":"...AE","isVpn":false,"externalIp":"...4950"},"server":{"id":4087,"host":"speedtest.wtnet.de","port":8080,"name":"wilhelm.tel","location":"Norderstedt","country":"Germany","ip":"...3:2"},"result":{"id":"fea91c99-07ee-4ff1-ae4d-8cd14483123","url":"https://www.speedtest.net/result/c/fea91c99-07ee-4ff1-ae4d-8cd144333823","persisted":true}}
          @patrickfro
          Hast du das Skript vollständig und richtig kopiert?
            Eigentlich schon
            patrick@VM-IoBroker:~$ sudo apt-get install curl
            [sudo] Passwort für patrick:
            Paketlisten werden gelesen… Fertig
            Abhängigkeitsbaum wird aufgebaut… Fertig
            Statusinformationen werden eingelesen… Fertig
            curl ist schon die neueste Version (7.88.1-10+deb12u4).
            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            patrick@VM-IoBroker:~$ curl -s https://packagecloud.io/install/repositories/ookl        a/speedtest-cli/script.deb.sh | sudo bash
            Detected operating system as debian/bookworm.
            Checking for curl...
            Detected curl...
            Checking for gpg...
            Detected gpg...
            Detected apt version as 2.6.1
            Running apt-get update... done.
            Installing debian-archive-keyring which is needed for installing
            apt-transport-https on many Debian systems.
            Installing apt-transport-https... done.
            Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.
            Importing packagecloud gpg key... Packagecloud gpg key imported to /etc/apt/keyr        ings/ookla_speedtest-cli-archive-keyring.gpg
            done.
            The repository is setup! You can now install packages.
            patrick@VM-IoBroker:~$ sudo apt-get install speedtest
            Die folgenden NEUEN Pakete werden installiert:
              speedtest
            0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            Es müssen noch 0 B von 1.106 kB an Archiven heruntergeladen werden.
            Nach dieser Operation werden 2.628 kB Plattenplatz zusätzlich benutzt.
            Vormals nicht ausgewähltes Paket speedtest wird gewählt.
            (Lese Datenbank ... 167253 Dateien und Verzeichnisse sind derzeit installiert.)
            Vorbereitung zum Entpacken von .../speedtest_1.2.0.84-1.ea6b6773cf_amd64.deb ...
            Entpacken von speedtest (1.2.0.84-1.ea6b6773cf) ...
            speedtest (1.2.0.84-1.ea6b6773cf) wird eingerichtet ...
            Trigger für man-db (2.11.2-2) werden verarbeitet ...
            Da ich kein Raspberry hab, konnte ich nicht das komplette Script von Kreyenborg nutzen, sondern musste auf https://www.speedtest.net/de/apps/cli ausweichen.
              @patrickfro sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
              Heh? Versteh ich nicht.
              Hast du das Skript kopiert, im javaskript-Adapter als Java-Skript angelegt und die erforderlichen Änderungen getätigt?
                genau, hab es gerade nochmal deinstalliert und so wie du im ersten Post installiert (ist ja selber Weg). Selbes Ergebnis:
                javascript.1 (10238) script.js.common.VIS_2024.Scripte_andere_Seiten.Speedtest: Speedtest konnte nicht ausgeführt werden! Error: Command failed: /usr/bin/speedtest -f json --accept-license --accept-gdpr /bin/sh: 1: /usr/bin/speedtest: not found
                  PatrickFro @PatrickFro last edited by
                  @patrickfro Ähm... Ich glaube ich habs. Ich habe Master und Slave und wohl Javascript vom Slave genommen...
                  1000 Mal sorry, teste es mal
                    Eine Frage noch:
                    Das obere Bild ist das Ergebnis vom Speedtest über das Script, der untere ist direkt auf der Webseite durchgeführt. Uploadgeschwindigkeit passt ja halbwegs, aber Download so gar nicht. Ist auch bei weiteren Tests so unterschiedlich.
                    Linux ist auf Proxmox installiert und hängt an einem LAN-Kabel direkt an der Fritzbox. Wo ist hier die Bremse?
                      @patrickfro
                      Du musst dir einen in deiner Region gut verfügbaren Server suchen und den immer anklingeln. Musste was probieren.
                        @thomas-braun Hab ich ja, beide Server in den Bildern sind in Norderstedt
                          localhorst @Thomas Braun last edited by
                          @thomas-braun said in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                          Tip am Rande:
                          Per
                          https://c.speedtest.net/speedtest-servers-static.php
                          sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
                          var fav_server = 12345;
                          Ich habe eine deutlich umfangreichere Liste für die Server IDs gefunden, die ich euch nicht vorenthalten möchte:
                          https://williamyaps.github.io/wlmjavascript/servercli.html
                          • SKB
                            SKB Developer Most Active @localhorst last edited by
                            @localhorst hier ist immer die Frage, wie aktuell eine solche Liste ist bzw. gehalten wird.
                            Die Liste, die von Speedtest selbst kommt, zeigt immer die Server in der Nähe an.
                            Eine Messung durch einen Server in Albanien kann interessant sein, wird aber wohl nicht das gewünschte Ergebnis bringen 😉
                              localhorst @SKB last edited by
                              @skb
                              Via https://c.speedtest.net/speedtest-servers-static.php bekomme ich nichts Brauchbares.
