    4. [gelöst] IOB per https nicht erreichbar / Zertifikat def.
      schneidy76 @Thomas Braun last edited by Homoran
      Connecting to 192.168.0.115 port 22, please wait...
      login as: pi pi@192.168.0.115's password:
      Linux raspberrypi-Master 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Wed Oct 25 16:23:32 2023 from 192.168.0.202
      SSH is enabled and the default password for the 'pi' user has not been changed.
      This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      pi@raspberrypi-Master:~ $ iob restart admin
      The adapter "admin.0" was started.
      pi@raspberrypi-Master:~ $ iob diag
      The state system.host.raspberrypi-Master.versions.npmNewestNext was not found!
      The state system.host.raspberrypi-Master.versions.nodeCurrent was not found!
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      ======== Start marking the full check here =========
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi-Master
             Icon name: computer
      Operating System: Raspbian GNU/Linux 12 (bookworm)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
      Model    : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       17:03:17 up  4:20,  3 users,  load average: 1.47, 0.78, 0.62
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      No throttling issues detected.
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2023-10-25 17:03:17 BST
                 Universal time: Wed 2023-10-25 16:03:17 UTC
                       RTC time: n/a
                      Time zone: Europe/London (BST, +0100)
      System clock synchronized: yes
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:   false
      Desktop:
      Terminal:   tty
      Boot Target:   multi-user.target
      *** MEMORY ***
                     total        used        free      shared  buff/cache   available
      Mem:            1.9G        1.5G        222M         36K        250M        401M
      Swap:           104M        104M        630K
      Total:          2.0G        1.6G        222M
               1848 M total memory
               1464 M used memory
               1415 M active memory
                 31 M inactive memory
                212 M free memory
                  4 M buffer memory
                235 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      lifetime oom required: 0 Mbytes
      total time in oom handler: 0 ms
      max time spent in oom handler: 0 ms
      *** FAILED SERVICES ***
        UNIT LOAD ACTIVE SUB DESCRIPTION
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem     Type      Size  Used Avail Use% Mounted on
      /dev/root      ext4      118G   13G  101G  11% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      tmpfs          tmpfs     370M  868K  369M   1% /run
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1      vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      Messages concerning ext4 filesystem in dmesg:
      [Wed Oct 25 12:42:31 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:37:E1:5C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=043caf75-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): 11 orphan inodes deleted
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): recovery complete
      [Wed Oct 25 12:42:33 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Oct 25 12:42:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed Oct 25 12:42:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems \(real ones only\):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      Files in neuralgic directories:
      /var:
      1.1G  /var/
      651M  /var/log
      646M  /var/log/journal/55a635084cf04e71bfee02b63eaea0f9
      167M  /var/cache
      Archived and active journals take up 645.4M in the file system.
      /opt/iobroker/backups:
      6.8G  /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      464M  /opt/iobroker/iobroker-data/
      243M  /opt/iobroker/iobroker-data/files
      97M  /opt/iobroker/iobroker-data/backup-objects
      92M  /opt/iobroker/iobroker-data/node-red/node_modules
      The five largest files in iobroker-data are:
      30M  /opt/iobroker/iobroker-data/objects.jsonl
      21M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      19M  /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      8.9M  /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
      8.3M  /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs   v18.18.2
      /usr/bin/node     v18.18.2
      /usr/bin/npm     9.8.1
      /usr/bin/npx     9.8.1
      /usr/bin/corepack   0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1+rpi1 500
              500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Temp directories causing npm8 problem: 0
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:   5.0.12
      admin:     6.10.1
      javascript:   7.1.4
      Adapters from github:   5
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi-Master                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi-Master                       -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi-Master                       -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi-Master                       -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi-Master                       -  enabled
      + system.adapter.denon.0                  : denon                 : raspberrypi-Master                       -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi-Master                       -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi-Master                       -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi-Master                       -  enabled
      + system.adapter.enigma2.0                : enigma2               : raspberrypi-Master                       -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi-Master                       -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi-Master                       -  enabled
      + system.adapter.harmony.0                : harmony               : raspberrypi-Master                       -  enabled
      + system.adapter.history.0                : history               : raspberrypi-Master                       -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi-Master                       -  enabled
      + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
      + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
      + system.adapter.hm-rpc.5                 : hm-rpc                : raspberrypi-Master                       -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : raspberrypi-Master                       -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : raspberrypi-Master                       -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi-Master                       -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi-Master                       -  enabled
      + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
      + system.adapter.knx.0                    : knx                   : raspberrypi-Master                       -  enabled, bind: 192.168.0.115
