    4. [gelöst] IOB per https nicht erreichbar / Zertifikat def.
      schneidy76 @Thomas Braun last edited by schneidy76
      @thomas-braun okay, könnte noch einiges auf dem Slave auslagern. Der hat zwar auch nur 1GB, da läuft im Moment aber nicht viel drauf.
      Wie belebe ich den Admin dann aber wieder?
      Ach Mist, ohne den Admin geht das ja nicht...
        Thomas Braun Most Active @schneidy76 last edited by
        @schneidy76
        iob restart admin
        schlägt sich wie im LogFile nieder?
          schneidy76 @Thomas Braun last edited by Homoran
          Connecting to 192.168.0.115 port 22, please wait...
          login as: pi pi@192.168.0.115's password:
          Linux raspberrypi-Master 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Wed Oct 25 16:23:32 2023 from 192.168.0.202
          SSH is enabled and the default password for the 'pi' user has not been changed.
          This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
          Wi-Fi is currently blocked by rfkill.
          Use raspi-config to set the country before use.
          pi@raspberrypi-Master:~ $ iob restart admin
          The adapter "admin.0" was started.
          pi@raspberrypi-Master:~ $ iob diag
          The state system.host.raspberrypi-Master.versions.npmNewestNext was not found!
          The state system.host.raspberrypi-Master.versions.nodeCurrent was not found!
          *** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          ======== Start marking the full check here =========
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi-Master
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 12 (bookworm)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
          Model    : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           17:03:17 up  4:20,  3 users,  load average: 1.47, 0.78, 0.62
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          No throttling issues detected.
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2023-10-25 17:03:17 BST
                     Universal time: Wed 2023-10-25 16:03:17 UTC
                           RTC time: n/a
                          Time zone: Europe/London (BST, +0100)
          System clock synchronized: yes
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:   false
          Desktop:
          Terminal:   tty
          Boot Target:   multi-user.target
          *** MEMORY ***
                         total        used        free      shared  buff/cache   available
          Mem:            1.9G        1.5G        222M         36K        250M        401M
          Swap:           104M        104M        630K
          Total:          2.0G        1.6G        222M
                   1848 M total memory
                   1464 M used memory
                   1415 M active memory
                     31 M inactive memory
                    212 M free memory
                      4 M buffer memory
                    235 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          lifetime oom required: 0 Mbytes
          total time in oom handler: 0 ms
          max time spent in oom handler: 0 ms
          *** FAILED SERVICES ***
            UNIT LOAD ACTIVE SUB DESCRIPTION
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem     Type      Size  Used Avail Use% Mounted on
          /dev/root      ext4      118G   13G  101G  11% /
          devtmpfs       devtmpfs  667M     0  667M   0% /dev
          tmpfs          tmpfs     925M     0  925M   0% /dev/shm
          tmpfs          tmpfs     370M  868K  369M   1% /run
          tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
          /dev/sda1      vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
          Messages concerning ext4 filesystem in dmesg:
          [Wed Oct 25 12:42:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:37:E1:5C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=043caf75-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): write access will be enabled during recovery
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): 11 orphan inodes deleted
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): recovery complete
          [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Oct 25 12:42:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Wed Oct 25 12:42:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems \(real ones only\):
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          Files in neuralgic directories:
          /var:
          1.1G  /var/
          651M  /var/log
          646M  /var/log/journal/55a635084cf04e71bfee02b63eaea0f9
          167M  /var/cache
          Archived and active journals take up 645.4M in the file system.
