    4. [Neuer Adapter] Homepilot20
      DominikW last edited by
      Moin,
      hier ein Screenshot der Config:
      Es ist dieses Produkt:
      https://de.homepilot-smarthome.com/produkte/pakete/starterset-rollladen-smart
      Das ist der beinhaltete Gateway:
      https://de.homepilot-smarthome.com/produkte/steuerung/gateway-premium
        homecineplexx @DominikW last edited by
        @dominikw dann setz doch bitte mal den hacken bei "Device is Bridge"
          Habe ich grade ausprobiert, leider keine Änderung.
          Hier mal das Protokoll des IOB, vielleicht hilft das?
          homepilot20.0
          2023-09-19 19:29:33.984	warn	Transmitter sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:33 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Transmitter","query":"devtype=Transmitter","pathname":"/v4/devices","path":"/v4/devices?devtype=Transmitter","href":"http://192.168.1.117/v4/devices?devtype=Transmitter"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
          homepilot20.0
          2023-09-19 19:29:33.866	warn	Read sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:33 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Sensor","query":"devtype=Sensor","pathname":"/v4/devices","path":"/v4/devices?devtype=Sensor","href":"http://192.168.1.117/v4/devices?devtype=Sensor"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
          homepilot20.0
          2023-09-19 19:29:30.979	warn	Transmitter sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Transmitter","query":"devtype=Transmitter","pathname":"/v4/devices","path":"/v4/devices?devtype=Transmitter","href":"http://192.168.1.117/v4/devices?devtype=Transmitter"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
          homepilot20.0
          2023-09-19 19:29:30.867	warn	Read sensors -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Sensor","query":"devtype=Sensor","pathname":"/v4/devices","path":"/v4/devices?devtype=Sensor","href":"http://192.168.1.117/v4/devices?devtype=Sensor"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
          homepilot20.0
          2023-09-19 19:29:30.856	warn	Read actuator -> Cannot connect to Homepilot: {"statusCode":404,"body":"{\"error_description\":\"GET URI not found\",\"error_code\":5002}","headers":{"server":"nginx/1.22.1","date":"Tue, 19 Sep 2023 17:29:30 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"192.168.1.117","port":80,"hostname":"192.168.1.117","hash":null,"search":"?devtype=Actuator","query":"devtype=Actuator","pathname":"/v4/devices","path":"/v4/devices?devtype=Actuator","href":"http://192.168.1.117/v4/devices?devtype=Actuator"},"method":"GET","headers":{"0":{},"1":{"Content-Type":"application/json"}}}}
            @dominikw said in [Neuer Adapter] Homepilot20:
            homepilot20.0
            homepilot20.0
            homepilot20.0
            homepilot20.0
            homepilot20.0
            versuch mal http://192.168.1.117/v4/devices?devtype=Actuator
            was gibt er da aus?
              DominikW @homecineplexx last edited by
              @homecineplexx
              Im Browser steht folgendes:
              {"error_description":"GET URI not found","error_code":5002}
              H D 2 Replies Last reply Reply Quote 0
                @dominikw dann kommst aber mit http://192.168.1.117 nicht hin scheinbar
                  Daniel @DominikW last edited by
                  @dominikw Ich hatte das gleiche Problem: Wenn ich das richtig verstanden habe, gibt es jetzt zwei Marken: Rademacher und Homepilot. Das "Gateway Premium" von Homepilot scheint nicht mit den Iobroker-Adaptern zu funktionieren - so wie ich das verstanden habe, haben die gar keine öffentlich verfügbare API (zumindest nicht die gleiche, wie die "alten" und neuen Rademacher-Geräte) und auch kein lokales Web-Interface.
                  Ich habe das noch im Widerruf-Zeitraum festgestellt und mich beim Homepilot-Support gemeldet: Die waren sehr entgegenkommend und haben mir netterweise als Austauschgerät eine "Rademacher SmartHome Box" geschickt. Interessanterweise sind die Boxen (Gateway Premium von Homepilot und SmartHome Box von Rademacher) äußerlich fast identisch. Die Rademacher-Box hat wieder ein lokales Web-Interface und auch die altbekannte API - und lässt sich wieder ohne Probleme mit dem Homepilot-Adapter verbinden.
                  Besten Gruß
                  Daniel
                    Hey,
                    ich habe heute auch einen Homepilot Gateway erhalten. Diesen habe ich versucht, mit dem Adapter zu verbinden. Im Log erhalte ich folgenden Fehler:
                    2023-10-21 20:29:33.841 - info: homepilot20.0 (901675) starting. Version 0.0.43 (non-npm: homecineplexx/ioBroker.homepilot20#master) in /opt/iobroker/node_modules/iobroker.homepilot20, node: v18.18.0, js-controller: 4.0.24
                    2023-10-21 20:29:34.641 - error: homepilot20.0 (901675) Login/get password-salt -> Cannot connect to Homepilot: {"statusCode":401,"body":"Unauthorized","headers":{"server":"nginx/1.22.1","date":"Sat, 21 Oct 2023 18:29:34 GMT","content-type":"text/html;charset=utf-8","transfer-encoding":"chunked","connection":"close"},"request":{"uri":{"protocol":"http:","slashes":true,"auth":null,"host":"172.16.20.40","port":80,"hostname":"172.16.20.40","hash":null,"search":null,"query":null,"pathname":"/authentication/password_salt","path":"/authentication/password_salt","href":"http://172.16.20.40/authentication/password_salt"},"method":"POST","headers":{"content-length":0}}}
                    2023-10-21 20:29:34.645 - error: homepilot20.0 (901675) Adapter will be stopped
                    Das Passwort habe ich im Adapter gesetzt (und auch in der App nochmals getestet, dass es das richtige ist).
                    http://172.16.20.40/v4/devices?devtype=Actuator
                    erzeugt:
                    Unauthorized
                    Edit:
                    Habe jetzt die lokale Passwordabfrage entfernt und lande dann bei dem gleichen Problem wie bei
                    @DominikW.
