    4. USB in Docker via neuer Container über Compose u.a. andere
      Chrisham @OliverIO last edited by
      @oliverio vielen Dank, also so korrekt (schon bei allen services den gleichen netzwerknamen (iobroker-4)?
      version: '3'
      services:
        iobroker:
          restart: always
          image: buanet/iobroker:latest
          container_name: iobroker-4
          hostname: iobroker-4
          ports:
            - "8081:8081"
          volumes:
            - /volume1/docker/iobroker-Chrisham:/opt/iobroker
            - /volume1/docker/userscripts:/opt/userscripts
            - /volume1/docker/Backup:/opt/backup/
          environment:
            - PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
            - DEBIAN_FRONTEND=teletype
            - LANG=de_DE.UTF-8
            - LANGUAGE=de_DE:de
            - LC_ALL=de_DE.UTF-8
            - SETGID=1000
            - SETUID=1000
            - TZ=Europe/Berlin
            - USBDEVICES=/dev/ttyUSB0
            - PACKAGES=ffmpeg lame sox libsox-fmt-mp3 asterisk influxdb2-cli
          devices:
            - /dev/ttyUSB0:/dev/ttyUSB0
          networks:
            iobroker-4:
        influxdb:
          restart: always
          image: influxdb:latest
          container_name: influxdb-4
          ports:
            - "8086:8086"
          volumes:
            - /volume1/docker/influxdb/config:/etc/influxdb2
            - /volume1/docker/influxdb/data:/var/lib/influxdb2
          environment:
            - GOSU_VER=1.12
            - INFLUXDB_VERSION=2.7.1
            - INFLUX_CLI_VERSION=2.7.3
            - INFLUX_CONFIGS_PATH=/etc/influxdb2/influx-configs
            - INFLUXD_INIT_PORT=8086
            - INFLUXD_INIT_PING_ATTEMPTS=600
            - DOCKER_INFLUXDB_INIT_CLI_CONFIG_NAME=default
            - DOCKER_INFLUXDB_INIT_MODE=setup
            - DOCKER_INFLUXDB_INIT_USERNAME=iobroker
            - DOCKER_INFLUXDB_INIT_PASSWORD=*1Xs(QD5gY0!B&XHe1_x
            - DOCKER_INFLUXDB_INIT_ORG=smarthome
            - DOCKER_INFLUXDB_INIT_BUCKET=iobroker
          networks:
            iobroker-4:
        grafana:
          restart: always
          image: grafana/grafana:latest
          container_name: grafana-4
          ports:
            - "3000:3000"
          volumes:
            - /volume1/docker/grafana:/var/lib/grafana
            - /volume1/docker/grafana:/var/lib/grafana/plugins
          environment:
            - PATH=/usr/share/grafana/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
            - GF_PATHS_CONFIG=/etc/grafana/grafana.ini
            - GF_PATHS_DATA=/usr/share/grafana
            - GF_PATHS_HOME=/usr/share/grafana
            - GF_PATHS_LOGS=/var/log/grafana
            - GF_PATHS_PLUGINS=/var/lib/grafana/plugins
            - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
            - GF_AUTH_access enabled=true
            - GF_AUTH_org_name=CH_Smart
          networks:
            iobroker-4:
      networks:
        dockerMACVLAN:
          external: true
        iobroker-4:
      bei influxdb hatte ich im compose-file nichts mit IP drin, das war nur im DSM-Config, d.h. dann einfach nur den eintrag mit networks...?
      Container laufen schon, baut aber noch im Hintergrund, bin gespannt...
      Auf DSM-Ebene habe ich beobachtet, dass sich nun der iobroker-name geändert hat (erklärbar...?):
      C OliverIO 2 Replies Last reply Reply Quote 0
        Chrisham @Glasfaser last edited by
        @glasfaser gut so?
          Chrisham @Chrisham last edited by
          @chrisham Gibt Probleme, Grafana container will nicht so recht:
          2023/10/24 23:27:56,stdout,"You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
          2023/10/24 23:27:56,stdout,GF_PATHS_DATA='/usr/share/grafana' is not writable.
          Das sind exakt die Env-Var/Pfade, die ich bisher beim DSM-Docker-config angegeben habe:
          Hat sich doch also nichts geändert und das sind doch Pfade innerhalb des Containers.
