    3. Einsteigerfragen
    4. Hue Adapter startet zu oft neu [gelöst]
      Thomas Braun Most Active @GiB64 last edited by
      @gib64
      Bring das erstmal auf die stabile Basis nodejs@18.
        GiB64 @Thomas Braun last edited by
        Danke, habe ich erledigt. "iob diag" zeigte auch keine Fehler oder Probleme. Dann zur Sicherheit auch den HueAdapter neu installiert, Bridge suchen lassen und User erstellt aber er kommt einfach nicht hoch:
        hue.0
        15998	2023-10-23 13:02:40.889	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
        hue.0
        15998	2023-10-23 13:02:40.888	error	Error
        hue.0
        15998	2023-10-23 13:02:40.816	error	Could not get UUIDs: Unexpected token < in JSON at position 0
        hue.0
        15998	2023-10-23 13:02:40.625	info	Push connection established
        hue.0
        15998	2023-10-23 13:02:36.711	error	Could not poll all: Error
        hue.0
        15998	2023-10-23 13:02:35.379	info	Push connection established
        hue.0
        15998	2023-10-23 13:02:35.361	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
        hue.0
        15998	2023-10-23 13:02:35.360	error	Error
        hue.0
        15998	2023-10-23 13:02:34.148	info	starting. Version 3.10.1 in /opt/iobroker/node_modules/iobroker.hue, node: v18.18.2, js-controller: 5.0.14
        hue.0
        15998	2023-10-23 13:02:33.239	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        hue.0
        12731	2023-10-23 13:02:22.128	info	terminating
        hue.0
        12731	2023-10-23 13:02:21.621	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        hue.0
        12731	2023-10-23 13:02:21.618	info	terminating
        hue.0
        12731	2023-10-23 13:02:21.615	info	Got terminate signal TERMINATE_YOURSELF
        hue.0
        12731	2023-10-23 13:02:14.144	info	created new User: 89SPx-bvuQt6XnucMC6gbRwRzExjDBxPleIto6qW
        hue.0
        12731	2023-10-23 13:01:54.362	warn	[{"name":"Hue Bridge","ipaddress":"192.168.1.9","modelid":"BSB002","swversion":"1960149090"}]
          @gib64 sagte in Hue Adapter startet zu oft neu:
          Was zeigt es denn überhaupt?
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: raspberry64
                     Icon name: computer
              Operating System: Debian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             12:58:43 up 46 min,  1 user,  load average: 3.30, 2.43, 1.60
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            This system needs to be REBOOTED!
            *** Time and Time Zones ***
                           Local time: Mon 2023-10-23 12:58:43 CEST
                       Universal time: Mon 2023-10-23 10:58:43 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            3.8G        2.0G         76M        1.0M        1.8G        1.8G
            Swap:            99M          0B         99M
            Total:          3.9G        2.0G        176M
                     3794 M total memory
                     1955 M used memory
                     2341 M active memory
                     1130 M inactive memory
                       78 M free memory
                      209 M buffer memory
                     1551 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       59G   51G  5.4G  91% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.2M  758M   1% /run
            /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
            [Mon Oct 23 12:11:59 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:18:FD:47 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=42eef330-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Mon Oct 23 12:12:00 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Mon Oct 23 12:12:00 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mon Oct 23 12:12:03 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            43G     /var/
            41G     /var/lib/influxdb/engine/data/41eab7a7769b909a/autogen
            Archived and active journals take up 1.0G in the file system.
