    4. jarvis v3.1.x - just another remarkable vis
      MCU @mpl1338 last edited by
      @mpl1338 Also, wenn Raffstore_Küche_fahren = true -> rauf und bei false -> runter?
        als Notlösung mach ich das über ein Skript. Wenn 100 dann true, wenn 0 dann false, wenn 1-99 dann 1-99
          mpl1338 @MCU last edited by
          @mcu said in jarvis v3.1.x - just another remarkable vis:
          true = runter(0), false = hoch(100)
            MCU @mpl1338 last edited by MCU
            @mpl1338
            https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/actionelement/blindlevelaction
            M S 2 Replies Last reply Reply Quote 0
              @mpl1338
              Super, funzt.
                smarthome2020 @MCU last edited by smarthome2020
                @mcu
                Bei mir spuckt das Skript auch Fehlermeldungen aus:
                Dazu wird mein ioBroker-Log auch zugespammt:
                javascript.0
                2023-10-26 21:15:09.679	error	at processTimers (node:internal/timers:512:7)
                javascript.0
                2023-10-26 21:15:09.679	error	at listOnTimeout (node:internal/timers:569:17)
                javascript.0
                2023-10-26 21:15:09.679	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
                javascript.0
                2023-10-26 21:15:09.679	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
                javascript.0
                2023-10-26 21:15:09.679	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
                javascript.0
                2023-10-26 21:15:09.679	error	at JSON.parse (<anonymous>)
                javascript.0
                2023-10-26 21:15:09.679	error	Error in callback: SyntaxError: Unexpected end of JSON input
                javascript.0
                2023-10-26 21:14:39.012	error	at processTimers (node:internal/timers:512:7)
                javascript.0
                2023-10-26 21:14:39.012	error	at listOnTimeout (node:internal/timers:569:17)
                javascript.0
                2023-10-26 21:14:39.012	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
                javascript.0
                2023-10-26 21:14:39.012	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
                javascript.0
                2023-10-26 21:14:39.012	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
                javascript.0
                2023-10-26 21:14:39.012	error	at JSON.parse (<anonymous>)
                javascript.0
                2023-10-26 21:14:39.012	error	Error in callback: SyntaxError: Unexpected end of JSON input
                EDIT: Habe die Datenpunkte unter Objekte alle gelöscht und das Skript nochmal neugestartet... Dann ging alles wieder.
                  MCU @smarthome2020 last edited by MCU
                  @smarthome2020 nameArr war anscheinend falsch? Was stand da drin?
                  Darf nicht gelöscht werden. Und wenn dann -> []
                    @mcu
                    War ein Schreibfehler drin.
                    Wie kann ich die Namen der Rubriken "category", "name", "ip" und "active" umbenennen bzw. ausblenden/löschen?
                      @smarthome2020
                      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/module/jsontable/v3.x.x
                        @mcu
                        Danke, nun läuft alles wie es soll.
                          @mcu
                          Läuft doch noch nicht alles optimal. Ich habe nun für alle Geräte in der nameArr Einstellungen vorgenommen.
                          Für ein Echo-Device, welches keine Weboberfläche hat, wird mir bei folgenden Einstellungen aber angezeigt, dass es in die Kategorie mit Weboberfläche gehört (wenn ich filter):
                              "ip": "192.168.xxx.xx",
                              "category": "Amazon",
                              "name": "Echo-Wohnzimmer"
                          Der Eintrag in jsonDevices lautet dabei:
                              "name": "Echo-Wohnzimmer",
                              "ip": "<button title=\"Echo-Wohnzimmer \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                              "active": true
                          In einem anderen Geräten, die keine Weboberfläche haben, sehen die Einträge so aus:
                                  "name": "Blink-Kamera"
                              "name": "Blink-Kamera",
                              "ip": "<button title=\"Blink-Kamera \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                              "active": true
                          Ich würde gerne das oberste Amazon-Gerät so abändern, dass es mir nicht in der Liste angezeigt wird, die an sich eine Weboberfläche haben sollte.
                            MCU last edited by
                            @smarthome2020 Versuch mal v1.0.5. Danke für den Hinweis.
                            S Marc_el_K 2 Replies Last reply Reply Quote 1
                              @mcu
                              Super 🙂 Geht nun. Danke für deine stets schnelle Hilfe.
                              • Marc_el_K
                                Marc_el_K @MCU last edited by
                                @mcu sagte in jarvis v3.1.x - just another remarkable vis:
                                Wäre es auch möglich folgende Adapter/Kategorien erkennen zu lassen?
                                • Tuja
                                • Tasmota
                                • Shelly
                                  MCU @Marc_el_K last edited by MCU
                                  @marc_el_k
                                  Du meintest im Script?
                                  Da brauch ich die ObjekteStruktur. Also einmal exportieren und hier einfügen.
                                  von tuja, tasmota, shelly
                                  Marc_el_K 1 Reply Last reply Reply Quote 0
                                    @mcu
                                    Ich habe nun versucht Grafana einzubinden in ein iFrame.
                                    Die Darstellung ist jedoch nicht wirklich gelungen:
                                    Kann man die Anzeige bearbeiten, so dass sich der Inhalt an das Widget anpasst? Finde dazu keine Einstellung.
                                      MCU last edited by MCU
                                      @smarthome2020 Was soll man einstellen?
                                      Wie sind denn die Einstellungen?
                                        @mcu
                                        Die Kurvendarstellung ist viel kleiner als das Widget es selber ist. Kann ich den Inhalt auf die Widgetgröße skalieren?
                                        Hier die Einstellungen:
                                          @smarthome2020 Passt sich bei mir automatisch an.
                                          Nimm mal das &kiosk=1 raus
                                          bei Sandbox-Optionen alle selektieren
                                            @mcu
                                            Ändert leider auch nichts:
                                            92
                                            1815
                                            662219
