    4. [gelöst] IOB per https nicht erreichbar / Zertifikat def.
      Thomas Braun Most Active @schneidy76 last edited by
      @schneidy76
      Dann die Langfassung von
      iob diag
        schneidy76 @Thomas Braun last edited by Homoran
        Connecting to 192.168.0.115 port 22, please wait...
        login as: pi pi@192.168.0.115's password:
        Linux raspberrypi-Master 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Wed Oct 25 16:05:20 2023 from 192.168.0.202
        SSH is enabled and the default password for the 'pi' user has not been changed.
        This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
        Wi-Fi is currently blocked by rfkill.
        Use raspi-config to set the country before use.
        pi@raspberrypi-Master:~ $ iob diag
        The state system.host.raspberrypi-Master.versions.nodeNewestNext was not found!
        The state system.host.raspberrypi-Master.versions.npmNewestNext was not found!
        The state system.host.raspberrypi-Master.versions.nodeCurrent was not found!
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        ======== Start marking the full check here =========
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi-Master
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
        Model    : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         16:24:26 up  3:41,  3 users,  load average: 0.20, 0.48, 0.72
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        No throttling issues detected.
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-10-25 16:24:27 BST
                   Universal time: Wed 2023-10-25 15:24:27 UTC
                         RTC time: n/a
                        Time zone: Europe/London (BST, +0100)
        System clock synchronized: yes
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:   false
        Desktop:
        Terminal:   tty
        Boot Target:   multi-user.target
        *** MEMORY ***
                       total        used        free      shared  buff/cache   available
        Mem:            1.9G        1.5G         74M         40K        463M        465M
        Swap:           104M         20M         84M
        Total:          2.0G        1.5G        158M
                 1848 M total memory
                 1404 M used memory
                 1376 M active memory
                  112 M inactive memory
                   70 M free memory
                   13 M buffer memory
                  428 M swap cache
                   99 M total swap
                   19 M used swap
                   80 M free swap
        Raspberry only:
        oom events: 0
        lifetime oom required: 0 Mbytes
        total time in oom handler: 0 ms
        max time spent in oom handler: 0 ms
        *** FAILED SERVICES ***
          UNIT LOAD ACTIVE SUB DESCRIPTION
        0 loaded units listed.
        *** FILESYSTEM ***
        Filesystem     Type      Size  Used Avail Use% Mounted on
        /dev/root      ext4      118G   13G  101G  11% /
        devtmpfs       devtmpfs  667M     0  667M   0% /dev
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        tmpfs          tmpfs     370M  868K  369M   1% /run
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      255M   51M  205M  20% /boot
        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
        Messages concerning ext4 filesystem in dmesg:
        [Wed Oct 25 12:42:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:37:E1:5C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=043caf75-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): write access will be enabled during recovery
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): 11 orphan inodes deleted
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): recovery complete
        [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Oct 25 12:42:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Oct 25 12:42:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems \(real ones only\):
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        Files in neuralgic directories:
        /var:
        1.1G  /var/
        651M  /var/log
        646M  /var/log/journal/55a635084cf04e71bfee02b63eaea0f9
        167M  /var/cache
        Archived and active journals take up 645.4M in the file system.
