    4. Update von 4.0.24 auf 5.0.12 deckt Systemprobleme auf
    • N
      nobbiman @Codierknecht last edited by
      @codierknecht ```
      Copy text starting here:
                              v.2023-10-10
         Static hostname: iobroker-pi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.15.84-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               armhf
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": getaddrinfo EAI_AGAIN download.iobroker.net
      Cannot download repository file from "http://download.iobroker.net/sources-dist.json": getaddrinfo EAI_AGAIN download.iobroker.net
      Pending iob updates:    20
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                              /usr/bin/node           v16.19.0
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              /usr/bin/corepack       0.15.1
      Recommended versions are nodejs 16.20.2 and npm 8.19.4
      MEMORY:
      Mem:            3.9G        764M        2.5G        0.0K        623M        3.1G
      Swap:            99M          0B         99M
      Total:          4.0G        764M        2.6G
      Active iob-Instances:   12
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : iobroker-pi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                13244
      States:                 10968
      Size of iob-Database:
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/objects.json.migrated
      2.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      2.8M    /opt/iobroker/iobroker-data/states.jsonl
      28K     /opt/iobroker/iobroker-data/states.json.migrated
      28K     /opt/iobroker/iobroker-data/states.json.bak.migrated
      === Mark text until here for copying ===
        Thomas Braun Most Active @nobbiman last edited by
        @nobbiman
        Die Langfassung bitte.
        • N
          nobbiman @Thomas Braun last edited by nobbiman
          @thomas-braun Verschwunden, muss ich neu starten!
          Langfassung:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           21:46:09 up 2 min,  1 user,  load average: 3.10, 1.56, 0.60
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2023-10-23 21:46:09 CEST
                     Universal time: Mon 2023-10-23 19:46:09 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.9G        970M        2.6G        0.0K        317M        2.9G
          Swap:            99M          0B         99M
          Total:          4.0G        970M        2.7G
                   3888 M total memory
                    970 M used memory
                    163 M active memory
                   1035 M inactive memory
                   2600 M free memory
                     65 M buffer memory
                    252 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       15G   13G  1.4G  91% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     778M  736K  777M   1% /run
          /dev/mmcblk0p1 vfat      247M   50M  197M  21% /boot
          tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
          [Mon Oct 23 21:43:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A4:AD:F2 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tty1 root=PARTUUID=15adb72e-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): 3 orphan inodes deleted
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): recovery complete
          [Mon Oct 23 21:43:39 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Mon Oct 23 21:43:39 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Mon Oct 23 21:43:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          1.3G    /var/
          710M    /var/cache
          703M    /var/cache/apt
          638M    /var/cache/apt/archives
          331M    /var/log
          Archived and active journals take up 328.1M in the file system.
          /opt/iobroker/backups:
          58M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          7.7G    /opt/iobroker/iobroker-data/
          7.5G    /opt/iobroker/iobroker-data/history
          131M    /opt/iobroker/iobroker-data/files
          94M     /opt/iobroker/iobroker-data/history/20230131
          78M     /opt/iobroker/iobroker-data/history/20230201
          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
          6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          5.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/44.59b48e42.chunk.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Installed: 16.19.0-deb-1nodesource1
            Candidate: 16.19.0-deb-1nodesource1
            Version table:
           *** 16.19.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u3 500
                  500 http://security.debian.org/debian-security bullseye-security/main armhf Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  4.0.24
          admin:          6.3.5
          javascript:     7.0.3
          Adapters from github:   1
          Adapter State
            system.adapter.backitup.0               : backitup              : iobroker-pi                              - disabled
          + system.adapter.controme.0               : controme              : iobroker-pi                              -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
          + system.adapter.fhem.0                   : fhem                  : iobroker-pi                              -  enabled, port: 7072
            system.adapter.fritzdect.0              : fritzdect             : iobroker-pi                              - disabled
          + system.adapter.growatt.0                : growatt               : iobroker-pi                              -  enabled
            system.adapter.habpanel.0               : habpanel              : iobroker-pi                              -  enabled
          + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
            system.adapter.hm-rega.0                : hm-rega               : iobroker-pi                              - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              - disabled, port: 0
          + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
          + system.adapter.jeelink.0                : jeelink               : iobroker-pi                              -  enabled
