    4. jarvis v3.1.x - just another remarkable vis
      sigi234 Forum Testing Most Active @MCU last edited by sigi234
      @mcu
      Hallo, wenn ich keine entsprechende Geräte habe kann ich die wo deaktivieren im Skript?
      javascript.0
      2023-10-25 18:03:21.965	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:03:21.965	warn	at script.js.Sigi.Devices:56:21
      javascript.0
      2023-10-25 18:03:21.964	warn	getState "hue-extended.0.config.ipaddress" not found (3)
      javascript.0
      2023-10-25 18:02:55.543	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:55.543	warn	at script.js.Sigi.Devices:56:21
      javascript.0
      2023-10-25 18:02:55.543	warn	getState "hue-extended.0.config.ipaddress" not found (3)
      javascript.0
      2023-10-25 18:02:52.614	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.614	warn	at script.js.Sigi.Devices:76:4
      javascript.0
      2023-10-25 18:02:52.614	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
      javascript.0
      2023-10-25 18:02:52.614	warn	State "0_userdata.0.devices.useBroadlink2" not found
      javascript.0
      2023-10-25 18:02:52.613	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.613	warn	at script.js.Sigi.Devices:71:4
      javascript.0
      2023-10-25 18:02:52.613	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
      javascript.0
      2023-10-25 18:02:52.613	warn	State "0_userdata.0.devices.useWifilight" not found
      javascript.0
      2023-10-25 18:02:52.612	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.612	warn	at script.js.Sigi.Devices:60:5
      javascript.0
      2023-10-25 18:02:52.611	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
      javascript.0
      2023-10-25 18:02:52.610	warn	State "0_userdata.0.devices.useMeross" not found
      javascript.0
      2023-10-25 18:02:52.609	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.609	warn	at script.js.Sigi.Devices:56:21
      javascript.0
      2023-10-25 18:02:52.608	warn	getState "hue-extended.0.config.ipaddress" not found (3)
      javascript.0
      2023-10-25 18:02:52.608	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.608	warn	at script.js.Sigi.Devices:54:5
      javascript.0
      2023-10-25 18:02:52.608	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
      javascript.0
      2023-10-25 18:02:52.608	warn	State "0_userdata.0.devices.useSonoff" not found
      javascript.0
      2023-10-25 18:02:52.606	warn	at script.js.Sigi.Devices:353:3
      javascript.0
      2023-10-25 18:02:52.606	warn	at script.js.Sigi.Devices:48:5
      javascript.0
      2023-10-25 18:02:52.605	warn	at setState (C:\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1740:20)
      javascript.0
      2023-10-25 18:02:52.603	warn	State "0_userdata.0.devices.useWLED" not found
        MCU @sigi234 last edited by MCU
        @sigi234 Sillte automatisch deaktiviert werden, ausser bei hue-extended da weiss ich es , habe ich vergessen. Aber sonst muss ich mir anschauen. Bin noch unterwegs. Danke für den Hinweis.
        Kann auch sein, dass die Fehler nur beim ersten Start aufgetreten sind?
          smarthome2020 @MCU last edited by
          @mcu sagte in jarvis v3.1.x - just another remarkable vis:
          [{"Rubrik":"Erste","Gerätename":"FritzBox","IP":"<a href="https://192.168.178.1" target="_blank­">192.168.178.1</a>"}, usw.]
          Du bist schon genial 🙂 Danke für deine Lösung
            Ja, teilweise:
            javascript.0
            2023-10-25 20:36:55.651	info	script.js.Sigi.Devices: registered 27 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            javascript.0
            2023-10-25 20:36:55.649	info	script.js.Sigi.Devices: Keine WifiLight`s vorhanden -> useWifiLight false
            javascript.0
            2023-10-25 20:36:55.647	info	script.js.Sigi.Devices: Keine WifiLight`s vorhanden -> useWifiLight false
            javascript.0
            2023-10-25 20:36:55.644	info	script.js.Sigi.Devices: Keine Meross`s vorhanden -> useMeross false
            javascript.0
            2023-10-25 20:36:55.643	warn	at script.js.Sigi.Devices:353:3
            javascript.0
            2023-10-25 20:36:55.643	warn	at script.js.Sigi.Devices:56:21
            javascript.0
            2023-10-25 20:36:55.642	warn	getState "hue-extended.0.config.ipaddress" not found (3)
            javascript.0
            2023-10-25 20:36:55.642	info	script.js.Sigi.Devices: Keine Sonoffs vorhanden -> useSonoff false
            javascript.0
            2023-10-25 20:36:55.640	info	script.js.Sigi.Devices: Keine WLED vorhanden -> useWLED false
            javascript.0
            2023-10-25 20:36:55.626	info	Start javascript script.js.Sigi.Devices
            javascript.0
            2023-10-25 20:36:55.620	info	Stop script script.js.Sigi.Devices
              @smarthome2020 Ja dann
              [{"Rubrik":"Erste","Gerätename":"FritzBox","IP":"<a href=\"https://192.168.178.1\" target=\"_blank­\">192.168.178.1</a>"}, usw.]
