    4. Test Adapter Growatt v3.3.1
    • Sefina
      Sefina last edited by
      Hi zusammen,
      Adapter läuft schon nice.
      Ich habe hier ein Growatt MOD 10KTL3-X, bei Typ steht laut Adapter max.
      Gibt es eine Möglichkeit die Wirkleistung auch per Adapter bei diesen Wechselrichter einzustellen ?
      Stehe gern als Testobjekt zur verfügung
      MfG
      PLCHome 0 1 Reply Last reply Reply Quote 0
      • PLCHome 0
        PLCHome 0 Developer @Sefina last edited by PLCHome 0
        @sefina
        Hast du dir einmal weiter oben angeschaut, wie im Browser die Daten mitgeschnitten werden?
        Wenn du mir die Mitschnitte zum Auslesen und Setzen lieferst, kann ich die eintragen.
        https://forum.iobroker.net/topic/36474/test-adapter-growatt-v3-2-0/476
        • Sefina
          Also bei Typ steht max
          Gesendet wurde :
          Als Antwort kamm :
          function dialog_setMAX_init(did,dialog,max){
          if(max==null){
          max=JSON.parse('{"innerVersion":"DLAA07510019","afciThresholdH":"0","communicationVersion":"ZBAA-0019","afciSelfCheck":"0","afciThresholdL":"0","pflinep1_lp":"255","afciThresholdD":"0","lcdLanguage":"1","haveAfci":"false","lost":"false","model":"2377900603503345764","backflowDefaultPower":"-0.1","facHigh":"52.5","pvPfCmdMemoryState":"1","pflinep1_pf":"1.0","fftThresholdCount":"0","deviceType":"0","voltageLowLimit":"276.6","pflinep4_lp":"255","nominalPower":"10000","pflinep4_pf":"1.0","status":"1","lastUpdateTime":"2023-10-25 15:56:20","facLow":"47.5","pflinep3_lp":"255","timezone":"2","voltageHighLimit":"496.3","afciReset":"0","reactiveRate":"0","modelText":"S21B00D00T00P0FU01M0064","dtc":"5002","activeRate":"20","svgEnabled":"0","alias":"QXHJD4S08V","datalogSn":"XGD6D5518H","sysTime":"2017-01-10 23:14:22","fwVersion":"DL1.0","sn":"QXHJD4S08V","pflinep3_pf":"1.0","onOff":"1","vacHigh":"498.0","address":"1","pflinep2_lp":"255","plantId":"2289714","pfModel":"0","plantCountry":"Germany","exportLimitPowerRate":"0.0","afciEnabled":"0","exportLimit":"0","frequencyHighLimit":"50.5","pf":"0.0","frequencyLowLimit":"47.51","deviceModel":"MOD 10KTL3-X","location":"","vacLow":"274.9","pflinep2_pf":"1.0"}');
          if(dialog==null){
          dialog=$("#setDevice")
          CURR_PLANTID=JSON.parse('{"innerVersion":"DLAA07510019","afciThresholdH":"0","communicationVersion":"ZBAA-0019","afciSelfCheck":"0","afciThresholdL":"0","pflinep1_lp":"255","afciThresholdD":"0","lcdLanguage":"1","haveAfci":"false","lost":"false","model":"2377900603503345764","backflowDefaultPower":"-0.1","facHigh":"52.5","pvPfCmdMemoryState":"1","pflinep1_pf":"1.0","fftThresholdCount":"0","deviceType":"0","voltageLowLimit":"276.6","pflinep4_lp":"255","nominalPower":"10000","pflinep4_pf":"1.0","status":"1","lastUpdateTime":"2023-10-25 15:56:20","facLow":"47.5","pflinep3_lp":"255","timezone":"2","voltageHighLimit":"496.3","afciReset":"0","reactiveRate":"0","modelText":"S21B00D00T00P0FU01M0064","dtc":"5002","activeRate":"20","svgEnabled":"0","alias":"QXHJD4S08V","datalogSn":"XGD6D5518H","sysTime":"2017-01-10 23:14:22","fwVersion":"DL1.0","sn":"QXHJD4S08V","pflinep3_pf":"1.0","onOff":"1","vacHigh":"498.0","address":"1","pflinep2_lp":"255","plantId":"2289714","pfModel":"0","plantCountry":"Germany","exportLimitPowerRate":"0.0","afciEnabled":"0","exportLimit":"0","frequencyHighLimit":"50.5","pf":"0.0","frequencyLowLimit":"47.51","deviceModel":"MOD 10KTL3-X","location":"","vacLow":"274.9","pflinep2_pf":"1.0"}').plantId
          Ich hoffe das ist was du brauchst 😁
          MfG
          • PLCHome 0
            @sefina Super das die halbe Miete. Weiter unten in dem Dialog kannst du auch den Wert lesen mit Advanced Set. Davon brauche ich auch mal eine Hardcopy.
            • Sefina
              Ich glaube es ist falsch,
              ich finde nichts was nach deinem Bild ausschaut.
              Was muss ich auslössen um diesen eintrag zu generieren ?
              • PLCHome 0
                • Sefina
                  Ok auch das habe ich gefunden,
                  was brauchst du genau ?
