    4. Iobroker nicht mehr erreichbar / Festplatte voll?
      erazor86 @Thomas Braun last edited by
      @thomas-braun said in Iobroker nicht mehr erreichbar / Festplatte voll?:
      df -h
      ok zu früh gefreut:
      pi@raspberrypi:/opt/iobroker $ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      /dev/root        29G   28G     0 100% /
      devtmpfs        1.8G     0  1.8G   0% /dev
      tmpfs           1.9G     0  1.9G   0% /dev/shm
      tmpfs           1.9G   25M  1.9G   2% /run
      tmpfs           5.0M  4.0K  5.0M   1% /run/lock
      tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/sda1       253M   49M  204M  20% /boot
      tmpfs           384M     0  384M   0% /run/user/1000
      pi@raspberrypi:/opt/iobroker $ iob restart
      pi@raspberrypi:/opt/iobroker $ iob diag
        Thomas Braun Most Active @erazor86 last edited by
        @erazor86
        sudo tail -200 /var/log/kern.log
          A Former User @erazor86 last edited by
          @erazor86 sagte in Iobroker nicht mehr erreichbar / Festplatte voll?:
          sudo lsof/var/log/kern.log
          Moin,
          da fehlt ein Leerzeichen!
          # sudo lsof /var/log/kern.log
          Kopieren nicht Abschreiben 😉
          VG
          Bernd
            erazor86 @Guest last edited by
            @dp20eic said in Iobroker nicht mehr erreichbar / Festplatte voll?:
            ich hatte beides probiert.. kommt leider bei beidem die gleiche Meldung
            pi@raspberrypi:/opt/iobroker $ sudo lsof /var/log/kern.log
            sudo: lsof: command not found
              pi@raspberrypi:/opt/iobroker $ sudo tail -200 /var/log/kern.log
              Oct 24 11:42:56 raspberrypi kernel: [    1.207680] pci_bus 0000:00: root bus resource [bus 00-ff]
              Oct 24 11:42:56 raspberrypi kernel: [    1.207715] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
              Oct 24 11:42:56 raspberrypi kernel: [    1.207828] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
              Oct 24 11:42:56 raspberrypi kernel: [    1.208085] pci 0000:00:00.0: PME# supported from D0 D3hot
              Oct 24 11:42:56 raspberrypi kernel: [    1.211577] PCI: bus0: Fast back to back transfers disabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.211932] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
              Oct 24 11:42:56 raspberrypi kernel: [    1.212076] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
              Oct 24 11:42:56 raspberrypi kernel: [    1.212527] pci 0000:01:00.0: PME# supported from D0 D3cold
              Oct 24 11:42:56 raspberrypi kernel: [    1.216022] PCI: bus1: Fast back to back transfers disabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.216138] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
              Oct 24 11:42:56 raspberrypi kernel: [    1.216179] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
              Oct 24 11:42:56 raspberrypi kernel: [    1.216283] pci 0000:00:00.0: PCI bridge to [bus 01]
              Oct 24 11:42:56 raspberrypi kernel: [    1.216322] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
              Oct 24 11:42:56 raspberrypi kernel: [    1.216744] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
              Oct 24 11:42:56 raspberrypi kernel: [    1.216992] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
              Oct 24 11:42:56 raspberrypi kernel: [    1.225698] iproc-rng200 fe104000.rng: hwrng registered
              Oct 24 11:42:56 raspberrypi kernel: [    1.226026] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
              Oct 24 11:42:56 raspberrypi kernel: [    1.226913] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
              Oct 24 11:42:56 raspberrypi kernel: [    1.239215] brd: module loaded
              Oct 24 11:42:56 raspberrypi kernel: [    1.251549] loop: module loaded
              Oct 24 11:42:56 raspberrypi kernel: [    1.253319] Loading iSCSI transport class v2.0-870.
