    4. Test Adapter Linux Control v1.x.x
      Thomas Braun Most Active @Negalein last edited by Thomas Braun
      @negalein
      Vor dem nodejs-update ist ein
      iob fix
      durchzuführen.
      Könnte sogar sein, dass danach iob diag funktioniert.
      • Negalein
        Negalein Global Moderator @Thomas Braun last edited by
        @thomas-braun sagte in Test Adapter Linux Control v1.x.x:
        hab den Controller auch gleich geupdatet.
        Jetzt funktioniert auch iob diag wieder.
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 22.04.3 LTS
                  Kernel: Linux 5.15.30-2-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         17:44:09 up  2:03,  2 users,  load average: 0.93, 2.52, 2.31
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Thu 2023-10-26 17:44:09 CEST
                   Universal time: Thu 2023-10-26 15:44:09 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CEST, +0200)
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        nega
        /home/nega
        nega adm dialout sudo users iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             10G        387M        8.2G        0.0K        1.4G        9.7G
        Swap:           2.0G          0B        2.0G
        Total:           12G        387M         10G
                10048 M total memory
                  388 M used memory
                  845 M active memory
                  623 M inactive memory
                 8234 M free memory
                    0 M buffer memory
                 1425 M swap cache
                 2048 M total swap
                    0 M used swap
                 2048 M free swap
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        * iobroker.service     loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type   Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--0 ext4    45G   17G   26G  41% /
        10.0.1.21:/volume1/Backups       nfs4    14T   11T  3.7T  75% /opt/iobroker/backups
        none                             tmpfs  492K  4.0K  488K   1% /dev
        tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs  3.2G  148K  3.2G   1% /run
        tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET                  SOURCE                           FSTYPE OPTIONS
        /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
        `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
        /var:
        2.6G    /var/
        2.1G    /var/log
        2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
        295M    /var/lib
        Archived and active journals take up 1.9G in the file system.
        /opt/iobroker/backups:
        599M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        4.7G    /opt/iobroker/iobroker-data/
        3.1G    /opt/iobroker/iobroker-data/history
        1.1G    /opt/iobroker/iobroker-data/files
        353M    /opt/iobroker/iobroker-data/files/vis.0
        327M    /opt/iobroker/iobroker-data/backup-objects
        57M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
        31M     /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.18.2
        /usr/bin/node           v18.18.2
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 18.18.2-1nodesource1
          Candidate: 18.18.2-1nodesource1
          Version table:
         *** 18.18.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.9~dfsg-1ubuntu3 500
                500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.14
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   10
        Adapter State
          system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
          system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
          system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
          system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
          system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
          system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
          system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
          system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
          system.adapter.devices.0                : devices               : ioBroker                                 - disabled
          system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
          system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
          system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
          system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
          system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
          system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
          system.adapter.enigma2.1                : enigma2               : ioBroker                                 -  enabled
          system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
          system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
          system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
          system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
          system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
          system.adapter.history.0                : history               : ioBroker                                 -  enabled
          system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
          system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
          system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
          system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
          system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
          system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
          system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
          system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
          system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
          system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
          system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
          system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
          system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
          system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
          system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 -  enabled
          system.adapter.mihome.0                 : mihome                : ioBroker                                 -  enabled, port: 9898, bind: 0.0.0.0
          system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
          system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
          system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
          system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
          system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
          system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
          system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
          system.adapter.philips-tv-android.0     : philips-tv-android    : ioBroker                                 - disabled
          system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
