    4. Test Adapter Linux Control v1.x.x
      Thomas Braun Most Active @Negalein last edited by
      @negalein sagte in Test Adapter Linux Control v1.x.x:
      Nein, definitiv nicht.
      Aber zu 99%iger Sicherheit. Der Code wartet an der Stelle auf eine bestimmt Tastatureingaben, die laufen aber bei virtuellen Tastaturen über einen anderen Kanal.
      • Negalein
        Negalein Global Moderator @Thomas Braun last edited by
        @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
        funktioniert bei dir? Oder knallt das auch ohne Abfragen durch?
        nega@ioBroker:/opt/iobroker$ iob nodejs-update
        iobroker [command]
        Commands:
          iobroker setup                                               Setup ioBroker
          iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
          iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
          iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
          iobroker info                                                Shows the host info
          iobroker logs [<adapter>]                                    Monitor log
          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
          iobroker rebuild [<module>]                                  Rebuild all native modules or path
          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
          iobroker update [<repositoryUrl>]                            Update repository and list adapters
          iobroker upgrade                                             Upgrade management
          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
          iobroker object                                              Object management  [aliases: o]
          iobroker state                                               State management  [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
          iobroker list <type> [<filter>]                              List all entries, like objects
          iobroker chmod <mode> <file>                                 Change file rights
          iobroker chown <user> <group> <file>                         Change file ownership
          iobroker touch <file>                                        Touch file
          iobroker rm <file>                                           Remove file
          iobroker file                                                File management
          iobroker user                                                User commands
          iobroker group                                               group management
          iobroker host <hostname>                                     Set host to given hostname
          iobroker set <adapter>.<instance>                            Change settings of adapter config
          iobroker license <license.file or license.text>              Update license by given file
          iobroker cert                                                Certificate management
          iobroker clean <yes>                                         Clears all objects and states
          iobroker backup                                              Create backup
          iobroker restore <backup name or path>                       Restore a specified backup
          iobroker validate <backup name or path>                      Validate a specified backup
          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
          iobroker repo [<name>]                                       Show repo information
          iobroker uuid                                                Show uuid of the installation  [aliases: id]
          iobroker unsetup                                             Reset license, installation secret and language
          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
          iobroker multihost                                           Multihost management
          iobroker compact                                             compact group management
          iobroker plugin                                              Plugin management
          iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
        Options:
          --help  Show help  [boolean]
        • Negalein
          dann hab ich ein Problem.
          Mit einer Hardware-Tastatur kann ich nicht.
            @negalein
            War ja auch nur meine Vermutung/Erklärung warum iob diag ohne Zwischenstopp durchrasselt.
              Thomas Braun Most Active @Negalein last edited by Thomas Braun
              @negalein
              Vor dem nodejs-update ist ein
              iob fix
              durchzuführen.
              Könnte sogar sein, dass danach iob diag funktioniert.
              • Negalein
                hab den Controller auch gleich geupdatet.
                Jetzt funktioniert auch iob diag wieder.
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                 Static hostname: ioBroker
                       Icon name: computer-container
                         Chassis: container
                  Virtualization: lxc
                Operating System: Ubuntu 22.04.3 LTS
                          Kernel: Linux 5.15.30-2-pve
                    Architecture: x86-64
                model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
                Docker          : false
                Virtualization  : lxc
                Kernel          : x86_64
                Userland        : amd64
                Systemuptime and Load:
                 17:44:09 up  2:03,  2 users,  load average: 0.93, 2.52, 2.31
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Thu 2023-10-26 17:44:09 CEST
                           Universal time: Thu 2023-10-26 15:44:09 UTC
                                 RTC time: n/a
                                Time zone: Europe/Vienna (CEST, +0200)
                              NTP service: inactive
                          RTC in local TZ: no
                *** User and Groups ***
                nega
                /home/nega
                nega adm dialout sudo users iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             10G        387M        8.2G        0.0K        1.4G        9.7G
                Swap:           2.0G          0B        2.0G
                Total:           12G        387M         10G
                        10048 M total memory
                          388 M used memory
                          845 M active memory
                          623 M inactive memory
                         8234 M free memory
                            0 M buffer memory
                         1425 M swap cache
                         2048 M total swap
                            0 M used swap
                         2048 M free swap
                *** FAILED SERVICES ***
                  UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                * iobroker.service     loaded failed failed ioBroker Server
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                2 loaded units listed.