        system.adapter.labcom.0                 : labcom                : raspberrypi-Master                       -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi-Master                       -  enabled, port: 54321
      + system.adapter.node-red.0               : node-red              : raspberrypi-Master                       -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi-Master                       -  enabled
      + system.adapter.parcel.0                 : parcel                : raspberrypi-Master                       -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi-Master                       -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi-Master                       -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi-Master                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.socketio.0               : socketio              : raspberrypi-Master                       -  enabled, port: 8084, bind: 192.168.0.115, run as: admin
      + system.adapter.solarlog.0               : solarlog              : raspberrypi-Master                       -  enabled, port: 80
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.sql.0                    : sql                   : raspberrypi-Master                       - disabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-Master                       -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-Master                       -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi-Master                       -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi-Master                       -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi-Master                       -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi-Master                       -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi-Master                       -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-Master                       -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi-Master                       -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wifilight.0              : wifilight             : raspberrypi-Master                       - disabled
      + instance is alive
      Enabled adapters with bindings
      ioBroker-Repositories
      sources       : conf/sources-dist.json
      online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
      stable        : http://download.iobroker.net/sources-dist.json
      beta          : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.1    , installed 2.8.1
      Adapter    "cec2"         : 0.1.1    , installed 0.1.1
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.5    , installed 2.8.5
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "flot"         : 1.12.0   , installed 1.12.0
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue"          : 3.10.1   , installed 3.10.0 [Updatable]
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "knx"          : 2.0.22   , installed 2.0.22
      Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "scenes"       : 2.3.9    , installed 2.3.9
      Adapter    "simple-api"   : 2.7.2    , installed 2.7.2
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "solarlog"     : 2.2.8    , installed 2.2.6  [Updatable]
      Adapter    "sonos"        : 2.3.1    , installed 2.3.1
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 1.0.1, installed 1.0.1
      Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
      Adapter    "vis-fancyswitch": 1.1.0  , installed 1.1.0
      Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
      Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material-advanced": 1.7.4, installed 1.7.4
      Adapter    "vis-metro"    : 1.2.0    , installed 1.2.0
      Adapter    "vis-timeandweather": 1.2.2, installed 1.2.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Objects and States
      Please stand by - This may take a while
      Objects:   14467
      States:   10597
      *** OS-Repositories and Updates ***
      W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       User       Inode      PID/Program name
      tcp        0      0 192.168.0.115:8701      0.0.0.0:*               LISTEN      1001       62182      7806/io.hm-rpc.5
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       63203      7739/node-red
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11243      552/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       63194      7739/node-red
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       63916      7595/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       61183      7595/iobroker.js-co
      tcp        0      0 192.168.0.115:2001      0.0.0.0:*               LISTEN      1001       61392      7776/io.hm-rpc.3
      tcp        0      0 192.168.0.115:2010      0.0.0.0:*               LISTEN      1001       63168      7791/io.hm-rpc.4
      tcp        0      0 192.168.0.115:8084      0.0.0.0:*               LISTEN      1001       65716      8101/io.socketio.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11245      552/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65757      8135/io.simple-api.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66688      8086/io.web.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       65580      8011/io.harmony.0
      udp        0      0 192.168.0.115:40058     0.0.0.0:*                           1001       80043      8161/io.knx.0
      udp        0      0 192.168.0.115:52383     0.0.0.0:*                           1001       81433      8161/io.knx.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       62372      7913/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11059      392/avahi-daemon: r
      udp        0      0 192.168.0.115:57675     0.0.0.0:*                           1001       63229      7739/node-red
      udp        0      0 192.168.0.115:46558     0.0.0.0:*                           1001       66752      8161/io.knx.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       64680      7898/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       64681      7898/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       65581      8011/io.harmony.0
      udp        0      0 192.168.0.115:35494     0.0.0.0:*                           1001       80850      8161/io.knx.0
      udp        0      0 192.168.0.115:43869     0.0.0.0:*                           1001       78660      8161/io.knx.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       63202      7739/node-red
      udp        0      0 0.0.0.0:54151           0.0.0.0:*                           108        11061      392/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15451      800/dhcpcd
      udp6       0      0 :::52333                :::*                                108        11062      392/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        11060      392/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13152      800/dhcpcd
      *** Log File - Last 25 Lines ***
      2023-10-25 17:00:15.764  - info: daswetter.0 (9535) cleaned everything up...