              Oct 24 11:42:56 raspberrypi kernel: [    1.256654] libphy: Fixed MDIO Bus: probed
              Oct 24 11:42:56 raspberrypi kernel: [    1.258364] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
              Oct 24 11:42:56 raspberrypi kernel: [    1.275207] libphy: bcmgenet MII bus: probed
              Oct 24 11:42:56 raspberrypi kernel: [    1.355325] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
              Oct 24 11:42:56 raspberrypi kernel: [    1.356517] usbcore: registered new interface driver r8152
              Oct 24 11:42:56 raspberrypi kernel: [    1.356604] usbcore: registered new interface driver lan78xx
              Oct 24 11:42:56 raspberrypi kernel: [    1.356697] usbcore: registered new interface driver smsc95xx
              Oct 24 11:42:56 raspberrypi kernel: [    1.358350] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
              Oct 24 11:42:56 raspberrypi kernel: [    1.358531] xhci_hcd 0000:01:00.0: xHCI Host Controller
              Oct 24 11:42:56 raspberrypi kernel: [    1.358580] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
              Oct 24 11:42:56 raspberrypi kernel: [    1.361973] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
              Oct 24 11:42:56 raspberrypi kernel: [    1.363334] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
              Oct 24 11:42:56 raspberrypi kernel: [    1.363376] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              Oct 24 11:42:56 raspberrypi kernel: [    1.363412] usb usb1: Product: xHCI Host Controller
              Oct 24 11:42:56 raspberrypi kernel: [    1.363442] usb usb1: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
              Oct 24 11:42:56 raspberrypi kernel: [    1.363473] usb usb1: SerialNumber: 0000:01:00.0
              Oct 24 11:42:56 raspberrypi kernel: [    1.364208] hub 1-0:1.0: USB hub found
              Oct 24 11:42:56 raspberrypi kernel: [    1.364323] hub 1-0:1.0: 1 port detected
              Oct 24 11:42:56 raspberrypi kernel: [    1.365005] xhci_hcd 0000:01:00.0: xHCI Host Controller
              Oct 24 11:42:56 raspberrypi kernel: [    1.365048] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
              Oct 24 11:42:56 raspberrypi kernel: [    1.365093] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
              Oct 24 11:42:56 raspberrypi kernel: [    1.365700] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
              Oct 24 11:42:56 raspberrypi kernel: [    1.365740] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              Oct 24 11:42:56 raspberrypi kernel: [    1.365776] usb usb2: Product: xHCI Host Controller
              Oct 24 11:42:56 raspberrypi kernel: [    1.365805] usb usb2: Manufacturer: Linux 5.10.63-v7l+ xhci-hcd
              Oct 24 11:42:56 raspberrypi kernel: [    1.365836] usb usb2: SerialNumber: 0000:01:00.0
              Oct 24 11:42:56 raspberrypi kernel: [    1.366578] hub 2-0:1.0: USB hub found
              Oct 24 11:42:56 raspberrypi kernel: [    1.366696] hub 2-0:1.0: 4 ports detected
              Oct 24 11:42:56 raspberrypi kernel: [    1.368409] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
              Oct 24 11:42:56 raspberrypi kernel: [    1.368731] dwc_otg: FIQ enabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.368746] dwc_otg: NAK holdoff enabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.368761] dwc_otg: FIQ split-transaction FSM enabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.368778] Module dwc_common_port init
              Oct 24 11:42:56 raspberrypi kernel: [    1.369242] usbcore: registered new interface driver uas
              Oct 24 11:42:56 raspberrypi kernel: [    1.369379] usbcore: registered new interface driver usb-storage
              Oct 24 11:42:56 raspberrypi kernel: [    1.369591] mousedev: PS/2 mouse device common for all mice
              Oct 24 11:42:56 raspberrypi kernel: [    1.371242] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
              Oct 24 11:42:56 raspberrypi kernel: [    1.374643] sdhci: Secure Digital Host Controller Interface driver
              Oct 24 11:42:56 raspberrypi kernel: [    1.374677] sdhci: Copyright(c) Pierre Ossman
              Oct 24 11:42:56 raspberrypi kernel: [    1.375484] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
              Oct 24 11:42:56 raspberrypi kernel: [    1.376078] sdhci-pltfm: SDHCI platform and OF driver helper
              Oct 24 11:42:56 raspberrypi kernel: [    1.380224] ledtrig-cpu: registered to indicate activity on CPUs
              Oct 24 11:42:56 raspberrypi kernel: [    1.380573] hid: raw HID events driver (C) Jiri Kosina
              Oct 24 11:42:56 raspberrypi kernel: [    1.380808] usbcore: registered new interface driver usbhid
              Oct 24 11:42:56 raspberrypi kernel: [    1.380839] usbhid: USB HID core driver
              Oct 24 11:42:56 raspberrypi kernel: [    1.386881] Initializing XFRM netlink socket
              Oct 24 11:42:56 raspberrypi kernel: [    1.386944] NET: Registered protocol family 17
              Oct 24 11:42:56 raspberrypi kernel: [    1.387087] Key type dns_resolver registered
              Oct 24 11:42:56 raspberrypi kernel: [    1.387431] Registering SWP/SWPB emulation handler
              Oct 24 11:42:56 raspberrypi kernel: [    1.387614] registered taskstats version 1
              Oct 24 11:42:56 raspberrypi kernel: [    1.387655] Loading compiled-in X.509 certificates
              Oct 24 11:42:56 raspberrypi kernel: [    1.388527] Key type ._fscrypt registered
              Oct 24 11:42:56 raspberrypi kernel: [    1.388557] Key type .fscrypt registered
              Oct 24 11:42:56 raspberrypi kernel: [    1.388585] Key type fscrypt-provisioning registered
              Oct 24 11:42:56 raspberrypi kernel: [    1.400115] uart-pl011 fe201000.serial: there is not valid maps for state default
              Oct 24 11:42:56 raspberrypi kernel: [    1.400447] uart-pl011 fe201000.serial: cts_event_workaround enabled
              Oct 24 11:42:56 raspberrypi kernel: [    1.400538] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
              Oct 24 11:42:56 raspberrypi kernel: [    1.408608] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
              Oct 24 11:42:56 raspberrypi kernel: [    1.409715] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
              Oct 24 11:42:56 raspberrypi kernel: [    1.409749] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
              Oct 24 11:42:56 raspberrypi kernel: [    1.440004] of_cfs_init
              Oct 24 11:42:56 raspberrypi kernel: [    1.440281] of_cfs_init: OK
              Oct 24 11:42:56 raspberrypi kernel: [    1.447588] mmc1: Controller never released inhibit bit(s).
