    4. Umzug von Raspi auf Proxmox
      guitardoc @Guest last edited by
      @dp20eic Ja, ich habe viel gelernt bei der Aktion. Vielen Dank noch mal bei der Hilfe!
      Der Conbee II läuft jetzt am ioBroker LXC, richtig. Das funktioniert ohne Probleme.
        guitardoc @guitardoc last edited by
        Ich habe gleich noch eine Frage. Hab den iob diag mal drüber laufen lassen, weil ich Fehler im Protokoll habe. Hier die Ausgabe:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.2.16-15-pve
            Architecture: x86-64
        model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         13:49:55 up 1 day,  4:17,  3 users,  load average: 0.98, 0.47, 0.28
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Tue 2023-10-24 13:49:55 CEST
                   Universal time: Tue 2023-10-24 11:49:55 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        mn
        /home/mn
        mn adm dialout sudo users iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            4.3G        2.5G        1.4G        131K        398M        1.8G
        Swap:           536M          0B        536M
        Total:          4.8G        2.5G        2.0G
                 4096 M total memory
                 2347 M used memory
                  170 M active memory
                 2438 M inactive memory
                 1367 M free memory
                    0 M buffer memory
                  380 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  2.9G  4.6G  39% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        /dev/mapper/pve-root             ext4       94G  4.3G   85G   5% /dev/ttyACM0
        udev                             devtmpfs   32G     0   32G   0% /dev/tty
        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
        tmpfs                            tmpfs      13G  120K   13G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET         SOURCE                                                 FSTYPE OPTIONS
        /              /dev/mapper/pve-vm--101--disk--0                       ext4   rw,relatime,stripe=16
        `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
        /var:
        446M	/var/
        251M	/var/cache
        247M	/var/cache/apt
        172M	/var/cache/apt/archives
        145M	/var/lib
        Archived and active journals take up 48.0M in the file system.
        /opt/iobroker/backups:
        30M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        291M	/opt/iobroker/iobroker-data/
        157M	/opt/iobroker/iobroker-data/files
        96M	/opt/iobroker/iobroker-data/backup-objects
        52M	/opt/iobroker/iobroker-data/files/javascript.admin
        34M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        35M	/opt/iobroker/iobroker-data/objects.jsonl
        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        7.1M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        6.6M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.18.2
        /usr/bin/node 		v18.18.2
        /usr/bin/npm 		9.8.1
        /usr/bin/npx 		9.8.1
        /usr/bin/corepack 	0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.12
        admin: 		6.10.1
        javascript: 	7.1.4
        Adapters from github: 	1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
        + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        stable        : https://download.iobroker.net/sources-dist.json
        beta          : https://download.iobroker.net/sources-dist-latest.json
        live-stable   : http://iobroker.live/repo/sources-dist.json
        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "eusec"        : 1.1.2    , installed 1.1.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "followthesun" : 0.4.2    , installed 0.4.2
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.67   , installed 0.1.3
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects: 	10537
        States: 	8720
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       28955      132/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       19417      132/iobroker.js-con
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       37990      391/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       37989      391/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34068      421/io.shelly.1
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19123      1/init
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          19308      296/master
        tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       42087      602/go2rtc
        tcp        0      0 127.0.0.1:34653         0.0.0.0:*               LISTEN      1000       46256      1039/io.yahka.0
        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       42080      602/go2rtc
        tcp6       0      0 :::111                  :::*                    LISTEN      0          19125      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          26426      1/init
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       45417      1009/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       38452      512/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       32794      319/io.admin.0
        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       42082      602/go2rtc
        tcp6       0      0 :::45545                :::*                    LISTEN      1000       46219      1039/io.yahka.0
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          19309      296/master
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19124      1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       46220      1039/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       38023      406/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       34086      436/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       34087      436/io.tuya.0
        udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       42083      602/go2rtc
        udp        0      0 0.0.0.0:46126           0.0.0.0:*                           1000       38911      557/io.eusec.0
        udp        0      0 0.0.0.0:51323           0.0.0.0:*                           1000       7820103    406/io.shelly.0
        udp        0      0 0.0.0.0:57687           0.0.0.0:*                           1000       38906      557/io.eusec.0
        udp6       0      0 :::111                  :::*                                0          19126      1/init
        udp6       0      0 :::8443                 :::*                                1000       42088      602/go2rtc
        2023-10-24 02:43:23.983  - warn: zigbee.0 (466) Device '0x54ef441000017f65' announced itself
        2023-10-24 03:03:23.397  - warn: eusec.0 (557) Heartbeat check failed for station T8010P2320100018. Connection seems lost. Try to reconnect...
