    4. Iobroker nicht mehr erreichbar / Festplatte voll?
    • DJMarc75
      DJMarc75 @erazor86 last edited by
      @erazor86 sagte in Iobroker nicht mehr erreichbar / Festplatte voll?:
      die Backups manuell angestoßen
      manuelle Backups werden nicht automatisch gelöscht. Musst Du selber machen.
        erazor86 @Thomas Braun last edited by erazor86
        okay verstanden... nun hoffentlich richtig:
        pi@raspberrypi:/opt/iobroker $ sudo ncdu /
        ncdu 1.13 ~ Use the arrow keys to navigate, press ? for help
           23.0 GiB [##########] /var
            2.9 GiB [#         ] /opt
            1.3 GiB [          ] /usr
          731.8 MiB [          ] /home
           48.1 MiB [          ] /boot
            8.4 MiB [          ] /run
            3.5 MiB [          ] /etc
           32.0 KiB [          ] /tmp
           32.0 KiB [          ] /root
        e  16.0 KiB [          ] /lost+found
        e   4.0 KiB [          ] /srv
        e   4.0 KiB [          ] /mnt
        e   4.0 KiB [          ] /media
            0.0   B [          ] /sys
        .   0.0   B [          ] /proc
            0.0   B [          ] /dev
        @   0.0   B [          ]  sbin
        @   0.0   B [          ]  lib
        @   0.0   B [          ]  bin
        dann ist die Größte Datei wohl der Log??
        das ist im Pfad var/log aufgelistet
           11.4 GiB [##########]  syslog
           11.4 GiB [######### ]  kern.log
          608.0 KiB [          ]  daemon.log
          444.0 KiB [          ]  daemon.log.1
           68.0 KiB [          ]  syslog.1
           48.0 KiB [          ]  wtmp
           44.0 KiB [          ] /apt
           40.0 KiB [          ]  auth.log.1
           36.0 KiB [          ]  messages
           28.0 KiB [          ]  daemon.log.4.gz
           28.0 KiB [          ]  daemon.log.3.gz
           24.0 KiB [          ]  daemon.log.2.gz
           24.0 KiB [          ]  kern.log.3.gz
           24.0 KiB [          ]  auth.log
            8.0 KiB [          ]  dpkg.log.2.gz
            8.0 KiB [          ]  syslog.5.gz
            8.0 KiB [          ]  syslog.3.gz
            8.0 KiB [          ]  syslog.4.gz
            8.0 KiB [          ]  syslog.2.gz
            8.0 KiB [          ]  syslog.7.gz
            8.0 KiB [          ]  syslog.6.gz
            4.0 KiB [          ]  lastlog
            4.0 KiB [          ]  faillog
        e   4.0 KiB [          ] /private
            4.0 KiB [          ]  debug.1
            4.0 KiB [          ]  auth.log.3.gz
            4.0 KiB [          ]  auth.log.2.gz
            4.0 KiB [          ]  auth.log.4.gz
            4.0 KiB [          ]  debug
            4.0 KiB [          ]  messages.1
            4.0 KiB [          ]  dpkg.log.1
            4.0 KiB [          ]  fontconfig.log
            4.0 KiB [          ]  debug.2.gz
            4.0 KiB [          ]  debug.4.gz
            4.0 KiB [          ]  debug.3.gz
            4.0 KiB [          ]  user.log.1
            4.0 KiB [          ]  kern.log.1
            4.0 KiB [          ]  kern.log.2.gz
            4.0 KiB [          ]  messages.4.gz
            4.0 KiB [          ]  kern.log.4.gz
            4.0 KiB [          ]  messages.3.gz
            4.0 KiB [          ]  messages.2.gz
            4.0 KiB [          ]  user.log.3.gz
            4.0 KiB [          ]  user.log.4.gz
            4.0 KiB [          ]  user.log.2.gz
            0.0   B [          ]  dpkg.log
            0.0   B [          ]  btmp.1
            0.0   B [          ]  btmp
            0.0   B [          ]  bootstrap.log
            0.0   B [          ]  alternatives.log
          Thomas Braun Most Active @erazor86 last edited by
          @erazor86
          Dann solltest du da mal reinschauen und prüfen wo es dem Patienten weh tut
            @thomas-braun leider bin ich in Linux nicht so fit das ich da mal eben reinschauen kann. Ich wäre ja erstmal froh wenn ich Iobroker wieder gestartet bekäme... eigentlich lief das System ganz gut ohne Störungen.. Was verbirgt sich hinter den Logs?
            pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker/var/log/syslog
            -bash: cd: /opt/iobroker/var/log/syslog: No such file or directory
              @erazor86
              In den Logs stehen halt Meldungen vom/zum System drin.