            /opt/iobroker/backups:
            15M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            604M    /opt/iobroker/iobroker-data/files
            216M    /opt/iobroker/iobroker-data/backup-objects
            156M    /opt/iobroker/iobroker-data/history
            96M     /opt/iobroker/iobroker-data/files/vis-2-beta
            50M     /opt/iobroker/iobroker-data/states.jsonl
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5f66c5d9.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.9f2a6569.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.5f66c5d9.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DK0E0QPU-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.18.2
            /usr/bin/node           v18.18.2
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            /usr/bin/corepack       0.19.0
            nodejs:
              Installed: 18.18.2-1nodesource1
              Candidate: 18.18.2-1nodesource1
              Version table:
             *** 18.18.2-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            admin:          6.11.0
            javascript:     7.1.5
            Adapters from github:   2
            Adapter State
              system.adapter.adb.0                    : adb                   : raspberry64                              - disabled
            + system.adapter.admin.0                  : admin                 : raspberry64                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : raspberry64                              -  enabled
            + system.adapter.backitup.0               : backitup              : raspberry64                              -  enabled
              system.adapter.ble.0                    : ble                   : raspberry64                              -  enabled
              system.adapter.cameras.0                : cameras               : raspberry64                              - disabled, port: 8200, bind: 127.0.0.1
            + system.adapter.chromecast.0             : chromecast            : raspberry64                              -  enabled
              system.adapter.device-reminder.0        : device-reminder       : raspberry64                              -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : raspberry64                              -  enabled
            + system.adapter.discovery.0              : discovery             : raspberry64                              -  enabled
              system.adapter.echarts.0                : echarts               : raspberry64                              -  enabled
            + system.adapter.email.0                  : email                 : raspberry64                              -  enabled
              system.adapter.feiertage.0              : feiertage             : raspberry64                              -  enabled
              system.adapter.firetv.0                 : firetv                : raspberry64                              - disabled
              system.adapter.flot.0                   : flot                  : raspberry64                              - disabled
              system.adapter.hiob.0                   : hiob                  : raspberry64                              -  enabled
            + system.adapter.history.0                : history               : raspberry64                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : raspberry64                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberry64                              -  enabled, port: 12001
            + system.adapter.hm-rpc.1                 : hm-rpc                : raspberry64                              -  enabled, port: 12010
            + system.adapter.hue-extended.0           : hue-extended          : raspberry64                              -  enabled
            + system.adapter.hue.0                    : hue                   : raspberry64                              -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : raspberry64                              - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : raspberry64                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberry64                              - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberry64                              - disabled
            + system.adapter.influxdb.0               : influxdb              : raspberry64                              -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : raspberry64                              -  enabled
            + system.adapter.net-tools.0              : net-tools             : raspberry64                              -  enabled
              system.adapter.openweathermap.0         : openweathermap        : raspberry64                              -  enabled
            + system.adapter.pi-hole.0                : pi-hole               : raspberry64                              -  enabled
            + system.adapter.ping.0                   : ping                  : raspberry64                              -  enabled
            + system.adapter.radar2.0                 : radar2                : raspberry64                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberry64                              -  enabled
              system.adapter.schoolfree.0             : schoolfree            : raspberry64                              -  enabled
            + system.adapter.signal-cmb.0             : signal-cmb            : raspberry64                              -  enabled
            + system.adapter.smartmeter.0             : smartmeter            : raspberry64                              -  enabled
            + system.adapter.smartthings.0            : smartthings           : raspberry64                              -  enabled
            + system.adapter.socketio.0               : socketio              : raspberry64                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberry64                              -  enabled
            + system.adapter.synology.0               : synology              : raspberry64                              -  enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberry64                              -  enabled
            + system.adapter.telegram.0               : telegram              : raspberry64                              -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : raspberry64                              -  enabled
            + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberry64                              -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberry64                              -  enabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberry64                              -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberry64                              -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberry64                              - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberry64                              - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberry64                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberry64                              - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberry64                              -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberry64                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberry64                              -  enabled
              system.adapter.vis-map.0                : vis-map               : raspberry64                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberry64                              -  enabled
              system.adapter.vis.0                    : vis                   : raspberry64                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberry64                              - disabled
            + system.adapter.web.0                    : web                   : raspberry64                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wled.0                   : wled                  : raspberry64                              -  enabled
              system.adapter.ws.0                     : ws                    : raspberry64                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "adb"          : 0.0.7    , installed 0.0.7
            Adapter    "admin"        : 6.11.0   , installed 6.11.0
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "ble"          : 0.13.4   , installed 0.13.4
            Adapter    "cameras"      : 1.3.0    , installed 1.3.0
            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
            Adapter    "device-reminder": 3.0.0  , installed 2.0.1  [Updatable]
            Adapter    "device-watcher": 2.9.4   , installed 2.9.4
            Adapter    "echarts"      : 1.5.4    , installed 1.5.4
            Adapter    "email"        : 1.2.0    , installed 1.2.0
            Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
            Adapter    "firetv"       : 2.0.2    , installed 2.0.2
            Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
            Adapter    "history"      : 3.0.0    , installed 3.0.0
            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "hue"          : 3.10.1   , installed 3.10.1
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "javascript"   : 7.1.5    , installed 7.1.5
            Controller "js-controller": 5.0.14   , installed 5.0.14
            Adapter    "openweathermap": 0.4.5   , installed 0.4.5
            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
            Adapter    "radar2"       : 2.0.8    , installed 2.0.8
            Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
            Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
            Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
            Adapter    "smartthings"  : 0.1.0    , installed 0.1.0
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "synology"     : 3.0.1    , installed 3.0.1
            Adapter    "telegram"     : 2.0.1    , installed 2.0.1
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
            Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
            Adapter    "vis-2-widgets-material": 1.3.1, installed 1.3.1
            Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "weatherunderground": 3.6.0, installed 3.6.0
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "wled"         : 0.7.1    , installed 0.7.1
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Objects and States
            Objects:        12432
            States:         10630
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:5 https://repos.influxdata.com/debian stable InRelease
            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          70612      9068/sshd: /usr/sbi
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       79088      12304/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       78621      12304/iobroker.js-c
            tcp        0      0 192.168.1.19:12001      0.0.0.0:*               LISTEN      1001       78801      12476/io.hm-rpc.0
            tcp        0      0 192.168.1.19:12010      0.0.0.0:*               LISTEN      1001       80112      12500/io.hm-rpc.1
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          74873      9157/cupsd
            tcp6       0      0 :::3000                 :::*                    LISTEN      116        16398      580/grafana
            tcp6       0      0 :::22                   :::*                    LISTEN      0          70614      9068/sshd: /usr/sbi
            tcp6       0      0 :::2211                 :::*                    LISTEN      1001       85198      13362/io.hiob.0
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          74872      9157/cupsd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       84354      13263/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       78667      12325/io.admin.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        12270      591/influxd
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       85128      13313/io.socketio.0
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       81978      12546/io.radar2.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14865      575/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          70649      9160/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       85036      13289/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       75740      12435/io.chromecast
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13591      394/avahi-daemon: r
            udp        0      0 0.0.0.0:34290           0.0.0.0:*                           108        13593      394/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          14876      575/dhcpcd