          In der Ref (https://grafana.com/docs/grafana/latest/setup-grafana/installation/docker/#migrate-to-v51-or-later) steht noch was drin, dass der Container mit User gestartet werden soll, der ents. Rechte hat:
          Use bind mounts
          If you plan to use directories on your host for the database or configuration when running Grafana in Docker, you must start the container with a user that has the permission to access and write to the directory you map.
          Die werden ja durch Portainer gestartet....
          In der o.g. Referenz stehen bei dem docker-compose Bsp. gar keine Env-Variablen/Pfade drin, soll ich die auch mal rausnehmen...?
          Der Weg ist doch etwas beschwerlicher als gedacht, dabei wollte ich doch nur mein USB-Smart-Meter anschließen... 😠
          C OliverIO 3 Replies Last reply Reply Quote 0
            @chrisham Es stimmen andere Dinge noch nicht:
            • der "komische" iobroker-Container (heißt aber nur so in DSM) scheint kaputt zu sein, allerdings in Portainer sieht alles ok aus:
            • Portainer:
            • DSM:
              --> Kann da auch kein Terminal öffnen.
            Hmm, bin mal gespannt ob dieses Vorhaben irgendwann noch konvergiert....😧
            • OliverIO
              OliverIO @Chrisham last edited by OliverIO
              @chrisham sagte in USB in Docker via neuer Container über Compose u.a. andere:
              diese beiden Zeilen bitte löschen.
              das hat mit macvlan zu tun. das hast du nicht
              dockerMACVLAN:
                external: true
              dann würde ich den bindestrich im netzwerknamen weglassen iobroker-4:
              kann funktionieren, weiß ich nicht. bei solchen namen halte ich mich immer an die regel a-z0-9
              ansonsten passt das.
              du kannst es ja dann selber mal probieren, in dem du die console bspw im iobroker container öffnest (nicht die console auf deinem host system) und dann
              ping grafana
              machen. da müsste dann eine ip adresse kommen, aber keine aus deinem normalen lan-adressbereich.. das ist dann die ip unter der grafana innerhalb dieser service definition erreichbar ist. aber wie gesagt. normalerweise musst du dich bei docker nicht um konkrete ip adressen kümmern. das macht docker für dich. du sprichst die services nur über den servicenamen=hostname an
                @oliverio ok, danke. baut gerade neuen stack mit:
                version: '3'
                services:
                  iobroker:
                    restart: always
                    container_name: iobroker-6
                    hostname: iobroker-6
                    ports:
                      - "8081:8081"
                    volumes:
                    environment:
                      - LANG=de_DE.UTF-8
                      - LANGUAGE=de_DE:de
                      - SETGID=1000
                      - SETUID=1000
                      - TZ=Europe/Berlin
                    devices:
                    networks:
                      iobroker6:
                  influxdb:
                    restart: always
                    container_name: influxdb-6
                    ports:
                      - "8086:8086"
                    volumes:
                    environment:
                      - GOSU_VER=1.12
                    networks:
                      iobroker6:
                  grafana:
                    restart: always
                    container_name: grafana-6
                    ports:
                      - "3000:3000"
                    volumes:
                    networks:
                      iobroker6:
                networks:
                  iobroker6:
                Für heute noch diesen Versuch, sonst gehts morgen weiter....
                • OliverIO
                  das ist der richtige abschnitt
                  https://grafana.com/docs/grafana/latest/setup-grafana/installation/docker/#use-bind-mounts-1
                  das ist eine berechtigungsgeschichte. viele container laufen intern mit root.
                  das ändert sich aber, so das auch innen, wie es sein sollte mit dedizierten usern gearbeitet wird. diese benötigen allerdings schreibrechte auf dem gastlaufwerk. diese information muss man dem container mitgeben.
                  füge im grafana abschnitt noch hinzu
                  user: '0'
                  und probiere ob es dann geht.
                  alternativ
                  das hier, da weiß ich aber nicht ob shell substitution unter portainer funktioniert.
                  user: $(id -u)
                    @oliverio ok, danke. mach ich morgen dann.
                    Letzter Versuch mit o.g. Änderungen war leider nicht erfolgreich:
                    • influx connected noch nicht
                      (auch asterisk install scheint noch nicht zu funktionieren, jedenfalls kann adapter nicht verbinden, oder wird der linux-proc nur nicht automatisch gestartet...? wobei ich die pakete über container-terminal an der üblichen stelle (/etc/init.d) auch nicht gefunden habe....