                *** FILESYSTEM ***
                Filesystem                       Type   Size  Used Avail Use% Mounted on
                /dev/mapper/pve-vm--100--disk--0 ext4    45G   17G   26G  41% /
                10.0.1.21:/volume1/Backups       nfs4    14T   11T  3.7T  75% /opt/iobroker/backups
                none                             tmpfs  492K  4.0K  488K   1% /dev
                tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                tmpfs                            tmpfs  3.2G  148K  3.2G   1% /run
                tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
                dmesg: read kernel buffer failed: Operation not permitted
                TARGET                  SOURCE                           FSTYPE OPTIONS
                /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
                /var:
                2.6G    /var/
                2.1G    /var/log
                2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
                295M    /var/lib
                Archived and active journals take up 1.9G in the file system.
                /opt/iobroker/backups:
                599M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                4.7G    /opt/iobroker/iobroker-data/
                3.1G    /opt/iobroker/iobroker-data/history
                1.1G    /opt/iobroker/iobroker-data/files
                353M    /opt/iobroker/iobroker-data/files/vis.0
                327M    /opt/iobroker/iobroker-data/backup-objects
                57M     /opt/iobroker/iobroker-data/objects.jsonl
                35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
                31M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.18.2
                /usr/bin/node           v18.18.2
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                /usr/bin/corepack       0.19.0
                nodejs:
                  Installed: 18.18.2-1nodesource1
                  Candidate: 18.18.2-1nodesource1
                  Version table:
                 *** 18.18.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                        100 /var/lib/dpkg/status
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                     12.22.9~dfsg-1ubuntu3 500
                        500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                iobroker is not running on this host.
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.14
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   10
                Adapter State
                  system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                  system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
                  system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                  system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                  system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
                  system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
                  system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                  system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
                  system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
                  system.adapter.devices.0                : devices               : ioBroker                                 - disabled
                  system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
                  system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
                  system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                  system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
                  system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                  system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
                  system.adapter.enigma2.1                : enigma2               : ioBroker                                 -  enabled
                  system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
                  system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
                  system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                  system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
                  system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
                  system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
                  system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
                  system.adapter.history.0                : history               : ioBroker                                 -  enabled
                  system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                  system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
                  system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                  system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
                  system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
                  system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                  system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
                  system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
                  system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
                  system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
                  system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                  system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
                  system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
                  system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                  system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                  system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
                  system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
                  system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
                  system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
                  system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
                  system.adapter.mihome.0                 : mihome                : ioBroker                                 -  enabled, port: 9898, bind: 0.0.0.0
                  system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
                  system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
                  system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                  system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
                  system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
                  system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
                  system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
                  system.adapter.philips-tv-android.0     : philips-tv-android    : ioBroker                                 - disabled
                  system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
                  system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                  system.adapter.places.0                 : places                : ioBroker                                 - disabled
                  system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
                  system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
                  system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
                  system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
                  system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 -  enabled, port: 8002
                  system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
                  system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
                  system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
                  system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                  system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