      2023-10-25 17:00:15.780  - info: host.raspberrypi-Master instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-25 17:00:18.622  - info: ical.0 (9565) Terminated (NO_ERROR): Without reason
      2023-10-25 17:00:19.153  - info: host.raspberrypi-Master instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-10-25 17:01:00.068  - info: host.raspberrypi-Master instance system.adapter.dwd.0 started with pid 9582
      2023-10-25 17:01:03.129  - info: dwd.0 (9582) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 17:01:04.128  - info: dwd.0 (9582) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-25 17:01:04.666  - info: host.raspberrypi-Master instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-10-25 17:02:00.090  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 started with pid 9597
      2023-10-25 17:02:03.010  - info: openweathermap.0 (9597) starting. Version 0.3.9 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 17:02:20.699  - info: openweathermap.0 (9597) Terminated (NO_ERROR): Without reason
      2023-10-25 17:02:21.232  - info: host.raspberrypi-Master instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2023-10-25 17:02:52.970  - info: host.raspberrypi-Master instance system.adapter.admin.0 started with pid 9666
      2023-10-25 17:02:57.004  - info: admin.0 (9666) starting. Version 6.10.1 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.12
      2023-10-25 17:02:57.066  - info: admin.0 (9666) requesting all objects
      2023-10-25 17:03:00.301  - info: admin.0 (9666) received all objects
      2023-10-25 17:03:01.130  - info: admin.0 (9666) Request actual repository...
      2023-10-25 17:03:01.178  - error: admin.0 (9666) Cannot create web-server: Error: error:05800074:x509 certificate routines::key values mismatch
      2023-10-25 17:03:01.182  - info: admin.0 (9666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-10-25 17:03:01.551  - error: admin.0 (9666) Cannot update news: TypeError: newNews.forEach is not a function
      2023-10-25 17:03:01.772  - warn: admin.0 (9666) Cannot check node.js/npm version
      2023-10-25 17:03:02.162  - info: admin.0 (9666) terminating https server on port 8081
      2023-10-25 17:03:02.565  - info: host.raspberrypi-Master Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-10-25 17:03:02.938  - info: host.raspberrypi-Master instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2023-10-25 17:03:02.939  - info: host.raspberrypi-Master Do not restart adapter system.adapter.admin.0 because desired by instance
      ============ Mark until here for C&P =============
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      ======================= SUMMARY =======================
            v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Installation:     native
      Kernel:     aarch64
      Userland:     armhf
      Timezone:     Europe/London (BST, +0100)
      User-ID:     1000
      X-Server:     false
      Pending OS-Updates:   0
      Pending iob updates:   3
      Nodejs-Installation:   /usr/bin/nodejs   v18.18.2
            /usr/bin/npm     9.8.1
            /usr/bin/npx     9.8.1
      Recommended versions are nodejs  and npm
      Your nodejs installation is correct
      MEMORY:
      Mem:            1.9G        1.5G        112M         36K        348M        389M
      Swap:           104M        104M        245K
      Total:          2.0G        1.7G        112M
      Active iob-Instances:   34
      ioBroker Core:     js-controller     5.0.12
            admin       6.10.1
      ioBroker Status:   iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Status admin and web instance:
      Objects:     14467
      States:     10597
      Size of iob-Database:
      4.0M  /opt/iobroker/iobroker-data/states.jsonl
      =================== END OF SUMMARY ====================
      === Mark text until here for copying ===
        schneidy76 @schneidy76 last edited by
        @schneidy76
        bin den Weg über eine zusätzliche Admin Instance gegangen. Ohne SSL geht es. Sobald ich das aktiviere, bekomme ich den Adapter nicht mehr grün.