                    Nunja, war heute halt nicht so erfolgreich, muss noch paar h schlafen, morgen gehts weiter, dennoch vielen dank für den stetigen support!
                    • OliverIO
                      in der container konfiguration immer so sparsam mit angaben umgehen wie möglich.
                      normalerweise hat ein container meist default werte, so das ein container einfach mal läuft.
                      daher nur die angaben hinzufügen, die gemäß doku unbedingt gefordert sind. alles andere kann man erst mal weglassen. erst wenn du merkst, das du da was anderes haben wills, dann kannst du ergänzen.
                      hier der abschnitt zu den ganzen pfad angaben.
                      https://grafana.com/docs/grafana/latest/setup-grafana/configure-docker/#default-paths
                      wenn du da nix änderst, dann musst du da auch nix angeben,
                      ich mach mir bspw bei jedem container gedanken, was will ich da sichern und wo stehen diese daten. dann schaue ich, wie ich die da herausbekommen.
                      zum besseren verständnis von docker und dem dateisystem. docker nutzt ein layer dateisystem. jeder darüberliegende layer überdeckt die einzelnen dateien und verzeichnisse des darunterliegenden layers. normalerweise kommt ganz unten der layer mit dem betriebssystem. dann wird darauf die applikation gelegt.
                      jetzt kommst du und legst darüber nochmal ein named volume oder ein verzeichnis/datei aus deinem dateisystem.
                      dadurch kannst du bspw einzelne dateien oder ganze verzeichnisse nach aussen legen und die dann wegsichern.
                      alle daten, die während der laufzeit im container erzeugt werden und nicht in einem volume liegen, sind nach der regeneration des containers wieder weg.
                      wenn du etwas sichern willst, dann ist sicherlich /var/lib/grafana (data) interessant
                      wenn du plugins installierst evtl auch den pfad zu den plugins, bin aber in grafana sicht so firm und weiß nicht was in den einzelnen verzeichnissen wirklich etwas abgelegt wird.
                      • OliverIO
                        warum steht im protokoll dann immer noch 127.0.0.1?
                        das ist localhost, also wenn eine applikation zu einer anderen auf der gleichen maschine kontakt aufnehmen will.
                        influxdb hast du in einem eigenen container. das ist wie ein weiterer rechner mit eigener ip. also musst du dem iobroker-.influx-adapter in der configuration bei ip influxdb eintragen. das ist gemäß deiner konfiguration der servicename und damit auch gleich der hostname unter der der container erreichbar ist.
                        C 2 Replies Last reply Reply Quote 0
                          @oliverio gut Frage. Ich schwör, ich hab nur das im compose:
                          version: '3'
                          services:
                            iobroker:
                              restart: always
                              ports:
                                - "8081:8081"
                              volumes:
                              environment:
                                - LANG=de_DE.UTF-8
                                - LANGUAGE=de_DE:de
                                - SETGID=1000
                                - SETUID=1000
                                - TZ=Europe/Berlin
                              devices:
                              networks:
                                iobroker6:
                            influxdb:
                              restart: always
                              ports:
                                - "8086:8086"
                              volumes:
                              environment:
                                - GOSU_VER=1.12
                              networks:
                                iobroker6:
                            grafana:
                              restart: always
                              ports:
                                - "3000:3000"
                              volumes:
                              networks:
                                iobroker6:
                          networks:
                            iobroker6:
                          Oder ist das dann nicht die IP, die für die interne Bridge zwischen den Containern vergeben wird. Aber ich kenn mich ja selbst nicht damit aus... wo könnte da noch was verkehrt konfiguriert sein?
                            @oliverio Guten Morgen,
                            gerade kam noch ein Gedanke: Config innerhalb des influx-Adapters, die übernimmt ja dann der neue Container wieder.
                            Und zwar steht da im influx-Adapter config, innerhalb iobroker, also "localhost":
                            Kann das sein, dass das dann als 127.0.0.1 aufgelöst wird? Soll ich das rausnehmen? Weiß nur nicht, ob dann Adapter noch in bisheriger Container-Config läuft...
                            War ne spontane Idee, falls das eine mögliche ursache ist, dann kann ich das heute Abend mal testen (bin jetzt tagsüber erstmal bei der regulären Arbeit...)
