    3. Entwicklung
    4. [Neuer Adapter] Proxmox VM
      isch guck später nach
        A Former User @arteck last edited by
        @arteck sagte in [Neuer Adapter] Proxmox VM:
        ... wenn du schon dabei bist... hier kam gerade waehrend des Backups des LXC, indem iobroker laeuft, diese Errors:
        2023-10-27 12:26:58.713  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:26:58.714  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:26:58.832  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
        2023-10-27 12:26:58.669  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: unlocked
        2023-10-27 12:27:01.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2023-10-27 12:27:01.121  - info: sonoff.0 (640) Client [S5V-4] connection closed: closed
        2023-10-27 12:27:02.964  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Querying lock battery state: failed
        2023-10-27 12:27:03.716  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:08.116  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading config. Result: failed
        2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:08.719  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:09.061  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402429044_5996
        2023-10-27 12:27:11.065  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2023-10-27 12:27:12.460  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub BI: Reading advanced config. Result: failed
        2023-10-27 12:27:13.721  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:18.723  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:21.064  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2023-10-27 12:27:23.725  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:28.727  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:31.066  - warn: tuya.0 (788) bf88c2fc494909d538nhnf.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2023-10-27 12:27:32.385  - info: mqtt.1 (1223) Client [Presence1221] connection closed: timeout
        2023-10-27 12:27:33.730  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:38.732  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:43.734  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:48.735  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:48.736  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:53.738  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:27:56.752  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
        2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:27:58.740  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:02.713  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402482713_3323
        2023-10-27 12:28:03.321  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: unlocked
        2023-10-27 12:28:03.742  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:08.744  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:13.746  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:17.676  - warn: synochat.0 (5912) Attempt to send message '8b032070-74b3-11ee-8289-9fa88030d194' failed due to too fast sending sequence: 'create post too fast' > Delaying the message for 1 second/s...
        2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:18.748  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:23.750  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:28.752  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:33.753  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:38.756  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:41.532  - info: mqtt.1 (1223) Client [Presence1220] connection closed: timeout
        2023-10-27 12:28:43.758  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:48.760  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:48.890  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: Querying lock state: Querying lock state: Querying lock state: unlocked
        2023-10-27 12:28:53.762  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:28:58.764  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:01.064  - info: mqtt.1 (1223) Client [Presence1222] connection closed: timeout
        2023-10-27 12:29:02.932  - info: mqtt.1 (1223) Client [Presence1221] connection closed: closed
        2023-10-27 12:29:03.766  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:29:07.889  - info: javascript.0 (461) script.js.common.Nuki.mqtt2log: NUKI Hub WT: Querying lock state: Querying lock state: unlocked
        2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:08.769  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:13.229  - info: mqtt.1 (1223) Client [Presence1220] connected with secret 1698402553186_4082
        2023-10-27 12:29:13.771  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:29:16.778  - info: bluelink.0 (1435) Read new update for KMHKR81AFNU011963 directly from the car
