    4. jarvis v3.1.x - just another remarkable vis
      mpl1338 @MCU last edited by
      @mcu said in jarvis v3.1.x - just another remarkable vis:
      @mpl1338
      Super, funzt.
        smarthome2020 @MCU last edited by smarthome2020
        @mcu
        Bei mir spuckt das Skript auch Fehlermeldungen aus:
        Dazu wird mein ioBroker-Log auch zugespammt:
        javascript.0
        2023-10-26 21:15:09.679	error	at processTimers (node:internal/timers:512:7)
        javascript.0
        2023-10-26 21:15:09.679	error	at listOnTimeout (node:internal/timers:569:17)
        javascript.0
        2023-10-26 21:15:09.679	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
        javascript.0
        2023-10-26 21:15:09.679	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
        javascript.0
        2023-10-26 21:15:09.679	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
        javascript.0
        2023-10-26 21:15:09.679	error	at JSON.parse (<anonymous>)
        javascript.0
        2023-10-26 21:15:09.679	error	Error in callback: SyntaxError: Unexpected end of JSON input
        javascript.0
        2023-10-26 21:14:39.012	error	at processTimers (node:internal/timers:512:7)
        javascript.0
        2023-10-26 21:14:39.012	error	at listOnTimeout (node:internal/timers:569:17)
        javascript.0
        2023-10-26 21:14:39.012	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2777:34)
        javascript.0
        2023-10-26 21:14:39.012	error	at Object.<anonymous> (script.js.Peripherie.Jarvis.Fritzbox-Geräte:92:9)
        javascript.0
        2023-10-26 21:14:39.012	error	at setJSON (script.js.Peripherie.Jarvis.Fritzbox-Geräte:149:24)
        javascript.0
        2023-10-26 21:14:39.012	error	at JSON.parse (<anonymous>)
        javascript.0
        2023-10-26 21:14:39.012	error	Error in callback: SyntaxError: Unexpected end of JSON input
        EDIT: Habe die Datenpunkte unter Objekte alle gelöscht und das Skript nochmal neugestartet... Dann ging alles wieder.
          MCU @smarthome2020 last edited by MCU
          @smarthome2020 nameArr war anscheinend falsch? Was stand da drin?
          Darf nicht gelöscht werden. Und wenn dann -> []
            @mcu
            War ein Schreibfehler drin.
            Wie kann ich die Namen der Rubriken "category", "name", "ip" und "active" umbenennen bzw. ausblenden/löschen?
              @smarthome2020
              https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/module/jsontable/v3.x.x
                @mcu
                Danke, nun läuft alles wie es soll.
                  @mcu
                  Läuft doch noch nicht alles optimal. Ich habe nun für alle Geräte in der nameArr Einstellungen vorgenommen.
                  Für ein Echo-Device, welches keine Weboberfläche hat, wird mir bei folgenden Einstellungen aber angezeigt, dass es in die Kategorie mit Weboberfläche gehört (wenn ich filter):
                      "ip": "192.168.xxx.xx",
                      "category": "Amazon",
                      "name": "Echo-Wohnzimmer"
                  Der Eintrag in jsonDevices lautet dabei:
                      "name": "Echo-Wohnzimmer",
                      "ip": "<button title=\"Echo-Wohnzimmer \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                      "active": true
                  In einem anderen Geräten, die keine Weboberfläche haben, sehen die Einträge so aus:
                          "name": "Blink-Kamera"
                      "name": "Blink-Kamera",
                      "ip": "<button title=\"Blink-Kamera \"style=\"width: 120px; font-weight:bold; background-color:transparent; color:white; border: 2px solid green /* #1976d2 */; border-radius:10px;\" >192.168.xxx.xx</button>",
                      "active": true
                  Ich würde gerne das oberste Amazon-Gerät so abändern, dass es mir nicht in der Liste angezeigt wird, die an sich eine Weboberfläche haben sollte.
                    MCU last edited by
                    @smarthome2020 Versuch mal v1.0.5. Danke für den Hinweis.
                    S Marc_el_K 2 Replies Last reply Reply Quote 1
                      @mcu
                      Super 🙂 Geht nun. Danke für deine stets schnelle Hilfe.
                      • Marc_el_K
                        Marc_el_K @MCU last edited by
                        @mcu sagte in jarvis v3.1.x - just another remarkable vis:
                        Wäre es auch möglich folgende Adapter/Kategorien erkennen zu lassen?
                        • Tuja
                        • Tasmota
                        • Shelly
                          MCU @Marc_el_K last edited by MCU
                          @marc_el_k
                          Du meintest im Script?
                          Da brauch ich die ObjekteStruktur. Also einmal exportieren und hier einfügen.
                          von tuja, tasmota, shelly
                          Marc_el_K 1 Reply Last reply Reply Quote 0
                            @mcu
                            Ich habe nun versucht Grafana einzubinden in ein iFrame.
                            Die Darstellung ist jedoch nicht wirklich gelungen:
                            Kann man die Anzeige bearbeiten, so dass sich der Inhalt an das Widget anpasst? Finde dazu keine Einstellung.
                              MCU last edited by MCU
                              @smarthome2020 Was soll man einstellen?
                              Wie sind denn die Einstellungen?
                                @mcu
                                Die Kurvendarstellung ist viel kleiner als das Widget es selber ist. Kann ich den Inhalt auf die Widgetgröße skalieren?
                                Hier die Einstellungen:
                                  @smarthome2020 Passt sich bei mir automatisch an.
                                  Nimm mal das &kiosk=1 raus
                                  bei Sandbox-Optionen alle selektieren
                                    @mcu
                                    Ändert leider auch nichts:
                                      @smarthome2020 Wie ist denn die Anzeige in Grafana? Evtl eingeschränkt?
                                      Die drei punkte rechts oben anklicken und auf view klicken
                                        @mcu
                                        Im Widget oder bei Grafana selbst?
                                          @smarthome2020 Jetzt im Widget
                                            @mcu
                                            Da habe ich weniger Punkte als du in deinem Beispiel.
                                            92
                                            1815
                                            662194