            udp6       0      0 :::60574                :::*                                108        13594      394/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13592      394/avahi-daemon: r
            2023-10-23 13:00:00.617  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Wohnzimmer:<span style="color:lime;"><b>true</b></span> Außentemperatur ist mindestens 0,6 Grad kühler als innen (b2lp):
            2023-10-23 13:00:00.617  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Wohnzimmer:<span style="color:red;"><b>false</b></span> Außenluft ist mind. 0,4 g/kg trockener als innen (b1lp):  xa: 9.5 <= (xi - 0.4) 9.16
            2023-10-23 13:00:00.617  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Wohnzimmer: Lüftungsempfehlung (alle Bedingungen auf true):
            2023-10-23 13:00:00.618  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Wohnzimmer, ti:20.9, ta: 13.4, xi:9.56, xa: 9.5, mih:17.5, mit:17
            2023-10-23 13:00:00.619  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: <b>------ Wohnzimmer ------- Aussensensor: TF_Terrasse -----------</b>
            2023-10-23 13:00:04.096  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
            2023-10-23 13:00:04.107  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Start
            2023-10-23 13:00:04.107  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
            2023-10-23 13:00:04.109  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: strJSONfinal = [{"Raum":"TF_Terrasse","Feuchtegehalt_Absolut":"9.50","relative_Luftfeuchtigkeit":"99.00","Taupunkt":"13.20","Temperatur":"13.40","DETAILS.Enthalpie":"37.47","DETAILS.Sättigungsdampfdruck":"15.37","DETAILS.Dampfdruck":"15.22","Dampfgewicht":"11.51","DETAILS.Dampfgewicht_maximal":"11.63","Lüftungsempfehlung":"","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"NaN"},{"Raum":"Keller","Feuchtegehalt_Absolut":"8.15","relative_Luftfeuchtigkeit":"56.00","Taupunkt":"11.00","Temperatur":"20.00","DETAILS.Enthalpie":"40.80","DETAILS.Sättigungsdampfdruck":"23.38","DETAILS.Dampfdruck":"13.09","Dampfgewicht":"9.68","DETAILS.Dampfgewicht_maximal":"17.28","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"false","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Mia","Feuchtegehalt_Absolut":"8.95","relative_Luftfeuchtigkeit":"61.00","Taupunkt":"12.30","Temperatur":"20.10","DETAILS.Enthalpie":"42.92","DETAILS.Sättigungsdampfdruck":"23.53","DETAILS.Dampfdruck":"14.35","Dampfgewicht":"10.60","DETAILS.Dampfgewicht_maximal":"17.38","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"},{"Raum":"Wohnzimmer","Feuchtegehalt_Absolut":"9.56","relative_Luftfeuchtigkeit":"62.00","Taupunkt":"13.30","Temperatur":"20.90","DETAILS.Enthalpie":"45.30","DETAILS.Sättigungsdampfdruck":"24.72","DETAILS.Dampfdruck":"15.32","Dampfgewicht":"11.29","DETAILS.Dampfgewicht_maximal":"18.21","Lüftungsempfehlung":"false","DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten":"false","DETAILS_Lüftungsempfehlung.Lüften_b2_Kühlen":"true","DETAILS_Lüftungsempfehlung.Lüften_b3_Auskühlschutz":"true","DETAILS_Lüftungsempfehlung.Lüften_b4_Raumfeuchte":"true","DETAILS_Lüftungsempfehlung.Lüften_Hysterese":"false","DETAILS_Lüftungsempfehlung.Lüftungsempfehlung_Beschreibung":"Fenster zu:<br>Entfeuchten:    Außenluft ist zu feucht<br>"}]
            2023-10-23 13:00:04.109  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: anyLueften = false, Anzahl Lüftungsempfehlungen: 0
            2023-10-23 13:00:04.111  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
            2023-10-23 13:00:04.111  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: Erzeugung JSON Ende
            2023-10-23 13:00:04.115  - info: javascript.0 (12382) script.js.Lüften_und_Wetter.TaupunktAusForum: =========================================================
            2023-10-23 13:00:04.308  - warn: javascript.0 (12382) You are assigning a string to the state "hm-rpc.0.TEQ1854862.16.LED_STATUS" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
            2023-10-23 13:00:04.309  - warn: javascript.0 (12382)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
            2023-10-23 13:00:04.309  - warn: javascript.0 (12382)     at Object.<anonymous> (script.js.Keller_lüften_LED16:7:5)
            2023-10-23 13:00:04.309  - warn: javascript.0 (12382)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
            2023-10-23 13:00:04.310  - warn: javascript.0 (12382)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2023-10-23 13:00:04.310  - warn: javascript.0 (12382)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8470:62)
            2023-10-23 13:00:04.319  - warn: javascript.0 (12382)     at processImmediate (node:internal/timers:476:21)
            2023-10-23 13:00:04.476  - info: javascript.0 (12382) State value to set for "hm-rpc.0.TEQ1854862.16.LED_STATUS" has to be type "number" but received type "string"
            2023-10-23 13:00:18.612  - info: smartmeter.0 (12664) Received 4 values, 2 updated
            2023-10-23 13:00:35.995  - info: sourceanalytix.0 (13128) Initialization of smartmeter.0.1-0:1_8_0__255.value successfully
            2023-10-23 13:00:36.012  - info: sourceanalytix.0 (13128) Successfully activated SourceAnalytix for 2 of 2 states, will do my Job until you stop me!
            2023-10-23 13:00:37.465  - info: tankerkoenig.0 (13186) Start first request
            iob diag has finished.
            Press any key for a summary
              Thomas Braun Most Active @GiB64 last edited by Thomas Braun
              @gib64
              Und die Karte ist voll.
                @thomas-braun Reboot hatte ich natürlich... Tatsächlich, die 64GB SD Card ist voll, 1TB SSD bestellt, morgen geht es hoffentlich weiter 😉
                Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                  Dann müsste die Meldung aber verschwinden.
                  • haselchen
                    haselchen Most Active @GiB64 last edited by haselchen
                    @GiB64
                    Zeig mal deine Einstellungen im HUE Adapter.
                    Kann mir schon denken, wo es da hakt.
                    Mit deiner SD hat das wenig zu tun.
                    Das Geld hättest du dir sparen können.
                    Räum mal deine Influx Database auf, dann sind auch wieder mehr GB vorhanden.
                    41GB sind schon nen Brett für Influx.