                            • OliverIO
                              @chrisham
                              bitte meine posts sorgfältig lesen und bei nicht verstehen nachfragen
                              ich hatte das schon 2 mal geschrieben
                              https://de.wikipedia.org/wiki/Localhost
                              @oliverio sagte in USB in Docker via neuer Container über Compose u.a. andere:
                              im adapter steht sicherlich localhost drin, da zuvor influxdb direkt mit iobroker zusammen installiert ist.
                              siehe oben, einfach die netzwerkkonfiguration in der docker konfiguration vornehmen und im adapter dann influxdb anstatt localhost eintragen
                                @oliverio Ah ok, Chef. Sorry, das war jetzt peinlich 😌 (ohne Rechtfertigung: war wohl spät, zu viele Probleme gleichzeitig...)
                                Now works like a charm 😀 - zumindest mal influxdb, jetzt muss ich mich noch um asterisk Linux paket/prozess und KNX kümmern...
                                Vielen Dank und Sorry nochmals!
                                  @oliverio Ich weiß, KNX ist nicht deine Spezialität, nur kurz den Status und ob du hier noch einen Hinweis hättest.
                                  Es geht wohl um diese Einstellung (local iobroker IP):
                                  Da muss lt. Anleitung (https://www.npmjs.com/package/iobroker.knx) eigentlich die IP unter der das KNX-IP-Gateway den IOBroker findet. Das ist natürlich die NAS-Adresse, die ich über DHCP in Fritzbox auf https://10.74.178.99/ vergebe.
                                  Allerdings ist es so, dass dieser Parameter nicht frei eingegeben werden kann, sondern nur ausgewählt werden kann. Im neuen Container-Setup findet der KNX-Adapter nicht diese Adresse bzw. bietet sie nicht zur Auswahl an:
                                  Ich weiß, ich nicht dein Ding, aber vllt. hast ja noch eine Idee...
                                  • OliverIO
                                    OliverIO last edited by OliverIO
                                    @chrisham
                                    ok
                                    leider weiß ich nicht, wie der knx adapter funktioniert
                                    in den source kann man auch nicht reinschauen,
                                    auf jeden Fall nicht über github
                                    Ich interpretiere, das im adapter ein server läuft.
                                    daher schadet es nicht, in der docker konfiguration des iobrokers den port noch hinzuzufügen
                                        ports:
                                          - "8081:8081"
                                          - "3671:3671"
                                    dadurch werden anfragen von aussen auf diesem port in den container weitergereicht.
                                    evtl reicht das, das in dem feld dann die ip (der host maschine) deines iobrokers angezeigt wird.
                                    kannst du das feld selber füllen, auch wenn die ip nicht zur auswahl bereit steht?
                                    falls der knx-adapter udp-broadcast nutzt, dann muss man leider den network mode ändern.
                                    da gibt es dann nur hostmode. da nutzt dein container dann die gleiche netzwerk schnittstelle wie die host maschine.
                                    oder, was ich empfehlen würde, macvlan. dadurch erhält der iobroker eine komplett eigenständige ip, allerdings ist das zu beginn nicht so einfach zu konfigurieren und man muss sich ein paar gedanken machen, wieviele ip-adressen man in zukunft braucht. dann müssen diese ip-adressen in einer bestimmten range sein. diese range, darf nicht von deinem router anderweitig vergeben werden.
                                    aber erst einmal probieren, mit der port-angabe in der konfiguration
                                      @oliverio Ah ok, danke. Ich denke, jetzt kommen wir dem Problem näher.
                                      Also das mit dem Port habe ich gleich getestet:
                                      version: '3'
                                      services:
                                        iobroker:
                                          restart: always
                                          container_name: iobroker-7
                                          hostname: iobroker-7
                                          ports:
                                            - "8081:8081"
                                            - "3671:3671"
                                          volumes:
                                          environment:
                                            - LANG=de_DE.UTF-8
                                            - LANGUAGE=de_DE:de
                                            - SETGID=1000
                                            - SETUID=1000
                                            - TZ=Europe/Berlin
                                          devices:
                                          networks:
                                            iobroker7:
                                        influxdb:
                                          restart: always
                                          container_name: influxdb-7
                                          ports:
                                            - "8086:8086"
                                          volumes:
                                          environment:
                                            - GOSU_VER=1.12
                                          networks:
                                            iobroker7:
                                        grafana:
                                          restart: always
                                          container_name: grafana-7
                                          ports:
                                            - "3000:3000"
                                          volumes:
                                          networks:
                                            iobroker7:
                                      networks:
                                        iobroker7:
                                      Hat leider nichts geändert an dem Verhalten des KNX-Adapters.