          system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          system.adapter.places.0                 : places                : ioBroker                                 - disabled
          system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
          system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
          system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
          system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
          system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 -  enabled, port: 8002
          system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
          system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
          system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
          system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
          system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
          system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
          system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
          system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
          system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
          system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
          system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
          system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
          system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
          system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Beta (latest)
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "birthdays"    : 2.4.0    , installed 2.4.0
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "device-watcher": 2.9.4   , installed 2.9.4
        Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
        Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fuelpricemonitor": 0.3.6 , installed 0.3.6
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hs100"        : 2.1.2    , installed 2.1.2
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.14   , installed 5.0.14
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "linux-control": 1.1.5    , installed 1.1.6
        Adapter    "logparser"    : 2.2.0    , installed 2.2.0
        Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mytime"       : 0.7.12   , installed 0.7.12
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "parser"       : 2.0.7    , installed 2.0.7
        Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "places"       : 1.1.2    , installed 1.1.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "proxmox"      : 2.2.0    , installed 2.2.0
        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
        Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "seq"          : 0.3.0    , installed 0.3.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 2.0.1    , installed 2.0.1
        Adapter    "telegram-menu": 0.8.3    , installed 0.8.3
        Adapter    "tractive-gps" : 0.1.2    , installed 0.1.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "unifi"        : 0.6.6    , installed 0.6.6
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
        Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "xbox"         : 1.1.0    , installed 1.1.0
        Objects and States
        Objects:        52090
        States:         47239
        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       378604442  13679/sshd: nega@pt
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          377972316  1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          377973526  150/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          377975287  307/master
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        377974400  113/systemd-resolve
        tcp6       0      0 :::111                  :::*                    LISTEN      0          377972318  1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          377973528  150/sshd: /usr/sbin
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          377975288  307/master
        tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       378604441  13679/sshd: nega@pt
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        377974399  113/systemd-resolve
        udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        377972518  100/systemd-network
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          377972317  1/init
        udp6       0      0 :::111                  :::*                                0          377972319  1/init
        2023-10-26 17:41:43.183  - warn: host.ioBroker instance system.adapter.nina.0 terminated due to SIGTERM
        2023-10-26 17:41:43.183  - info: host.ioBroker instance system.adapter.nina.0 terminated with code null ()
        2023-10-26 17:41:43.217  - warn: host.ioBroker instance system.adapter.parser.0 terminated due to SIGTERM
        2023-10-26 17:41:43.217  - info: host.ioBroker instance system.adapter.parser.0 terminated with code null ()
        2023-10-26 17:41:43.259  - warn: host.ioBroker instance system.adapter.pi-hole.0 terminated due to SIGTERM
        2023-10-26 17:41:43.259  - info: host.ioBroker instance system.adapter.pi-hole.0 terminated with code null ()
        2023-10-26 17:41:43.292  - warn: host.ioBroker instance system.adapter.proxmox.0 terminated due to SIGTERM
        2023-10-26 17:41:43.292  - info: host.ioBroker instance system.adapter.proxmox.0 terminated with code null ()
        2023-10-26 17:41:43.336  - warn: host.ioBroker instance system.adapter.rest-api.0 terminated due to SIGTERM
        2023-10-26 17:41:43.336  - info: host.ioBroker instance system.adapter.rest-api.0 terminated with code null ()
        2023-10-26 17:41:43.369  - warn: host.ioBroker instance system.adapter.samsung_tizen.0 terminated due to SIGTERM
        2023-10-26 17:41:43.369  - info: host.ioBroker instance system.adapter.samsung_tizen.0 terminated with code null ()
        2023-10-26 17:41:43.414  - warn: host.ioBroker instance system.adapter.telegram-menu.0 terminated due to SIGTERM
        2023-10-26 17:41:43.414  - info: host.ioBroker instance system.adapter.telegram-menu.0 terminated with code null ()
        2023-10-26 17:41:43.448  - warn: host.ioBroker instance system.adapter.trashschedule.0 terminated due to SIGTERM
        2023-10-26 17:41:43.448  - info: host.ioBroker instance system.adapter.trashschedule.0 terminated with code null ()
        2023-10-26 17:41:43.497  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGTERM
        2023-10-26 17:41:43.497  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
        2023-10-26 17:41:43.530  - info: host.ioBroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2023-10-26 17:41:43.585  - info: host.ioBroker instance system.adapter.influxdb.1 terminated with code 0 (NO_ERROR)
        2023-10-26 17:41:43.623  - info: host.ioBroker instance system.adapter.influxdb.2 terminated with code 0 (NO_ERROR)
        2023-10-26 17:41:43.663  - info: host.ioBroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
        2023-10-26 17:41:43.711  - info: host.ioBroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
        2023-10-26 17:41:43.711  - info: host.ioBroker All instances are stopped.