                      Thomas Braun Most Active @haselchen last edited by
                      @haselchen sagte in Hue Adapter startet zu oft neu:
                      Natürlich nicht. Aber das ist die nächste Tür, vor die gerannt werden wird.
                      • haselchen
                        haselchen Most Active @Thomas Braun last edited by
                        Nicht, wenn er seine Influx DB mal abspeckt.
                        Und generell mal sein System auf "Schwächen" prüft.
                        Ich hab ne 32GB Karte und die läuft mit History und Gedöns seit mehreren Jahren.
                          Ja, würde sich auch empfehlen. Die ist schon etwas schwergewichtig...
                            @thomas-braun Ich hatte die Ausgabe für den Fall der fälle in einen Editor gespeichert, neu gestartet und gleich nach Reboot wieder diese abstürzende Hue Meldung...
                            Bin jetzt erstmal auf ein USB Laufwerk ausgewichen nachdem die M2 SSD nicht in das empfohlene Gehäuse passte. Influx gehe ich dann bei Zeiten mal an aber da stehe ich auf auf dem Kriegsfuß da die Sicherung von Influx auch noch nicht funktioniert.. Kaum mit 256GB gebootet, gleich wieder die Meldung vom zu oft abstürzenden Hue. Downgrade versucht, dass selbe und dabei lief der so lange problemlos...
                            Meine Hue Einstellungen:
                            Noch jemand eine Idee?
                              GiB64 @GiB64 last edited by
                              Was soll ich sagen, downgrade noch mal mit unterschiedlichen Konfig-Einstellungen probiert... Dann Deinstalliert und zur Sicherheit ein Reboot. Dann aktuelle Version neu installiert und zuerst sah es aus wie immer (cannot read, terminated,....) und dann auf einmal völlig selbständig ging es... Erklären kann ich mir es nicht. Mal schauen wie lange das gut geht 😉
                              hue.0
                              3142	2023-10-25 10:28:18.059	info	creating/updating bridge device
                              hue.0
                              3142	2023-10-25 10:28:18.058	info	created/updated 108 scenes
                              hue.0
                              3142	2023-10-25 10:28:18.048	info	created/updated 16 groups channels
                              hue.0
                              3142	2023-10-25 10:28:18.044	warn	channel "Schlafzimmer" already exists, using "Schlafzimmer_Room" for group 13
                              hue.0
                              3142	2023-10-25 10:28:18.040	warn	channel "discoAGroupEven" already exists, using "discoAGroupEven_LightGroup" for group 12
                              hue.0
                              3142	2023-10-25 10:28:17.898	warn	channel "Küche" already exists, using "Küche_Room" for group 10
                              hue.0
                              3142	2023-10-25 10:28:17.870	warn	channel "discoAGroupOdd" already exists, using "discoAGroupOdd_LightGroup" for group 8
                              hue.0
                              3142	2023-10-25 10:28:17.864	warn	channel "discoAGroup" already exists, using "discoAGroup_LightGroup" for group 5
                              hue.0
                              3142	2023-10-25 10:28:17.857	warn	channel "Mia" already exists, using "Mia_Room" for group 1
                              hue.0
                              3142	2023-10-25 10:28:17.848	info	created/updated 23 light channels
                              hue.0
                              3142	2023-10-25 10:28:16.014	info	created/updated 8 sensor channels
                              hue.0
                              3142	2023-10-25 10:28:16.013	info	skip switch: Hue outdoor temp. sensor 1.usertest
                              hue.0
                              3142	2023-10-25 10:28:16.013	info	skip switch: Hue outdoor temp. sensor 1.ledindication
                              hue.0
                              3142	2023-10-25 10:28:16.012	info	skip switch: Hue outdoor temp. sensor 1.alert
                              hue.0
                              3142	2023-10-25 10:28:16.003	info	skip switch: Hue outdoor light sensor 1.usertest
                              hue.0
                              3142	2023-10-25 10:28:16.003	info	skip switch: Hue outdoor light sensor 1.ledindication
                              hue.0
                              3142	2023-10-25 10:28:16.002	info	skip switch: Hue outdoor light sensor 1.tholdoffset
                              hue.0
                              3142	2023-10-25 10:28:16.002	info	skip switch: Hue outdoor light sensor 1.tholddark
                              hue.0
                              3142	2023-10-25 10:28:16.001	info	skip switch: Hue outdoor light sensor 1.alert
                              hue.0
                              3142	2023-10-25 10:28:15.990	info	skip switch: Hue outdoor motion sensor 1.usertest
                              hue.0
                              3142	2023-10-25 10:28:15.990	info	skip switch: Hue outdoor motion sensor 1.ledindication
                              hue.0
                              3142	2023-10-25 10:28:15.989	info	skip switch: Hue outdoor motion sensor 1.sensitivitymax
                              hue.0
                              3142	2023-10-25 10:28:15.988	info	skip switch: Hue outdoor motion sensor 1.sensitivity
