    4. jarvis v3.1.x - just another remarkable vis
      MCU @mpl1338 last edited by MCU
      @mpl1338
      https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/geraet/actionelement/blindlevelaction
      M S 2 Replies Last reply Reply Quote 0
        mpl1338 @MCU last edited by
        @mcu said in jarvis v3.1.x - just another remarkable vis:
        @mpl1338
        Super, funzt.
          smarthome2020 @MCU last edited by smarthome2020
          @mcu
          Bei mir spuckt das Skript auch Fehlermeldungen aus:
          Dazu wird mein ioBroker-Log auch zugespammt:
          javascript.0
          2023-10-26 21:15:09.679	error	at processTimers (node:internal/timers:512:7)
          javascript.0
          2023-10-26 21:15:09.679	error	at listOnTimeout (node:internal/timers:569:17)
          javascript.0
          2023-10-26 21:15:09.679	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
          javascript.0
          2023-10-26 21:15:09.679	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
          javascript.0
          2023-10-26 21:15:09.679	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
          javascript.0
          2023-10-26 21:15:09.679	error	at JSON.parse (<anonymous>)
          javascript.0
          2023-10-26 21:15:09.679	error	Error in callback: SyntaxError: Unexpected end of JSON input
          javascript.0
          2023-10-26 21:14:39.012	error	at processTimers (node:internal/timers:512:7)
          javascript.0
          2023-10-26 21:14:39.012	error	at listOnTimeout (node:internal/timers:569:17)
          javascript.0
          2023-10-26 21:14:39.012	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
          javascript.0
          2023-10-26 21:14:39.012	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
          javascript.0
          2023-10-26 21:14:39.012	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
          javascript.0
          2023-10-26 21:14:39.012	error	at JSON.parse (<anonymous>)
          javascript.0
          2023-10-26 21:14:39.012	error	Error in callback: SyntaxError: Unexpected end of JSON input
          EDIT: Habe die Datenpunkte unter Objekte alle gelöscht und das Skript nochmal neugestartet... Dann ging alles wieder.
            MCU @smarthome2020 last edited by MCU
            @smarthome2020 nameArr war anscheinend falsch? Was stand da drin?
            Darf nicht gelöscht werden. Und wenn dann -> []
              @mcu
              War ein Schreibfehler drin.
              Wie kann ich die Namen der Rubriken "category", "name", "ip" und "active" umbenennen bzw. ausblenden/löschen?
                @smarthome2020
                https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/module/jsontable/v3.x.x
                  @mcu
                  Danke, nun läuft alles wie es soll.
                    @mcu
                    Läuft doch noch nicht alles optimal. Ich habe nun für alle Geräte in der nameArr Einstellungen vorgenommen.
                    Für ein Echo-Device, welches keine Weboberfläche hat, wird mir bei folgenden Einstellungen aber angezeigt, dass es in die Kategorie mit Weboberfläche gehört (wenn ich filter):
                        "ip": "192.168.xxx.xx",
                        "category": "Amazon",
                        "name": "Echo-Wohnzimmer"
                    Der Eintrag in jsonDevices lautet dabei:
                        "name": "Echo-Wohnzimmer",
                        "ip": "<button title=\"Echo-Wohnzimmer \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                        "active": true
                    In einem anderen Geräten, die keine Weboberfläche haben, sehen die Einträge so aus:
                            "name": "Blink-Kamera"
                        "name": "Blink-Kamera",
                        "ip": "<button title=\"Blink-Kamera \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                        "active": true
                    Ich würde gerne das oberste Amazon-Gerät so abändern, dass es mir nicht in der Liste angezeigt wird, die an sich eine Weboberfläche haben sollte.
                      MCU last edited by
                      @smarthome2020 Versuch mal v1.0.5. Danke für den Hinweis.
                      S Marc_el_K 2 Replies Last reply Reply Quote 1
                        @mcu
                        Super 🙂 Geht nun. Danke für deine stets schnelle Hilfe.
                        • Marc_el_K
                          Marc_el_K @MCU last edited by
                          @mcu sagte in jarvis v3.1.x - just another remarkable vis:
                          Wäre es auch möglich folgende Adapter/Kategorien erkennen zu lassen?
                          • Tuja
                          • Tasmota
                          • Shelly
                            MCU @Marc_el_K last edited by MCU
                            @marc_el_k
                            Du meintest im Script?
                            Da brauch ich die ObjekteStruktur. Also einmal exportieren und hier einfügen.
                            von tuja, tasmota, shelly
                            Marc_el_K 1 Reply Last reply Reply Quote 0
                              @mcu
                              Ich habe nun versucht Grafana einzubinden in ein iFrame.
                              Die Darstellung ist jedoch nicht wirklich gelungen:
                              Kann man die Anzeige bearbeiten, so dass sich der Inhalt an das Widget anpasst? Finde dazu keine Einstellung.
                                MCU last edited by MCU
                                @smarthome2020 Was soll man einstellen?
                                Wie sind denn die Einstellungen?
                                  @mcu
                                  Die Kurvendarstellung ist viel kleiner als das Widget es selber ist. Kann ich den Inhalt auf die Widgetgröße skalieren?
                                  Hier die Einstellungen:
                                    @smarthome2020 Passt sich bei mir automatisch an.
                                    Nimm mal das &kiosk=1 raus
                                    bei Sandbox-Optionen alle selektieren
                                      @mcu
                                      Ändert leider auch nichts:
                                        @smarthome2020 Wie ist denn die Anzeige in Grafana? Evtl eingeschränkt?
                                        Die drei punkte rechts oben anklicken und auf view klicken
                                          @mcu
                                          Im Widget oder bei Grafana selbst?
                                            @smarthome2020 Jetzt im Widget
                                            92
                                            1815
                                            662194