        2023-10-26 17:41:43.807  - info: host.ioBroker terminated
        iob diag has finished.
        Press any key for a summary
          @negalein sagte in Test Adapter Linux Control v1.x.x:
          Das hatte ich vermutet.
          • Negalein
            Negalein Global Moderator @crunchip last edited by
            @crunchip sagte in Test Adapter Linux Control v1.x.x:
            da is nimmer viel Platz
            wurde gerade vergrößert 😉
            @meister-mopper sagte in Test Adapter Linux Control v1.x.x:
            Na dann stimmt etwas nicht, sollte 18.18.2 sein
            erledigt 🙂
            vllt mal die entsprechenden Datenpunkte löschen und neu hinzu fügen
            System ist nun 100% aktuell.
            DP gerade nochmal gelöscht.
            Brachte aber leider nichts.
            Ich bin ja nicht alleine mit dem Problem.
            https://github.com/Scrounger/ioBroker.linux-control/pull/57
            Leider bringt der Fork von ihm bei mir nichts neues.
            copystring created this issue in Scrounger/ioBroker.linux-control
            open Fix https://github.com/Scrounger/ioBroker.linux-control/issues/46 #57
            Meister Mopper crunchip 2 Replies Last reply Reply Quote 0
            • Meister Mopper
              Meister Mopper @Negalein last edited by
              Dann lügt deine Signatur 😉
                crunchip Forum Testing Most Active @Negalein last edited by
                Auch den Hinweis auf deine 2Gb backups gesehen?
                Machst du nicht extern backups?
                Dann dürfte in /opt/iobroker/backups eigentlich gar nichts liegen
                Negalein Thomas Braun 2 Replies Last reply Reply Quote 0
                • Negalein
                  Ja, eigentlich schon.
                  Scheinen auch in der Syno auf.
                  Lösch ich auf der Syno, sind sie auch in ioB weg.
                  Hab das damals nach dem Tut. von Dutchman gemacht.
                  • Negalein
                    Negalein Global Moderator @Meister Mopper last edited by
                    nö 😉
                    da_Woody Meister Mopper 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @crunchip last edited by
                      Das Dateisystem ist permanent eingehängt.
                      • da_Woody
                        da_Woody @Negalein last edited by
                        @negalein immer der schummler. 🤠
                        Könntest aber noch iob diag einbauen... 🙄
                          Thomas Braun Most Active @da_Woody last edited by Thomas Braun
                          @da_woody
                          Meinst du mich? Ist in iob diag natürlich schon drin:
                          *** FILESYSTEM ***
                          • da_Woody
                            da_Woody @Thomas Braun last edited by
                            @thomas-braun nope, meinte unser negalein! 😀
                            • Meister Mopper
                              nö 😉
                              Doch, hast du nicht Ubuntu 22.04 lts installiert? 😉
                              • David G.
                                David G. last edited by
                                Ich wollte eben mal AptUpgrade über den Adapter testen.
                                Irgendwie micheoes nicht.
                                sudo: Leider dürfen die folgenden Umgebungsvariablen nicht gesetzt werden: DEBIAN_FRONTEND
                                • Negalein
                                  @Scrounger
                                  kannst du zu meinem Issue irgendwas sagen?
                                  Seit JS-Controller 5 kommen die Fehler und dein Adapter stoppt.
                                  Er sagt irgendwas von invalid Characters. Aber welche?