                  PLCHome 0 2 Replies Last reply Reply Quote 0
                  • PLCHome 0
                    @sefina nur den Payload (Nutzlast) vom MAX
                    • PLCHome 0
                      @sefina such mal in der iobroker Installation die Datei:
                      node_odules/iobroker.growatt/node_odules/growatt/lib/growatttype.js
                      oder
                      am besten machst du eine Sicherungskopie der Datei.
                      dann ersetzt du:
                      [MAX]: {
                          snParam: 'maxSn',
                          getTotalData: '/panel/max/getMAXTotalData',
                          getHistory: '/device/getMAXHistory',
                      gegen:
                      [MAX]: {
                          snParam: 'maxSn',
                          readParam: 'readMinParam',
                          writeParam: 'maxSet',
                          comInverter: {
                            time: {
                              type: 'pf_sys_year',
                              paramId: 'pf_sys_time_mutli',
                              parseRet: PARSERET.parseRetDate,
                              param: { param1: { name: 'Time', type: 'DATETIME' } },
                            pvActivePRate: {
                              name: 'PV active power rate',
                              type: 'pv_active_p_rate',
                              paramId: 'pv_active_p_rate',
                              parseRet: PARSERET.parseRetNum,
                              param: { param1: { name: 'Active power rate', type: 'INUM_0_100', unit: '%' }, param2: { name: 'Store', type: 'BOOL', def: false } },
                      Ich gehe aber davon aus, das 'readMinParam' falsch ist.
                      • Sefina
                        Achso, dass
                        Rest teste ich gleich
                        Sefina 1 Reply Last reply Reply Quote 0
                        • Sefina
                          Sefina @Sefina last edited by
                          Also ich habe es ausgetauscht und erhalte jetzt folgende objekte im IOBroker
                          über parm1 habe ich 50% eingetragen und kein ack bekommen (grüne schrift)
                          seltsammer weiße kann ich über die cloud (auch bei abgeschalteten Adapter) keine Wirkleistung abrufen noch eintragen
                          Es kann also sein (ich gehe davon aus) das zu wenig sonne scheint das ich Werte gerade ändern kann.
                          • Sefina
                            @plchome-0 said in Test Adapter Growatt v3.2.0:
                            'readMinParam'
                            ich habe es jetzt bereits gegen "readMaxParm" geändert.
                            Ja der Inverter ist aus und daher wohl auch keine Anpassung der Werte.
                            MfG
                            • PLCHome 0
                              @sefina Ja, mach du morgen mal in ruhe. Bitte prüfe auch mal ob sich die Zeit auslesen und setzen lässt.
                              • Sefina
                                Also alles geht so wie es soll.
                                Ich kann die Werte setzen und abrufen und auch die Zeit kann ich abrufen.
                                Beim setzen bin ich mir zwar nicht sicher was er macht, .... aber es gibt eine meldung : "inv_set_param_exist"
                                Ich danke dir auf jedenfall, falls du interesse an emhr einstellungen hast, stehe ich gern zur verfügung.
                                MfG
                                  jerzimeik last edited by
                                  die Installation hat geklappt und auch der Connect ist mit Benutzername und Passwort da.
                                  Leider kommt unter "Datenlogger verwalten" nichts, wenn ich den Aktualisieren-Button drücke. Entsprechend sind auch keine Objekte da.
                                  Was habe ich falsch gemacht?
                                  VG
                                  • PLCHome 0
                                    PLCHome 0 Developer @jerzimeik last edited by
                                    @jerzimeik
                                    Select it if your Growatt page is a black C&I page
                                    Select it if your Growatt page is a C&I Plant page with indexbC or plantDo in the Path of the Growatt webinterface.
                                    The black C&I pages (commercial and industrial) have an other path to the objects but it semms to work if this Checkbox is on. It Changed index to indexbC in the webpath.
                                    Wählen Sie es aus, wenn Ihre Growatt-Seite eine schwarze C&I-Seite ist
                                    Wählen Sie es aus, wenn Ihre Growatt-Seite eine C&I-Pflanzenseite mit indexbC oder plantDo im Pfad der Growatt-Weboberfläche ist.
                                    Die schwarzen C&I-Seiten (gewerblich und industriell) haben einen anderen Pfad zu den Objekten, aber es scheint zu funktionieren, wenn dieses Kontrollkästchen aktiviert ist. Der Index wurde im Webpfad in indexbC geändert.
                                    Den Schalter geprüft?
                                      jerzimeik @PLCHome 0 last edited by
                                      @plchome-0
                                      Danke, das war es.
                                      Ich hatte gedacht, dass das nur zur Anmeldung war, denn ohne den Haken klappt der connect beim letzten Mal nicht!
                                        RKBroker last edited by
                                        Der Adapter steht bei mir auf "grün", aber es werden keine Datenlogger gefunden. Kann es sein, dass die MIC und MIN Serien mit dem Adapter nicht unterstützt werden?
                                        • PLCHome 0
                                          PLCHome 0 Developer @RKBroker last edited by
                                          @rkbroker ne sind beider drin. Und du bist sicher, dass du nicht das gleiche Problem wie @jerzimeik hast?
                                            RKBroker @PLCHome 0 last edited by RKBroker
                                            @plchome-0 Wenn der Haken für C&I gesetzt ist, wird der Adapter grün. Ohne wird keine Verbindung aufgebaut und im Log taucht "Growatt exception: Error: {"result":3}" auf.
                                            adapter growatt pv-anlage shine solar test tester
                                            72
                                            808
                                            315661