        /opt/iobroker/backups:
        6.8G  /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        464M  /opt/iobroker/iobroker-data/
        243M  /opt/iobroker/iobroker-data/files
        97M  /opt/iobroker/iobroker-data/backup-objects
        92M  /opt/iobroker/iobroker-data/node-red/node_modules
        The five largest files in iobroker-data are:
        29M  /opt/iobroker/iobroker-data/objects.jsonl
        21M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        19M  /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        8.9M  /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.3M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
        find: '/dev/serial/by-id/': No such file or directory
        *** NodeJS-Installation ***
        /usr/bin/nodejs   v18.18.2
        /usr/bin/node     v18.18.2
        /usr/bin/npm     9.8.1
        /usr/bin/npx     9.8.1
        /usr/bin/corepack   0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1+rpi1 500
                500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        Temp directories causing npm8 problem: 0
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:   5.0.12
        admin:     6.10.1
        javascript:   7.1.4
        Adapters from github:   5
        Adapter State
          system.adapter.admin.0                  : admin                 : raspberrypi-Master                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi-Master                       -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi-Master                       -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi-Master                       -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi-Master                       -  enabled
        + system.adapter.denon.0                  : denon                 : raspberrypi-Master                       -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi-Master                       -  enabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi-Master                       -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi-Master                       -  enabled
        + system.adapter.enigma2.0                : enigma2               : raspberrypi-Master                       -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi-Master                       -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi-Master                       -  enabled
        + system.adapter.harmony.0                : harmony               : raspberrypi-Master                       -  enabled
        + system.adapter.history.0                : history               : raspberrypi-Master                       -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi-Master                       -  enabled
        + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
        + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
        + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : raspberrypi-Master                       -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : raspberrypi-Master                       -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi-Master                       -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi-Master                       -  enabled
        + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
        + system.adapter.knx.0                    : knx                   : raspberrypi-Master                       -  enabled, bind: 192.168.0.115
          system.adapter.labcom.0                 : labcom                : raspberrypi-Master                       -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi-Master                       -  enabled, port: 54321
        + system.adapter.node-red.0               : node-red              : raspberrypi-Master                       -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.openweathermap.0         : openweathermap        : raspberrypi-Master                       -  enabled
        + system.adapter.parcel.0                 : parcel                : raspberrypi-Master                       -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi-Master                       -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi-Master                       -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi-Master                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
        + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
        + system.adapter.socketio.0               : socketio              : raspberrypi-Master                       -  enabled, port: 8084, bind: 192.168.0.115, run as: admin
        + system.adapter.solarlog.0               : solarlog              : raspberrypi-Master                       -  enabled, port: 80
          system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.sql.0                    : sql                   : raspberrypi-Master                       - disabled, port: 3306
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-Master                       -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-Master                       -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi-Master                       -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi-Master                       -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-Master                       -  enabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi-Master                       -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi-Master                       -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-Master                       -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi-Master                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wifilight.0              : wifilight             : raspberrypi-Master                       - disabled
        + instance is alive
        Enabled adapters with bindings
        ioBroker-Repositories
        sources       : conf/sources-dist.json
        online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
        stable        : http://download.iobroker.net/sources-dist.json
        beta          : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.10.1   , installed 6.10.1
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "cec2"         : 0.1.1    , installed 0.1.1
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "dwd"          : 2.8.5    , installed 2.8.5
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "flot"         : 1.12.0   , installed 1.12.0
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "knx"          : 2.0.22   , installed 2.0.22
        Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "solarlog"     : 2.2.8    , installed 2.2.6  [Updatable]
        Adapter    "sonos"        : 2.3.1    , installed 2.3.1