              Oct 24 11:42:56 raspberrypi kernel: [    1.471253] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
              Oct 24 11:42:56 raspberrypi kernel: [    1.472965] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Oct 24 11:42:56 raspberrypi kernel: [    1.474672] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Oct 24 11:42:56 raspberrypi kernel: [    1.478089] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
              Oct 24 11:42:56 raspberrypi kernel: [    1.479795] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              Oct 24 11:42:56 raspberrypi kernel: [    1.485253] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
              Oct 24 11:42:56 raspberrypi kernel: [    1.485904] Waiting for root device PARTUUID=7a2feeee-02...
              Oct 24 11:42:56 raspberrypi kernel: [    1.545642] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
              Oct 24 11:42:56 raspberrypi kernel: [    1.548722] mmc1: new high speed SDIO card at address 0001
              Oct 24 11:42:56 raspberrypi kernel: [    1.577032] usb 2-1: New USB device found, idVendor=14b0, idProduct=0206, bcdDevice= 1.00
              Oct 24 11:42:56 raspberrypi kernel: [    1.577074] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
              Oct 24 11:42:56 raspberrypi kernel: [    1.577108] usb 2-1: Product: Force LS SSD
              Oct 24 11:42:56 raspberrypi kernel: [    1.577137] usb 2-1: Manufacturer: Corsair
              Oct 24 11:42:56 raspberrypi kernel: [    1.577166] usb 2-1: SerialNumber: 1234567815F4
              Oct 24 11:42:56 raspberrypi kernel: [    1.603092] scsi host0: uas
              Oct 24 11:42:56 raspberrypi kernel: [    1.604627] scsi 0:0:0:0: Direct-Access     Corsair  Force LS SSD     0    PQ: 0 ANSI: 6
              Oct 24 11:42:56 raspberrypi kernel: [    1.606824] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.9 GiB)
              Oct 24 11:42:56 raspberrypi kernel: [    1.607041] sd 0:0:0:0: [sda] Write Protect is off
              Oct 24 11:42:56 raspberrypi kernel: [    1.607077] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
              Oct 24 11:42:56 raspberrypi kernel: [    1.607426] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
              Oct 24 11:42:56 raspberrypi kernel: [    1.608240] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
              Oct 24 11:42:56 raspberrypi kernel: [    1.611321]  sda: sda1 sda2
              Oct 24 11:42:56 raspberrypi kernel: [    1.614496] sd 0:0:0:0: [sda] Attached SCSI disk
              Oct 24 11:42:56 raspberrypi kernel: [    1.652086] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
              Oct 24 11:42:56 raspberrypi kernel: [    1.652185] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              Oct 24 11:42:56 raspberrypi kernel: [    1.654243] devtmpfs: mounted
              Oct 24 11:42:56 raspberrypi kernel: [    1.664143] Freeing unused kernel memory: 2048K
              Oct 24 11:42:56 raspberrypi kernel: [    1.705486] Run /sbin/init as init process
              Oct 24 11:42:56 raspberrypi kernel: [    1.705516]   with arguments:
              Oct 24 11:42:56 raspberrypi kernel: [    1.705531]     /sbin/init
              Oct 24 11:42:56 raspberrypi kernel: [    1.705545]   with environment:
              Oct 24 11:42:56 raspberrypi kernel: [    1.705560]     HOME=/
              Oct 24 11:42:56 raspberrypi kernel: [    1.705574]     TERM=linux
              Oct 24 11:42:56 raspberrypi kernel: [    1.725615] usb 1-1: new high-speed USB device number 2 using xhci_hcd
              Oct 24 11:42:56 raspberrypi kernel: [    1.907733] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
              Oct 24 11:42:56 raspberrypi kernel: [    1.907779] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
              Oct 24 11:42:56 raspberrypi kernel: [    1.907813] usb 1-1: Product: USB2.0 Hub
              Oct 24 11:42:56 raspberrypi kernel: [    1.909890] hub 1-1:1.0: USB hub found
              Oct 24 11:42:56 raspberrypi kernel: [    1.910131] hub 1-1:1.0: 4 ports detected
              Oct 24 11:42:56 raspberrypi kernel: [    1.967238] NET: Registered protocol family 10
              Oct 24 11:42:56 raspberrypi kernel: [    1.968685] Segment Routing with IPv6
              Oct 24 11:42:56 raspberrypi kernel: [    2.607403] random: systemd: uninitialized urandom read (16 bytes read)
              Oct 24 11:42:56 raspberrypi kernel: [    2.615594] random: systemd: uninitialized urandom read (16 bytes read)
              Oct 24 11:42:56 raspberrypi kernel: [    2.619523] random: systemd: uninitialized urandom read (16 bytes read)
              Oct 24 11:42:56 raspberrypi kernel: [    3.118773] EXT4-fs (sda2): re-mounted. Opts: (null)
              Oct 24 11:42:56 raspberrypi kernel: [    3.795339] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
              Oct 24 11:42:56 raspberrypi kernel: [    3.795967] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
              Oct 24 11:42:56 raspberrypi kernel: [    3.796534] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
              Oct 24 11:42:56 raspberrypi kernel: [    3.797073] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
              Oct 24 11:42:56 raspberrypi kernel: [    3.884618] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    3.888199] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    3.889781] mc: Linux media interface: v0.10
              Oct 24 11:42:56 raspberrypi kernel: [    3.903059] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
