    4. Problem Deconz Bookworm
      Thomas Braun Most Active @Vandura last edited by
      @vandura sagte in Problem Deconz Bookworm:
      aber kann ja nicht sein, das ich keinen reboot mehr machen kann......
      Nö, das sollte aber auch damit nix zu tun haben.
      systemctl status deconz*
      sagt?
      Vandura 1 Reply Last reply Reply Quote 0
      • Vandura
        Vandura @Thomas Braun last edited by
        @thomas-braun sagte in Problem Deconz Bookworm:
        ● deconz.service - deCONZ: ZigBee gateway -- REST API
             Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabl>
             Active: active (running) since Sat 2023-10-28 12:57:19 CEST; 2h 7min ago
           Main PID: 552 (deCONZ)
              Tasks: 5 (limit: 8740)
                CPU: 4min 40.254s
             CGroup: /system.slice/deconz.service
                     └─552 /usr/bin/deCONZ -platform minimal --http-port=80
        Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee>
        Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not se>
        Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect >
        Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagate>
        Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagate>
        lines 1-15/15 (END)...skipping...
             Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabled)
                CPU: 4min 40.254s
        Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
        Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
        Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect sRGB profile
        Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
        Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
          @vandura
          Okay.
          Und nach einem Reboot fehlen da Zigbee-Geräte?
          • Vandura
            @thomas-braun Nein, sie sind alle noch vorhanden, aber reagieren nicht mehr und gehen alle auf open / true.....rechable sind alle aber müssen dur knöpfendrücken neu registriert werden behalten aber zum Glück die alte Bezeichnung und Adresse
              @vandura
              Und wie sieht das in der Phoscon App aus?
              • Vandura
                @thomas-braun Auch alle vorhanden und nicht augegraut, also das sie nicht erreichbar wäre......alles wie es sein muß
                  Den Satz verstehe ich nicht.
                  • Vandura
                    Beispiel.......sollten sie nicht erreichbar sein, werden sie schwach grau.....
                      @vandura
                      Und die Sensoren, die hier als 'geschlossen' geführt werden tauchen im Adapter als 'geöffnet' auf?
                      • Vandura
                        @thomas-braun nein, sie tauchen überall als geöffnet auf, ist ein Bild, wo ich sie schon wieder angelernt habe
                          Dann ist es ein Ding für Phoscon/Deconz. Der Adapter verarbeitet ja nur das was da vom Stick angeliefert wird. Wenn das nicht stimmt...
                          • Vandura
                            @thomas-braun ok, dann werde ich mal dort den Kundendienst kontaktieren.....hätte ja sein können das in der Konfiguration irgend etwas krumm ist....Danke trotzdem für deine Geduld und Hilfe.....👍
                            Thomas Braun W 2 Replies Last reply Reply Quote 0
                              @vandura
                              Nur der Neugierde halber:
                              sudo apt update
                              apt policy deconz*
                              sagt?
                              • Vandura
                                pi@raspberrypi:~ $ sudo apt update
                                Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
                                Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                Hit:4 http://phoscon.de/apt/deconz bookworm InRelease
                                Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [83.7 kB]
                                Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [86.1 kB]
                                Fetched 218 kB in 3s (84.0 kB/s)
                                Reading package lists... Done
                                Building dependency tree... Done
                                All packages are up to date.
                                W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                pi@raspberrypi:~ $ apt policy deconz*
                                deconz:
                                 Installed: 2.23.02-debian-buster-stable
                                 Candidate: 2.23.02-debian-buster-stable
                                 Version table:
                                *** 2.23.02-debian-buster-stable 500
                                       500 http://phoscon.de/apt/deconz bookworm/main arm64 Packages
                                       100 /var/lib/dpkg/status
                                deconz-dev:
                                 Installed: (none)
                                 Version table:
                                pi@raspberrypi:~ $
                                  Wildbill @Vandura last edited by
                                  @vandura Nur zur Info. Auch mit dem Conbee und Phoscon/Deconz brauchen batteriebetriebene Geräte (wie Sensoren beispielsweise) teilweise längere Zeit, bis sie sich wieder mit dem aktuellen Stand bei Deconz melden. Ich habe da zwei Ikea-Schalter, die erst nach Stunden wieder mal einen Zustand melden. Danach dann aber zuverlässig.
                                  Wenn Du sofort nach einem Neustart den aktuellen Status eines Sensors willst, musst Du entweder die Pairung-taste einmal kurz drücken oder eben das Fenster einmal auf- und wieder zumachen.
                                  Wenn die Sensoren im Sekundentakt immer senden würden, könntest Du viermal am Tag die Batterien wechseln. So wird eben über längere Zeit mal ein Status gesendet, ansonsten nur bei Status-Änderungen.
                                  Das ist weder ein fehler von Deconz oder iobroker, sondern ganz normal.
                                  Gruss, Jürgen
                                  Thomas Braun Vandura 2 Replies Last reply Reply Quote 2
                                    Thomas Braun Most Active @Wildbill last edited by
                                    @wildbill
                                    Das stimmt. Hatte ich aber als bekannt vorausgesetzt.
                                    • Vandura
                                      Vandura @Wildbill last edited by Vandura
                                      @wildbill Ist ja richtig, aber das war vorher nicht so, da waren nach einem reboot alle Betriebsbereit und haben reagiert.
                                      und das öffnen und schließen, hat auch nichts gebracht.....Pairingtaste kurz auch nicht sondern erst ein langer Druck als wenn ich einen neuen anlernen möchte......
                                        @vandura Das war schon immer so und war nie anders. Batteriebetriebene Geräte reagieren auf ihre Status-Änderung oder wenn man sie manuell anstößt, indem man die Pairing-Taste drückt. Daran hat sich nie was geändert. Wie sollte es auch? Wenn es je anders gewesen wäre, dann hättest Du einen Berg leerer Batterien bei Dir rumliegen.
                                        Also entweder meinst Du etwas komplett anderes als wir, oder wir verstehen nicht, worum es Dir genau geht. Dann versuch doch bitte mal genau zu beschreiben, worin Dein jetziges Problem besteht, dass erst nach einem Update aufgetreten ist und vor allem, wie es vor dem Update genau war.
                                        Gruss, Jürgen
                                        Vandura 1 Reply Last reply Reply Quote 1
                                        • Vandura
                                          @wildbill
                                          Wir verstehen uns schon richtig.
                                          Der Zustand vor dem Update, war: Status der Sensoren auch nach einem reboot wie vor dem reboot, kein einziger Sensor hat seinen Zustand von false auf true geändert und war auch Betriebsbereit und hat reagiert wenn er benutzt wurde.
                                          Zustand jetzt: nach dem reboot gehen alle Sensoren auf true und reagieren auch nicht wenn sie benutzt werden oder auf kurzen Druck auf pairing. Erst ein langer Druck auf pairing mit deinschalten in der Deconz Oberfläche erweckt den Sensor wieder zum leben.
                                          Und großen Batterie Verbrauch habe ich nie gehabt und das System lief vorher schon über zwei Jahren mit diversen reboots.
                                            @vandura Redest Du von "falschen" Zuständen nach einem reboot in iobroker oder schon in Deconz/Phoscon?
                                            Was rebootest Du dabei? iobroker oder deconz? Oder ist es egal, welches davon?
                                            Gruss, Jürgen
                                            4489
