    4. Test Adapter Weather-Warnings
      sigi234 Forum Testing Most Active @ticaki last edited by
      @ticaki sagte in Test Adapter Weather-Warnings:
      Hab ich auch gerade mit Admin 11 installiert und dann admin auf 12 weil kein Fehler kam.
      Das auch nicht?
      admin.0
      2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
        ticaki Developer @sigi234 last edited by
        @sigi234
        Ich hab den Fehler reproduzieren können - vorlagen email dann da was geändert hin zurück bam
          ticaki Developer @sigi234 last edited by ticaki
          @sigi234
          Kannst du bitte die aktuellen Version nochmal testen, hab in der jetzt 100 mal rumgeklickt und Dinge geändert ohne GUI Fehler.
          Desweiteren gibts zu der Warnmeldung, die du hast eine Issue im Admin:
          EDIT: Und ja den Fehler hatte ich, aber da weiß ich das es kein Fehler von mir ist. Daher kein Fehler. 🙂
        admin.0        2023-10-25 21:40:29.463	warn	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
          https://github.com/ioBroker/adapter-react-v5/issues/195
          foxriver76 created this issue in ioBroker/adapter-react-v5
          closed add component `accordion` to schema #195
          rtwl sigi234 2 Replies Last reply Reply Quote 0
          • rtwl
            rtwl @ticaki last edited by rtwl
            Ich hab auch soeben aktualisiert.
            zu Email kann ich nichts sagen, aber mir ist aufgefallen, dass ich im Tab Vorlagen und Pushover nicht speichern konnte. weder "Speichern" noch "Speichern und Schließen" hat funkioniert. (Ja, ich hatte etwas verändert)
            Hab dann bei "Allgemein" die Testdaten aktiviert, dann konnte ich Speichern. - Keine Ahnung ob das an mir lag, so gewollt ist, oder ein Bug ist.
              ticaki Developer @rtwl last edited by ticaki
              @rtwl
              So gewollt ist es nicht, Ich hab in der Vorlagentabelle einen kopierten Vergleich drin der das Speichern verhinderen kann, aber der ist von Anfang an drin.
              Ah es könnte auch das sein, nachdem Installieren startet der Adapter einmal/zweimal neu, wenn die Adminoberfläche dabei offen ist, könnte es zu dem Verhalten kommen. Ich korrigiere dann Daten in der Konfiguration oder erstelle Arrays mit internen Adapter Daten. Diesesmal schreibe ich die Warntypen in das Hilfstextfeld das du unter dem Icon Pfad siehst. Dann aktualisiert sich diese Hilfe, wenn ich was an den Warntypen ändere.
              Präziser: Ich schreibe die Daten in die Konfiguration, das schreiben zwingt den Adapter zum Neustart.
              Ich erstelle dann gleich nochmal eine neue Version 0.4.4 müsste dann morgen(2:00) im latest sein.
              rtwl 1 Reply Last reply Reply Quote 0
              • rtwl
                @ticaki
                kann man eigentlich mit deinen Testdaten auch testen wie die Meldung aussieht, wenn eine von den 2 Warnungen aufgehoben wird. also keine Neue Warnung und auch nicht "All clear".
                  @rtwl
                  gute Idee, mach bitte eine Request danke 🙂
                  Edit: Wobei, wenn du lange warten kannst, dann geht das auch schon jetzt. Die Warnungen stehen für eine zufällige Zeit, dann sind sie weg für eine zufällige Zeit. Aber damit kann man das nicht schnell testen.
                  Die Zeiten sind 20-90 Minuten so um den dreh.
                    sigi234 Forum Testing Most Active @ticaki last edited by sigi234
                    Error in GUI!
                    weather-warnings.0
                    2023-10-25 22:45:25.863	error	[zamg-msg] No template for Key: [object Object]!
                    weather-warnings.0
                    2023-10-25 22:45:25.862	error	[zamg-msg] No template for Key: [object Object]!
                    weather-warnings.0
                    2023-10-25 22:41:50.635	error	[zamg-msg] No template for Key: [object Object]!
                    weather-warnings.0
                      @sigi234
                      Speichere bitte mal die Konfig nachdem du was beliebiges geändert hast, da ist was kaputt. Es kann einfach nicht sein, dass diese Fehlermeldung kommt. Außer da sind templates ausgewählt die es garnicht gibt. Die GUI Fehler helfen mir und sagen mir nichts leider nicht. Ich kenn mit mit react nicht aus.