              https://wiki.ubuntuusers.de/systemd/journalctl/
                ich hatte nachdem Iobroker nicht erreichbar war einen reboot durchgeführt. Daher werden mir nur die Logs nach dem Reboot angezeigt:
                pi@raspberrypi:/opt/iobroker $ journalctl --list-boots
                 0 d2f67408b68a4116aa7a4c2aa2a32fca Tue 2023-10-24 11:42:53 CEST—Tue 2023-10-24 13:35:28 CEST
                pi@raspberrypi:/opt/iobroker $ journalctl --since "2023-10-24" --until "60 minutes ago"
                -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 13:24:26 CEST. --
                Oct 24 11:42:53 raspberrypi kernel: Booting Linux on physical CPU 0x0
                Oct 24 11:42:53 raspberrypi kernel: Linux version 5.10.63-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:56 GMT 2021
                Oct 24 11:42:53 raspberrypi kernel: CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
                Oct 24 11:42:53 raspberrypi kernel: CPU: div instructions available: patching division code
                Oct 24 11:42:53 raspberrypi kernel: CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
                Oct 24 11:42:53 raspberrypi kernel: OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
                Oct 24 11:42:53 raspberrypi kernel: random: fast init done
                Oct 24 11:42:53 raspberrypi kernel: Memory policy: Data cache writealloc
                Oct 24 11:42:53 raspberrypi kernel: Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
                Oct 24 11:42:53 raspberrypi kernel: OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                Oct 24 11:42:53 raspberrypi kernel: Zone ranges:
                Oct 24 11:42:53 raspberrypi kernel:   DMA      [mem 0x0000000000000000-0x000000002fffffff]
                Oct 24 11:42:53 raspberrypi kernel:   Normal   empty
                Oct 24 11:42:53 raspberrypi kernel:   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
                Oct 24 11:42:53 raspberrypi kernel: Movable zone start for each node
                Oct 24 11:42:53 raspberrypi kernel: Early memory node ranges
                Oct 24 11:42:53 raspberrypi kernel:   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
                Oct 24 11:42:53 raspberrypi kernel:   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
                Oct 24 11:42:53 raspberrypi kernel: Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
                Oct 24 11:42:53 raspberrypi kernel: On node 0 totalpages: 1012480
                Oct 24 11:42:53 raspberrypi kernel:   DMA zone: 1728 pages used for memmap
                Oct 24 11:42:53 raspberrypi kernel:   DMA zone: 0 pages reserved
                Oct 24 11:42:53 raspberrypi kernel:   DMA zone: 196608 pages, LIFO batch:63
                Oct 24 11:42:53 raspberrypi kernel:   HighMem zone: 815872 pages, LIFO batch:63
                Oct 24 11:42:53 raspberrypi kernel: percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
                Oct 24 11:42:53 raspberrypi kernel: pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
                Oct 24 11:42:53 raspberrypi kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                Oct 24 11:42:53 raspberrypi kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1010752
                Oct 24 11:42:53 raspberrypi kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:46:FB:BC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff0000
                Oct 24 11:42:53 raspberrypi kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
                Oct 24 11:42:53 raspberrypi kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
                Oct 24 11:42:53 raspberrypi kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
                Oct 24 11:42:53 raspberrypi kernel: software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
                Oct 24 11:42:53 raspberrypi kernel: Memory: 3600108K/4049920K available (10240K kernel code, 1364K rwdata, 3192K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3263488K highmem)
                Oct 24 11:42:53 raspberrypi kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                Oct 24 11:42:53 raspberrypi kernel: ftrace: allocating 34315 entries in 68 pages
                Oct 24 11:42:53 raspberrypi kernel: ftrace: allocated 68 pages with 2 groups
                Oct 24 11:42:53 raspberrypi kernel: rcu: Hierarchical RCU implementation.
                Oct 24 11:42:53 raspberrypi kernel:         Rude variant of Tasks RCU enabled.
                Oct 24 11:42:53 raspberrypi kernel:         Tracing variant of Tasks RCU enabled.
                Oct 24 11:42:53 raspberrypi kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
                Oct 24 11:42:53 raspberrypi kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                Oct 24 11:42:53 raspberrypi kernel: GIC: Using split EOI/Deactivate mode
                Oct 24 11:42:53 raspberrypi kernel: random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
                Oct 24 11:42:53 raspberrypi kernel: sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
                Oct 24 11:42:53 raspberrypi kernel: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
                Oct 24 11:42:53 raspberrypi kernel: bcm2835: system timer (irq = 25)
                Oct 24 11:42:53 raspberrypi kernel: arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                Oct 24 11:42:53 raspberrypi kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                Oct 24 11:42:53 raspberrypi kernel: sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                Oct 24 11:42:53 raspberrypi kernel: Switching to timer-based delay loop, resolution 18ns
                Oct 24 11:42:53 raspberrypi kernel: Console: colour dummy device 80x30
                Oct 24 11:42:53 raspberrypi kernel: printk: console [tty1] enabled
                Oct 24 11:42:53 raspberrypi kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
                Oct 24 11:42:53 raspberrypi kernel: pid_max: default: 32768 minimum: 301
                Oct 24 11:42:53 raspberrypi kernel: LSM: Security Framework initializing
                Oct 24 11:42:53 raspberrypi kernel: Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                Oct 24 11:42:53 raspberrypi kernel: Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
                Oct 24 11:42:53 raspberrypi kernel: cgroup: Disabling memory control group subsystem
                Oct 24 11:42:53 raspberrypi kernel: CPU: Testing write buffer coherency: ok
                Oct 24 11:42:53 raspberrypi kernel: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                das ist übrigens nur Seite 1 von 62... benötigst du alle?
