    4. Nicht vorhandener Datenpunkt im Log
      Radi last edited by
      Ich betreibe meinen IOBroker in einer VM unter Proxmox. Das System dürfte halbwegs aktuell sein.
                              v.2023-10-10
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-26-amd64
            Architecture: x86-64
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/node           v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
                              /usr/bin/corepack       0.19.0
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:            9.9G        7.1G        1.5G        0.0K        1.4G        2.6G
      Swap:           974M        5.0M        969M
      Total:           10G        7.1G        2.4G
      Active iob-Instances:   68
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.12
                              admin                   6.10.1
      Objects type: jsonl
      States  type: redis
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
      Objects:                75800
      States:                 57074
      Size of iob-Database:
      58M     /opt/iobroker/iobroker-data/objects.jsonl
      8.7M    /opt/iobroker/iobroker-data/states.jsonl
      Nun taucht in meinem Log regelmäßig alle 3 Minuten folgende Fehlermeldung auf:
      web.1
      	2023-10-24 08:57:04.991	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:57:04.958	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:57:04.780	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      web.1
      	2023-10-24 08:57:04.676	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:54:04.981	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:54:04.957	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:54:04.956	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:54:04.775	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:54:04.620	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:51:05.287	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:51:05.204	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      web.1
      	2023-10-24 08:51:05.159	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      web.1
      	2023-10-24 08:51:04.872	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
      Den zugehörigen Datenpunkt gibt es bei mir aber gar nicht.
      Selbst bei ausgeschalteter Milight- Instanz kommt die Fehlermeldung alle 3 Minuten.
      Wie bekomme ich diese wieder weg?
      Wo kann ich noch suchen? Werden noch Infos benötigt?
        sigi234 Forum Testing Most Active @Radi last edited by
        @radi
        Objekte löschen und neu einlesen lassen
          Radi @sigi234 last edited by
          @sigi234 Gesagt, getan. Die Objekte des Milight-Adapters gelöscht, die Instanz wieder gestartet.
          Der Fehler ist immer noch da.
          web.1
          	2023-10-24 09:21:04.176	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:21:04.092	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:21:04.029	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:21:03.964	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:21:03.831	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:18:04.532	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:18:04.462	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:18:04.445	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:18:04.212	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:18:04.154	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:15:05.373	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:15:05.178	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          	2023-10-24 09:15:05.177	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          web.1
          web.1
          	2023-10-24 09:15:04.899	warn	State "milight-smart-light.0.bad.rgbw-4.rgb" has no existing object, this might lead to an error in future versions
          Was mich wundert ist, das die web.1-Instanz meckert. Ich habe noch eine zweite web-Instanz laufen. Die sagt nichts.
            Wildbill @Radi last edited by
            @radi Hast Du eventuell irgendeine Visualisierung, bei der dieser fehlende Punkt irgendwie enthalten ist? Oder ein Script, welches auf diesen Punkt triggert?
            Ich meine, ich hatte sowas mal, als ich ein Gerät getauscht hatte, in einer VIS-View aber noch irgendwo der Datenpunkt enthalten war.
            Gruss, Jürgen
              Radi @Wildbill last edited by Radi
              @wildbill Danke für den Hinweis. Ich schaue mal durch meine Vis und meine Scripte. Was mich irritiert ist, das ich Bad nie einen Milight-Strip oder -Leuchte verbaut hatte.
              Gruss Ralf
                Wildbill @Radi last edited by Wildbill
                @radi Gibt es bei Dir einen
                milight-smart-light.0.bad.xxx
                ? Also irgendein Gerät, was so heisst und wo nur dieser Datenpunkt fehlt?
                Gruss, Jürgen
                EDIT: Unter Scripts kannst Du ja mal direkt nach
                suchen, oben links als Filter setzen. Dann siehst Du gleich, ob da irgendein Script darauf triggert. Wenn nicht, bleibt nur die VIS.
                  @wildbill sagte in Nicht vorhandener Datenpunkt im Log:
                  Jürgen, du bist mein Held. Ich hatte mal in meiner Vis mit einem farbtastic Widget herumgespielt und da stand doch wirklich dieser Datenpunkt drin. Hab den erstmal gelöscht und warte ab was passiert.
                  Die 3 Minuten sind rum und keine Fehlermeldung mehr.
                  Danke sagt Ralf