        2023-10-24 03:03:23.400  - info: eusec.0 (557) Disconnected from station T8010P2320100018
        2023-10-24 03:03:34.281  - info: eusec.0 (557) Connected to station T8010P2320100018 on host 52.58.242.75 and port 13526
        2023-10-24 04:10:17.254  - warn: weatherunderground.0 (3395) get state error: Connection is closed.
        2023-10-24 05:04:00.015  - info: telegram.0 (361) Scheduled restart.
        2023-10-24 05:04:00.523  - info: telegram.0 (361) terminating
        2023-10-24 05:04:00.524  - info: telegram.0 (361) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2023-10-24 05:04:02.849  - info: telegram.0 (3499) starting. Version 1.16.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.12
        2023-10-24 06:02:14.604  - error: modbus.0 (376) Socket Error
        2023-10-24 06:02:14.606  - error: modbus.0 (376) Client in error state.
        2023-10-24 06:02:14.606  - warn: modbus.0 (376) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
        2023-10-24 06:02:15.607  - info: modbus.0 (376) Disconnected from slave 192.168.188.90
        2023-10-24 06:03:15.608  - info: modbus.0 (376) Connected to slave 192.168.188.90
        2023-10-24 07:31:22.086  - info: eusec.0 (557) Push notification connection closed
        2023-10-24 07:31:28.100  - info: eusec.0 (557) Push notification connection successfully established
        2023-10-24 07:49:15.504  - info: javascript.0 (346) script.js.common.Kameras.Status_Eufy_Homebase_anwesend_abwesend: Homebase Nordost und Homebase Südwest wurden auf Guard Mode Anwesend (1) gesetzt.
        2023-10-24 09:32:08.877  - error: admin.0 (319) Cannot update news: TypeError: newNews.forEach is not a function
        2023-10-24 09:33:20.215  - info: info.0 (610) Reading/updating systemdata.
        2023-10-24 09:33:20.351  - info: info.0 (610) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
        2023-10-24 09:33:20.678  - info: info.0 (610) cpu Temp res = {"main":54,"cores":[56,54,52,52],"max":56,"socket":[],"chipset":null}
        2023-10-24 09:50:36.953  - error: weatherunderground.0 (4390) WUnderground reported an error: --/{"message":"timeout of 15000ms exceeded","name":"AxiosError","stack":"AxiosError: timeout of 15000ms exceeded\n    at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/axios/lib/adapters/http.js:630:16)\n    at RedirectableRequest.emit (node:events:517:28)\n    at RedirectableRequest.emit (node:domain:489:12)\n    at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:179:12)\n    at listOnTimeout (node:internal/timers:569:17)\n    at processTimers (node:internal/timers:512:7)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":15000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8","User-Agent":"Mozilla/5.0 (Windows) Gecko/20100101 Firefox/68.0","Accept-Language":"de-DE,de;q=0.8,en-US;q=0.5,en;q=0.3","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"https://api.weather.com/v3/wx/forecast/daily/5day?apiKey=e1f10a1e78da46f5b10a1e78da96f525&icaoCode=EDDP&units=m&language=de&format=json"},"code":"ECONNABORTED","status":null}
        2023-10-24 11:30:45.132  - warn: weatherunderground.0 (4552) get state error: Connection is closed.
        2023-10-24 12:20:08.446  - warn: weatherunderground.0 (4632) get state error: Connection is closed.