          /opt/iobroker/backups:
          6.8G  /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          464M  /opt/iobroker/iobroker-data/
          243M  /opt/iobroker/iobroker-data/files
          97M  /opt/iobroker/iobroker-data/backup-objects
          92M  /opt/iobroker/iobroker-data/node-red/node_modules
          The five largest files in iobroker-data are:
          30M  /opt/iobroker/iobroker-data/objects.jsonl
          21M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
          19M  /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
          8.9M  /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          8.3M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs   v18.18.2
          /usr/bin/node     v18.18.2
          /usr/bin/npm     9.8.1
          /usr/bin/npx     9.8.1
          /usr/bin/corepack   0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1+rpi1 500
                  500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Temp directories causing npm8 problem: 0
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:   5.0.12
          admin:     6.10.1
          javascript:   7.1.4
          Adapters from github:   5
          Adapter State
            system.adapter.admin.0                  : admin                 : raspberrypi-Master                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi-Master                       -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi-Master                       -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi-Master                       -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi-Master                       -  enabled
          + system.adapter.denon.0                  : denon                 : raspberrypi-Master                       -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi-Master                       -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi-Master                       -  enabled
          + system.adapter.email.0                  : email                 : raspberrypi-Master                       -  enabled
          + system.adapter.enigma2.0                : enigma2               : raspberrypi-Master                       -  enabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi-Master                       -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi-Master                       -  enabled
          + system.adapter.harmony.0                : harmony               : raspberrypi-Master                       -  enabled
          + system.adapter.history.0                : history               : raspberrypi-Master                       -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi-Master                       -  enabled
          + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
          + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
          + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : raspberrypi-Master                       -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : raspberrypi-Master                       -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi-Master                       -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi-Master                       -  enabled
          + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
          + system.adapter.knx.0                    : knx                   : raspberrypi-Master                       -  enabled, bind: 192.168.0.115
            system.adapter.labcom.0                 : labcom                : raspberrypi-Master                       -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi-Master                       -  enabled, port: 54321
          + system.adapter.node-red.0               : node-red              : raspberrypi-Master                       -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi-Master                       -  enabled
          + system.adapter.parcel.0                 : parcel                : raspberrypi-Master                       -  enabled
          + system.adapter.sayit.0                  : sayit                 : raspberrypi-Master                       -  enabled
          + system.adapter.scenes.0                 : scenes                : raspberrypi-Master                       -  enabled
          + system.adapter.simple-api.0             : simple-api            : raspberrypi-Master                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
          + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
          + system.adapter.socketio.0               : socketio              : raspberrypi-Master                       -  enabled, port: 8084, bind: 192.168.0.115, run as: admin
          + system.adapter.solarlog.0               : solarlog              : raspberrypi-Master                       -  enabled, port: 80
            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
            system.adapter.sql.0                    : sql                   : raspberrypi-Master                       - disabled, port: 3306
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-Master                       -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-Master                       -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi-Master                       -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi-Master                       -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-Master                       -  enabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi-Master                       -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi-Master                       -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-Master                       -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi-Master                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wifilight.0              : wifilight             : raspberrypi-Master                       - disabled
          + instance is alive
          Enabled adapters with bindings
          ioBroker-Repositories
          sources       : conf/sources-dist.json
          online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
          stable        : http://download.iobroker.net/sources-dist.json
          beta          : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.10.1   , installed 6.10.1
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "cec2"         : 0.1.1    , installed 0.1.1
          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "denon"        : 1.15.4   , installed 1.15.4
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "dwd"          : 2.8.5    , installed 2.8.5
          Adapter    "email"        : 1.2.0    , installed 1.2.0
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "flot"         : 1.12.0   , installed 1.12.0
          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
          Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
          Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
          Adapter    "icons-material-png": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
          Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
          Adapter    "iot"          : 1.14.5   , installed 1.14.5
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "knx"          : 2.0.22   , installed 2.0.22
          Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "parcel"       : 0.0.27   , installed 0.0.27
          Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "scenes"       : 2.3.9    , installed 2.3.9
          Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "solarlog"     : 2.2.8    , installed 2.2.6  [Updatable]
          Adapter    "sonos"        : 2.3.1    , installed 2.3.1
          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
          Adapter    "vis-canvas-gauges": 1.0.1, installed 1.0.1
          Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
          Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
          Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
          Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-material-advanced": 1.7.4, installed 1.7.4
          Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
          Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Objects and States
          Please stand by - This may take a while
          Objects:   14467
          States:   10597
          *** OS-Repositories and Updates ***
          W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          Active Internet connections (only servers)
          Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
          tcp        0      0 192.168.0.115:8701      0.0.0.0:*               LISTEN      1001       62182      7806/io.hm-rpc.5
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       63203      7739/node-red
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11243      552/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       63194      7739/node-red
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63916      7595/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61183      7595/iobroker.js-co
          tcp        0      0 192.168.0.115:2001      0.0.0.0:*               LISTEN      1001       61392      7776/io.hm-rpc.3
          tcp        0      0 192.168.0.115:2010      0.0.0.0:*               LISTEN      1001       63168      7791/io.hm-rpc.4
          tcp        0      0 192.168.0.115:8084      0.0.0.0:*               LISTEN      1001       65716      8101/io.socketio.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11245      552/sshd: /usr/sbin
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65757      8135/io.simple-api.