              Beispiel
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/system-effektprog./tr064-devices-jsontable
              Ich bin nun nach deiner Anleitung vorgegangen. Ich habe insgesamt 8 Tasmota-Steckdosen-Plugs aktiv. Es wird mir aber nur eine als Tasmota-Device angezeigt. Kann ich die anderen manuell noch definieren?
                MCU @smarthome2020 last edited by MCU
                @smarthome2020 Man muss die Geräte alle in der Instanz tr064 definiert haben, sonst werden sie nicht in der Liste vom tr064 übernommen?
                  @mcu
                  Die Plugs sind in der Liste vorhanden. Sie werden nur nicht blau hinterlegt, so dass eine Website dazu geöffnet werden kann.
                  Beispiel: Badezimmersteckdose ist ein Tasmota-Device
                  PC-Steckdose ist auch ein Tasmota-Device (gleiche Steckdose)
                    MCU last edited by MCU
                    @smarthome2020 ok. Dann haben die Geräte keine IP in der Info.
                    Du kannst aber zu der IP in dem nameArr-Objekt Dein Link, den du haben möchtest zu dieser IP, einstellen.
                    Wenn man nur zur IP ein Link setzen möchte, dann so:
                        "ip": "192.168.178.75",
                        "link": "http://192.168.178.75/cs?"
                    Sonoff prüft auf diese Objekte: sonoff.0.*.INFO.IPAddress
                    Die Steckdose ist aber im sonoff-Adapter hinterlegt? Ich dachte INFO wäre da Standard.
                      @sigi234 Programm korrigiert, sollte nicht mehr vorkommen.
                      Doku -> STRG+F5. -> v1.0.1
                          @sigi234 Nochmal bitte -> v1.0.2
                              @sigi234 Jo, auf ein Neues ->v1.0.3
                                Jupp, läuft. 👍
                                  @sigi234 Danke.
                                    mpl1338 @mpl1338 last edited by
                                    @mpl1338 said in jarvis v3.1.x - just another remarkable vis:
                                    Ist es möglich einen Rollladen per true/false zu fahren?
                                    Im Moment läuft es über "Absolute Position" , hier wird bei Pfeil hoch/runter 100 bzw 0 an die GA "Absolute Position" gesendet.
                                    Ich habe jedoch eine weitere GA "Auf/Ab" diese reagiert auf false/true.
                                    Hintergrund ist, dass mein Jalousie Aktor gerne mal die Absolute Position vergisst und dann keine fahrbefehle per Absolute Position mehr annimmt bis er wieder in einer endlage ist. Die fahrbefehle per AUF/AB (0/1) hingegen nimmt er an.
                                    kann mir niemand helfen?
                                      MCU @mpl1338 last edited by
                                      @mpl1338 Zeig mal bitte die ioBroker-Objekte zu den einzelnen Rollladen.
                                        mpl1338 @MCU last edited by
                                        @mcu said in jarvis v3.1.x - just another remarkable vis:
                                        aktuelle Konfiguration funktioniert wie gewollt.
                                        Screenshot 2023-10-26 193657.png Screenshot 2023-10-26 193509.png Screenshot 2023-10-26 193448.png
                                        mir wäre es jedoch lieber über "Raffstore_küche_fahren" zu fahren.
                                          @mpl1338 Also, wenn Raffstore_Küche_fahren = true -> rauf und bei false -> runter?
                                            als Notlösung mach ich das über ein Skript. Wenn 100 dann true, wenn 0 dann false, wenn 1-99 dann 1-99
                                            92
                                            1815
                                            662158
