    4. Test Adapter Traccar v0.0.x
    • IdleBit
      IdleBit @ManfredHi last edited by
      @manfredh-1 Ja das ist richtig da ich noch keine neue Version rausgeben habe, werde ich aber gleich nachholen 😉
        liv-in-sky last edited by
        @arteck
        moin moin,
        habe jetzt erstmal alles vorbereitet (clients umgestellt,...) um deine neue version zu testen - werde nachher mal eine testfahrt machen um dir feedback zu geben.
        was aber jetzt schon sichtbar ist, ist folgende meldung: kommt bei all diesen datenpunkten - habe alle dp gelöscht und neu anlegen lassen
        traccar.1
        2023-10-28 05:58:59.061	info	State value to set for "traccar.1.geofences.6.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.5.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.4.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.3.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.059	info	State value to set for "traccar.1.geofences.2.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.3.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.058	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:59.050	info	State value to set for "traccar.1.devices.1.last_update" has to be type "string" but received type "number"
        traccar.1
        2023-10-28 05:58:58.755	info	Connect to server over websocket connection.
        traccar.1
        2023-10-28 05:58:58.549	info	starting. Version 1.1.3 (non-npm: arteck/ioBroker.traccar#b51ac9173cba2d182177d0742dce731caaf57eda) in /opt/iobroker/node_modules/iobroker.traccar, node: v18.17.1, js-controller: 5.0.12
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.37.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.36.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.35.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.34.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.33.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.32.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.461	info	State value to set for "traccar.0.geofences.30.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.29.last_update" has to be type "string" but received type "number"
        traccar.0
        2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.28.last_update" has to be type "string" but received type "number"
          arteck Developer Most Active @liv-in-sky last edited by arteck
          @liv-in-sky jo korrigiert..komisch dass du die meldung bekommst und ich nicht..
          M liv-in-sky 2 Replies Last reply Reply Quote 0
            MartyBr @arteck last edited by
            @arteck Ich habe gestern auch den Adapter installiert. Er liefert auch Werte von dem Traccar-Server.
            Ich habe eine Frage zu dem Adapter. Wo sehe ich die Änderungen? In Github sehe ich keine aktuellen Zeiten. Wie kann ich die neue Version installieren? Latest oder per Github?
              liv-in-sky @arteck last edited by liv-in-sky
              @arteck bin noch am testen - sieht ganz gut aus - leider wird die total_distance hochgezählt, obwohl ich gerade daheim stehe - ist kein adapter thema - liegt wohl am handy - suche gerade lösung
              State value to set for "traccar.1.geofences.26.last_update" has to be type "string" but received type "number"
              die meldung verstehe ich eh nicht - da steht ein datum drin - kein timestamp - ist aber immer noch da
                @liv-in-sky ja musst du den DP mal löschen..
                  arteck Developer Most Active @MartyBr last edited by
                  @martybr erstmal nur bei mir https://github.com/arteck/ioBroker.traccar
                    @arteck wie oben erwähnt - hatte ich schon gemacht
                      @liv-in-sky ach seh ich erst jetzt.. ist er andere DP.. jetzt nochmal von GIT
                      die total_distance kommt vom Server da rechnen wir nix
                        @arteck sagte in Test Adapter Traccar v0.0.x:
                        total_distance
                        ja - ich weiß - konte das über eine einstellung beenden
                        <entry key='filter.distance'>20</entry>
                         <entry key='filter.enable'>true</entry>
                          jetzt is es weg - mercy
                            @arteck
                            also momentan sieht es ganz gut aus - der letzte fahrtest und mein script hat seine aufgabe erfüllt
                            vielen dank, dass du dir die zeit genommen hast - werde ab montag weiter beobachten , wenn wieder "on-tour"
                            so sieht die history aus für geofencies:
                            also keine andauernden updates auf diesen dp 🙂
                              @liv-in-sky das klingt doch schon mal gut.. ich schieb es mal ins normal repo
                              • BananaJoe
                                BananaJoe Most Active last edited by
                                Ich bin gerade dabei mich darin einzuarbeiten.
                                Es gibt ja einen Datenpunkt in dem steht innerhalb welches Geofencing das Gerät sich befindet:
                                traccar.0.devices.1.geofences_string
                                Da steht bei mir nun z.B. Wohnort drin.
                                Meine Tochter bewegt sich nun schon zum 3 Geofence und unter Ihrem Gerät ändert sich nichts, also am
                                Umgekehrt sollte wohl bei den Geofences stehen wer gerade dort ist:
                                Aber dort habe ich auch nie etwas gesehen.
                                Muss ich auf der Traccar-Seite noch etwas einstellen?
                                Danke!
                                  liv-in-sky @BananaJoe last edited by liv-in-sky
                                  @bananajoe du musst im traccar server das geofence definieren und dann beim benutzer (handy) dieses geofence noch auswählen
                                  also die geofencies müssen auch dem handy zugewiesen werden
                                  • BananaJoe
                                    BananaJoe Most Active @liv-in-sky last edited by
                                    @liv-in-sky ah, ok, den Geofence "Wohnort" hatte ich aus dem Kontext meines Gerätes erstellt, deshalb war der gleich zugeordnet.
                                    Jetzt habe ich den Dialog an den Geräten gefunden, Danke!
                                    • N
                                      navlis last edited by
                                      Hallo ihr,
                                      Ich habe heute nacht mal den Tracccar server installiert und mein handy darin aufgenommen soweit so gut 👍
                                      Dann wollte ich den adapter verbinden, klappte auch.
                                      Aber ich erhalte keine Daten die zwei Zonen die ich angelegt habe so wie mein Handy nix kommt im adapter an ?
                                      Gibbet da nen geheimen Trick den ich net kenne oder bin ich erstmal zu doof 😅🫣
                                      Server und adapter sind die neueste Version
                                      Hoffe auf eure Hilfe
                                      LG
                                      Silvan
                                      crunchip liv-in-sky 2 Replies Last reply Reply Quote 0
                                        crunchip Forum Testing Most Active @navlis last edited by
                                        @navlis sagte in Test Adapter Traccar v0.0.x:
                                        also Verbindung steht?
                                        Server sowie Handy aktiv?
                                        welche Daten kamen an und welche fehlen?
                                          liv-in-sky @navlis last edited by
                                          @navlis hast du die 3 Posts über dir gelesen
                                          • N
                                            navlis @crunchip last edited by
                                            @crunchip der Server läuft da sehe ich mein Handy und auch positions Veränderungen so wie akku Stand.
                                            Der adapter sagt er ist verbunden aber ich habe keine Daten die ankommen die Ordner bleiben leer
                                            Danke für die schnelle Antwort 😉
                                            Screenshot_20240107_160650_Chrome.jpg Screenshot_20240107_160730_Chrome.jpg Screenshot_20240107_160836_Chrome.jpg
                                            31.7k
                                            79.8k
                                            adapter test traccar
                                            15
                                            88
                                            5976