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66688      8086/io.web.0
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       65580      8011/io.harmony.0
          udp        0      0 192.168.0.115:40058     0.0.0.0:*                           1001       80043      8161/io.knx.0
          udp        0      0 192.168.0.115:52383     0.0.0.0:*                           1001       81433      8161/io.knx.0
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       62372      7913/io.mihome-vacu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11059      392/avahi-daemon: r
          udp        0      0 192.168.0.115:57675     0.0.0.0:*                           1001       63229      7739/node-red
          udp        0      0 192.168.0.115:46558     0.0.0.0:*                           1001       66752      8161/io.knx.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       64680      7898/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       64681      7898/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       65581      8011/io.harmony.0
          udp        0      0 192.168.0.115:35494     0.0.0.0:*                           1001       80850      8161/io.knx.0
          udp        0      0 192.168.0.115:43869     0.0.0.0:*                           1001       78660      8161/io.knx.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       63202      7739/node-red
          udp        0      0 0.0.0.0:54151           0.0.0.0:*                           108        11061      392/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15451      800/dhcpcd
          udp6       0      0 :::52333                :::*                                108        11062      392/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        11060      392/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          13152      800/dhcpcd
          *** Log File - Last 25 Lines ***
          2023-10-25 17:00:15.764  - info: daswetter.0 (9535) cleaned everything up...
          2023-10-25 17:00:15.780  - info: host.raspberrypi-Master instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-25 17:00:18.622  - info: ical.0 (9565) Terminated (NO_ERROR): Without reason
          2023-10-25 17:00:19.153  - info: host.raspberrypi-Master instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2023-10-25 17:01:00.068  - info: host.raspberrypi-Master instance system.adapter.dwd.0 started with pid 9582
          2023-10-25 17:01:03.129  - info: dwd.0 (9582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
          2023-10-25 17:01:04.128  - info: dwd.0 (9582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-25 17:01:04.666  - info: host.raspberrypi-Master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-10-25 17:02:00.090  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 started with pid 9597
          2023-10-25 17:02:03.010  - info: openweathermap.0 (9597) starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.2, js-controller: 5.0.12
          2023-10-25 17:02:20.699  - info: openweathermap.0 (9597) Terminated (NO_ERROR): Without reason
          2023-10-25 17:02:21.232  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
          2023-10-25 17:02:52.970  - info: host.raspberrypi-Master instance system.adapter.admin.0 started with pid 9666
          2023-10-25 17:02:57.004  - info: admin.0 (9666) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
          2023-10-25 17:02:57.066  - info: admin.0 (9666) requesting all objects
          2023-10-25 17:03:00.301  - info: admin.0 (9666) received all objects
          2023-10-25 17:03:01.130  - info: admin.0 (9666) Request actual repository...