                Thomas Braun E 2 Replies Last reply Reply Quote 0
                  benötigst du alle?
                  Nicht alle. Aber deutlich mehr als die paar Zeilen jetzt.
                    erazor86 @erazor86 last edited by erazor86
                    @Thomas-Braun okay sorry habe jetzt allerdings etwa sProbelme mit der Zeichnebegrenzung....
                    pi@raspberrypi:/opt/iobroker $ journalctl --since "2023-10-23" --until "60 minutes ago"
                    -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 13:41:31 CEST. --
                    Oct 24 11:42:53 raspberrypi kernel: Setting up static identity map for 0x200000 - 0x20003c
                    Oct 24 11:42:53 raspberrypi kernel: rcu: Hierarchical SRCU implementation.
                    Oct 24 11:42:53 raspberrypi kernel: smp: Bringing up secondary CPUs ...
                    Oct 24 11:42:53 raspberrypi kernel: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                    Oct 24 11:42:53 raspberrypi kernel: CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                    Oct 24 11:42:53 raspberrypi kernel: CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                    Oct 24 11:42:53 raspberrypi kernel: smp: Brought up 1 node, 4 CPUs
                    Oct 24 11:42:53 raspberrypi kernel: SMP: Total of 4 processors activated (432.00 BogoMIPS).
                    Oct 24 11:42:53 raspberrypi kernel: CPU: All CPU(s) started in HYP mode.
                    Oct 24 11:42:53 raspberrypi kernel: CPU: Virtualization extensions available.
                    Oct 24 11:42:53 raspberrypi kernel: devtmpfs: initialized
                    Oct 24 11:42:53 raspberrypi kernel: VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
                    Oct 24 11:42:53 raspberrypi kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                    Oct 24 11:42:53 raspberrypi kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: pinctrl core: initialized pinctrl subsystem
                    Oct 24 11:42:53 raspberrypi kernel: NET: Registered protocol family 16
                    Oct 24 11:42:53 raspberrypi kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
                    Oct 24 11:42:53 raspberrypi kernel: audit: initializing netlink subsys (disabled)
                    Oct 24 11:42:53 raspberrypi kernel: audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
                    Oct 24 11:42:53 raspberrypi kernel: thermal_sys: Registered thermal governor 'step_wise'
                    Oct 24 11:42:53 raspberrypi kernel: hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
                    Oct 24 11:42:53 raspberrypi kernel: hw-breakpoint: maximum watchpoint size is 8 bytes.
                    Oct 24 11:42:53 raspberrypi kernel: Serial: AMBA PL011 UART driver
                    Oct 24 11:42:53 raspberrypi kernel: bcm2835-mbox fe00b880.mailbox: mailbox enabled
                    Oct 24 11:42:53 raspberrypi kernel: raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
                    Oct 24 11:42:53 raspberrypi kernel: raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
                    Oct 24 11:42:53 raspberrypi kernel: Kprobes globally optimized
                    Oct 24 11:42:53 raspberrypi kernel: bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
                    Oct 24 11:42:53 raspberrypi kernel: vgaarb: loaded
                    Oct 24 11:42:53 raspberrypi kernel: SCSI subsystem initialized
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver usbfs
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver hub
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new device driver usb
                    Oct 24 11:42:53 raspberrypi kernel: usb_phy_generic phy: supply vcc not found, using dummy regulator
                    Oct 24 11:42:53 raspberrypi kernel: clocksource: Switched to clocksource arch_sys_counter
                    Oct 24 11:42:53 raspberrypi kernel: VFS: Disk quotas dquot_6.6.0
                    Oct 24 11:42:53 raspberrypi kernel: VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                    Oct 24 11:42:53 raspberrypi kernel: FS-Cache: Loaded
                    Oct 24 11:42:53 raspberrypi kernel: CacheFiles: Loaded
                    Oct 24 11:42:53 raspberrypi kernel: NET: Registered protocol family 2
                    Oct 24 11:42:53 raspberrypi kernel: IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: TCP: Hash tables configured (established 8192 bind 8192)
                    Oct 24 11:42:53 raspberrypi kernel: UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
                    Oct 24 11:42:53 raspberrypi kernel: RPC: Registered named UNIX socket transport module.
                    Oct 24 11:42:53 raspberrypi kernel: RPC: Registered udp transport module.
                    Oct 24 11:42:53 raspberrypi kernel: RPC: Registered tcp transport module.