              Oct 24 11:42:56 raspberrypi kernel: [    3.903084] [vc_sm_connected_init]: start
              Oct 24 11:42:56 raspberrypi kernel: [    3.922455] [vc_sm_connected_init]: installed successfully
              Oct 24 11:42:56 raspberrypi kernel: [    3.928161] bcm2835_audio bcm2835_audio: card created with 8 channels
              Oct 24 11:42:56 raspberrypi kernel: [    3.946690] videodev: Linux video capture interface: v2.00
              Oct 24 11:42:56 raspberrypi kernel: [    3.962512] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    3.963869] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    3.982102] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    4.004861] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    4.012310] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
              Oct 24 11:42:56 raspberrypi kernel: [    4.012850] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
              Oct 24 11:42:56 raspberrypi kernel: [    4.013555] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
              Oct 24 11:42:56 raspberrypi kernel: [    4.013864] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
              Oct 24 11:42:56 raspberrypi kernel: [    4.013897] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              Oct 24 11:42:56 raspberrypi kernel: [    4.013923] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              Oct 24 11:42:56 raspberrypi kernel: [    4.013946] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              Oct 24 11:42:56 raspberrypi kernel: [    4.013968] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              Oct 24 11:42:56 raspberrypi kernel: [    4.014163] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
              Oct 24 11:42:56 raspberrypi kernel: [    4.035473] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              Oct 24 11:42:56 raspberrypi kernel: [    4.084263] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
              Oct 24 11:42:56 raspberrypi kernel: [    4.125844] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              Oct 24 11:42:56 raspberrypi kernel: [    4.131060] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
              Oct 24 11:42:56 raspberrypi kernel: [    4.131124] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
              Oct 24 11:42:56 raspberrypi kernel: [    4.152115] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
              Oct 24 11:42:56 raspberrypi kernel: [    4.152161] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
              Oct 24 11:42:56 raspberrypi kernel: [    4.187406] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
              Oct 24 11:42:56 raspberrypi kernel: [    4.187524] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
              Oct 24 11:42:56 raspberrypi kernel: [    4.197382] brcmfmac: F1 signature read @0x18000000=0x15264345
              Oct 24 11:42:56 raspberrypi kernel: [    4.199442] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
              Oct 24 11:42:56 raspberrypi kernel: [    4.199505] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
              Oct 24 11:42:56 raspberrypi kernel: [    4.215428] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              Oct 24 11:42:56 raspberrypi kernel: [    4.217461] usbcore: registered new interface driver brcmfmac
              Oct 24 11:42:56 raspberrypi kernel: [    4.267380] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
              Oct 24 11:42:56 raspberrypi kernel: [    4.273451] sd 0:0:0:0: Attached scsi generic sg0 type 0
              Oct 24 11:42:56 raspberrypi kernel: [    4.352522] [drm] No displays found. Consider forcing hotplug if HDMI is attached
              Oct 24 11:42:56 raspberrypi kernel: [    4.352670] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
              Oct 24 11:42:56 raspberrypi kernel: [    4.360451] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
              Oct 24 11:42:56 raspberrypi kernel: [    4.478969] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              Oct 24 11:42:56 raspberrypi kernel: [    4.479088] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              Oct 24 11:42:56 raspberrypi kernel: [    4.488535] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
              Oct 24 11:42:56 raspberrypi kernel: [    6.570331] random: crng init done
              Oct 24 11:42:56 raspberrypi kernel: [    6.570362] random: 7 urandom warning(s) missed due to ratelimiting
              Oct 24 11:42:56 raspberrypi kernel: [    6.676105] 8021q: 802.1Q VLAN Support v1.8
              Oct 24 11:42:56 raspberrypi kernel: [    6.729120] uart-pl011 fe201000.serial: no DMA platform data
              Oct 24 11:42:57 raspberrypi kernel: [    6.926777] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
              Oct 24 11:42:57 raspberrypi kernel: [    7.035965] Adding 51196k swap on /var/swap.  Priority:-2 extents:133 across:23083960k SSFS
              Oct 24 11:42:57 raspberrypi kernel: [    7.101788] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
              Oct 24 11:42:57 raspberrypi kernel: [    7.102036] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
              Oct 24 11:42:57 raspberrypi kernel: [    7.102161] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              Oct 24 11:42:59 raspberrypi kernel: [    9.118481] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