                                  linux-control.0 2023-11-05 15:21:15.201	error	adapter disabled
                                  linux-control.0 2023-11-05 15:20:43.666	error	[needrestart] Proxmox (10.0.1.201:22): error: Cannot find view "system", stack: Error: Cannot find view "system" at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4317:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4392:37)
                                  linux-control.0 2023-11-05 15:20:43.612	error	Cannot find view "system" for search "state" : Connection is closed.
                                  linux-control.0 2023-11-05 15:20:43.610	error	[servicesInfo] Proxmox (10.0.1.201:22): error: Connection is closed., stack: Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
                                  linux-control.0 2023-11-05 15:20:43.250	error	The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.250	error	Error: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2467:15) at StateRedisClient.subscribe (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1108:27) at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  linux-control.0 2023-11-05 15:20:43.184	error	unhandled promise rejection: The pattern "io.linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.184	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  linux-control.0 2023-11-05 15:20:43.181	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop
                                  linux-control.0 2023-11-05 15:20:43.177	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.177	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                  linux-control.0 2023-11-05 15:20:43.177	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.177	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  linux-control.0 2023-11-05 15:20:43.098	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.start changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.start
                                  linux-control.0 2023-11-05 15:20:43.098	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  linux-control.0 2023-11-05 15:20:43.088	error	Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.088	error	ReplyError: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                                  linux-control.0 2023-11-05 15:20:43.086	error	unhandled promise rejection: Error The pattern "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart" is not a valid ID pattern
                                  linux-control.0 2023-11-05 15:20:43.086	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  linux-control.0 2023-11-05 15:20:43.018	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.restart changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.restart
                                  linux-control.0 2023-11-05 15:20:42.973	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description" has no existing object, this might lead to an error in future versions
                                  linux-control.0 2023-11-05 15:20:42.971	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.description changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.description
                                  linux-control.0 2023-11-05 15:20:42.967	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running" has no existing object, this might lead to an error in future versions
                                  linux-control.0 2023-11-05 15:20:42.965	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.running changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.running
                                  linux-control.0 2023-11-05 15:20:42.962	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active" has no existing object, this might lead to an error in future versions
                                  linux-control.0 2023-11-05 15:20:42.958	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.active changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.active
                                  linux-control.0 2023-11-05 15:20:42.916	warn	State "linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load" has no existing object, this might lead to an error in future versions
                                  linux-control.0 2023-11-05 15:20:42.913	warn	Used invalid characters: linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.load changed to linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.load
                                  Das zB control.0.Proxmox.services.systemd-fsck@dev-disk-by\x2duuid-9C29\x2d4D7D.stop wurde lt. Log nach linux-control.0.Proxmox.services.systemd-fsck@dev-disk-by_x2duuid-9C29_x2d4D7D.stop geändert.
                                  Aber warum? Ich hab nichts verändert an der Konfig.
                                  Was kann ich machen?
                                  • wendy2702
                                    wendy2702 @Negalein last edited by
                                    Das hakt ja schon hier:
                                    Gibt es den View noch?
                                    Dann welche Version von Proxmox und ist der fsck ein selbst definierter Befehl ?
                                    Wie sieht der aus?
                                    Gibt es das Device/laufwerk noch?
                                    • Negalein
                                      Negalein Global Moderator @wendy2702 last edited by Negalein
                                      @wendy2702 sagte in Test Adapter Linux Control v1.x.x:
                                      Nein, hat es auch nie gegeben.