                    Oct 24 11:42:53 raspberrypi kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
                    Oct 24 11:42:53 raspberrypi kernel: PCI: CLS 0 bytes, default 64
                    Oct 24 11:42:53 raspberrypi kernel: Initialise system trusted keyrings
                    Oct 24 11:42:53 raspberrypi kernel: workingset: timestamp_bits=14 max_order=20 bucket_order=6
                    Oct 24 11:42:53 raspberrypi kernel: zbud: loaded
                    Oct 24 11:42:53 raspberrypi kernel: FS-Cache: Netfs 'nfs' registered for caching
                    Oct 24 11:42:53 raspberrypi kernel: NFS: Registering the id_resolver key type
                    Oct 24 11:42:53 raspberrypi kernel: Key type id_resolver registered
                    Oct 24 11:42:53 raspberrypi kernel: Key type id_legacy registered
                    Oct 24 11:42:53 raspberrypi kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                    Oct 24 11:42:53 raspberrypi kernel: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                    Oct 24 11:42:53 raspberrypi kernel: Key type asymmetric registered
                    Oct 24 11:42:53 raspberrypi kernel: Asymmetric key parser 'x509' registered
                    Oct 24 11:42:53 raspberrypi kernel: bounce: pool size: 64 pages
                    Oct 24 11:42:53 raspberrypi kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                    Oct 24 11:42:53 raspberrypi kernel: io scheduler mq-deadline registered
                    Oct 24 11:42:53 raspberrypi kernel: io scheduler kyber registered
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
                    Oct 24 11:42:53 raspberrypi kernel: brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
                    Oct 24 11:42:53 raspberrypi kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
                    Oct 24 11:42:53 raspberrypi kernel: pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:00:00.0: PME# supported from D0 D3hot
                    Oct 24 11:42:53 raspberrypi kernel: PCI: bus0: Fast back to back transfers disabled
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:01:00.0: PME# supported from D0 D3cold
                    Oct 24 11:42:53 raspberrypi kernel: PCI: bus1: Fast back to back transfers disabled
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:00:00.0: PCI bridge to [bus 01]
                    Oct 24 11:42:53 raspberrypi kernel: pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
                    Oct 24 11:42:53 raspberrypi kernel: pcieport 0000:00:00.0: enabling device (0140 -> 0142)
                    Oct 24 11:42:53 raspberrypi kernel: pcieport 0000:00:00.0: PME: Signaling with IRQ 62
                    Oct 24 11:42:53 raspberrypi kernel: iproc-rng200 fe104000.rng: hwrng registered
                    Oct 24 11:42:53 raspberrypi kernel: vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
                    Oct 24 11:42:53 raspberrypi kernel: gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
                    Oct 24 11:42:53 raspberrypi kernel: brd: module loaded
                    Oct 24 11:42:53 raspberrypi kernel: loop: module loaded
                    Oct 24 11:42:53 raspberrypi kernel: Loading iSCSI transport class v2.0-870.
                    Oct 24 11:42:53 raspberrypi kernel: libphy: Fixed MDIO Bus: probed
                    Oct 24 11:42:53 raspberrypi kernel: bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
                    Oct 24 11:42:53 raspberrypi kernel: libphy: bcmgenet MII bus: probed
                    Oct 24 11:42:53 raspberrypi kernel: unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver r8152
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver lan78xx
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver smsc95xx
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: xHCI Host Controller
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
                    Oct 24 11:42:53 raspberrypi kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
                    Oct 24 11:42:53 raspberrypi kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                    Oct 24 11:42:53 raspberrypi kernel: usb usb1: Product: xHCI Host Controller
                    Oct 24 11:42:53 raspberrypi kernel: usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
                    Oct 24 11:42:53 raspberrypi kernel: usb usb1: SerialNumber: 0000:01:00.0
                    Oct 24 11:42:53 raspberrypi kernel: hub 1-0:1.0: USB hub found
                    Oct 24 11:42:53 raspberrypi kernel: hub 1-0:1.0: 1 port detected
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
                    Oct 24 11:42:53 raspberrypi kernel: xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
                    Oct 24 11:42:53 raspberrypi kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
                    Oct 24 11:42:53 raspberrypi kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                    Oct 24 11:42:53 raspberrypi kernel: usb usb2: Product: xHCI Host Controller
                    Oct 24 11:42:53 raspberrypi kernel: usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
                    Oct 24 11:42:53 raspberrypi kernel: usb usb2: SerialNumber: 0000:01:00.0
                    Oct 24 11:42:53 raspberrypi kernel: hub 2-0:1.0: USB hub found
                    Oct 24 11:42:53 raspberrypi kernel: hub 2-0:1.0: 4 ports detected
                    Oct 24 11:42:53 raspberrypi kernel: dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                    Oct 24 11:42:53 raspberrypi kernel: dwc_otg: FIQ enabled
                    Oct 24 11:42:53 raspberrypi kernel: dwc_otg: NAK holdoff enabled
                    Oct 24 11:42:53 raspberrypi kernel: dwc_otg: FIQ split-transaction FSM enabled
                    Oct 24 11:42:53 raspberrypi kernel: Module dwc_common_port init
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver uas