                              Über die verlinkte Liste konnte ich gezielt meinen Wunschserver (Wilhelm.tel) sofort finden.
                              Wie auch immer, muss ja niemand verwenden.
                                Tenjo78 last edited by
                                Hallo, bin absoluter JVScript Laie. Ich hätte den Speedtest gern bei mir eingebunden um mit den vielen Daten dann auch in Grafana übern zu können. Nur leider hab ich diese Fehlermeldung.
                                // Erstelle die benötigten Datenpunkte
                                function datenpunkte_erstellen() {
                                    for (var i = 0; i < objekt.length; i++) {
                                        createState(datenpunkt + objekt[i], "", ueberschreiben, {
                                            desc: beschreibung[i],
                                            type: typen[i],
                                            role: rolle[i],
                                            unit: einheiten[i]
                                15:30:05.263	info	javascript.0 (337674) script.js.common.Speedtest: Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                                15:30:05.264	info	javascript.0 (337674) script.js.common.Speedtest: exec is not available. Please enable "Enable Exec" option in instance settings
                                15:30:05.266	error	javascript.0 (337674) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! exec is not available. Please enable "Enable Exec" option in instance settings
                                15:30:05.273	info	javascript.0 (337674) script.js.common.Speedtest: Speedtest gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                                15:30:05.274	info	javascript.0 (337674) script.js.common.Speedtest: exec is not available. Please enable "Enable Exec" option in instance settings
                                15:30:05.278	error	javascript.0 (337674) script.js.common.Speedtest: Speedtest konnte nicht ausgeführt werden! exec is not available. Please enable "Enable Exec" option in instance settings
                                Vielleicht hat jemand eine schnelle, einfache Lösung für mich. Danke
                                • SKB
                                  SKB Developer Most Active @Tenjo78 last edited by
                                  @tenjo78 der Fehler steht doch schon im Log:
                                  Exec I'm Javascript Adapter erlauben.
                                  Wer lesen kann ist klar im Vorteil 🙂
                                  T 1 Reply Last reply Reply Quote 2
                                    Tenjo78 @SKB last edited by
                                    @skb Alles klar. Im Java-Adapter. Erledigt. LÄUFT!
                                    Danke!
                                      und was bedeutet das?
                                      No overload matches this call.
                                        The last overload gave the following error.
                                          Type 'boolean' has no properties in common with type 'Partial<StateCommon>'.(2769)
                                      javascript.d.ts(1527, 11): The last overload is declared here.
                                        cyqx13 last edited by
                                        habe auch den Speedtest Adapter installiert, über ssh werden auch korrekte Ergebnisse geliefert.
                                        Dann habe ich das js Skript importiert, Pfad angepasst und bekomme folgende Fehlermeldung:
                                        2024-01-17 22:23:50.140 - error: javascript.0 (32246) script.js.common.Speedtest: SyntaxError: Unexpected end of JSON input
                                        2024-01-17 22:23:50.141 - error: javascript.0 (32246) at JSON.parse ()
                                        2024-01-17 22:23:50.142 - error: javascript.0 (32246) at generiere_array (script.js.common.Speedtest:181:18)
                                        2024-01-17 22:23:50.142 - error: javascript.0 (32246) at script.js.common.Speedtest:229:28
                                        2024-01-17 22:23:50.142 - error: javascript.0 (32246) at ChildProcess.exithandler (node:child_process:414:7)
                                        2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:events:517:28)
                                        2024-01-17 22:23:50.143 - error: javascript.0 (32246) at ChildProcess.emit (node:domain:489:12)
                                        2024-01-17 22:23:50.143 - error: javascript.0 (32246) at maybeClose (node:internal/child_process:1098:16)
                                        2024-01-17 22:23:50.143 - error: javascript.0 (32246) at Process.ChildProcess._handle.onexit (node:internal/child_process:303:5)
                                        Kann mir da jemand helfen?
                                          Thomas Braun Most Active @cyqx13 last edited by
                                          @cyqx13
                                          sudo apt update
                                          apt policy speedtest
                                          sagt?
                                            cyqx13 @Thomas Braun last edited by Negalein
                                            pi@iobroker:~ $ sudo apt update
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                            OK:3 https://repos.influxdata.com/debian stable InRelease
                                            OK:4 https://packages.grafana.com/oss/deb stable InRelease
                                            OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            Ign:6 https://packagecloud.io/ookla/speedtest-cli/raspbian buster InRelease
                                            Fehl:7 https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release
                                              404  Not Found [IP: 2600:1f1c:2e5:6900:e12:7a5d:4cf3:3662 443]
                                            E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/raspbian buster Release« enthält keine Release-Datei.
                                            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                            pi@iobroker:~ $ apt policy speedtest-cli
                                            speedtest-cli:
                                              Installiert:           2.0.2-1+deb10u2
                                              Installationskandidat: 2.0.2-1+deb10u2
                                              Versionstabelle:
                                             *** 2.0.2-1+deb10u2 500
                                                    100 /var/lib/dpkg/status
                                            391
                                            73618