        2023-10-24 13:10:07.814  - warn: weatherunderground.0 (4755) get state error: Connection is closed.
        			v.2023-10-10
          Virtualization: lxc
        Installation: 		lxc
        Kernel: 		x86_64
        Userland: 		amd64
        Timezone: 		Europe/Berlin (CEST, +0200)
        User-ID: 		1001
        X-Server: 		false
        Pending OS-Updates: 	0
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.2
        			/usr/bin/npm 		9.8.1
        			/usr/bin/npx 		9.8.1
        Recommended versions are nodejs 18.18.2 and npm 9.8.1
        MEMORY:
        Mem:            4.3G        2.5G        1.3G        131K        555M        1.8G
        Swap:           536M          0B        536M
        Total:          4.8G        2.5G        1.8G
        Active iob-Instances: 	23
        ioBroker Core: 		js-controller 		5.0.12
        			admin 			6.10.1
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		10537
        States: 		8720
        Size of iob-Database:
        42M	/opt/iobroker/iobroker-data/objects.jsonl
        5.4M	/opt/iobroker/iobroker-data/states.jsonl
        Kann da jemand etwas damit anfangen?
        Insbesondere seltsam ist, dass ich Info im GUI nicht aufrufen kann (steht auch was im Protokoll).
        Auch zu ext4 steht da weiter oben ein Fehler und zu USB-Sticks. Oder ist das so OK?
          A Former User @guitardoc last edited by A Former User
          @guitardoc sagte in Umzug von Raspi auf Proxmox:
          Moin,
          welche?
          Las uns das nicht suchen, sondern zeige das direkt.
          Edit
          *** FILESYSTEM ***
          /dev/mapper/pve-root             ext4       94G  4.3G   85G   5% /dev/ttyACM0       <- das ist Unsinn, was hast Du da gemacht????
          Daraus resultiert auch, dass der USB-Stick ja kein Speicher-Stick ist, somit ist da auch kein ext4 Filesystem drauf.
          Zeig mal, die Konfiguration
          # cat /etc/pve/lxc/<lxc_id>.conf
          Und auch
          VG
          Bernd
            guitardoc @Guest last edited by guitardoc
            @dp20eic Die Fehler aus dem Protokoll sind oben in meinem letzten Post mit drin. Für Weatherunderground scheint der Adapter wohl einen Fehler zu haben, da hatte ich letztens schon öfter solche Fehlermeldungen drin.
            Warum der Modbus da einen Fehler liefert weiß ich nicht - da hatte ich aber auch immer mal was drin.
            Mich bewegt vor allem der error. admin.0:
            admin.0 2023-10-24 09:32:08.877	error	Cannot update news: TypeError: newNews.forEach is not a function
            Ich habe einmal den Conbee II Stick dran und dann noch eine USB-SSD-Festplatte (256 GB), die verwende ich als Backup-Laufwerk für die Proxmox Container. Die habe ich ext4 formatiert.
            root@proxmox:~# cat /etc/pve/lxc/101.conf
            ## ioBroker LXC
            #  ### https%3A//tteck.github.io/Proxmox/
            #  <a href='https%3A//ko-fi.com/D1D7EP4GF'><img src='https%3A//img.shields.io/badge/%E2%98%95-Buy me a coffee-red' /></a>
            arch: amd64
            cores: 2
            features: keyctl=1,nesting=1
            hostname: iobroker
            memory: 4096
            net0: name=eth0,bridge=vmbr0,gw=192.168.188.1,hwaddr=62:41:1B:12:5C:1C,ip=192.168.188.124/24,type=veth
            onboot: 1
            ostype: debian
            rootfs: local-lvm:vm-101-disk-0,size=8G
            swap: 512
            tags: cli-user-mn;homeautomation;proxmox-helper-scripts
            unprivileged: 1
            lxc.cgroup2.devices.allow: c 189:* rwm
            lxc.mount.entry: usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00 none bind,optional,create=file
            lxc.cgroup2.devices.allow: c 166:* rwm
            lxc.mount.entry: /var/lib/lxc/101/devices/ttyACM0 dev/ttyACM0 none bind,optional,create=file
            root@proxmox:~#
              Moin,
              ja, nur vielleicht sehe ich andere Dinge als Du, somit reden wir aneinander vorbei, ich bin dann mal in den Abschnitt mit den Logs gegangen
              Zu aller erst, das sind Warnungen, keine Fehler -> Warn ≠ Error!