        2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:18.773  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:21.407  - info: sonoff.0 (640) Client [nx4519-1] reconnected. Old secret 1698388565136_7187. New secret 1698402561404_1831
        2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends publish. Ignore! Actual secret is 1698402561404_1831
        2023-10-27 12:29:21.506  - warn: sonoff.0 (640) Old client nx4519-1 with secret 1698388565136_7187 sends pingreq. Ignore! Actual secret is 1698402561404_1831
        2023-10-27 12:29:21.889  - info: mqtt.1 (1223) Client [Presence1221] connected with secret 1698402561878_5954
        2023-10-27 12:29:23.775  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:28.777  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:31.327  - info: mqtt.1 (1223) Client [Presence1222] connected with secret 1698402571314_8823
        2023-10-27 12:29:32.379  - info: tuya.0 (788) 30530530c45bbedb673e: Connect locally to device
        2023-10-27 12:29:32.380  - info: tuya.0 (788) 30530530c45bbedb673e Init with IP=10.1.12.106, Key=>':x*F6`S#`J14cF, Version=3.3
        2023-10-27 12:29:33.779  - error: proxmox.0 (78860) Unable to update ticket: -1
        2023-10-27 12:29:37.865  - info: bluelink.0 (1435) Update for KMHKR81AFNU011963 successfull
        2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Use Next Proxmox Host because of communication failure https://192.168.0.210:8006/api2/json/nodes/hpg380/storage/VMBackup/content
        2023-10-27 12:29:38.781  - error: proxmox.0 (78860) Error received response from /nodes/hpg380/storage/VMBackup/content
          arteck Developer Most Active @Guest last edited by arteck
          @ilovegym sagte in [Neuer Adapter] Proxmox VM:
          da ist der storage nicht da.. und da du nur 1 node hast oder nur angegeben hast, kann der nicht switchen
          früher war die meldung unterdrückt
            @arteck
            ja, weil er gerade am backup schreiben ist.. hmmpff d.h. die Meldung kommt jetzt immer, wenn ich ein Backup mache in Proxmox.. ? mit dem LXC.. ?
            Kann man da das Timeout hoeher setzen.. fuer den Fehler? er kommt genau einmal, wie im Logfile, dann ist wieder ruhe..
            • Negalein
              Negalein Global Moderator @arteck last edited by
              lösche den mal .. und starte den adapter neu
              Danke, funktioniert wieder.
                @ilovegym dann guckemal jetzt
                • bahnuhr
                  bahnuhr Forum Testing Most Active @arteck last edited by bahnuhr
                  @arteck
                  habe auch von git installiert.
                  Bitte noch überprüfen:
                  maxmem wird bei den Objekten nicht aktualisiert.
                  sowohl dies:
                  als auch dies:
                    arteck Developer Most Active @bahnuhr last edited by arteck
                    @bahnuhr
                    vm :
                    doch..die maschiene muss aber laufen..
                    node schau ich noch
                    das ist die einstellung
                    • bahnuhr
                      @arteck
                      Na klar ist die Maschine an.
                      Und ja, der DP wird bei start der Instanz aktualisiert.
                      Aber dann nicht mehr.
                      Die anderen DP von mem werden dagegen regelmäßig (so alle 30 Sek.) aktualisiert.
                      arteck ? 2 Replies Last reply Reply Quote 0
                        @bahnuhr guckmal jetzt
                        ausserdem macht der nur eine Aktualisierung wenn sich was geändert hat...
                          A Former User @bahnuhr last edited by A Former User
                          @bahnuhr sagte in [Neuer Adapter] Proxmox VM:
                          Moin,
                          max Mem. ist ja eher ein statischer Wert, der sich nicht laufend ändert, wohin gegen Mem. sich zur Laufzeit schon veränder, Du muss mal mit der Einstellung von MaxMem, spielen und dann schauen, ob die Änderung angezeigt wird.
                          VG
                          Bernd
                          • David G.
                            Neulich ist ja ein DP mit einer JSON der die Backups beinhaltet in den Adapter gekommen.
                            Ich habe da mal eine kleine Tabelle für meine Visu für gemacht.
                            Ist die Unterste Tabelle im ersten Post
                            https://forum.iobroker.net/topic/59661/zusammenstellung-meiner-tabellen?_=1701274643122
                            Edit:
                            @Meistertr
                            Wie oft wird die Datei mit den Infos über die Backups aktualisiert?
                            Durch die Tabelle habe ich jetzt gemerkt, dass es Teilweise Stunden braucht, bis ich aktuelle Daten bekomme.
                            • David G.
                              Seit dem ich die oben genannte Tabelle im Einsatz habe ist mir aufgefallen, dass mir der Adapter andauert abschmiert.
                              Mal nach ein paar Minuten, mL nach ein paar Stunden.