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver usb-storage
                    Oct 24 11:42:53 raspberrypi kernel: mousedev: PS/2 mouse device common for all mice
                    Oct 24 11:42:53 raspberrypi kernel: bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                    Oct 24 11:42:53 raspberrypi kernel: sdhci: Secure Digital Host Controller Interface driver
                    Oct 24 11:42:53 raspberrypi kernel: sdhci: Copyright(c) Pierre Ossman
                    Oct 24 11:42:53 raspberrypi kernel: mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
                    Oct 24 11:42:53 raspberrypi kernel: sdhci-pltfm: SDHCI platform and OF driver helper
                    Oct 24 11:42:53 raspberrypi kernel: ledtrig-cpu: registered to indicate activity on CPUs
                    Oct 24 11:42:53 raspberrypi kernel: hid: raw HID events driver (C) Jiri Kosina
                    Oct 24 11:42:53 raspberrypi kernel: usbcore: registered new interface driver usbhid
                    Oct 24 11:42:53 raspberrypi kernel: usbhid: USB HID core driver
                    Oct 24 11:42:53 raspberrypi kernel: Initializing XFRM netlink socket
                    Oct 24 11:42:53 raspberrypi kernel: NET: Registered protocol family 17
                    Oct 24 11:42:53 raspberrypi kernel: Key type dns_resolver registered
                    Oct 24 11:42:53 raspberrypi kernel: Registering SWP/SWPB emulation handler
                    Oct 24 11:42:53 raspberrypi kernel: registered taskstats version 1
                    Oct 24 11:42:53 raspberrypi kernel: Loading compiled-in X.509 certificates
                    Oct 24 11:42:53 raspberrypi kernel: Key type ._fscrypt registered
                    Oct 24 11:42:53 raspberrypi kernel: Key type .fscrypt registered
                    Oct 24 11:42:53 raspberrypi kernel: Key type fscrypt-provisioning registered
                    Oct 24 11:42:53 raspberrypi kernel: uart-pl011 fe201000.serial: there is not valid maps for state default
                    Oct 24 11:42:53 raspberrypi kernel: uart-pl011 fe201000.serial: cts_event_workaround enabled
                    Oct 24 11:42:53 raspberrypi kernel: fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
                    Oct 24 11:42:53 raspberrypi kernel: bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                    Oct 24 11:42:53 raspberrypi kernel: mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
                    Oct 24 11:42:53 raspberrypi kernel: mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
                    Oct 24 11:42:53 raspberrypi kernel: of_cfs_init
                    Oct 24 11:42:53 raspberrypi kernel: of_cfs_init: OK
                    Oct 24 11:42:53 raspberrypi kernel: mmc1: Controller never released inhibit bit(s).
                    Oct 24 11:42:53 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                    Oct 24 11:42:53 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                    Oct 24 11:42:53 raspberrypi kernel: mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                    Oct 24 11:42:53 raspberrypi kernel: mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
                    Oct 24 11:42:53 raspberrypi kernel: Waiting for root device PARTUUID=7a2feeee-02...
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
                    Oct 24 11:42:53 raspberrypi kernel: mmc1: new high speed SDIO card at address 0001
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: New USB device found, idVendor=14b0, idProduct=0206, bcdDevice= 1.00
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: Product: Force LS SSD
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: Manufacturer: Corsair
                    Oct 24 11:42:53 raspberrypi kernel: usb 2-1: SerialNumber: 1234567815F4
                    Oct 24 11:42:53 raspberrypi kernel: scsi host0: uas
                    Oct 24 11:42:53 raspberrypi kernel: scsi 0:0:0:0: Direct-Access     Corsair  Force LS SSD     0    PQ: 0 ANSI: 6
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] Write Protect is off
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
                    Oct 24 11:42:53 raspberrypi kernel:  sda: sda1 sda2
                    Oct 24 11:42:53 raspberrypi kernel: sd 0:0:0:0: [sda] Attached SCSI disk
                    Oct 24 11:42:53 raspberrypi kernel: EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                    Oct 24 11:42:53 raspberrypi kernel: VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    Oct 24 11:42:53 raspberrypi kernel: devtmpfs: mounted
                    Oct 24 11:42:53 raspberrypi kernel: Freeing unused kernel memory: 2048K
                    Oct 24 11:42:53 raspberrypi kernel: Run /sbin/init as init process
                    lines 63-124
                    -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 13:43:36 CEST. --
                    lines 125-186
                    -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 13:44:11 CEST. --
                    lines 187-248
                    wie dem Log zu entnehmen ist, ist die Festplatte 60gb groß und das Image nur ca. 30... Mein Ansatz wäre jetzt zu versuchen das Image zu erweitern.. oder ist das nicht ohne weiteres möglich?
                      A Former User @erazor86 last edited by A Former User
                      Moin,
                      Du kannst das auf errors eingrenzen
                      # sudo journalctl -g `error`
                      Edit
                      Du kannst erst einmal das journal eindampfen, denn ich denke, die Fehler helfen Dir jetzt auch nicht mehr, ich gehe davon aus, dass das Logfile Rotating irgendwann nicht mehr ging und deswegen das journal weiter angewachsen ist.
                      Eindampfen, geht mit
                      # sudo journalctl --flush --rotate --vacuum-time=144h
                      danke für den Hinweis, doch der Befehl funktionierte nicht...