                      Falls der Fehler bleibt, bitte mal die Config hier posten, ich füge die dann bei mir ein und schaue auf dem dev-server was da passiert.
                        entfernt
                        Fehler bleibt, wenn ich EMails deaktiviere funktioniert alles.
                          @sigi234
                          Das ist mir eine lehre nichts mit Defaults auszuprobieren:
                          repariert:
                          Datei entfernt
                          "email_Title": "none",
                          da war ein Object drin gespeichert. So ist es richtig.
                            @ticaki
                            Bei mir importieren oder Update?
                              @sigi234
                              Importieren. Hab ausser dem Punkt nichts geändert. Sollte dann problemlos gehen. Danke fürs testen 🙂
                                @sigi234
                                läuft wieder. 👍
                                  ticaki Developer last edited by ticaki
                                  update github
                                  • Testwarnungen (die aller unterste Option) verändert
                                  • Bei dieser Option bleibt der Adapter gelb
                                  • Testwarnungen aktivieren!... wird von dieser Option selbstständig intern aktiviert.
                                  Ablauf jetzt je Durchlauf:
                                  1. Alle Testwarnungen sind aktiv
                                  2. Alle zufällig(gerade oder ungeraden) werden aufgehoben. Das bedeutet es gibt zur Zeit 1 aktive Warnung pro Provider und Warnzelle.
                                  3. Alle werden aufgehoben -> weiter bei 1.
                                  Intervallzeit sollte 1 Minute sein, aber kann zwischen 30 - 180 Sekunden liegen, je nachdem was ich zuletzt getestet habe und ob ich ans zurückstellen dachte. 🙂
                                    update github
                                      @sigi234
                                      ich wäre froh ich würde mal nen richtig komplizierten Fehler machen. 🙂 4 Zeichen vergessen, weil ich weg musste. Wenn Online editiere ich mienen letzten Beitrag.
                                        @sigi234
                                        Wie bekomme ich den Ort in die Mail Vorlage? So geht es nicht:
                                          @sigi234
                                          Zur Zeit gehen in Title, Kopfzeile und Fußzeile keine Tokens ausser ${status}. Die 3. werden immer für jede Nachricht verwendet. In Kopf und Fußzeile geht es schon von der Codeseite aktuell nicht. Title ist ein ganz normale "Nachricht" bei keiner Nachricht sind die Tokens - keine Ahnung was dann da drin steht, ansonsten steht die Daten der letzten geschriebenen Warnung im Title bei Email und in Pushover immer die gerade bearbeitete.
                                          online
                                          Kann aber mal schauen ob ich da locationcustom rein bekomme. aber dann stehen alle locationscustoms da drin.
                                          Hm... hab bei Email das RemoveAll Template vergessen.
                                            update
                                            • locationcustom geht jetzt in Titel
                                            • RemoveAll als Vorlage im Admin Email eingefügt.
                                            Ich hab das für Emails jetzt so gelöst:
                                            Sortierung - neu, aufgehoben, gültig (die Sortierung nach startzeitpunkt fehlt da noch)
                                            Title da steht der Datensatz der 1. Warnung zur Verfügung und wenn keine Warnung da ist die Daten vom Controller - dieser enthält dann status (All Clear) und alle locationcustom
                                            So ohne weiteres bekomme ich bei aktiven Meldungen nicht alle locationscustoms da rein.
                                            Nochwas "nebensächliches" das beim Testen aber nach einem Fehler aussehen könnte... Alle konvertierten Vorlagen werden für 1 Minute gecacht. Da könnt ihr noch soviel auf manuelle Nachricht drücken. 🙂 Heißt auch der Status von Neu zu gültig ändert sich erst nach 1 Minute...
                                            Em und ich hab vergessen das Test ding zurück auf 1 Minute zu stelllen steht auf 15 Sekunden. 🙂
                                            EDIT: Und noch eine Besonderheit bei Emails:
                                            Aus der Meldung
                                            Kopfzeile
                                            Warnung vor Sturm
                                            Warnung vor Sturm
                                            Warnung vor Sturm
                                            Warnung vor Regen
                                            Fußzeile
                                            Wird vor dem Versand.
                                            Kopfzeile
                                            Warnung vor Sturm
                                            Warnung vor Regen
                                            Fußzeile
                                            Dabei zählt ob die Zeichenkette in der fertigen Meldung identisch zu andern ist.
                                            1077
                                            269462