          2023-10-25 17:03:01.178  - error: admin.0 (9666) Cannot create web-server: Error: error:05800074:x509 certificate routines::key values mismatch
          2023-10-25 17:03:01.182  - info: admin.0 (9666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-10-25 17:03:01.551  - error: admin.0 (9666) Cannot update news: TypeError: newNews.forEach is not a function
          2023-10-25 17:03:01.772  - warn: admin.0 (9666) Cannot check node.js/npm version
          2023-10-25 17:03:02.162  - info: admin.0 (9666) terminating https server on port 8081
          2023-10-25 17:03:02.565  - info: host.raspberrypi-Master Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2023-10-25 17:03:02.938  - info: host.raspberrypi-Master instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          2023-10-25 17:03:02.939  - info: host.raspberrypi-Master Do not restart adapter system.adapter.admin.0 because desired by instance
          ============ Mark until here for C&P =============
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
          ======================= SUMMARY =======================
                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
          Installation:     native
          Kernel:     aarch64
          Userland:     armhf
          Timezone:     Europe/London (BST, +0100)
          User-ID:     1000
          X-Server:     false
          Pending OS-Updates:   0
          Pending iob updates:   3
          Nodejs-Installation:   /usr/bin/nodejs   v18.18.2
                /usr/bin/npm     9.8.1
                /usr/bin/npx     9.8.1
          Recommended versions are nodejs  and npm
          Your nodejs installation is correct
          MEMORY:
          Mem:            1.9G        1.5G        112M         36K        348M        389M
          Swap:           104M        104M        245K
          Total:          2.0G        1.7G        112M
          Active iob-Instances:   34
          ioBroker Core:     js-controller     5.0.12
                admin       6.10.1
          ioBroker Status:   iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Status admin and web instance:
          Objects:     14467
          States:     10597
          Size of iob-Database:
          4.0M  /opt/iobroker/iobroker-data/states.jsonl
          =================== END OF SUMMARY ====================
          === Mark text until here for copying ===
            schneidy76 @schneidy76 last edited by
            @schneidy76
            bin den Weg über eine zusätzliche Admin Instance gegangen. Ohne SSL geht es. Sobald ich das aktiviere, bekomme ich den Adapter nicht mehr grün.
            • bahnuhr
              bahnuhr Forum Testing Most Active @schneidy76 last edited by
              @schneidy76 sagte in Admin Webseite nicht mehr erreichbar:
              SSL
              was haste denn vor mit dem ssl ?
              • Codierknecht
                Codierknecht Developer Most Active @bahnuhr last edited by
                @bahnuhr sagte in Admin Webseite nicht mehr erreichbar:
                SSL
                @schneidy76
                Eben.
                Was willst Du mit SSL im Heimnetz?
                  Ich nutze unter anderen den KNX Adapter (habe eine immer steigende Anzahl an KNX Teilnehmer bei uns im Haus). Unter anderen auch KNX-RF Geräte. Eine KNX-RF Linie benötigt eine Domain, ab da muss ich das KNX Projekt verschlüsseln.
                  Um das Projekt, und damit die Gruppenadressen, korrekt einzulesen, benötige ich ebenfalls eine SSL Verschlüsselung von ioBroker.
                  Warum, keine Ahnung, aber es ist eben so.... 😏
                  Das Ganze lief ja auch 2 Jahre ohne Probleme.
                  VG Torsten
                  • bahnuhr
                    Na, wenns so is, dann isses so.
                    Ich bin damit aber raus.
                    Codierknecht S 2 Replies Last reply Reply Quote 0
                    • Codierknecht
                      Ich auch.
                      Security sucks! 😞
                        schneidy76 @bahnuhr last edited by
                        @bahnuhr Trotzdem Danke
                          schneidy76 @Codierknecht last edited by
                          @codierknecht ich habe den Betreff mal aktualisiert, vielleicht kann ja jemand helfen
                          • Marc Berg
                            Marc Berg Most Active last edited by Marc Berg
                            @schneidy76 sagte in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                            Wenn du jetzt eine weitere Admin-Instanz am Start hast, kannst du doch jetzt mal das Debug Log der Instanz "0" aktivieren, diese Instanz neu starten und das Log (nicht "iob diag"!) hier posten. Eine entsprechende Frage von @Thomas-Braun hattest du noch nicht beantwortet.
                              schneidy76 @Marc Berg last edited by
                              @marc-berg said in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                              Hallo Marc,
                              stelle ich den Log auf Debug um und starte die Admin.0 Instance mit SSL Authentifizierung, bekomme ich trotz den nicht startenden Adapter keine Meldung ins Log.
                              Also zurück auf INFO?
                              • Marc Berg
                                Marc Berg Most Active @schneidy76 last edited by
                                Gegenprobe: bekommst du bei der Instanz.1 Meldungen im Log, wenn du auf "debug" schaltest?