        • bahnuhr
          bahnuhr Forum Testing Most Active @schneidy76 last edited by
          @schneidy76 sagte in Admin Webseite nicht mehr erreichbar:
          SSL
          was haste denn vor mit dem ssl ?
          • Codierknecht
            Codierknecht Developer Most Active @bahnuhr last edited by
            @bahnuhr sagte in Admin Webseite nicht mehr erreichbar:
            SSL
            @schneidy76
            Eben.
            Was willst Du mit SSL im Heimnetz?
              Ich nutze unter anderen den KNX Adapter (habe eine immer steigende Anzahl an KNX Teilnehmer bei uns im Haus). Unter anderen auch KNX-RF Geräte. Eine KNX-RF Linie benötigt eine Domain, ab da muss ich das KNX Projekt verschlüsseln.
              Um das Projekt, und damit die Gruppenadressen, korrekt einzulesen, benötige ich ebenfalls eine SSL Verschlüsselung von ioBroker.
              Warum, keine Ahnung, aber es ist eben so.... 😏
              Das Ganze lief ja auch 2 Jahre ohne Probleme.
              VG Torsten
              • bahnuhr
                Na, wenns so is, dann isses so.
                Ich bin damit aber raus.
                Codierknecht S 2 Replies Last reply Reply Quote 0
                • Codierknecht
                  Ich auch.
                  Security sucks! 😞
                    schneidy76 @bahnuhr last edited by
                    @bahnuhr Trotzdem Danke
                      schneidy76 @Codierknecht last edited by
                      @codierknecht ich habe den Betreff mal aktualisiert, vielleicht kann ja jemand helfen
                      • Marc Berg
                        Marc Berg Most Active last edited by Marc Berg
                        @schneidy76 sagte in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                        Wenn du jetzt eine weitere Admin-Instanz am Start hast, kannst du doch jetzt mal das Debug Log der Instanz "0" aktivieren, diese Instanz neu starten und das Log (nicht "iob diag"!) hier posten. Eine entsprechende Frage von @Thomas-Braun hattest du noch nicht beantwortet.
                          schneidy76 @Marc Berg last edited by
                          @marc-berg said in Admin Webseite nicht mehr erreichbar / SSL Keys defekt?:
                          Hallo Marc,
                          stelle ich den Log auf Debug um und starte die Admin.0 Instance mit SSL Authentifizierung, bekomme ich trotz den nicht startenden Adapter keine Meldung ins Log.
                          Also zurück auf INFO?
                          • Marc Berg
                            Marc Berg Most Active @schneidy76 last edited by
                            Gegenprobe: bekommst du bei der Instanz.1 Meldungen im Log, wenn du auf "debug" schaltest?
                              schneidy76 @Marc Berg last edited by schneidy76
                              @marc-berg
                              Gegenprobe 1: Admin.0 steht auf "Alles" und nichts kommt an
                              Gegenprobe 2: Admin.1 steht auf "Debug" Meldungen mit Level Debug kommen
                              1. Habe ein Update (Edit: auf Admin 6.12.0) angeboten bekommen und dieses ausgeführt. Augenscheinlich durchgelaufen, aber Fehler:
                              SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
                              im Dialogfenster.
                              Vg Torsten
                                Zwischenstand:
                                bin nun auf einen RP4 mit 8GB RAM umgestiegen.
                                Es gab einige Probleme beim Zurückspielen des Backups, die ich aber lösen konnte.