            system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
          + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
            system.adapter.net-tools.0              : net-tools             : iobroker-pi                              - disabled
            system.adapter.ping.0                   : ping                  : iobroker-pi                              - disabled
            system.adapter.powerfox2.0              : powerfox2             : iobroker-pi                              -  enabled
            system.adapter.pushover.0               : pushover              : iobroker-pi                              - disabled
            system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              - disabled
            system.adapter.shelly.0                 : shelly                : iobroker-pi                              - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              - disabled
            system.adapter.tr-064.0                 : tr-064                : iobroker-pi                              - disabled
            system.adapter.tr-064.1                 : tr-064                : iobroker-pi                              - disabled
            system.adapter.tr-064.2                 : tr-064                : iobroker-pi                              - disabled
            system.adapter.tr-064.3                 : tr-064                : iobroker-pi                              - disabled
          + system.adapter.viessmann.0              : viessmann             : iobroker-pi                              -  enabled, port: 3002
          + system.adapter.viessmannapi.0           : viessmannapi          : iobroker-pi                              -  enabled
            system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.3.5  [Updatable]
          Adapter    "alias-manager": 1.2.6    , installed 1.2.4  [Updatable]
          Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "fhem"         : 2.0.5    , installed 2.0.3  [Updatable]
          Adapter    "fritzdect"    : 2.3.1    , installed 2.2.6  [Updatable]
          Adapter    "growatt"      : 3.2.1    , installed 3.0.2  [Updatable]
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.18 [Updatable]
          Adapter    "javascript"   : 7.1.4    , installed 7.0.3  [Updatable]
          Adapter    "jeelink"      : 1.2.3    , installed 0.1.4  [Updatable]
          Controller "js-controller": 5.0.12   , installed 4.0.24 [Updatable]
          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
          Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "openhab"      : 1.1.0    , installed 1.1.0
          Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
          Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "shelly"       : 6.4.1    , installed 6.4.1
          Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
          Adapter    "synology"     : 3.0.0    , installed 2.1.13 [Updatable]
          Adapter    "viessmann"    : 1.4.4    , installed 1.4.3  [Updatable]
          Adapter    "viessmannapi" : 2.3.0    , installed 2.0.9  [Updatable]
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "web"          : 6.1.2    , installed 4.3.0  [Updatable]
          Adapter    "ws"           : 2.5.5    , installed 1.3.0  [Updatable]
          Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
          Objects and States
          Objects:        13244
          States:         10967
          W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
          W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
          W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
          W: Failed to fetch https://www.debmatic.de/debmatic/dists/stable/InRelease  Temporary failure resolving 'www.debmatic.de'
          W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Temporary failure resolving 'deb.nodesource.com'
          W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'archive.raspberrypi.org'
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Err:1 https://deb.nodesource.com/node_16.x bullseye InRelease
          Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Err:3 http://deb.debian.org/debian bullseye InRelease
          Err:4 http://deb.debian.org/debian bullseye-updates InRelease
          Err:5 https://www.debmatic.de/debmatic stable InRelease
          Err:6 http://security.debian.org/debian-security bullseye-security InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14690      759/lighttpd
          tcp        0      0 0.0.0.0:9292            0.0.0.0:*               LISTEN      0          14698      759/lighttpd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11755      504/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:31999           0.0.0.0:*               LISTEN      0          14085      1373/ReGaHss.normal
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14472      471/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13456      471/iobroker.js-con
          tcp        0      0 0.0.0.0:8183            0.0.0.0:*               LISTEN      0          15354      1373/ReGaHss.normal
          tcp        0      0 0.0.0.0:8181            0.0.0.0:*               LISTEN      0          14692      759/lighttpd
          tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      0          14700      759/lighttpd
          tcp        0      0 0.0.0.0:2000            0.0.0.0:*               LISTEN      0          14702      759/lighttpd
          tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      0          14696      759/lighttpd
          tcp        0      0 0.0.0.0:1999            0.0.0.0:*               LISTEN      0          14694      759/lighttpd
          tcp        0      0 127.0.0.1:30080         0.0.0.0:*               LISTEN      0          16819      1149/lighttpd
          tcp6       0      0 :::80                   :::*                    LISTEN      0          14691      759/lighttpd
          tcp6       0      0 :::9292                 :::*                    LISTEN      0          14699      759/lighttpd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11757      504/sshd: /usr/sbin