              Dann, so weit mir bekannt, tauchen diese Warnungen, bei allen Zeitgesteuerten Adaptern auf und sagen nur, dass der Abruf der Daten beim Dienst abgeschlossen ist und die Verbindung geschlossen wurde. Du kannst schauen, ob sich die DP in den Zeitstempeln ändern.
              Es gibt ein issue -> https://github.com/iobroker-community-adapters/ioBroker.weatherunderground/issues/197
              Du erkennst dies zeitgesteuerten Dienste am
              Zum modebus.0 kann ich nichts sagen, setze diesen Adapter nicht ein, weiß auch nicht was da der Client/Slave und der Server ist, was verbirgt sich hinter der IP?
              Hier aus dem Forum
              • https://forum.iobroker.net/topic/58112/modbus-adapter-ständig-error-messages
                Aus dem WWW
              • https://noegel.io/posts/2022-10-09-sungrow/
                Da ich Deine Sachen nicht kenne, suche ich da mal nicht weiter.
              Nun zum Fehler des admin.0
              Da gibt es, hier im Forum schon ein Thread dazu und auch schon ein issue https://github.com/ioBroker/ioBroker.admin/issues/2163
              So, lange Rede, kurzer Sinn, alles erklärbar.
              Außer modbuss, dass nur Du lösen kannst, da Du das Wissen über Deine Komponenten und Parametrierung hast.
              VG
              Bernd
              BenAhrdt created this issue in iobroker-community-adapters/ioBroker.weatherunderground
              open Connection closed meldung seit js-controller 5.0.12 #197
              HGlab01 created this issue in ioBroker/ioBroker.admin
              closed Cannot update news: TypeError: newNews.forEach is not a function #2163
                Moin,
                dazu kann ich aktuell auch nicht viel sagen, denn ich kenne das Skript nicht, das Dir den LX Container angelegt hat, dieser Abschnitt sieht bei mir anders aus und ich verstehe aktuell nicht warum die ttyACM0 aus einem File, das aus /var/lib/lxc/101/devices/ kommt in den LX Container gemountet wird,
                das würde aus meiner Sicht nur Sinn machen, wenn es ein Speicher-Stick wäre, aber ttyACMx sind Character devices, deswegen das c am Anfang
                dp20eic@iobroker:~$ ls -la /dev/ttyACM*
                crw-rw-rw- 1 nobody nogroup 166, 0 Oct 24 16:08 /dev/ttyACM0
                crw-rw-rw- 1 nobody nogroup 166, 2 Oct 24 15:32 /dev/ttyACM2
                Nicht wie bei Block Devices, also Festplatten
                root@pve:~# ls -la /dev/sda*
                brw-rw---- 1 root disk 8, 0 Oct 22 14:31 /dev/sda
                brw-rw---- 1 root disk 8, 1 Oct 22 14:31 /dev/sda1
                brw-rw---- 1 root disk 8, 2 Oct 22 14:31 /dev/sda2
                brw-rw---- 1 root disk 8, 3 Oct 22 14:31 /dev/sda3
                VG
                Bernd
                P.S.: beobachten, aber wenn alles läuft, ist es ja ok.
                  @dp20eic said in Umzug von Raspi auf Proxmox:
                  Ahhh - im ioB diag wird der Fehler von Weatherunderground nicht mit angezeigt, von daher: sorry... Im Log ist da aber einer drin, der ist aber egal. Laufen tut der Adapter jedenfalls.
                  Das ist die IP meines Wechselrichters. Aber auch der liefert die richtigen Werte. Von daher ist auch der Fehler nicht so schlimm.
                  Ahhh - den hatte ich noch gar nicht gesehen. Bis vor dem Umzug hatte ich den Fehler auch nicht. Muss ich mal genauer nachlesen, hab noch nicht reingeschaut.
                  Ich denke mal, das ist die Weiterleitung des Conbee II Sticks in den ioBroker LXC? Ich habe das nach einer Anleitung gemacht und es hat so funktioniert. Hintergrund ist wohl, dass der Conbee II Stick immer wieder die Verbindung verliert. Den Container mit ioBroker hab ich mit dem Helperscript erstellt und bin zur Einbindung des Conbee II nach dieser Erläuerterung vorgegangen: https://www.youtube.com/watch?v=1U7Sl8mfjDE
                    Moin,
                    ja, das scheint eine Eigenart des Conbee II zu sein.