        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
        Adapter    "vis-canvas-gauges": 1.0.1, installed 1.0.1
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-material-advanced": 1.7.4, installed 1.7.4
        Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
        Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Objects and States
        Please stand by - This may take a while
        Objects:   14623
        States:   10828
        *** OS-Repositories and Updates ***
        W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        Active Internet connections (only servers)
        Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
        tcp        0      0 192.168.0.115:8701      0.0.0.0:*               LISTEN      1001       62182      7806/io.hm-rpc.5
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       63203      7739/node-red
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11243      552/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       63194      7739/node-red
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63916      7595/iobroker.js-co
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61183      7595/iobroker.js-co
        tcp        0      0 192.168.0.115:2001      0.0.0.0:*               LISTEN      1001       61392      7776/io.hm-rpc.3
        tcp        0      0 192.168.0.115:2010      0.0.0.0:*               LISTEN      1001       63168      7791/io.hm-rpc.4
        tcp        0      0 192.168.0.115:8084      0.0.0.0:*               LISTEN      1001       65716      8101/io.socketio.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11245      552/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65757      8135/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66688      8086/io.web.0
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       65580      8011/io.harmony.0
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       62372      7913/io.mihome-vacu
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11059      392/avahi-daemon: r
        udp        0      0 192.168.0.115:57675     0.0.0.0:*                           1001       63229      7739/node-red
        udp        0      0 192.168.0.115:46558     0.0.0.0:*                           1001       66752      8161/io.knx.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       64680      7898/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       64681      7898/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       65581      8011/io.harmony.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       63202      7739/node-red
        udp        0      0 0.0.0.0:54151           0.0.0.0:*                           108        11061      392/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15451      800/dhcpcd
        udp6       0      0 :::52333                :::*                                108        11062      392/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11060      392/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13152      800/dhcpcd
        *** Log File - Last 25 Lines ***
        2023-10-25 16:21:24.173  - info: web.0 (8086)
        2023-10-25 16:24:51.323  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:00.601  - info: solarlog.0 (8052) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
        2023-10-25 16:25:00.609  - info: solarlog.0 (8052) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
        2023-10-25 16:25:01.235  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:11.225  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:16.322  - info: web.0 (8086)
        2023-10-25 16:25:16.333  - info: web.0 (8086)
        2023-10-25 16:25:17.468  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:21.165  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:26.239  - info: web.0 (8086)
        2023-10-25 16:25:26.253  - info: web.0 (8086)
        2023-10-25 16:25:27.320  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:31.229  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:32.469  - info: web.0 (8086)
        2023-10-25 16:25:32.486  - info: web.0 (8086)
        2023-10-25 16:25:33.585  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:38.360  - error: parcel.0 (8251) Error: read ETIMEDOUT
        2023-10-25 16:25:41.245  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:47.324  - info: web.0 (8086)
        2023-10-25 16:25:47.336  - info: web.0 (8086)
        2023-10-25 16:25:47.469  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        2023-10-25 16:25:47.626  - info: web.0 (8086)
        2023-10-25 16:25:47.628  - info: web.0 (8086)
        2023-10-25 16:25:53.637  - info: web.0 (8086) ==> Connected system.user.admin from ::ffff:192.168.0.110
        ============ Mark until here for C&P =============
        iob diag has finished.
        Press any key for a summary
        Copy text starting here:
        ======================= SUMMARY =======================
              v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Installation:     native
        Kernel:     aarch64
        Userland:     armhf
        Timezone:     Europe/London (BST, +0100)
        User-ID:     1000
        X-Server:     false
        Pending OS-Updates:   0
        Pending iob updates:   3
        Nodejs-Installation:   /usr/bin/nodejs   v18.18.2
              /usr/bin/npm     9.8.1
              /usr/bin/npx     9.8.1
        Recommended versions are nodejs  and npm
        Your nodejs installation is correct
        MEMORY:
        Mem:            1.9G        1.5G        109M         24K        441M        480M
        Swap:           104M        104M        204K
        Total:          2.0G        1.6G        109M
        Active iob-Instances:   34
        ioBroker Core:     js-controller     5.0.12
              admin       6.10.1
        ioBroker Status:   iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Status admin and web instance:
        Objects:     14623
        States:     10828
        Size of iob-Database:
        30M  /opt/iobroker/iobroker-data/objects.jsonl
        3.7M  /opt/iobroker/iobroker-data/states.jsonl
        =================== END OF SUMMARY ====================
        === Mark text until here for copying ===
          schneidy76 @schneidy76 last edited by
          @schneidy76 hoffe ich habe das vom Handy richtig gemacht..
          Thomas Braun DJMarc75 3 Replies Last reply Reply Quote 0
            @schneidy76
            Solltest du dringend ändern.
            • DJMarc75
              DJMarc75 @schneidy76 last edited by
              @schneidy76
              Dir geht der RAM aus und die Kiste wurde wohl schon lieblos vom Strom getrennt 😉
                @thomas-braun hast Recht...
                  @schneidy76
                  Zeitzone richtig setzen. Vermutlich ist London falsch.