          tcp6       0      0 :::39292                :::*                    LISTEN      0          15264      1196/java
          tcp6       0      0 :::3389                 :::*                    LISTEN      109        14468      513/xrdp
          tcp6       0      0 :::8181                 :::*                    LISTEN      0          14693      759/lighttpd
          tcp6       0      0 :::2001                 :::*                    LISTEN      0          14701      759/lighttpd
          tcp6       0      0 :::2000                 :::*                    LISTEN      0          14703      759/lighttpd
          tcp6       0      0 :::2010                 :::*                    LISTEN      0          14697      759/lighttpd
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          13416      491/xrdp-sesman
          tcp6       0      0 :::1999                 :::*                    LISTEN      0          14695      759/lighttpd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17413      1045/io.admin.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        8731       372/avahi-daemon: r
          udp        0      0 0.0.0.0:60156           0.0.0.0:*                           108        8733       372/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          15413      1118/ssdpd
          udp        0      0 0.0.0.0:43439           0.0.0.0:*                           0          15116      1113/eq3configd
          udp        0      0 127.0.0.1:1998          0.0.0.0:*                           0          15355      1373/ReGaHss.normal
          udp        0      0 127.0.0.1:8182          0.0.0.0:*                           0          15456      1115/hss_led
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11788      720/dhcpcd
          udp6       0      0 :::42720                :::*                                0          15554      1196/java
          udp6       0      0 :::5353                 :::*                                108        8732       372/avahi-daemon: r
          udp6       0      0 :::58199                :::*                                108        8734       372/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          8827       720/dhcpcd
          2023-10-23 21:48:52.317  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | state > fhem.0.Anwesenheit.state present
          2023-10-23 21:48:52.317  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | boolean > fhem.0.Anwesenheit.state_boolean true
          2023-10-23 21:48:52.318  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | value > fhem.0.Anwesenheit.state_value 2
          2023-10-23 21:48:52.318  - info: fhem.0 (1283) event FHEM: handy_doris | PRESENCE handy_doris absent | state > fhem.0.handy_doris.state absent
          2023-10-23 21:48:52.319  - info: fhem.0 (1283) event FHEM: handy_doris | PRESENCE handy_doris absent | boolean > fhem.0.handy_doris.state_boolean false
          2023-10-23 21:48:52.319  - info: fhem.0 (1283) event FHEM: handy_doris | PRESENCE handy_doris absent | value > fhem.0.handy_doris.state_value 0
          2023-10-23 21:49:00.046  - info: host.iobroker-pi instance system.adapter.powerfox2.0 started with pid 2253
          2023-10-23 21:49:00.441  - info: fhem.0 (1283) stateChange (out): growatt.0.1397806.devices.SML0CHH0FT.historyLast.bdc1Soc | 8 > set growatt.0.1397806.devices.SML0CHH0FT.historyLast.bdc1Soc 8
          2023-10-23 21:49:18.376  - info: powerfox2.0 (2253) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.powerfox2, node: v16.19.0, js-controller: 4.0.24
          2023-10-23 21:49:00.508  - info: fhem.0 (1283) stateChange (out): growatt.0.1397806.devices.SML0CHH0FT.historyLast.bdc1Temp1 | 17.3 > set growatt.0.1397806.devices.SML0CHH0FT.historyLast.bdc1Temp1 17.3
          2023-10-23 21:49:00.773  - info: fhem.0 (1283) stateChange (out): growatt.0.1397806.devices.SML0CHH0FT.deviceData.pac | 8.7 > set growatt.0.1397806.devices.SML0CHH0FT.deviceData.pac 8.7
          2023-10-23 21:49:15.306  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | state > fhem.0.Anwesenheit.state present
          2023-10-23 21:49:15.306  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | boolean > fhem.0.Anwesenheit.state_boolean true
          2023-10-23 21:49:15.306  - info: fhem.0 (1283) event FHEM: Anwesenheit | structure Anwesenheit present | value > fhem.0.Anwesenheit.state_value 2
          2023-10-23 21:49:15.307  - info: fhem.0 (1283) event FHEM: handy_norbert | PRESENCE handy_norbert present | state > fhem.0.handy_norbert.state present
          2023-10-23 21:49:15.307  - info: fhem.0 (1283) event FHEM: handy_norbert | PRESENCE handy_norbert present | boolean > fhem.0.handy_norbert.state_boolean true
          2023-10-23 21:49:15.308  - info: fhem.0 (1283) event FHEM: handy_norbert | PRESENCE handy_norbert present | value > fhem.0.handy_norbert.state_value 2
          2023-10-23 21:49:18.505  - error: powerfox2.0 (2253) powerfox2 error: Error: getaddrinfo EAI_AGAIN backend.powerfox.energy
          2023-10-23 21:49:18.528  - error: powerfox2.0 (2253) powerfox2 error: Error: getaddrinfo EAI_AGAIN backend.powerfox.energy
          2023-10-23 21:49:18.542  - info: powerfox2.0 (2253) Terminated (NO_ERROR): Without reason
          2023-10-23 21:49:19.075  - info: host.iobroker-pi instance system.adapter.powerfox2.0 terminated with code 0 (NO_ERROR)
          2023-10-23 21:49:29.410  - info: fhem.0 (1283) event FHEM: myStatDevice | statistics myStatDevice Updated stats for: MiniPV_Messung_Shelly | state > fhem.0.myStatDevice.state Updated stats for: MiniPV_Messung_Shelly
          2023-10-23 21:49:36.172  - info: fhem.0 (1283) stateChange (out): growatt.0.xxxxxxxx.devices.yyyyyyyyyy.historyLast.bdc1Soc | 8 > set growatt.0.xxxxxxxx.devices.yyyyyyyyyy.historyLast.bdc1Soc 8
          2023-10-23 21:49:36.237  - info: fhem.0 (1283) stateChange (out): growatt.0.xxxxxxxx.devices.yyyyyyyyyy.historyLast.bdc1Temp1 | 17.3 > set growatt.0.xxxxxxxx.devices.yyyyyyyyyy.historyLast.bdc1Temp1 17.3
          2023-10-23 21:49:36.451  - info: fhem.0 (1283) stateChange (out): growatt.0.xxxxxxxx.devices.yyyyyyyyyy.deviceData.pac | 8.7 > set growatt.0.xxxxxxxx.devices.yyyyyyyyyy.deviceData.pac 8.7
          iob diag has finished.