                    Werde auch mal den Support anschreiben
                      homecineplexx @Guest last edited by
                      @darkness_08 du hast ein gateway? welches genau?
                      und zeig mal was du in den settings eingestellt hast (Foto).
                      Lg
                        A Former User @homecineplexx last edited by
                        @homecineplexx
                        Ich habe einen Homepilot Gateway Premium in der Softwareversion 1.0.7 und Funkversion 2.4
                        "Device is Bridge" aktiviert/deaktiviert ändert nichts.
                        (Jetzt ist die Instanz deaktiviert, da mir sonst das Log entsprechend groß wird)
                        R H 2 Replies Last reply Reply Quote 0
                          romans @Guest last edited by
                          @darkness_08 ich habe das gleiche Problem gehabt. füge einfach "/hp" zur IP hinzu. Damit sollten zumindest die Aktoren wieder funktionieren. Die Szenen schient es jedoch nicht mehr zu geben.
                          Wenn ich mal Zeit habe schaue ich es mir nochmal genauer an.
                            @darkness_08 said in [Neuer Adapter] Homepilot20:
                            und @romans also leider habe ich dieses neue Gateway nicht, sonst könnte ich das natürlich versuchen einzubauen. allerdings könnt ihr ja mal mit den Entwicklertools von eurem Browser schauen, was alles abgeholt wird, wenn ihr euer Homepilot Gateway über den Browser öffnet
                            • chriz77
                              chriz77 last edited by
                              kann mir jemand sagen, ob meine Rollomotoren mit der Version 2.0 funktionieren?
                              RADEMACHER RTFM 10/16 Z DuoFern Funk Rolladenmotor (26601065)
                              RADEMACHER RTFS 10/16 Z DuoFern Funk Rolladenmotor (26401065)
                              Momentan steuere ich sie über FHEM und einem DuoFern Stick, bez. auch über MQTT und Loxone, was leider nicht so richtig toll läuft. In Zukunft würde ich sie aber lieber über ioBroker steuern, da ich mittelfristig von FHEM weg möchte. Vermutlich es es egal, ob ich mir gebraucht den Homepilot 2 oder 3 hole oder?
                              Danke und viele Grüße
                              Chris
                                homecineplexx @chriz77 last edited by
                                @chriz77 said in [Neuer Adapter] Homepilot20:
                                MQTT und Loxone,
                                Hallo
                                also ich kann dir nur sagen dass ich den homepilot-3 habe mit der Version 5.7.15 und da läuft es. Sollten deine Rolladenmotoren noch nicht im Adapter inkludiert sein, kann ich dir das machen, aber dazu brauch ich deine Hilfe.
                                Schreib mich einfach an.
                                lg chris
                                chriz77 1 Reply Last reply Reply Quote 0
                                • chriz77
                                  chriz77 @homecineplexx last edited by chriz77
                                  Hi Chris,
                                  super, vielen Dank für die Info! 👍
                                  VG
                                  Chris
                                    Funkfrettchen last edited by
                                    Moin ...
                                    ich hab heute mal mein Gurtwickler (10251530) angebaut und eine Smart2Smart Bridge installiert. Die Kommunikation läuft auch.
                                    Den Homepilot20 zu installieren lief auch smooth durch.
                                    Allerdings wird der Gurtwickler nicht als Objekt aufgelistet. Heißt das das 10251530 Gurtwickler RolloTron pure smart schlichtweg noch nicht eingepflegt ist?
                                    Gruß Micha
                                    Output:
                                    http://192.168.178.174/v4/devices?devtype=Actuator
                                    {"response":"get_visible_devices","devices":[{"description":"Ihre Gerätebeschreibung","deviceGroup":2,"did":1,"hasErrors":0,"iconSetInverted":0,"iconSet":{"k":"iconset8"},"messages":[],"name":"Schlafzimmer","properties":{"closingContact":3,"dawn":3,"dusk":3,"motion":3,"rain":3,"smartphone":3,"smoke":3,"sun":3,"temperature":3,"time":3,"trigger":3,"warning":3,"wind":3},"statusValid":true,"statusesMap":{"Position":0},"visible":true,"deviceNumber":"10251530","uid":"4025fa_1","voiceControlledBy":"Alexa,Google","origin":"HomePilot"}]}
                                      homecineplexx @Funkfrettchen last edited by homecineplexx
                                      @funkfrettchen hallo
                                      könntest du mir unter git ein issue anlegen, dann kann ich mir das anschauen.
                                      https://github.com/homecineplexx/ioBroker.homepilot20
                                      und bitte versuch das auch noch und schreibs ins ticket:
                                      http://192.168.178.174/devices/1
                                      lg
                                        Funkfrettchen @homecineplexx last edited by
                                        @homecineplexx
                                        Moin .. wird gemacht 🙂
                                        Gruß Micha
                                          Funkfrettchen @Funkfrettchen last edited by
                                          @homecineplexx
                                          scheint zu funktionieren .. Dank Dir
                                            @funkfrettchen bitteschön..hab dir eine private message hier geschickt!
                                            adapter
                                            56
                                            261
                                            45463