                      Da fehlt ein sudo davor, wenn Du das als User machst, siehst Du nur Deinen Kram.
                      Edit_2
                      Auch das kern.log kann nicht mehr rotieren, da es auch schon zu groß ist und nicht mehr ins Memory passt.
                      Um da auch wieder Luft zu bekommen, folgendes
                      **feststellen wer gerade darauf zugreift***
                      # sudo lsof /var/log/kern.log
                      _z. B._
                      COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF     NODE NAME
                      rsyslogd 1503     root   12w   REG  253,1    33738 50334529 /var/log/kern.log
                      promtail 2879 promtail   25r   REG  253,1    33738 50334529 /var/log/kern.log
                      Dann müssen die Programme gestoppt werden, promtail sollte bei Dir nicht auftauchen, das ist etwas Spezielles, das ich hier am Laufen habe!
                      # sudo systemctl status rsyslog.service
                      ● rsyslog.service - System Logging Service
                           Loaded: loaded (/lib/systemd/system/rsyslog.service; enabled; preset: enabled)
                           Active: active (running) since Sat 2023-10-07 12:55:30 CEST; 2 weeks 3 days ago
                      TriggeredBy: ● syslog.socket
                             Docs: man:rsyslogd(8)
                                   man:rsyslog.conf(5)
                                   https://www.rsyslog.com/doc/
                         Main PID: 1503 (rsyslogd)
                            Tasks: 4 (limit: 38343)
                           Memory: 3.6M
                              CPU: 4.301s
                           CGroup: /system.slice/rsyslog.service
                                   └─1503 /usr/sbin/rsyslogd -n -iNONE
                      Oct 07 12:55:30 pve systemd[1]: Starting rsyslog.service - System Logging Service...
                      Oct 07 12:55:30 pve rsyslogd[1503]: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.2302.0]
                      Oct 07 12:55:30 pve systemd[1]: Started rsyslog.service - System Logging Service.
                      Oct 07 12:55:30 pve rsyslogd[1503]: [origin software="rsyslogd" swVersion="8.2302.0" x-pid="1503" x-info="https://www.rsyslog.com"] start
                      Oct 08 00:00:05 pve systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 1503 (rsyslogd) on client request.
                      Oct 08 00:00:05 pve rsyslogd[1503]: [origin software="rsyslogd" swVersion="8.2302.0" x-pid="1503" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                      Oct 15 00:00:04 pve systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 1503 (rsyslogd) on client request.
                      Oct 15 00:00:04 pve rsyslogd[1503]: [origin software="rsyslogd" swVersion="8.2302.0" x-pid="1503" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                      Oct 22 00:00:05 pve systemd[1]: rsyslog.service: Sent signal SIGHUP to main process 1503 (rsyslogd) on client request.
                      Oct 22 00:00:05 pve rsyslogd[1503]: [origin software="rsyslogd" swVersion="8.2302.0" x-pid="1503" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
                      ** Anschließend Stoppen**
                      # sudo systemctl stop rsyslog.service
                      Wenn, dann beim check, dass niemand mehr zugreift, dann
                      # sudo > /var/log/kern.log
                      **Check**
                      # sudo ls -la /var/log/kern.log*
                      Dann den rsyslog wieder starten
                      # sudo systemctl start rsyslog.service
                      VG
                      Bernd
                        erazor86 @Guest last edited by
                        @dp20eic danke für den Hinweis, doch der Befehl funktionierte nicht...
                        ich habe nun folgende Eingrenzung.. hoffe das ist auch okay?
                        pi@raspberrypi:/opt/iobroker $ journalctl -p err -b
                        -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 14:38:22 CEST. --
                        Oct 24 11:42:54 raspberrypi kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                        Oct 24 11:42:54 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                        Oct 24 11:42:57 raspberrypi kernel: brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                        Oct 24 11:43:03 raspberrypi bluetoothd[630]: Sap driver initialization failed.
                        Oct 24 11:43:03 raspberrypi bluetoothd[630]: sap-server: Operation not permitted (1)
                        Oct 24 11:43:03 raspberrypi bluetoothd[630]: Failed to set privacy: Rejected (0x0b)
                          @dp20eic said in Iobroker nicht mehr erreichbar / Festplatte voll?:
                          mit sudo davor kam folgendes:
                          pi@raspberrypi:/opt/iobroker $ sudo journalctl -p err -b
                          -- Logs begin at Tue 2023-10-24 11:42:53 CEST, end at Tue 2023-10-24 14:49:10 CEST. --
                          dann das journal eindampfen ergab folgendes:
                          pi@raspberrypi:~ $ sudo journalctl --flush --rotate --vacuum-time=144h
                          Vacuuming done, freed 0B of archived journals from /run/log/journal/4d6ae5397255480d87f8210555383486.
                          pi@raspberrypi:~ $
                          Thomas Braun ? 3 Replies Last reply Reply Quote 0
                            @erazor86
                            Ich würde die Kiste ohnehin nochmal von Grund auf mit Debian 12 'Bookworm' in der 64Bit-Variante neuinstallieren. Das syslog wie auch das kernel.log werden da gar nicht mehr verwendet, das läuft mittlerweile exklusiv über journalctl/systemd.