          Press any key for a summary
            Thomas Braun Most Active @nobbiman last edited by Thomas Braun
            @nobbiman sagte in Update von 4.0.24 auf 5.0.12 deckt Systemprobleme auf:
            Wieder per 'Stromweg-Exekution' neugestartet?
            Damit KILLST du das Dateisystem nur noch weiter.
            Installier das System neu (auf einem neuen Datenträger), diesmal als 64bit-Version. Backup drauf, fertig.
            • N
              @thomas-braun sagte in Update von 4.0.24 auf 5.0.12 deckt Systemprobleme auf:
              Nein, diesmal per putty-Neustart!
                @nobbiman
                Dann hast du erst Recht ein Problem mit der SD-Karte. Die ist offenbar 'durch'.
                • N
                  @thomas-braun keine andere Lösung?😕
                    @nobbiman
                    Nö.
                    • N
                      @thomas-braun Die Wahrheit ist manchmal gnadenlos!😧
                        @nobbiman
                        Was liegt denn da noch alles drauf? Die Karte ist beinahe rappelvoll:
                        • N
                          Eigentlich nur der ioBroker, wahrscheinlich mit viel zu viel gesammelten und unnötigen Datensammlungen.
                            Jaksa @nobbiman last edited by
                            @nobbiman
                            Kauf dir am besten eine SSD anstatt einer neuen SD Karte. Die sind deutlich langlebiger und der preisliche Unterschied ist auch nicht mehr so groß. Dann solltest du erstmal ruhe haben was solche Probleme angeht 🙂
                            • N
                              nobbiman @Jaksa last edited by
                              @jaksa Dann müsste es doch auch ein 64GB USB-Stick tun?
                              • Codierknecht
                                Codierknecht Developer Most Active @nobbiman last edited by
                                @nobbiman
                                SD-Karte oder Stick sind vergleichbar ... schlecht.
                                Die Dinger sind nicht für dermaßen viele Schreibzugriffe ausgelegt, wie es ioBroker oder vergleichbare Anwendungen erfordern.
                                N 1 Reply Last reply Reply Quote 1
                                • N
                                  @codierknecht Reicht denn die Stromversorgung am USB-Anschluss des RasPi für die SSD oder brauche ich eine gesonderte?
                                  Thomas Braun Codierknecht mcm1957 3 Replies Last reply Reply Quote 0
                                    @nobbiman
                                    Current issues:
                                    Die derzeitige Stromversorgung scheint ja ausreichend zu sein. Ich würde es probieren.
                                    • Codierknecht
                                      @nobbiman
                                      Keine Ahnung. Ich habe keinen Raspi.
                                      Aber Tante Gurgel liefert da massig Hilfestellung. Unter anderem:
                                      https://www.veuhoff.net/raspberry-pi-4-wie-eine-ssd-anstelle-von-einer-sd-karte-verwendet-werden-kann/
                                      • mcm1957
                                        mcm1957 @nobbiman last edited by
                                        @nobbiman said in Update von 4.0.24 auf 5.0.12 deckt Systemprobleme auf:
                                        Also ich betreibe einen Raspberry Pi 4 mit SSD im Argon One m2 Gehäuse mit dem originalen PI4 Netzteil schon seit über einem Jahr ohne Probleme. Hängt noch ein Zigbee Stick mit dran.
                                        Also von der Stromversorgung her sollte das eigentlich gehen.
                                        mcm1957
                                        N Thomas Braun 2 Replies Last reply Reply Quote 0
                                        • N
                                          nobbiman @mcm1957 last edited by
                                          @mcm57 Du meinst, eine externe SV sei doch nötig - USB reicht nicht?
                                            Thomas Braun Most Active @mcm1957 last edited by
                                            @mcm57 sagte in Update von 4.0.24 auf 5.0.12 deckt Systemprobleme auf:
                                            Hier auch. Funktioniert ohne Zicken.
                                            update
                                            3357