                              Das war der Log vor dem letzten Crash.
                              Jemand eine Idee?
                              -12-12 23:15:20.511  - debug: proxmox.0 (395719) found states: [["proxmox.0.storage.pve_tank","active","default_num",1],["proxmox.0.storage.pve_tank","avail","size",633887],["proxmox.0.storage.pve_tank","content","text","rootdir,images"],["proxmox.0.storage.pve_tank","total","size",1841664],["proxmox.0.storage.pve_tank","used_lev","level",65.58],["proxmox.0.storage.pve_tank","used","size",1207777],["proxmox.0.storage.pve_tank","shared","default_num",0],["proxmox.0.storage.pve_tank","type","text","zfspool"],["proxmox.0.storage.pve_tank","enabled","default_num",1]]
                              2023-12-12 23:15:33.369  - info: host.iobroker stopInstance system.adapter.proxmox.0 (force=false, process=true)
                              2023-12-12 23:15:33.373  - info: proxmox.0 (395719) Got terminate signal TERMINATE_YOURSELF
                              2023-12-12 23:15:33.373  - debug: proxmox.0 (395719) clearing request timeout
                              2023-12-12 23:15:33.374  - info: proxmox.0 (395719) terminating
                              2023-12-12 23:15:33.374  - info: proxmox.0 (395719) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2023-12-12 23:15:33.417  - info: host.iobroker stopInstance system.adapter.proxmox.0 send kill signal
                              2023-12-12 23:15:33.874  - info: proxmox.0 (395719) terminating
                              2023-12-12 23:15:33.963  - info: host.iobroker instance system.adapter.proxmox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-12-12 23:15:36.519  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 395797
                              2023-12-12 23:15:37.898  - info: proxmox.0 (395797) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.proxmox, node: v18.19.0, js-controller: 5.0.12
                              2023-12-12 23:15:37.909  - warn: proxmox.0 (395797) Using Proxmox API: https://192.168.99.58:8006/api2/json
                              Ab hier kommt im Log nichts mehr mit Proxmox.
                              Adapter v. 2.2.2
                              Proxmox 8.3.1
                              Admin: 6.12.0
                              node: 18.19
                              O/S: bookworm
                                arteck Developer Most Active @David G. last edited by
                                @david-g poste mal den gesammten LOG..
                                David G. Eduard77 2 Replies Last reply Reply Quote 0
                                • David G.
                                  David G. @arteck last edited by
                                  @arteck
                                  Den gesamten mit allen Adaptern oder nur mit proxmox.0?
                                    @david-g gesamt
                                    • David G.
                                      @arteck
                                      Das Log ist 13 MB groß.
                                      Wie darf ich es dir zukommen lassen? Darf hier nicht so viel hochladen.
                                      Das PW vom Proxmoxuser habe ich ersetzt. Habe gesehen, dass das im Klartext im Log steht.
                                      Hoffe, das machen die anderen Adapter nicht. Hab beim überfliegen nichts gesehen.
                                        @david-g was läuft denn da ..13 mb .. alder.
                                        dann machmal ab 23 Uhr
                                        • David G.
                                          @arteck
                                          Anbei:
                                          iobroker.2023-12-12.log
                                          Zur Loggröße:
                                          Am 12ten lief der Proxmoxadapter.
                                          Da schiebe ich das eindeutig mal auf diesen.......
                                          Stand aber glaube auch auf debug, da ich mal sehen wollte ich ich was finde warum er abstürzt.
                                          Grad aber nciht sicher, ob das am 12ten auch noch so war.
                                            @david-g der startet neu.. und läuft danach.. nur warum der neu startet ??
                                            stell den mal auf debug,, dann ab der Zeile /das ist der start)
                                            bis nach abbruch posten
                                            ? David G. 2 Replies Last reply Reply Quote 0
                                            proxmox
                                            75
                                            486
                                            109319