                              Moin,
                              dann setz mal die Stunden auf 1h
                              # sudo journalctl --flush --rotate --vacuum-time=1h
                              **und**
                              # sudo ls -la /var/log/journal/
                              VG
                              Bernd
                              P.S.: habe oben falsch gelesen, mich nur auf journalctl konzentriert, syslog geht definitiv anders, sollte man auch wie beim kern.log machen.
                                Thomas Braun Most Active @erazor86 last edited by Thomas Braun
                                @erazor86
                                tail -200 /var/log/syslog
                                sagt?
                                  @thomas-braun @dp20eic
                                  puh das waren jetzt einige Dinge auf einmal die ich da ausprobieren sollte... Also das system neu aufsetzen würde ich gerne vermeiden bzw. parallel mit einem zweiten Raspi machen. Habe noch einen mit 8gb am start. Aber erstmal würde ich den gerne wieder ans laufen bringen.
                                  hier mal ein paar Auszüge:
                                  pi@raspberrypi:/opt/iobroker $ sudo journalctl --flush --rotate --vacuum-time=1h
                                  Deleted archived journal /run/log/journal/4d6ae5397255480d87f8210555383486/system@4eb1d35fbf904cfe9b555db2060dd955-0000000000000001-0006087329a39cee.journal (23.9M).
                                  Vacuuming done, freed 23.9M of archived journals from /run/log/journal/4d6ae5397255480d87f8210555383486.
                                  pi@raspberrypi:/opt/iobroker $ sudo lsof/var/log/kern.log
                                  sudo: lsof/var/log/kern.log: command not found
                                  pi@raspberrypi:/opt/iobroker $ tail -n 200 /var/log/syslog
                                  Oct 24 15:11:32 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:11:32 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:11:34 raspberrypi bash[28083]: ENOSPC: no space left on device, write
                                  Oct 24 15:11:34 raspberrypi bash[28083]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:11:35 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:11:35 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:11:38 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:11:38 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2158.
                                  Oct 24 15:11:38 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:11:38 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:11:40 raspberrypi bash[28095]: ENOSPC: no space left on device, write
                                  Oct 24 15:11:40 raspberrypi bash[28095]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:11:41 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:11:41 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:11:44 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:11:44 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2159.
                                  Oct 24 15:11:44 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:11:44 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:11:45 raspberrypi bash[28107]: ENOSPC: no space left on device, write
                                  Oct 24 15:11:45 raspberrypi bash[28107]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:11:46 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:11:46 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:11:50 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:11:50 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2160.
                                  Oct 24 15:11:50 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:11:50 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:11:51 raspberrypi bash[28119]: ENOSPC: no space left on device, write
                                  Oct 24 15:11:51 raspberrypi bash[28119]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:11:52 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:11:52 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:11:55 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:11:55 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2161.
                                  Oct 24 15:11:55 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:11:55 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:11:57 raspberrypi bash[28131]: ENOSPC: no space left on device, write
                                  Oct 24 15:11:57 raspberrypi bash[28131]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:11:58 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:11:58 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:01 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:01 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2162.
                                  Oct 24 15:12:01 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:01 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:03 raspberrypi bash[28143]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:03 raspberrypi bash[28143]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:04 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:04 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:07 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:07 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2163.
                                  Oct 24 15:12:07 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:07 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:09 raspberrypi bash[28155]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:09 raspberrypi bash[28155]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:10 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:10 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:13 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:13 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2164.
                                  Oct 24 15:12:13 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:13 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:14 raspberrypi bash[28167]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:14 raspberrypi bash[28167]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:15 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:15 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:18 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:18 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2165.
                                  Oct 24 15:12:18 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:18 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:20 raspberrypi bash[28179]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:20 raspberrypi bash[28179]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:21 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:21 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:23 raspberrypi dhcpcd[595]: eth0: Router Advertisement from fe80::cece:1eff:fe79:6d19
                                  Oct 24 15:12:24 raspberrypi dhcpcd[595]: eth0: Router Advertisement from fe80::cece:1eff:fe79:6d19
                                  Oct 24 15:12:24 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:24 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2166.
                                  Oct 24 15:12:24 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:24 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:26 raspberrypi bash[28220]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:26 raspberrypi bash[28220]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:27 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:27 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:30 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:30 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2167.
                                  Oct 24 15:12:30 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:30 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:32 raspberrypi bash[28251]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:32 raspberrypi bash[28251]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:33 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:33 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:36 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:36 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2168.
                                  Oct 24 15:12:36 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:36 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:37 raspberrypi bash[28263]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:38 raspberrypi bash[28263]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:39 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:39 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:42 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:42 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2169.
                                  Oct 24 15:12:42 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:42 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:43 raspberrypi bash[28275]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:43 raspberrypi bash[28275]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:44 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:44 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:47 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:47 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2170.
                                  Oct 24 15:12:47 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:47 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:49 raspberrypi bash[28287]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:49 raspberrypi bash[28287]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:50 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:50 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:53 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:53 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2171.