                                      Dann noch 3 weitere Aspekte:
                                      1.) Nein, leider ist das keine Combo-Box, also keine Freitexteingabe möglich.
                                      2.) ich hatte noch einen anderen KNX-Adapter (OpenKNX) installiert, den ich nie verwendet hatte. Der hat aber eine ähnliche Konfiguration, auch ein Drop-down-Menü für die "local IP": und hier genau das gleiche Verhalten.
                                      Mit der bisherigen Container-Konfig findet er die Adresse und bietet sie an.
                                      Mit der neuen Konfig bietet er die Adresse nicht an:
                                      ![0_1698272081505_openknx-ip_1.png](Uploading 100%)
                                      3.) Hostmode: ich denke, in der bisherigen Config hatte ich den host-Mode gewählt:
                                      ![0_1698272120675_container-alt-setup.png](Uploading 100%)
                                      Wie würde ich den im docker-compose einstellen?
                                      Ansosten bzgl. IP-Adress-Vergabe: ich mache das für mein gesamtes Netzwerk eigentlich sehr systematisch. Habe IP-Adress-Bereiche mit unterschiedlichen Rechten (mit/ohne NAS-Zugriff,...) definiert und vergebe für alle (jedenfalls der bekannten Geräte (PC, Laptop, Switch, NAS, bekannte Handys,...) eigentlich feste IP-Adressen über DHCP in der Fritzbox, von daher wäre auch macvlan evtl. eine Option....
                                        @chrisham jetzt noch mit bilder:
                                        zu 2.)
                                        zu 3.)
                                        • OliverIO
                                          eingerückt unter dem abschnitt mit dem service. also so ungefähr
                                          iobroker:
                                            network_mode: "host"
                                          hier die beschreibung von buanet
                                          https://smarthome.buanet.de/2020/09/macvlan-ueber-portainer-einrichten/
                                          für docker-compose wird es bei dieser überschrift interessant
                                          Umsetzung mit docker-compose aka "Portainer Stacks"...
                                          aber auch die vorhergehenden abschnitte sorgfältig lesen.
                                          wenn du probleme hast meld dich.
                                          jier ein screenshot der netzdefinition aus dem portainer
                                          ein teilsegment kannst du mit dem netzwerkrechner von heise berechnen
                                          https://www.heise.de/netze/tools/netzwerkrechner/
                                          aus der angabe 192.168.1.80/28 kann man dann entnehmen,
                                          das dann nur ein ip bereich von .80 bis .95 zur Verfügung steht.
                                          IP-Adresse:
                                          192.168.1.80
                                          CIDR-Suffix:
                                          28
                                          Netzwerkmaske:
                                          255.255.255.240
                                          Inverse Netzwerkmaske:0.0.0.15
                                          Anzahl Hosts:14
                                          Netzadresse:192.168.1.80
                                          Broadcast:192.168.1.95
                                          Host-IPs von:192.168.1.81
                                          bis:192.168.1.94
                                          das kann man dann für die einzelnen container zuordnen. aber nicht jeder container benötigt wirklich eine eigene ip.
                                          macvlan wirkt dann netzwerktechnisch genauso wie wenn das ein eigenständiger rechner wäre. daher dann auch kein portmapping mehr und der broadcast funktioniert dann auch
                                          der bereich kann auch größer gewählt werden. der nächst größere bereich wäre dann 30 ip adressen (einstellbar über den cidr wert. allerdings verschiebt sich dann auch die komplette ip-range
                                            @oliverio Strike! Du hast mal wieder in Schwarze getroffen:
                                            • KNX-Adapter verbindet mit Gerät:
                                            Natürlich musste ich bei influxdb jetzt wieder zurückstellen auf "localhost". Und im compose-File mussten dann die
                                                networks:
                                                  iobroker-4:
                                            wieder rausgenommen werden. Aber so ist erstmal alles ok soweit, d.h. die Adapter sind grün.
                                            Noch zum tieferen Verständnis: Du schreibst "...dann muss man leider den network mode ändern."
                                            Was hat der host-Mode denn für Nachteile? Also ggü der vorigen Config mit "networks" oder ggf. auch ggü dem "macvlan"?
                                            Jetzt muss ich mich noch um die Linux-Pakete kümmern, da gibts auch noch Probleme, das asterisk-paket wird nicht richtig installiert, muss ich mal log analysieren...
                                            11240