              Oct 24 11:43:03 raspberrypi kernel: [   13.455693] Bluetooth: Core ver 2.22
              Oct 24 11:43:03 raspberrypi kernel: [   13.455755] NET: Registered protocol family 31
              Oct 24 11:43:03 raspberrypi kernel: [   13.455762] Bluetooth: HCI device and connection manager initialized
              Oct 24 11:43:03 raspberrypi kernel: [   13.455777] Bluetooth: HCI socket layer initialized
              Oct 24 11:43:03 raspberrypi kernel: [   13.455787] Bluetooth: L2CAP socket layer initialized
              Oct 24 11:43:03 raspberrypi kernel: [   13.455802] Bluetooth: SCO socket layer initialized
              Oct 24 11:43:03 raspberrypi kernel: [   13.464513] Bluetooth: HCI UART driver ver 2.3
              Oct 24 11:43:03 raspberrypi kernel: [   13.464524] Bluetooth: HCI UART protocol H4 registered
              Oct 24 11:43:03 raspberrypi kernel: [   13.464579] Bluetooth: HCI UART protocol Three-wire (H5) registered
              Oct 24 11:43:03 raspberrypi kernel: [   13.464740] Bluetooth: HCI UART protocol Broadcom registered
              Oct 24 11:43:03 raspberrypi kernel: [   13.631498] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              Oct 24 11:43:03 raspberrypi kernel: [   13.631508] Bluetooth: BNEP filters: protocol multicast
              Oct 24 11:43:03 raspberrypi kernel: [   13.631521] Bluetooth: BNEP socket layer initialized
              Oct 24 11:43:22 raspberrypi kernel: [   31.835180] vcc-sd: disabling
                Moin,
                Linux Grundkurs, diese Meldung sagt, dass das Programm lsof nicht gefunden wird, also ist es nicht installiert, Du kannst das nachinstallieren
                # sudo apt install lsof
                VG
                Bernd
                  erazor86 @Guest last edited by erazor86
                  Moin,
                  VG
                  Bernd
                  danke für die Hilfe, aber leider sagt er mir, dass nicht genug freier Speicher zum installieren vorhanden ist... 😕
                  pi@raspberrypi:~ $ sudo apt install lsof
                  Reading package lists... Done
                  Building dependency tree
                  The following NEW packages will be installed:
                    lsof
                  0 upgraded, 1 newly installed, 0 to remove and 122 not upgraded.
                  Need to get 307 kB of archives.
                  After this operation, 447 kB of additional disk space will be used.
                  E: You don't have enough free space in /var/cache/apt/archives/.
                  edit: So ich habe jetzt die Partition erweitert auf volle Festplattenkapazität und iob läuft zum glück auch wieder. Jetzt gilt es nur die Ursache ausfindig zu machen und das System zu bereinigen eh mir der Speicher wieder voll läuft...
                  aktuell sieht es so aus:
                  pi@raspberrypi:~ $ df -h
                  /dev/root        55G   28G   25G  54% /
                  tmpfs           1.9G  8.5M  1.9G   1% /run
                  pi@raspberrypi:~ $ iobroker start
                    lsof
                  Get:1 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
                  Fetched 307 kB in 0s (843 kB/s)
                  Selecting previously unselected package lsof.
                  (Reading database ... 50941 files and directories currently installed.)
                  Preparing to unpack .../lsof_4.91+dfsg-1_armhf.deb ...
                  Unpacking lsof (4.91+dfsg-1) ...
                  Setting up lsof (4.91+dfsg-1) ...
                  Processing triggers for man-db (2.8.5-2) ...
                  Thomas Braun ? 3 Replies Last reply Reply Quote 0
                    @erazor86
                    Dann schau 'live' in kern.log oder syslog rein und schau was da reinläuft. Irgendwo müssen die 11GB pro file a herkommen.
                    tail /var/log/syslog
                      Thomas Braun Most Active @erazor86 last edited by Thomas Braun
                      @erazor86
                      Davon abgesehen würde ich dringend zu einem Umzug auf das andere System raten.
                      Mach ein Backup vom jetzt wieder laufenden ioBroker und pack die Umzugskartons.
                        Oct 24 16:43:30 raspberrypi bash[625]: ================================== > LOG        REDIRECT system.adapter.jarvis.0 => true [system.adapter.jarvis.0.logging]
                        Oct 24 16:43:43 raspberrypi bash[625]: ================================== > LOG        REDIRECT system.adapter.jarvis.1 => true [system.adapter.jarvis.1.logging]
                        Oct 24 16:50:54 raspberrypi dhcpcd[623]: eth0: Router Advertisement from fe80::c        ece:1eff:fe79:6d19
                        Oct 24 16:54:38 raspberrypi dhcpcd[623]: eth0: Router Advertisement from fe80::c        ece:1eff:fe79:6d19
                        Oct 24 16:57:14 raspberrypi systemd[1]: Starting Cleanup of Temporary Directorie        s...
                        Oct 24 16:57:14 raspberrypi systemd[1]: systemd-tmpfiles-clean.service: Succeede        d.
                        Oct 24 16:57:14 raspberrypi systemd[1]: Started Cleanup of Temporary Directories        .
                        Oct 24 16:57:24 raspberrypi dhcpcd[623]: eth0: Router Advertisement from fe80::c        ece:1eff:fe79:6d19
                        Oct 24 16:57:25 raspberrypi dhcpcd[623]: eth0: Router Advertisement from fe80::c        ece:1eff:fe79:6d19
                        Oct 24 17:00:13 raspberrypi systemd[1]: Started Session 3 of user pi.