                                      10.0.1.201 = Proxmox
                                      10.0.1.202:8082/vis/index.html#080_System = ioB und die View heißt 080_System
                                      Gibt es das Device/laufwerk noch?>
                                      root@proxmox:~# ls -l /dev/disk/by-id/
                                      total 0
                                      lrwxrwxrwx 1 root root  9 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390 -> ../../sda
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part1 -> ../../sda1
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 ata-SanDisk_SDSSDH3_1T00_221348800390-part2 -> ../../sda2
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:06 ata-SanDisk_SDSSDH3_1T00_221348800390-part3 -> ../../sda3
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-root -> ../../dm-1
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-name-pve-swap -> ../../dm-0
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-name-pve-vm--100--disk--0 -> ../../dm-6
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-name-pve-vm--101--disk--0 -> ../../dm-7
                                      lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-name-pve-vm--102--disk--0 -> ../../dm-8
                                      lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-name-pve-vm--103--disk--0 -> ../../dm-9
                                      lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-name-pve-vm--104--disk--0 -> ../../dm-10
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-name-pve-vm--105--disk--1 -> ../../dm-12
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--106--disk--0 -> ../../dm-11
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-name-pve-vm--107--disk--0 -> ../../dm-13
                                      lrwxrwxrwx 1 root root 10 Nov  6 04:04 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxM3dxrDM3dBYhNgI8mpPV3YmfHk75VT2CZ -> ../../dm-8
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:00 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMEohxnWLY2pMegm2B06LWZhhOb4JtDLdQ -> ../../dm-6
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMOiAaJ18km9GOxKBboaWrAGtoGCssq5sm -> ../../dm-12
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMUldB8S2CZaYIN2ywWiLNCdTYvUJEz4ot -> ../../dm-0
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMdti3rBZdxZYTN3oDHliWCdLGGomqi2xj -> ../../dm-1
                                      lrwxrwxrwx 1 root root 10 Nov  6 04:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMfdz28y3obse8csoHkDgVo2rTfBy8uJfJ -> ../../dm-9
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMiOEhJ1hibDoUrRctAkyzN2exdG1ZcgxU -> ../../dm-13
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:05 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMljq2p7vA13bd3yyKg19GNtsJ0RmMBuBi -> ../../dm-7
                                      lrwxrwxrwx 1 root root 11 Nov  6 05:06 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMqu8b9ffqSwzJpJJH3V1dSl2uQhw8p3UP -> ../../dm-11
                                      lrwxrwxrwx 1 root root 11 Nov  6 04:07 dm-uuid-LVM-Um7uCQ5plpg4GO0G1hTw2LTdLSxAhLxMzv1OgYTuzbVrrzPLozpFivIdBr4F5xQv -> ../../dm-10
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:06 lvm-pv-uuid-gELFXe-CNIv-TyOf-EVPI-b8LY-bEn2-Pct9zA -> ../../sda3
                                      lrwxrwxrwx 1 root root  9 Sep  7 13:58 wwn-0x5001b448b72fa263 -> ../../sda
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part1 -> ../../sda1
                                      lrwxrwxrwx 1 root root 10 Sep  7 13:58 wwn-0x5001b448b72fa263-part2 -> ../../sda2
                                      lrwxrwxrwx 1 root root 10 Nov  6 05:06 wwn-0x5001b448b72fa263-part3 -> ../../sda3
                                      7.2-7
                                      Meister Mopper crunchip wendy2702 3 Replies Last reply Reply Quote 0
                                      • Meister Mopper
                                        7.2-7
                                        Ich fahre die 8.x und habe mit dem Adapter keine Pobleme. Aber vielleicht gibt es ja jemanden, der mit 7.2-7 auch keine Probleme hat, dann könnte man das Problem mglw. eingrenzen.
                                        • Negalein
                                          komisch ist, dass vor JS-Controller 5 keine Probleme waren.
                                          Muss mir mal das Tut für das Update auf 8.x anschaun.
                                          Auf den ersten Blick sieht es sehr umfangreich aus. 😞
                                          • Meister Mopper
                                            Meister Mopper @Negalein last edited by Meister Mopper
                                            Es war nicht kompliziert und ich habe meine komplette HA-Umgebung binnen ca. einer Stunde auf 8.x gehoben. Läuft hier auch sehr stabil, keinerlei Ausfälle oder Störungen.
                                            Wenn du ein Backup des node hast, kannst du das ja zurückpfeifen.
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            163896