                  system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
                  system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
                  system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                  system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
                  system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                  system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
                  system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                  system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                  system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                  system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                  system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
                  system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
                  system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
                + instance is alive
                ioBroker-Repositories
                Stable (default): http://download.iobroker.net/sources-dist.json
                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                Active repo(s): Beta (latest)
                Installed ioBroker-Instances
                Used repository: Beta (latest)
                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
                Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                Adapter    "birthdays"    : 2.4.0    , installed 2.4.0
                Adapter    "bring"        : 1.8.4    , installed 1.8.4
                Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                Adapter    "denon"        : 1.15.4   , installed 1.15.4
                Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                Adapter    "email"        : 1.2.0    , installed 1.2.0
                Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6
                Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                Adapter    "hue"          : 3.10.1   , installed 3.10.1
                Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "iot"          : 2.0.11   , installed 2.0.11
                Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.14   , installed 5.0.14
                Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
                Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                Adapter    "linux-control": 1.1.5    , installed 1.1.6
                Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                Adapter    "parser"       : 2.0.7    , installed 2.0.7
                Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
                Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                Adapter    "places"       : 1.1.2    , installed 1.1.2
                Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                Adapter    "proxmox"      : 2.2.0    , installed 2.2.0
                Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
                Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                Adapter    "seq"          : 0.3.0    , installed 0.3.0
                Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
                Adapter    "snmp"         : 3.1.0    , installed 3.1.0
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "synology"     : 3.0.1    , installed 3.0.1
                Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
                Adapter    "tractive-gps" : 0.1.2    , installed 0.1.2
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "unifi"        : 0.6.6    , installed 0.6.6
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
                Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Adapter    "xbox"         : 1.1.0    , installed 1.1.0
                Objects and States
                Objects:        52090
                States:         47239
                Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       378604442  13679/sshd: nega@pt
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          377972316  1/init
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          377973526  150/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          377975287  307/master
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        377974400  113/systemd-resolve
                tcp6       0      0 :::111                  :::*                    LISTEN      0          377972318  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          377973528  150/sshd: /usr/sbin
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          377975288  307/master
                tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       378604441  13679/sshd: nega@pt
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        377974399  113/systemd-resolve
                udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        377972518  100/systemd-network
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          377972317  1/init
                udp6       0      0 :::111                  :::*                                0          377972319  1/init
                2023-10-26 17:41:43.183  - warn: host.ioBroker instance system.adapter.nina.0 terminated due to SIGTERM
                2023-10-26 17:41:43.183  - info: host.ioBroker instance system.adapter.nina.0 terminated with code null ()
                2023-10-26 17:41:43.217  - warn: host.ioBroker instance system.adapter.parser.0 terminated due to SIGTERM
                2023-10-26 17:41:43.217  - info: host.ioBroker instance system.adapter.parser.0 terminated with code null ()
                2023-10-26 17:41:43.259  - warn: host.ioBroker instance system.adapter.pi-hole.0 terminated due to SIGTERM
                2023-10-26 17:41:43.259  - info: host.ioBroker instance system.adapter.pi-hole.0 terminated with code null ()
                2023-10-26 17:41:43.292  - warn: host.ioBroker instance system.adapter.proxmox.0 terminated due to SIGTERM
                2023-10-26 17:41:43.292  - info: host.ioBroker instance system.adapter.proxmox.0 terminated with code null ()
                2023-10-26 17:41:43.336  - warn: host.ioBroker instance system.adapter.rest-api.0 terminated due to SIGTERM
                2023-10-26 17:41:43.336  - info: host.ioBroker instance system.adapter.rest-api.0 terminated with code null ()
                2023-10-26 17:41:43.369  - warn: host.ioBroker instance system.adapter.samsung_tizen.0 terminated due to SIGTERM
                2023-10-26 17:41:43.369  - info: host.ioBroker instance system.adapter.samsung_tizen.0 terminated with code null ()
                2023-10-26 17:41:43.414  - warn: host.ioBroker instance system.adapter.telegram-menu.0 terminated due to SIGTERM
                2023-10-26 17:41:43.414  - info: host.ioBroker instance system.adapter.telegram-menu.0 terminated with code null ()
                2023-10-26 17:41:43.448  - warn: host.ioBroker instance system.adapter.trashschedule.0 terminated due to SIGTERM
                2023-10-26 17:41:43.448  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code null ()
                2023-10-26 17:41:43.497  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
                2023-10-26 17:41:43.497  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
                2023-10-26 17:41:43.530  - info: host.ioBroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                2023-10-26 17:41:43.585  - info: host.ioBroker instance system.adapter.influxdb.1 terminated with code 0 (NO_ERROR)
                2023-10-26 17:41:43.623  - info: host.ioBroker instance system.adapter.influxdb.2 terminated with code 0 (NO_ERROR)
                2023-10-26 17:41:43.663  - info: host.ioBroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
                2023-10-26 17:41:43.711  - info: host.ioBroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
                2023-10-26 17:41:43.711  - info: host.ioBroker All instances are stopped.