                        scheint wohl was mit Jarvis zu sein...
                          Das kannst du aus dem dutzend Zeilen nicht ableiten.
                            A Former User @erazor86 last edited by A Former User
                            Moin,
                            na, wenn Du lsof jetzt installiert hast, dann kannst Du ja mal schauen
                            ***Dann den/die Dinste stoppen, die das File nutzen**
                            # sudo systemctl status ....
                            # sudo systemctl stop ....
                            # sudo > /dev/log/kern.log
                            # sudo systemctl start ....
                            # sudo ls -la /var/log/kern.log*
                            Dann auch das gleiche, mit /var/log/syslog
                            Bei Dir ist das Logfile Rotation nicht aktiv, oder kaputt, deswegen wachsen die Logs an, normalerweise, wird entweder täglich, oder nach Größe rotiert.
                            VG
                            Bernd
                            P.S.: Danke @Thomas-Braun, habe ( in / ich korrigiert.
                            Thomas Braun E 2 Replies Last reply Reply Quote 0
                              @dp20eic sagte in Iobroker nicht mehr erreichbar / Festplatte voll?:
                              /var(log/kern.log
                              Das sollte eher jeweils
                              /var/log/kern.log
                              lauten. 😉
                                ich habe die Befehle mal nacheinander gestartet, aber da scheint es noch irgendwo zu hängen 😥
                                pi@raspberrypi:~ $ sudo lsof /var/log/kern.log
                                pi@raspberrypi:~ $ sudo systemctl status
                                ● raspberrypi
                                    State: degraded
                                     Jobs: 0 queued
                                   Failed: 1 units
                                    Since: Thu 1970-01-01 01:00:01 CET; 53 years 9 months ago
                                   CGroup: /
                                           ├─user.slice
                                           │ └─user-1000.slice
                                           │   ├─session-3.scope
                                           │   │ ├─3038 sshd: pi [priv]
                                           │   │ ├─3090 sshd: pi@pts/1
                                           │   │ ├─3091 -bash
                                           │   │ ├─4139 sudo systemctl status
                                           │   │ ├─4140 systemctl status
                                           │   │ └─4141 pager
                                           │   ├─user@1000.service
                                           │   │ └─init.scope
                                           │   │   ├─748 /lib/systemd/systemd --user
                                           │   │   └─749 (sd-pam)
                                           │   └─session-1.scope
                                           │     ├─678 sshd: pi [priv]
                                           │     ├─762 sshd: pi@pts/0
                                           │     └─763 -bash
                                lines 1-23...skipping...
                                ● raspberrypi
                                    State: degraded
                                     Jobs: 0 queued
                                   Failed: 1 units
                                   CGroup: /
                                           ├─user.slice
                                           │ └─user-1000.slice
                                           │   ├─session-3.scope
                                           │   │ ├─3091 -bash
                                           │   │ └─4141 pager
                                           │   │ └─init.scope
                                           │   │   └─749 (sd-pam)
                                           │   └─session-1.scope
                                           │     └─763 -bash
                                           ├─init.scope
                                           │ └─1 /sbin/init
                                           └─system.slice
                                             ├─alsa-state.service
                                             │ └─361 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
                                             ├─systemd-timesyncd.service
                                             │ └─311 /lib/systemd/systemd-timesyncd
                                             ├─dbus.service
                                             │ └─349 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                             ├─hciuart.service
                                             │ └─643 /usr/bin/hciattach /dev/serial1 bcm43xx 3000000 flow -
                                             ├─ssh.service
                                             │ └─631 /usr/sbin/sshd -D
                                             ├─avahi-daemon.service
                                             │ ├─358 avahi-daemon: running [raspberrypi.local]
                                             │ └─373 avahi-daemon: chroot helper
                                             ├─system-getty.slice
                                             │ └─getty@tty1.service
                                             │   └─630 /sbin/agetty -o -p -- \u --noclear tty1 linux
                                             ├─wpa_supplicant.service
                                             │ └─372 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
                                             ├─triggerhappy.service
                                             │ └─376 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                                             ├─systemd-logind.service
                                             │ └─389 /lib/systemd/systemd-logind
                                             ├─cron.service
                                             │ └─356 /usr/sbin/cron -f
                                             ├─systemd-udevd.service
                                             │ └─152 /lib/systemd/systemd-udevd
                                             ├─rsyslog.service
                                             │ └─4039 /usr/sbin/rsyslogd -n -iNONE
                                             ├─bluetooth.service
                                             │ └─658 /usr/lib/bluetooth/bluetoothd
                                             ├─systemd-journald.service
                                             │ └─134 /lib/systemd/systemd-journald
                                             ├─rng-tools.service
                                             │ └─351 /usr/sbin/rngd -r /dev/hwrng
                                             └─dhcpcd.service
                                               ├─486 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                                lines 1-62
                                ● raspberrypi
                                    State: degraded
                                     Jobs: 0 queued
                                   Failed: 1 units
                                   CGroup: /
                                           ├─user.slice
                                           │ └─user-1000.slice
                                           │   ├─session-3.scope
                                           │   │ ├─3091 -bash
                                           │   │ └─4141 pager
                                           │   │ └─init.scope
                                           │   │   └─749 (sd-pam)
                                           │   └─session-1.scope
                                           │     └─763 -bash
                                           ├─init.scope
                                           │ └─1 /sbin/init
                                           └─system.slice
                                             ├─dbus.service
                                             ├─hciuart.service
                                             ├─ssh.service
                                             ├─cron.service
                                             ├─rsyslog.service
                                             ├─bluetooth.service
                                             ├─rng-tools.service
                                             └─dhcpcd.service
                                               └─623 /sbin/dhcpcd -q -w
                                pi@raspberrypi:~ $ sudo systemctl stop
                                Too few arguments.