                                  Oct 24 15:12:53 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:53 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:12:55 raspberrypi bash[28299]: ENOSPC: no space left on device, write
                                  Oct 24 15:12:55 raspberrypi bash[28299]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:12:56 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:12:56 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:12:59 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:12:59 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2172.
                                  Oct 24 15:12:59 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:12:59 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:00 raspberrypi bash[28311]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:00 raspberrypi bash[28311]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:02 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:02 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:05 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:05 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2173.
                                  Oct 24 15:13:05 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:05 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:06 raspberrypi bash[28323]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:06 raspberrypi bash[28323]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:07 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:07 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:10 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:10 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2174.
                                  Oct 24 15:13:10 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:10 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:12 raspberrypi bash[28335]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:12 raspberrypi bash[28335]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:13 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:13 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:16 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:16 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2175.
                                  Oct 24 15:13:16 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:16 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:18 raspberrypi bash[28347]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:18 raspberrypi bash[28347]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:19 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:19 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:22 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:22 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2176.
                                  Oct 24 15:13:22 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:22 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:24 raspberrypi bash[28359]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:24 raspberrypi bash[28359]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:25 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:25 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:28 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:28 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2177.
                                  Oct 24 15:13:28 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:28 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:30 raspberrypi bash[28371]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:30 raspberrypi bash[28371]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:31 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:31 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:34 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:34 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2178.
                                  Oct 24 15:13:34 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:34 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:35 raspberrypi bash[28383]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:35 raspberrypi bash[28383]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:37 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:37 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:40 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:40 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2179.
                                  Oct 24 15:13:40 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:40 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:41 raspberrypi bash[28395]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:41 raspberrypi bash[28395]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:42 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:42 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:45 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:45 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2180.
                                  Oct 24 15:13:45 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:45 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:47 raspberrypi bash[28407]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:47 raspberrypi bash[28407]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:48 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:48 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  Oct 24 15:13:51 raspberrypi systemd[1]: iobroker.service: Service RestartSec=3s expired, scheduling restart.
                                  Oct 24 15:13:51 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 2181.
                                  Oct 24 15:13:51 raspberrypi systemd[1]: Stopped ioBroker Server.
                                  Oct 24 15:13:51 raspberrypi systemd[1]: Started ioBroker Server.
                                  Oct 24 15:13:53 raspberrypi bash[28419]: ENOSPC: no space left on device, write
                                  Oct 24 15:13:53 raspberrypi bash[28419]: Error: ENOSPC: no space left on device, write
                                  Oct 24 15:13:54 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                                  Oct 24 15:13:54 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                  edit: Also durch die Bereinigung sieht es zwischenzeitlich wie folgt aus:
                                  pi@raspberrypi:/opt/iobroker $ ncdu
                                  --- /opt/iobroker ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
                                      1.4 GiB [##########] /iobroker-data
                                    741.8 MiB [#####     ] /backups
                                    724.7 MiB [#####     ] /node_modules
                                    672.0 KiB [          ]  package-lock.json
                                    320.0 KiB [          ] /log
                                      8.0 KiB [          ]  reinstall.js
                                      4.0 KiB [          ]  package.json
                                      4.0 KiB [          ]  iobroker
                                      4.0 KiB [          ]  INSTALLER_INFO.txt
                                      4.0 KiB [          ]  .npmrc
                                  @   0.0   B [          ]  iob
                                      0.0   B [          ]  sudo journalctl -g
                                      0.0   B [          ]  since=yesterday
                                      0.0   B [          ]  pberrypi kernel: Booting Linux on physical CPU 0x0
                                      0.0   B [          ]  # sudo journalctl -g `error`
                                  aber IoBroker startet halt noch nicht 😧
                                    Du stehst im falschen Verzeichnis...
                                      @erazor86
                                      df -h
                                      sagt? Wieder Platz zum tanzen vorhanden?
                                      iob restart
                                      und dann nach ein paar Minuten
                                      iob diag
                                        @thomas-braun said in Iobroker nicht mehr erreichbar / Festplatte voll?:
                                        df -h
                                        ok zu früh gefreut:
                                        pi@raspberrypi:/opt/iobroker $ df -h
                                        Filesystem      Size  Used Avail Use% Mounted on
                                        /dev/root        29G   28G     0 100% /
                                        devtmpfs        1.8G     0  1.8G   0% /dev
                                        tmpfs           1.9G     0  1.9G   0% /dev/shm
                                        tmpfs           1.9G   25M  1.9G   2% /run
                                        tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                        tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
                                        /dev/sda1       253M   49M  204M  20% /boot
                                        tmpfs           384M     0  384M   0% /run/user/1000
                                        pi@raspberrypi:/opt/iobroker $ iob restart
                                        pi@raspberrypi:/opt/iobroker $ iob diag
                                          @erazor86
                                          sudo tail -200 /var/log/kern.log
                                            Moin,
                                            da fehlt ein Leerzeichen!
                                            Kopieren nicht Abschreiben 😉
                                            VG
                                            Bernd
                                            4270