                2023-10-26 17:41:43.807  - info: host.ioBroker terminated
                iob diag has finished.
                Press any key for a summary
                  Das hatte ich vermutet.
                  • Negalein
                    Negalein Global Moderator @crunchip last edited by
                    @crunchip sagte in Test Adapter Linux Control v1.x.x:
                    da is nimmer viel Platz
                    wurde gerade vergrößert 😉
                    @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
                    Na dann stimmt etwas nicht, sollte 18.18.2 sein
                    erledigt 🙂
                    vllt mal die entsprechenden Datenpunkte löschen und neu hinzu fügen
                    System ist nun 100% aktuell.
                    DP gerade nochmal gelöscht.
                    Brachte aber leider nichts.
                    Ich bin ja nicht alleine mit dem Problem.
                    https://github.com/Scrounger/ioBroker.linux-control/pull/57
                    Leider bringt der Fork von ihm bei mir nichts neues.
                    copystring created this issue in Scrounger/ioBroker.linux-control
                    open Fix https://github.com/Scrounger/ioBroker.linux-control/issues/46 #57
                    Meister Mopper crunchip 2 Replies Last reply Reply Quote 0
                    • Meister Mopper
                      Meister Mopper @Negalein last edited by
                      Dann lügt deine Signatur 😉
                        crunchip Forum Testing Most Active @Negalein last edited by
                        Auch den Hinweis auf deine 2Gb backups gesehen?
                        Machst du nicht extern backups?
                        Dann dürfte in /opt/iobroker/backups eigentlich gar nichts liegen
                        Negalein Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Negalein
                          Ja, eigentlich schon.
                          Scheinen auch in der Syno auf.
                          Lösch ich auf der Syno, sind sie auch in ioB weg.
                          Hab das damals nach dem Tut. von Dutchman gemacht.
                          • Negalein
                            Negalein Global Moderator @Meister Mopper last edited by
                            nö 😉
                            da_Woody Meister Mopper 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @crunchip last edited by
                              Das Dateisystem ist permanent eingehängt.
                              • da_Woody
                                da_Woody @Negalein last edited by
                                @negalein immer der schummler. 🤠
                                Könntest aber noch iob diag einbauen... 🙄
                                  Thomas Braun Most Active @da_Woody last edited by Thomas Braun
                                  @da_woody
                                  Meinst du mich? Ist in iob diag natürlich schon drin:
                                  *** FILESYSTEM ***
                                  • da_Woody
                                    da_Woody @Thomas Braun last edited by
                                    @thomas-braun nope, meinte unser negalein! 😀
                                    • Meister Mopper
                                      nö 😉
                                      Doch, hast du nicht Ubuntu 22.04 lts installiert? 😉
                                      • David G.
                                        David G. last edited by
                                        Ich wollte eben mal AptUpgrade über den Adapter testen.
                                        Irgendwie micheoes nicht.
                                        sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                                        • Negalein
                                          @Scrounger
                                          kannst du zu meinem Issue irgendwas sagen?
                                          Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
                                          Er sagt irgendwas von invalid Characters. Aber welche?
                                          linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
                                          linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                                          linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
                                          linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                                          linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                          linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
                                          linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                          linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
                                          linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                          linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                          linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
                                          linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
                                          linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
                                          linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
                                          linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
                                          linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
                                          linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
                                          linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
                                          linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
                                          Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
                                          Aber warum? Ich hab nichts verändert an der Konfig.
                                          Was kann ich machen?
                                          • wendy2702
                                            wendy2702 @Negalein last edited by
                                            Das hakt ja schon hier:
                                            Gibt es den View noch?
                                            Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
                                            Wie sieht der aus?
                                            Gibt es das Device/laufwerk noch?
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            163894
