    4. Problem Deconz Bookworm
      Thomas Braun Most Active @Vandura last edited by
      @vandura
      iob diag
      sagt zur Umgebung?
      Vandura 1 Reply Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Vandura last edited by
        @vandura sagte in Problem Deconz Bookworm:
        sind alle auf geöffnet/ open true
        na dann solltest Du diese Sensoren mal manuell "In Bewegung" bringen. Türe, Fenster, usw auf und zumachen. vll hilft das ja.
        • Vandura
          Vandura @Thomas Braun last edited by
          @thomas-braun ```
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi4-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           13:33:43 up 35 min,  2 users,  load average: 0.66, 0.60, 0.74
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2023-10-28 13:33:43 CEST
                     Universal time: Sat 2023-10-28 11:33:43 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.2G        2.3G        5.4G        1.2M        609M        5.9G
          Swap:           104M          0B        104M
          Total:          8.3G        2.3G        5.5G
                   7810 M total memory
                   2182 M used memory
                   2184 M active memory
                    319 M inactive memory
                   5169 M free memory
                     50 M buffer memory
                    530 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     782M  1.2M  780M   1% /run
          /dev/sda2      ext4      459G  5.7G  430G   2% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          /dev/sda1      vfat      510M   61M  450M  12% /boot/firmware
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Sat Oct 28 12:58:19 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:E2:12:0E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  115200 console=tty1 root=PARTUUID=02486d08-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sat Oct 28 12:58:25 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Oct 28 12:58:28 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime,commit=600
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          649M    /var/
          201M    /var/cache
          195M    /var/cache/apt
          183M    /var/log
          182M    /var/log/journal/7942b99bd7f64894befa33dc4a620fca
          Archived and active journals take up 181.7M in the file system.
          /opt/iobroker/backups:
          77M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          995M    /opt/iobroker/iobroker-data/
          519M    /opt/iobroker/iobroker-data/files
          219M    /opt/iobroker/iobroker-data/backup-objects
          133M    /opt/iobroker/iobroker-data/history
          62M     /opt/iobroker/iobroker-data/files/vis.0
          42M     /opt/iobroker/iobroker-data/states.jsonl
          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          23M     /opt/iobroker/iobroker-data/history/20201011/history.mihome-vacuum.0.history.allTableHTML.json
          21M     /opt/iobroker/iobroker-data/objects.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218695-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 500
                  100 /var/lib/dpkg/status
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          6.12.0
          javascript:     7.1.4
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
            system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9999
            system.adapter.material.0               : material              : raspberrypi                              -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
          + system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
            system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
          + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
          + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
            system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
            system.adapter.parcel.1                 : parcel                : raspberrypi                              - disabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.radar2.0                 : radar2                : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 0
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.tr-064.2                 : tr-064                : raspberrypi                              - disabled
          + system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
            system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
            system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          + system.adapter.yamaha.0                 : yamaha                : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): Stable (default)
          Installed ioBroker-Instances
          Used repository: Stable (default)
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
          Adapter    "backitup"     : 2.8.1    , installed 2.8.1
          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
          Controller "js-controller": 5.0.12   , installed 5.0.12
          Adapter    "kodi"         : 3.0.0    , installed 3.0.0
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
          Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
          Adapter    "openweathermap": 0.3.9   , installed 0.3.9
          Adapter    "parcel"       : 0.0.27   , installed 0.1.6
          Adapter    "radar2"       : 2.0.7    , installed 2.0.7
          Adapter    "shelly"       : 6.4.5    , installed 6.4.5
          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
          Adapter    "web"          : 6.1.2    , installed 6.1.2
          Adapter    "worx"         : 2.3.2    , installed 2.3.2
          Adapter    "ws"           : 2.5.5    , installed 2.5.5
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Objects and States
          Objects:        12744
          States:         11357
          W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
          Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18792      1504/io.sonoff.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18901      1624/io.shelly.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          631        744/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15838      552/deCONZ
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       16544      552/deCONZ
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15976      735/iobroker.js-con
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       16593      735/iobroker.js-con
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19113      1880/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       979        1116/io.admin.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          633        744/sshd: /usr/sbin
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       19690      1535/io.mihome.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24597      2526/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       17714      552/deCONZ
          udp        0      0 0.0.0.0:48194           0.0.0.0:*                           104        15754      547/avahi-daemon: r
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       17334      1729/io.radar2.0
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       22808      2650/io.musiccast.0
