    3. Einsteigerfragen
    4. Kann die 8081 Seite nicht aufrufen
      Thomas Braun Most Active @audioconcept last edited by
      @audioconcept
      Der RICHTIG interessate Teil kommt DAVOR... 😉
        @audioconcept
        Jedenfalls läuft der admin auf dem üblichen Port 8081.
        Muss eigentlich erreichbar sein. Daher dürfte es sich da um eine Einstellung auf deinem Rechner handeln.
          audioconcept @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi4-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           17:33:25 up 36 min,  2 users,  load average: 0.07, 0.12, 0.14
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2023-10-23 17:33:25 CEST
                     Universal time: Mon 2023-10-23 15:33:25 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          audioconcept
          /home/audioconcept
          audioconcept adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.2G        600M        7.1G        1.2M        613M        7.6G
          Swap:           104M          0B        104M
          Total:          8.3G        600M        7.2G
                   7811 M total memory
                    572 M used memory
                    555 M active memory
                    363 M inactive memory
                   6775 M free memory
                     43 M buffer memory
                    541 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     782M  1.2M  780M   1% /run
          /dev/mmcblk0p2 ext4      115G  3.3G  106G   3% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Mon Oct 23 16:57:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:0B:3F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fc7891d3-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Mon Oct 23 16:57:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Oct 23 16:57:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          679M    /var/
          217M    /var/cache
          211M    /var/cache/apt
          193M    /var/log/journal/ce79f07d8f8e48999025c2be52ce8883
          Archived and active journals take up 192.0M in the file system.
          /opt/iobroker/backups:
          1.3M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          30M     /opt/iobroker/iobroker-data/
          15M     /opt/iobroker/iobroker-data/files
          13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          7.5M    /opt/iobroker/iobroker-data/objects.jsonl
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
          1.3M    /opt/iobroker/iobroker-data/backup-objects/2023-10-22_18-35_objects.jsonl.gz
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 500
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.10.1
          javascript:     "javascript" not found
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Objects and States
          Objects:        161
          States:         118
          E: The repository 'https://repos.influxdata.com/debian bookworm Release' does not have a Release file.
          W: GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
          E: The repository 'https://repos.influxdata.com/debian stable InRelease' is not signed.
          Pending Updates: 1
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13092      709/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18515      930/node-red
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        13822      694/influxd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13181      696/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15722      696/iobroker.js-con
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13094      709/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16711      800/io.admin.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      106        13161      694/influxd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13022      552/avahi-daemon: r
          udp        0      0 0.0.0.0:32787           0.0.0.0:*                           104        13024      552/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        13023      552/avahi-daemon: r
          udp6       0      0 :::55150                :::*                                104        13025      552/avahi-daemon: r
          udp6       0      0 fe80::9e1f:5f40:dc3:546 :::*                                0          2026       634/NetworkManager
          2023-10-23 16:59:18.011  - info: admin.0 (800) failed connection to socket.io from ::ffff:192.168.0.62: Passport was not initialized
            hab alle Firerwall abgeschaltet, Kaspersky deinstalliert. Was soll es noch sein? Läuft auf allen drei Browsern nicht. Aber Handy und Tablet gehen.
            Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
              @audioconcept sagte in Kann die 8081 Seite nicht aufrufen:
              Dann muss es an deinem Computer liegen. Der ioBroker läuft.
              (Btw: Leg das influxdb-Repo neu an).
              • OliverIO
                OliverIO @audioconcept last edited by
                @audioconcept
                kann man das gerät aus der console des windows rechners anpingen.
                liegen beide rechner im gleichen netzsegment?
                also fängt die ip deines windows rechners auch mit 192.168.0 an
                ping 192.168.0.71
                  audioconcept @OliverIO last edited by
                  @oliverio Hi ja beides gleich.
                  Ich installiere alles noch mal neu.
                  • da_Woody
                    da_Woody @audioconcept last edited by
                    Kasperski und alle Firewalls ausgeschaltet
                    da bekomm ich schon kopfweh...
                    was hast du auf dem rechner alles installiert? wozu?
                      A Former User @audioconcept last edited by
                      Moin,
                      das ist ja Unsinn, Du kommst mit Handy und Tablet auf den ioBroker und willst den neu machen?????
                      Setz lieber Dein Windows-PC neu auf 🙂
                      Hast Du irgendwas in den Browsern an Schmu eingerichtet, dass die IP geblockt wird?
                      VG
                      Bernd
                        Homoran Global Moderator Administrators @Ralla66 last edited by
                        @audioconcept
                        was ist mit
                        @ralla66 sagte in Kann die 8081 Seite nicht aufrufen:
                        moderne Browser ersetzen gerne http mit https.
                        Der PC ruft wirklich http://192.168.0.71:8081 auf ?
                        • OliverIO
                          OliverIO @Homoran last edited by
                          er liest die Anweisungen immer nur teilweise.
                          mir hat er auch nur teilweise geantwortet.
                          • mcm1957
                            mcm1957 @OliverIO last edited by mcm1957
                            Hast du am PC ev. WIREGUARD installiert und aktiv?
                            Hab mal stundenlang gesucht warum ich auf einem PC ein (lokales) Gerät nicht erreichen konnte, auf dem danebenstehenden zweiten Laptop angemeldet am selben WLAN gings ...
                            Ursache:
                            Wireguard aktiv. Das hat den ganzen Traffic an die Öffentliche Seite der Fritzbox geroutet. Und dort waren natürlich (und GsD) meine internen Ziele nicht erreichbar.
                            1968