                    VG
                    Bernd
                      @dp20eic Ich bin den iob diag Ausdruck noch mal durchgegangen. Dabei sind mir diese Punkte noch aufgefallen:
                      USB-Devices by-id:
                      Muss ich diesbezüglich noch was unternehmen?
                        Moin,
                        Also ich habe mir noch nicht angeschaut, was das Skript iob diag genau an dieser Stelle macht, das kann aber @Thomas-Braun sicher aus dem Stand beantworten, ich vermute, dass das run-rpc_pipefs.mount, was mit NFS zu tun hat und das ist auf einem LX Container dann aber anders gelöst, das geht aber nur in privilegierten LXC
                        Also, denke ich, das kannst Du überlesen, stört nicht.
                        Auch hier, dreht es sich um einen Dienst, der auf dem PVE Läuft, aber nicht in einem LXC, da werden, virtuelle Mounts eingerichtet auf reale Kernel Files, die den Kernel steuern, da der LXC den Kernel vom Host (PVE) nutzt ist da auch nichts zu tun, stört nicht.
                        Auch hier, denke ich, dass durch die Verwendung eines LX Containers, aus dem Container, nicht auf den Kernel im Host (PVE) zugegriffen werden kann/darf. Würde ich also auch als stört nicht abhaken.
                        Show mounted filesystems (real ones only):
                        Auch hier, kann ich nur vermuten, dass der showmount<-> Teil von NFS, denkt, dass das von Dir angelegte USB Devise ein Mount auf ein reale gemountetes Device ist.
                        Test, unter PVE und LXC, wenn da nichts kommt, dann sind einige Pakete nicht installiert, ist aber NFS und sollte somit auch nicht stören.
                        # sudo showmount
                        # mount
                        USB-Devices by-id:
                        Hier verstehe ich Deine bedenken nicht?
                        VG
                        Bernd
                          @dp20eic sagte in Umzug von Raspi auf Proxmox:
                          Das Skript schaut lediglich beim systemd vorbei und schaut welche Services da mit 'failed' geführt werden.
                          • Fred Freund
                            Fred Freund last edited by
                            Hi, auch ich ziehe auf Proxmox um , LXC priviligiert.
                            warum mqtt probleme bereitet habe ich gefunden der alte mqtt client von raspi deactiviert..ok
                            auch ich bin nach dem Video vorgegangen von Eddy
                            Leider laeuft bei mir echart nicht mehr?
                            braucht das influxdb ? wo nimmt der die daten her?
                            da auf dem raspi mqtt broker, influxdb , grafana installiert wart hab ich jetzt alles in lxc containers...duerfte soweit funktionieren...
                            zigbee und zwave usb sticks ziehen erst um...muss ich mir ansehen...
                            Automation habe ich mit node red gemacht , dort ist auch noch viel zu installieren...die ganzen Bausteine fehlen.
                            Danke euch..
                            Homoran ? 2 Replies Last reply Reply Quote 0
                              Homoran Global Moderator Administrators @Fred Freund last edited by
                              @fred-freund sagte in Umzug von Raspi auf Proxmox:
                              Daher wo du die Datenreihen definiert hast.
                              das sieht dann entsprechend aus
                              dann wird es wohl so sein
                              anscheinend ja nicht
                                A Former User @Fred Freund last edited by
                                Moin,
                                das ist aber meiner Meinung, die falsche Reihenfolge, man sollte immer erst den LX Container korrekt einrichten, also auch das Durchreichen der USBs, dann testen, ob bei Shutdown/Reboot alles funktioniert, dann die Software installieren, die darauf zugreifen will und dann konfigurieren.
                                VG
                                Bernd
                                Fred Freund 1 Reply Last reply Reply Quote 2
                                • Fred Freund
                                  Fred Freund @Guest last edited by Fred Freund
                                  Hi, ich habe echarts neu installiert, duerfte ein bug sein das neu-installation nicht geht ohne den Speicher auf mind. 12GB zu herhoehen...
                                  naja wenn ich meine usbs abdrehe ..dann geht nix mehr 🙂
                                  124
                                  12435