                  2GB RAM sind zu knapp kalkuliert für 34 Instanzen.
                  Byebye, Daten die in diesen inodes gewohnt haben.
                    schneidy76 @DJMarc75 last edited by
                    @djmarc75 habe sie nicht freiwillig hart resetet, hatte heute beim ssl Zugang einen freeze
                      schneidy76 @Thomas Braun last edited by schneidy76
                      @thomas-braun okay, könnte noch einiges auf dem Slave auslagern. Der hat zwar auch nur 1GB, da läuft im Moment aber nicht viel drauf.
                      Wie belebe ich den Admin dann aber wieder?
                      Ach Mist, ohne den Admin geht das ja nicht...
                        @schneidy76
                        iob restart admin
                        schlägt sich wie im LogFile nieder?
                          Last login: Wed Oct 25 16:23:32 2023 from 192.168.0.202
                          pi@raspberrypi-Master:~ $ iob restart admin
                          The adapter "admin.0" was started.
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           17:03:17 up  4:20,  3 users,  load average: 1.47, 0.78, 0.62
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2023-10-25 17:03:17 BST
                                     Universal time: Wed 2023-10-25 16:03:17 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:   false
                          Desktop:
                          Terminal:   tty
                          *** MEMORY ***
                          Mem:            1.9G        1.5G        222M         36K        250M        401M
                          Swap:           104M        104M        630K
                          Total:          2.0G        1.6G        222M
                                   1848 M total memory
                                   1464 M used memory
                                   1415 M active memory
                                     31 M inactive memory
                                    212 M free memory
                                      4 M buffer memory
                                    235 M swap cache
                                     99 M total swap
                                     99 M used swap
                                      0 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.1G  /var/
                          651M  /var/log
                          167M  /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm     9.8.1
                          /usr/bin/npx     9.8.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:     6.10.1
                          javascript:   7.1.4
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:   14467
                          States:   10597
                          Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Pending Updates: 0
                          udp        0      0 192.168.0.115:40058     0.0.0.0:*                           1001       80043      8161/io.knx.0
                          udp        0      0 192.168.0.115:52383     0.0.0.0:*                           1001       81433      8161/io.knx.0
                          udp        0      0 192.168.0.115:35494     0.0.0.0:*                           1001       80850      8161/io.knx.0
                          udp        0      0 192.168.0.115:43869     0.0.0.0:*                           1001       78660      8161/io.knx.0
                          2023-10-25 17:00:15.764  - info: daswetter.0 (9535) cleaned everything up...
                          2023-10-25 17:00:15.780  - info: host.raspberrypi-Master instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-10-25 17:00:18.622  - info: ical.0 (9565) Terminated (NO_ERROR): Without reason
                          2023-10-25 17:00:19.153  - info: host.raspberrypi-Master instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                          2023-10-25 17:01:00.068  - info: host.raspberrypi-Master instance system.adapter.dwd.0 started with pid 9582
                          2023-10-25 17:01:03.129  - info: dwd.0 (9582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                          2023-10-25 17:01:04.128  - info: dwd.0 (9582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-10-25 17:01:04.666  - info: host.raspberrypi-Master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-10-25 17:02:00.090  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 started with pid 9597
                          2023-10-25 17:02:03.010  - info: openweathermap.0 (9597) starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.2, js-controller: 5.0.12
                          2023-10-25 17:02:20.699  - info: openweathermap.0 (9597) Terminated (NO_ERROR): Without reason
                          2023-10-25 17:02:21.232  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                          2023-10-25 17:02:52.970  - info: host.raspberrypi-Master instance system.adapter.admin.0 started with pid 9666
                          2023-10-25 17:02:57.004  - info: admin.0 (9666) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
                          2023-10-25 17:02:57.066  - info: admin.0 (9666) requesting all objects
                          2023-10-25 17:03:00.301  - info: admin.0 (9666) received all objects
                          2023-10-25 17:03:01.130  - info: admin.0 (9666) Request actual repository...