          udp        0      0 0.0.0.0:54321           0.0.0.0:*                           1001       18940      1699/io.mihome-vacu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15752      547/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       24599      2526/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       24598      2526/io.deconz.0
          udp6       0      0 fe80::4cb3:1e25:d26:546 :::*                                0          15854      724/NetworkManager
          udp6       0      0 :::38081                :::*                                104        15755      547/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        15753      547/avahi-daemon: r
          2023-10-26 12:19:34.639  - info: host.raspberrypi received SIGTERM
          2023-10-26 12:19:34.640  - info: admin.0 (897) terminating http server on port 8081
          2023-10-26 12:19:34.645  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
          2023-10-26 12:19:34.646  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
          2023-10-26 12:19:34.646  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
          2023-10-26 12:19:34.662  - info: admin.0 (897) Got terminate signal TERMINATE_YOURSELF
          2023-10-26 12:19:34.664  - info: discovery.0 (904) Got terminate signal TERMINATE_YOURSELF
          2023-10-26 12:19:34.665  - info: backitup.0 (974) Got terminate signal TERMINATE_YOURSELF
          2023-10-26 12:19:34.668  - info: backitup.0 (974) terminating
          2023-10-26 12:19:34.668  - info: discovery.0 (904) terminating
          2023-10-26 12:19:34.668  - info: admin.0 (897) terminating
          2023-10-26 12:19:34.671  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
          2023-10-26 12:19:34.671  - info: backitup.0 (974) Terminated (NO_ERROR): Without reason
          2023-10-26 12:19:34.671  - info: discovery.0 (904) Terminated (NO_ERROR): Without reason
          2023-10-26 12:19:34.672  - info: admin.0 (897) Terminated (NO_ERROR): Without reason
          2023-10-26 12:19:34.673  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
          2023-10-26 12:19:34.674  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
          2023-10-26 12:19:35.150  - info: backitup.0 (974) terminating
          2023-10-26 12:19:35.150  - info: discovery.0 (904) terminating
          2023-10-26 12:19:35.151  - info: admin.0 (897) terminating
          2023-10-26 12:19:35.362  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
          2023-10-26 12:19:35.401  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
          2023-10-26 12:19:35.402  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
          2023-10-26 12:19:35.402  - info: host.raspberrypi All instances are stopped.
          2023-10-26 12:19:35.503  - info: host.raspberrypi terminated
            @vandura
            Schaut, abgesehen vom veralteten Setup des Phoscon-Repos, soweit okay aus.
            Welchen Adapter verwendest du? Deconz oder zigbee?
            Start sieht wie im LogFile aus?
            • Vandura
              @thomas-braun Deconz Adapter und das System ist so wie im diag
                Joh, deswegen schaut man sich das ja an. Um zu sehen wie das Setup des Systems ist.
                • Vandura
                  @thomas-braun Was meinst du mit " Schaut, abgesehen vom veralteten Setup des Phoscon-Repos" muß ich da was ändern?
                    Im Moment nicht zwingend. Das wird aber in künftigen Versionen zu einem Fehler werden.
                    Hier steht der aktuelle Weg drin:
                    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                    Vandura 1 Reply Last reply Reply Quote 1
                    • Vandura
                      @thomas-braun ok, schau ich mal.....ich bin jetzt Sensor für Sensor einmal im deconz unter neuen Sensor hinzufügen einmal anpingen, ( obwohl sie da sind )dann geht er wieder....aber kann ja nicht sein, das ich keinen reboot mehr machen kann......
                        Nö, das sollte aber auch damit nix zu tun haben.
                        systemctl status deconz*
                        sagt?
                        • Vandura
                          @thomas-braun sagte in Problem Deconz Bookworm:
                          ● deconz.service - deCONZ: ZigBee gateway -- REST API
                               Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabl>
                               Active: active (running) since Sat 2023-10-28 12:57:19 CEST; 2h 7min ago
                             Main PID: 552 (deCONZ)
                                Tasks: 5 (limit: 8740)
                                  CPU: 4min 40.254s
                               CGroup: /system.slice/deconz.service
                                       └─552 /usr/bin/deCONZ -platform minimal --http-port=80
                          Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee>
                          Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not se>
                          Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect >
                          Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagate>
                          Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagate>
                          lines 1-15/15 (END)...skipping...
                               Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabled)
                                  CPU: 4min 40.254s
                          Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
                          Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                          Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect sRGB profile
                          Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
                          Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
                            @vandura
                            Okay.
                            Und nach einem Reboot fehlen da Zigbee-Geräte?
                            • Vandura
                              @thomas-braun Nein, sie sind alle noch vorhanden, aber reagieren nicht mehr und gehen alle auf open / true.....rechable sind alle aber müssen dur knöpfendrücken neu registriert werden behalten aber zum Glück die alte Bezeichnung und Adresse
                                @vandura
                                Und wie sieht das in der Phoscon App aus?
                                • Vandura
                                  @thomas-braun Auch alle vorhanden und nicht augegraut, also das sie nicht erreichbar wäre......alles wie es sein muß
                                    Den Satz verstehe ich nicht.
                                    • Vandura
                                      Beispiel.......sollten sie nicht erreichbar sein, werden sie schwach grau.....
                                        @vandura
                                        Und die Sensoren, die hier als 'geschlossen' geführt werden tauchen im Adapter als 'geöffnet' auf?
                                        • Vandura
                                          @thomas-braun nein, sie tauchen überall als geöffnet auf, ist ein Bild, wo ich sie schon wieder angelernt habe
                                            Dann ist es ein Ding für Phoscon/Deconz. Der Adapter verarbeitet ja nur das was da vom Stick angeliefert wird. Wenn das nicht stimmt...
                                            4508