                                  schneidy76 @Marc Berg last edited by schneidy76
                                  @marc-berg
                                  Gegenprobe 1: Admin.0 steht auf "Alles" und nichts kommt an
                                  Gegenprobe 2: Admin.1 steht auf "Debug" Meldungen mit Level Debug kommen
                                  1. Habe ein Update (Edit: auf Admin 6.12.0) angeboten bekommen und dieses ausgeführt. Augenscheinlich durchgelaufen, aber Fehler:
                                  SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
                                  im Dialogfenster.
                                  Vg Torsten
                                    Zwischenstand:
                                    bin nun auf einen RP4 mit 8GB RAM umgestiegen.
                                    Es gab einige Probleme beim Zurückspielen des Backups, die ich aber lösen konnte.
                                    Jetzt läuft der ioBroker wieder stabil mit genügend Reserven.
                                    Ich habe derzeit (zum Testen) 2 Admin Instanzen laufen:
                                    Admin.0 mit https und Authentifizierung Port 8081
                                    Admin.1 ohne SSL Port 8089
                                    Instanz Admin.0 konnte ich starten, nachdem ich den Befehl:
                                    iob cert create
                                    gefunden habe.
                                    Ich kann aber noch nicht per https zugreifen. Die Browser melden zurück:
                                    192.x.x.x erfüllt die Sicherheitsstandards nicht.
                                    ERR_SSL_SERVER_CERT_BAD_FORMAT
                                    Hat jemand ne Idee?
                                    Danke und VG Torsten
                                    • Marc Berg
                                      @schneidy76 sagte in Admin per https nicht erreichbar / Zertifikatprobleme:
                                      Ich weiß ja nicht, welchen Browser du nutzt, normalerweise muss man ja das Verwenden von selbstsignierten Zertifikaten am Browser explizit bestätigen.
                                      Ein weiterer Klassiker bei solchen Fehlern ist ein falsch eingestellte Zeitzone und/oder Zeit. Prüf das mal.
                                        @marc-berg
                                        Hi Marc, den Firefox konnte ich überreden, die Website per https anzuzeigen.
                                        Ich musste dazu den erweiterten Schutz deaktivieren und explizit bestätigen, dass ich mir dem Risiko bewusst bin.
                                        Google Chrom konnte ich noch nicht dazu bewegen - Safe Browsing habe ich dort nun ebenfalls deaktiviert. Trotzdem zeigt der mir die Seite nicht an...
                                        Ich teste weiter... 💪
                                          schneidy76 @schneidy76 last edited by schneidy76
                                          Lösung:
                                          So nun habe ich es endlich hinbekommen. Der Ausflug zu letsencrypt ging schief, nach einigen schlaflosen durchdachten Nächten, habe ich eine Lösung gefunden:
                                          • Backup der bestehenden Installation erstellen und per WinSCP (o.ä.) auf dem PC sichern
                                          • iob stop
                                          • ioBroker Installation per sudo rm -r /opt/iobroker plattmachen
                                          • ioBroker nach der Anleitung: Klick mich neu installieren
                                          • Im Assistenten "Authentifizierung erforderlich" auswählen und Admin Password vergeben
                                          • Nach dem Abschluss die ioBroker Einstellungen öffnen und zum Reiter Zertifikate gehen
                                          • Beide Zertifikate einzeln komplett markieren und als "Nur Text" in einer separaten WordPad Datei speichern.
                                          • Backup mit WinSCP (o.ä.) zurückspielen und per iob restore 0 wiederherstellen
                                          • iob rebuild durchlaufen lassen und anschließend den ioBroker gestartet
                                          • wieder in die Einstellungen des ioBroker gehen und in dem Reiter Zertifikate die bestehenden Zertifikate mit X löschen
                                          • die vorher gesicherten Zertifikate aus den Dateien ersetzen
                                          • Sichern und Schließen --> anschließend Instance "Admin" neu starten
                                          • FERTIG
                                            Rechte des Verzeichnisses /opt auf 777 setzen
                                            per sudo rm -r /opt plattmachen
                                            Warum das? Hört sich komplett unnötig, gefährlich und planlos an.
                                            gelöst iobroker nicht erreichbar ssl error when loading ssl-zertifikat
                                            2118