                                Jetzt läuft der ioBroker wieder stabil mit genügend Reserven.
                                Ich habe derzeit (zum Testen) 2 Admin Instanzen laufen:
                                Admin.0 mit https und Authentifizierung Port 8081
                                Admin.1 ohne SSL Port 8089
                                Instanz Admin.0 konnte ich starten, nachdem ich den Befehl:
                                iob cert create
                                gefunden habe.
                                Ich kann aber noch nicht per https zugreifen. Die Browser melden zurück:
                                192.x.x.x erfüllt die Sicherheitsstandards nicht.
                                ERR_SSL_SERVER_CERT_BAD_FORMAT
                                Hat jemand ne Idee?
                                Danke und VG Torsten
                                • Marc Berg
                                  @schneidy76 sagte in Admin per https nicht erreichbar / Zertifikatprobleme:
                                  Ich weiß ja nicht, welchen Browser du nutzt, normalerweise muss man ja das Verwenden von selbstsignierten Zertifikaten am Browser explizit bestätigen.
                                  Ein weiterer Klassiker bei solchen Fehlern ist ein falsch eingestellte Zeitzone und/oder Zeit. Prüf das mal.
                                    @marc-berg
                                    Hi Marc, den Firefox konnte ich überreden, die Website per https anzuzeigen.
                                    Ich musste dazu den erweiterten Schutz deaktivieren und explizit bestätigen, dass ich mir dem Risiko bewusst bin.
                                    Google Chrom konnte ich noch nicht dazu bewegen - Safe Browsing habe ich dort nun ebenfalls deaktiviert. Trotzdem zeigt der mir die Seite nicht an...
                                    Ich teste weiter... 💪
                                      schneidy76 @schneidy76 last edited by schneidy76
                                      Lösung:
                                      So nun habe ich es endlich hinbekommen. Der Ausflug zu letsencrypt ging schief, nach einigen schlaflosen durchdachten Nächten, habe ich eine Lösung gefunden:
                                      • Backup der bestehenden Installation erstellen und per WinSCP (o.ä.) auf dem PC sichern
                                      • iob stop
                                      • ioBroker Installation per sudo rm -r /opt/iobroker plattmachen
                                      • ioBroker nach der Anleitung: Klick mich neu installieren
                                      • Im Assistenten "Authentifizierung erforderlich" auswählen und Admin Password vergeben
                                      • Nach dem Abschluss die ioBroker Einstellungen öffnen und zum Reiter Zertifikate gehen
                                      • Beide Zertifikate einzeln komplett markieren und als "Nur Text" in einer separaten WordPad Datei speichern.
                                      • Backup mit WinSCP (o.ä.) zurückspielen und per iob restore 0 wiederherstellen
                                      • iob rebuild durchlaufen lassen und anschließend den ioBroker gestartet
                                      • wieder in die Einstellungen des ioBroker gehen und in dem Reiter Zertifikate die bestehenden Zertifikate mit X löschen
                                      • die vorher gesicherten Zertifikate aus den Dateien ersetzen
                                      • Sichern und Schließen --> anschließend Instance "Admin" neu starten
                                      • FERTIG
                                        Thomas Braun Most Active @schneidy76 last edited by
                                        Rechte des Verzeichnisses /opt auf 777 setzen
                                        per sudo rm -r /opt plattmachen
                                        Warum das? Hört sich komplett unnötig, gefährlich und planlos an.
                                          leider alternativlos denn ich brauche dringend den Zugang über https für mein KNX Projekt:
                                          Issues 251 GitHub
                                            Thomas Braun Most Active @schneidy76 last edited by Thomas Braun
                                            @schneidy76
                                            Ich meine das grobschlächtige löschen von /opt.
                                            Und warum setzt man das auf 'frei blasen für alle und jeden', wenn man das dann im nächsten Schritt ohnehin als root wegsenst?
                                            gelöst iobroker nicht erreichbar ssl error when loading ssl-zertifikat
                                            2118