                          2023-10-25 17:03:01.178  - error: admin.0 (9666) Cannot create web-server: Error: error:05800074:x509 certificate routines::key values mismatch
                          2023-10-25 17:03:01.182  - info: admin.0 (9666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-10-25 17:03:01.551  - error: admin.0 (9666) Cannot update news: TypeError: newNews.forEach is not a function
                          2023-10-25 17:03:01.772  - warn: admin.0 (9666) Cannot check node.js/npm version
                          2023-10-25 17:03:02.162  - info: admin.0 (9666) terminating https server on port 8081
                          2023-10-25 17:03:02.565  - info: host.raspberrypi-Master Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          2023-10-25 17:03:02.938  - info: host.raspberrypi-Master instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                          2023-10-25 17:03:02.939  - info: host.raspberrypi-Master Do not restart adapter system.adapter.admin.0 because desired by instance
                                v.2023-10-10
                                 Icon name: computer
                              Architecture: arm64
                          Kernel:     aarch64
                          Userland:     armhf
                          User-ID:     1000
                          X-Server:     false
                                /usr/bin/npm     9.8.1
                                /usr/bin/npx     9.8.1
                          MEMORY:
                          Mem:            1.9G        1.5G        112M         36K        348M        389M
                          Swap:           104M        104M        245K
                          Total:          2.0G        1.7G        112M
                                admin       6.10.1
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:     14467
                          States:     10597
                          4.0M  /opt/iobroker/iobroker-data/states.jsonl
                            @schneidy76
                            bin den Weg über eine zusätzliche Admin Instance gegangen. Ohne SSL geht es. Sobald ich das aktiviere, bekomme ich den Adapter nicht mehr grün.
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @schneidy76 last edited by
                              @schneidy76 sagte in Admin Webseite nicht mehr erreichbar:
                              SSL
                              was haste denn vor mit dem ssl ?
                              • Codierknecht
                                Codierknecht Developer Most Active @bahnuhr last edited by
                                @bahnuhr sagte in Admin Webseite nicht mehr erreichbar:
                                SSL
                                @schneidy76
                                Eben.
                                Was willst Du mit SSL im Heimnetz?
                                  Ich nutze unter anderen den KNX Adapter (habe eine immer steigende Anzahl an KNX Teilnehmer bei uns im Haus). Unter anderen auch KNX-RF Geräte. Eine KNX-RF Linie benötigt eine Domain, ab da muss ich das KNX Projekt verschlüsseln.
                                  Um das Projekt, und damit die Gruppenadressen, korrekt einzulesen, benötige ich ebenfalls eine SSL Verschlüsselung von ioBroker.
                                  Warum, keine Ahnung, aber es ist eben so.... 😏
                                  Das Ganze lief ja auch 2 Jahre ohne Probleme.
                                  VG Torsten
                                  • bahnuhr
                                    Na, wenns so is, dann isses so.
                                    Ich bin damit aber raus.
                                    Codierknecht S 2 Replies Last reply Reply Quote 0
                                    • Codierknecht
                                      Ich auch.
                                      Security sucks! 😞
                                        schneidy76 @bahnuhr last edited by
                                        @bahnuhr Trotzdem Danke
                                          schneidy76 @Codierknecht last edited by
                                          @codierknecht ich habe den Betreff mal aktualisiert, vielleicht kann ja jemand helfen
                                          • Marc Berg
                                            Marc Berg Most Active last edited by Marc Berg
                                            @schneidy76 sagte in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                                            Wenn du jetzt eine weitere Admin-Instanz am Start hast, kannst du doch jetzt mal das Debug Log der Instanz "0" aktivieren, diese Instanz neu starten und das Log (nicht "iob diag"!) hier posten. Eine entsprechende Frage von @Thomas-Braun hattest du noch nicht beantwortet.
                                            gelöst iobroker nicht erreichbar ssl error when loading ssl-zertifikat
                                            2121