                                pi@raspberrypi:~ $ sudo > /dev/log/kern.log
                                -bash: /dev/log/kern.log: Not a directory
                                pi@raspberrypi:~ $ sudo systemctl start
                                Too few arguments.
                                pi@raspberrypi:~ $ sudo ls -la /var/log/kern.log*
                                -rw-r----- 1 root adm 12281625684 Oct 24 16:41 /var/log/kern.log
                                -rw-r----- 1 root adm         456 Sep 23 20:36 /var/log/kern.log.1
                                -rw-r----- 1 root adm         298 Sep 18 17:02 /var/log/kern.log.2.gz
                                -rw-r----- 1 root adm       24217 Sep  5 09:56 /var/log/kern.log.3.gz
                                -rw-r----- 1 root adm         189 Aug 27 21:59 /var/log/kern.log.4.gz
                                Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                  @erazor86
                                  echo "" | sudo tee /var/log/kern.log
                                  sollte das kern.log löschen. Analog
                                  echo "" | sudo tee /var/log/syslog
                                    @erazor86
                                    super! danke euch beiden 🙂
                                    /dev/root        55G  5.1G   48G  10% /
                                    tmpfs           1.9G   17M  1.9G   1% /run
                                    jetzt habe ich erstmal was Zeit gewonnen und kann mal was essen 😄
                                      Moin,
                                      nach dem status muss natürlich auch das eingetragen werden, was bei lsof angezeigt wird.
                                      Bei mir z. B. promtail, ist nur ein Dienst bei mir
                                      # lsof /var/log/kern.log
                                      COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF     NODE NAME
                                      rsyslogd 1503     root   12w   REG  253,1    33738 50334529 /var/log/kern.log
                                      promtail 2879 promtail   25r   REG  253,1    33738 50334529 /var/log/kern.log
                                      Wenn bei dir da nichts kommt, dann muss man auch nichts stoppen, und kann gleich zum Löschen übergehen, die Methode von @Thomas-Braun geht auch, solange da keiner einen Filehandle drauf hat, mitunter, zieht man damit einem Programm den Stuhl unter dem Arsch weg, führt aber hier und jetzt zuweit.
                                      Gut, dass es jetzt erst einmal wieder aufgeräumt aussieht.
                                      Du solltest aber schauen, ob Log Rotate läuft
                                      dp20eic@iobroker:~$ systemctl status logrotate.timer
                                      * logrotate.timer - Daily rotation of log files
                                           Loaded: loaded (/lib/systemd/system/logrotate.timer; enabled; vendor preset: enabled)
                                           Active: active (waiting) since Tue 2023-10-17 09:21:40 CEST; 1 weeks 0 days ago
                                          Trigger: Wed 2023-10-25 00:00:00 CEST; 5h 17min left
                                         Triggers: * logrotate.service
                                             Docs: man:logrotate(8)
                                                   man:logrotate.conf(5)
                                      dp20eic@iobroker:~$ systemctl status logrotate.service
                                      * logrotate.service - Rotate log files
                                           Loaded: loaded (/lib/systemd/system/logrotate.service; static)
                                           Active: inactive (dead) since Tue 2023-10-24 00:00:43 CEST; 18h ago
                                      TriggeredBy: * logrotate.timer
                                          Process: 89270 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited, status=0/SUCCESS)
                                         Main PID: 89270 (code=exited, status=0/SUCCESS)
                                              CPU: 55ms
                                      Wie rotiert wird, steht in den Files unter /etc/logrotate.d z.b. so sieht das bei meinem Debian - Bookworm aus
                                      dp20eic@iobroker:~$ ls -la /etc/logrotate.d/*
                                      -rw-r--r-- 1 root root 120 Apr 19  2019 /etc/logrotate.d/alternatives
                                      -rw-r--r-- 1 root root 173 May 12  2020 /etc/logrotate.d/apt
                                      -rw-r--r-- 1 root root 130 Aug 29  2018 /etc/logrotate.d/btmp
                                      -rw-r--r-- 1 root root 181 Nov 28  2020 /etc/logrotate.d/cups-daemon
                                      -rw-r--r-- 1 root root 112 Apr 19  2019 /etc/logrotate.d/dpkg
                                      -rw-r--r-- 1 root root 374 Feb 17  2021 /etc/logrotate.d/rsyslog
                                      -rw-r--r-- 1 root root 131 Jul 29  2021 /etc/logrotate.d/telegraf
                                      -rw-r--r-- 1 root root 145 Feb 19  2018 /etc/logrotate.d/wtmp
                                      Wenn da auch wieder nichts kommt, dann setz die Kiste wirklich neu auf, denn dann laborierst du an einem toten Pferd.