                              hue.0
                              3142	2023-10-25 10:28:15.987	info	skip switch: Hue outdoor motion sensor 1.alert
                              hue.0
                              3142	2023-10-25 10:28:15.970	info	skip switch: Daylight.sunsetoffset
                              hue.0
                              3142	2023-10-25 10:28:15.969	info	skip switch: Daylight.sunriseoffset
                              hue.0
                              3142	2023-10-25 10:28:15.969	info	skip switch: Daylight.configured
                              hue.0
                              3142	2023-10-25 10:28:15.739	info	Push connection established
                              hue.0
                              3142	2023-10-25 10:28:14.943	info	starting. Version 3.10.1 in /opt/iobroker/node_modules/iobroker.hue, node: v18.18.2, js-controller: 5.0.14
                              hue.0
                              3142	2023-10-25 10:28:14.686	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                              hue.0
                              2957	2023-10-25 10:27:41.585	info	terminating
                              hue.0
                              2957	2023-10-25 10:27:41.148	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              hue.0
                              2957	2023-10-25 10:27:41.147	info	terminating
                              hue.0
                              2957	2023-10-25 10:27:41.146	info	cleaned everything up...
                              hue.0
                              2957	2023-10-25 10:27:41.078	error	Cannot read properties of undefined (reading 'name')
                              hue.0
                              2957	2023-10-25 10:27:41.077	error	TypeError: Cannot read properties of undefined (reading 'name') at Hue.getSensorChannelById (/opt/iobroker/node_modules/iobroker.hue/build/main.js:1115:23) at Hue.handleSensorUpdate (/opt/iobroker/node_modules/iobroker.hue/build/main.js:1008:34) at Hue.handleUpdate (/opt/iobroker/node_modules/iobroker.hue/build/main.js:987:24) at HuePushClient.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/build/main.js:957:30) at HuePushClient.emit (node:events:517:28) at _emit (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:287:17) at parseEventStreamLine (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:302:9) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:259:11) at IncomingMessage.emit (node:events:517:28) at addChunk (node:internal/streams/readable:335:12)
                              hue.0
                              2957	2023-10-25 10:27:41.076	error	unhandled promise rejection: Cannot read properties of undefined (reading 'name')
                              hue.0
                              2957	2023-10-25 10:27:41.075	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              hue.0
                              2957	2023-10-25 10:27:41.068	error	Cannot read properties of undefined (reading 'name')
                              hue.0
                              2957	2023-10-25 10:27:41.067	error	TypeError: Cannot read properties of undefined (reading 'name') at Hue.getSensorChannelById (/opt/iobroker/node_modules/iobroker.hue/build/main.js:1115:23) at Hue.handleSensorUpdate (/opt/iobroker/node_modules/iobroker.hue/build/main.js:1008:34) at Hue.handleUpdate (/opt/iobroker/node_modules/iobroker.hue/build/main.js:987:24) at HuePushClient.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/build/main.js:957:30) at HuePushClient.emit (node:events:517:28) at _emit (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:287:17) at parseEventStreamLine (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:302:9) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/eventsource/lib/eventsource.js:259:11) at IncomingMessage.emit (node:events:517:28) at addChunk (node:internal/streams/readable:335:12)
                              hue.0
                              2957	2023-10-25 10:27:41.066	error	unhandled promise rejection: Cannot read properties of undefined (reading 'name')
                              hue.0
                              2957	2023-10-25 10:27:41.065	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              hue.0
                              2957	2023-10-25 10:27:38.240	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:38.240	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:33.658	error	Could not poll all: Error
                              hue.0
                              2957	2023-10-25 10:27:33.127	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:33.127	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:28.020	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:28.020	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:23.638	error	Could not poll all: Error
                              hue.0
                              2957	2023-10-25 10:27:22.912	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:22.911	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:17.803	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:17.801	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:13.215	error	Could not poll all: Error
                              hue.0
