    3. Einsteigerfragen
    4. Kann die 8081 Seite nicht aufrufen
      audioconcept @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi4-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:33:25 up 36 min,  2 users,  load average: 0.07, 0.12, 0.14
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-10-23 17:33:25 CEST
                 Universal time: Mon 2023-10-23 15:33:25 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      audioconcept
      /home/audioconcept
      audioconcept adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.2G        600M        7.1G        1.2M        613M        7.6G
      Swap:           104M          0B        104M
      Total:          8.3G        600M        7.2G
               7811 M total memory
                572 M used memory
                555 M active memory
                363 M inactive memory
               6775 M free memory
                 43 M buffer memory
                541 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     782M  1.2M  780M   1% /run
      /dev/mmcblk0p2 ext4      115G  3.3G  106G   3% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Mon Oct 23 16:57:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:0B:3F vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fc7891d3-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Mon Oct 23 16:57:05 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Oct 23 16:57:07 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      679M    /var/
      217M    /var/cache
      211M    /var/cache/apt
      193M    /var/log/journal/ce79f07d8f8e48999025c2be52ce8883
      Archived and active journals take up 192.0M in the file system.
      /opt/iobroker/backups:
      1.3M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      30M     /opt/iobroker/iobroker-data/
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      7.5M    /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      1.3M    /opt/iobroker/iobroker-data/backup-objects/2023-10-22_18-35_objects.jsonl.gz
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 500
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.10.1
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Objects and States
      Objects:        161
      States:         118
      E: The repository 'https://repos.influxdata.com/debian bookworm Release' does not have a Release file.
      W: GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      E: The repository 'https://repos.influxdata.com/debian stable InRelease' is not signed.
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13092      709/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18515      930/node-red
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      106        13822      694/influxd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13181      696/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15722      696/iobroker.js-con
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13094      709/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16711      800/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      106        13161      694/influxd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13022      552/avahi-daemon: r
      udp        0      0 0.0.0.0:32787           0.0.0.0:*                           104        13024      552/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        13023      552/avahi-daemon: r
      udp6       0      0 :::55150                :::*                                104        13025      552/avahi-daemon: r
      udp6       0      0 fe80::9e1f:5f40:dc3:546 :::*                                0          2026       634/NetworkManager
      2023-10-23 16:59:18.011  - info: admin.0 (800) failed connection to socket.io from ::ffff:192.168.0.62: Passport was not initialized
        hab alle Firerwall abgeschaltet, Kaspersky deinstalliert. Was soll es noch sein? Läuft auf allen drei Browsern nicht. Aber Handy und Tablet gehen.
        Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @audioconcept last edited by
          @audioconcept sagte in Kann die 8081 Seite nicht aufrufen:
          Dann muss es an deinem Computer liegen. Der ioBroker läuft.
          (Btw: Leg das influxdb-Repo neu an).
          • OliverIO
            OliverIO @audioconcept last edited by
            @audioconcept
            kann man das gerät aus der console des windows rechners anpingen.
            liegen beide rechner im gleichen netzsegment?
            also fängt die ip deines windows rechners auch mit 192.168.0 an
            ping 192.168.0.71
              audioconcept @OliverIO last edited by
              @oliverio Hi ja beides gleich.
              Ich installiere alles noch mal neu.
              • da_Woody
                da_Woody @audioconcept last edited by
                Kasperski und alle Firewalls ausgeschaltet
                da bekomm ich schon kopfweh...
                was hast du auf dem rechner alles installiert? wozu?
                  A Former User @audioconcept last edited by
                  Moin,
                  das ist ja Unsinn, Du kommst mit Handy und Tablet auf den ioBroker und willst den neu machen?????
                  Setz lieber Dein Windows-PC neu auf 🙂
                  Hast Du irgendwas in den Browsern an Schmu eingerichtet, dass die IP geblockt wird?
                  VG
                  Bernd
                    Homoran Global Moderator Administrators @Ralla66 last edited by
                    @audioconcept
                    was ist mit
                    @ralla66 sagte in Kann die 8081 Seite nicht aufrufen:
                    moderne Browser ersetzen gerne http mit https.
                    Der PC ruft wirklich http://192.168.0.71:8081 auf ?
                    • OliverIO
                      OliverIO @Homoran last edited by
                      er liest die Anweisungen immer nur teilweise.
                      mir hat er auch nur teilweise geantwortet.
                      • mcm1957
                        mcm1957 @OliverIO last edited by mcm1957
                        Hast du am PC ev. WIREGUARD installiert und aktiv?
                        Hab mal stundenlang gesucht warum ich auf einem PC ein (lokales) Gerät nicht erreichen konnte, auf dem danebenstehenden zweiten Laptop angemeldet am selben WLAN gings ...
                        Ursache:
                        Wireguard aktiv. Das hat den ganzen Traffic an die Öffentliche Seite der Fritzbox geroutet. Und dort waren natürlich (und GsD) meine internen Ziele nicht erreichbar.
                        1965