                                      VG
                                      Bernd
                                        @dp20eic
                                        kaum zu glauben, zwischen meinem letzten und diesen Post wurde mein zweiter Sohn geboren. Bin gerade ausm Kreissaal zurück, damit hätte ich heute auch nicht mehr gerechnet 😄
                                        nun aber zurück zum Thema 😉
                                        es sieht so aus, als würde soweit alles laufen...
                                        Last login: Tue Oct 24 17:00:14 2023 from 192.168.178.117
                                        pi@raspberrypi:~ $ lsof /var/log/kern.log
                                        pi@raspberrypi:~ $ systemctl status logrotate.timer
                                        ● logrotate.timer - Daily rotation of log files
                                           Active: active (waiting) since Tue 2023-10-24 16:41:25 CEST; 7h ago
                                          Trigger: Thu 2023-10-26 00:00:00 CEST; 23h left
                                        Oct 24 16:41:25 raspberrypi systemd[1]: Started Daily rotation of log files.
                                        ...skipping...
                                        pi@raspberrypi:~ $ systemctl status logrotate.service
                                        ● logrotate.service - Rotate log files
                                           Loaded: loaded (/lib/systemd/system/logrotate.service; static; vendor preset:
                                           Active: inactive (dead) since Wed 2023-10-25 00:00:15 CEST; 37min ago
                                          Process: 29578 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited,
                                         Main PID: 29578 (code=exited, status=0/SUCCESS)
                                        Oct 25 00:00:14 raspberrypi systemd[1]: Starting Rotate log files...
                                        Oct 25 00:00:15 raspberrypi systemd[1]: logrotate.service: Succeeded.
                                        Oct 25 00:00:15 raspberrypi systemd[1]: Started Rotate log files.
                                        pi@raspberrypi:~ $ ls -la /etc/logrotate.d/*
                                        -rw-r--r-- 1 root root 173 Apr 19  2021 /etc/logrotate.d/apt
                                        -rw-r--r-- 1 root root 501 Feb 26  2019 /etc/logrotate.d/rsyslog
                                        pi@raspberrypi:~ $
                                        ich bin mir allerdings nicht sicher ob ich den rsyslog wieder starten sollte... er wird ja aktuell unter dem Befehl
                                        nicht als aktiv aufgeführt, aber das wurde er im Laufe des Tages definitiv einmal.. vermutlich habe ich ihn nach dem stoppen nicht wieder gestartet...?
                                        edit: Was mir noch aufgefallen ist, das ganze Theater begann ja heute morgen als ich den mihome-vacuum adapter einrichten wollte. Wenn ich diesen Deinstallieren möchte, tut er das lt.log auch. Die Instanz und auch die Objekte sind alle weg.. Aber er wird immer noch als installiert unter den Adaptern aufgeführt ...?
                                        Ansonsten läuft und verhält sich der Iobroker wieder ganz normal.
                                          Moin,
                                          mein Glückwunsch, und alles Gute für Mama und dem neuen Erdenbürger, dem großen Bruder und natürlich dem Papa.
                                          VG
                                          Bernd
                                            Moin,
                                            eigentlich meinte ich nicht, dass Du mir hier die Files für Logrotate noch einmal zeigst, sondern, dass Du Dir diese einmal anschauen solltest, was da drin steht um zu verstehen was Logrotate macht 🙂
                                            Wenn Du ihn nicht startest, dann werden einige Logfiles nicht mehr geschrieben, dann wachsen die auch nicht mehr an, aber sollte es ein Problem/Fehler geben, dann hat mal halt auch keine System-Logfiles.
                                            Ist also eine Entscheidung, die Du treffen musst.
                                            Was hast Du genau gemacht?
                                            Wenn Du nur unter dem Reiter Instanz die Instanz gelöscht hast, dann ist auch nur diese und die dazugehörigen Objekte gelöscht, Du musst auch den Adapter löschen.
                                            Du kannst Dir anschauen, welche Adapter Du installiert hast und eine oder mehrere Instanz(en) haben
                                            Du kannst Dir anschauen welche Adapter Du installiert hast, die aber keine Instanz haben
                                            Hier sollte bei Dir noch der mihome-vaccum auftauchen!
                                            Und Du hast eine Gesamtübersicht über alle Adapter
                                            Wenn Du nicht nur die Instanz, sondern auch den Adapter löschen möchtest, dann
                                            Man sieht, der Adapter ist noch installiert, hat aber keine Instanz mehr
                                            Jetzt ist er auch unter den Instanz losen Adaptern zu finden
                                            Um den Adapter zu deinstallieren, auf die drei Punkte klicken
                                            Und dann auf den Mülleimer
                                            Du kannst natürlich auch gleich im Adapter auf den Mülleimer klicken, dann werden meistens, erst die Objekte, dann die Instanz, und dann der Adapter gelöscht.
                                            VG
                                            Bernd
                                            4272