                              2957	2023-10-25 10:27:12.664	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:12.663	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:07.549	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:07.547	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:27:03.201	error	Could not poll all: Error
                              hue.0
                              2957	2023-10-25 10:27:02.443	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:27:02.442	error	Request failed with status code 429
                              hue.0
                              2957	2023-10-25 10:26:57.341	error	Could not get UUIDs: Unexpected token < in JSON at position 0
                              hue.0
                              2957	2023-10-25 10:26:57.334	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:26:57.333	error	Error
                              hue.0
                              2957	2023-10-25 10:26:57.313	info	Push connection established
                              hue.0
                              2957	2023-10-25 10:26:51.873	warn	Could not get configuration from HUE bridge (192.168.1.9:443)
                              hue.0
                              2957	2023-10-25 10:26:51.871	error	Error
                              hue.0
                              2957	2023-10-25 10:26:51.857	info	Push connection established
                              hue.0
                              2957	2023-10-25 10:26:50.929	info	starting. Version 3.10.1 in /opt/iobroker/node_modules/iobroker.hue, node: v18.18.2, js-controller: 5.0.14
                              G 2 Replies Last reply Reply Quote 0
                                GiB64 @GiB64 last edited by GiB64
                                Ich werde so langsam zum Elch. Jetzt wo Hue läuft wollte ich gleich mal sichern und bekomme zahlreiche Permissen Error:
                                Started iobroker ...
                                [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.1.13:/volume1/homes/gib/ioBroker/Backup /opt/iobroker/backups"
                                [DEBUG] [mount] - mount successfully completed
                                [DEBUG] [mount] - done
                                [DEBUG] [iobroker] - host.raspberry64 10926 states saved
                                [DEBUG] [iobroker] - host.raspberry64 12564 objects saved
                                [ERROR] [iobroker] - host.raspberry64 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2023_10_25-10_47_42_GiB_backupiobroker.tar.gz'
                                [ERROR] [iobroker] - host.raspberry64 Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2023_10_25-10_47_42_GiB_backupiobroker.tar.gz'
                                [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2023_10_25-10_47_42_GiB_backupiobroker.tar.gz'
                                [ERROR] [iobroker] - node:events:495
                                      throw er; // Unhandled 'error' event
                                Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                                Emitted 'error' event on  instance at:
                                    at Pack.emit (/opt/iobroker/node_modules/tar/node_modules/minipass/index.js:483:19)
                                    at WriteEntry.<anonymous> (/opt/iobroker/node_modules/tar/lib/pack.js:324:33)
                                    at WriteEntry.emit (node:events:517:28)
                                    at WriteEntry.emit (/opt/iobroker/node_modules/tar/node_modules/minipass/index.js:483:19)
                                    at WriteEntry.emit (/opt/iobroker/node_modules/tar/lib/write-entry.js:122:18)
                                    at /opt/iobroker/node_modules/tar/lib/write-entry.js:262:21
                                    at FSReqCallback.oncomplete (node:fs:200:23) {
                                  errno: -2,
                                  code: 'ENOENT',
                                  syscall: 'open',
                                  path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
                                Node.js v18.18.2
                                [DEBUG] [iobroker] - done
                                [DEBUG] [historyDB] - compress from historyDB started ...
                                [ERROR] [historyDB] - Error: EACCES: permission denied, open '/opt/iobroker/backups/historyDB_2023_10_25-10_48_17_GiB_backupiobroker.tar.gz'
                                Dann habe ich gesehen das die Sicherung zuletzt am. 8.10 lief....
                                Wie gehe ich jetzt am besten vor?
                                  😟 zu früh gefreut... Host meldet wieder abstürze! Es ist zum heulen..
                                  • haselchen
                                    @gib64
                                    Nimm mal das SSL da raus und den Port auf 80 stellen (HUE Adapter Einstellungen )
                                    Dann sollte es laufen.
                                      @haselchen Danke, das war es... Aber warum?? Es lief doch jetzt knapp ein Jahr problemlos
                                      • haselchen
                                        @gib64
                                        Ich war vor einem Jahr auch kein Vater...... 🙂
                                        Also frag lieber nicht 😬 , nimm es hin.....
                                        862
