    4. Neuer Adapter für Roborock-Staubsauger
    • copystring
      copystring last edited by
      @darkdevil Die robot coords sind richtig. Dies inklusive den eckigen Klammern in den goto befehl einfügen.
        DarkDevil @copystring last edited by
        @copystring leider funktioniert es nicht und bringt diverse Fehler ins log:
        so sieht der DP aus:
        und das sind die Meldungen im log:
        host.iobroker-produktiv
        2023-10-21 08:25:30.671	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at processImmediate (node:internal/timers:476:21)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11181:53)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at Roborock.emit (node:domain:489:12)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at Roborock.emit (node:events:514:28)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at Roborock.onStateChange (/opt/iobroker/node_modules/iobroker.roborock/main.js:869:55)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: at JSON.parse (<anonymous>)
        2023-10-21 08:25:30.671	error	Caught by controller[1]: SyntaxError: Unexpected token ; in JSON at position 6
        2023-10-21 08:25:30.671	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        roborock.0
        2023-10-21 08:25:30.024	error	Unexpected token ; in JSON at position 6
        roborock.0
        2023-10-21 08:25:30.024	error	SyntaxError: Unexpected token ; in JSON at position 6 at JSON.parse (<anonymous>) at Roborock.onStateChange (/opt/iobroker/node_modules/iobroker.roborock/main.js:869:55) at Roborock.emit (node:events:514:28) at Roborock.emit (node:domain:489:12) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11181:53) at processImmediate (node:internal/timers:476:21)
        roborock.0
        2023-10-21 08:25:29.949	error	unhandled promise rejection: Unexpected token ; in JSON at position 6
        roborock.0
        2023-10-21 08:25:29.946	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        copystring 1 Reply Last reply Reply Quote 0
        • copystring
          copystring @DarkDevil last edited by copystring
          @darkdevil warum das Semikolon? Da muss ein Komma sein.
            @copystring super, jetzt funktioniert es
              andibr @DarkDevil last edited by
              Hallo zusammen
              Ich weiss meine Frage ist etwas "Off-Topic" aber wir sind hier ja lauter Roborock-Spezialisten. Habt ihr alle schwellelose Wohnungen oder wie macht ihr das mit euren Sauger?
              Mein Küche ist eben 43mm tiefer da geht der nicht drüber, absolut chancenlos. Habt ihr Rampen platziert, wenn ja wie steill sind die bei euch? Ich habe eine gebastelt mit 30cm länge, aber so verschmäht mein Roborock 7 und fährt darum rum.
              Gruss Andi
              • David G.
                David G. last edited by
                Aktualisiert sich bei euch das base64 der Map auch nicht mehr regelmäßig von selber?
                Irgendwie macht er das bei mir nur ganz sporadisch. Beim Start oder Ende der Reinigung.
                Wenn ich die gui neu lade, aktualisieren sich die Daten.
                  tobitobsta last edited by
                  mein log sagt mir ich soll das melden 😉
                  roborock.0 2023-10-27 12:09:18.178 warn Unknown block type! Please report this to the developer. Block type is:34
                  des weiteren kann ich irgendwie die datenpunkte im Bereich roborock.0.Devices.xxx.floors.0.16 etc nicht ändern. Der normale info-log gibt dazu gar nix aus. Und der debug-log ist so crowded, dass ich nicht weiß, ob das überhaupt mit meinem Versuch, den Datenpunkt zu ändern zu tun hat, bzw. ob es was bringt, das hier zu posten...
                    tobitobsta @tobitobsta last edited by
                    @tobitobsta said in Neuer Adapter für Roborock-Staubsauger:
                    ... okay.... also... Problem wohl war vor dem Rechner... jetzt funktioniert es scheinbar, wüsste aber nicht, dass ich was geändert hab. Aber solche Aussagen höre ich von meinem Vater auch dauernd und glaube ihme nicht 😉
                    Wolf Home 1 Reply Last reply Reply Quote 0
                    • Wolf Home
                      Wolf Home @tobitobsta last edited by
                      ist es jemanden schon gelungen, die Karte in AIO Neo einzubauen ?
                      Außerdem würde mich das Kamerabild noch interessieren ?
                        TimoWald last edited by
                        @jahnbes Hallo würdest du deine VIS für den Roborock mit mir teilen?
                        jahnbes 1 Reply Last reply Reply Quote 0
                        • jahnbes
                          jahnbes @TimoWald last edited by
                          @timowald
                          Hallo, würde ich gern, allein meine gui basiert nicht auf VIS, sondern ist mit HABPanel erstellt, und nutzt Dir somit wenig. Oder?
                          Viele Grüße, Bert.
                            TimoWald @jahnbes last edited by
                            @jahnbes mich würde die Befehle interessieren wie du den robbi losschickst um nur einen Raum zu reinigen.
                            • jahnbes
                              jahnbes @TimoWald last edited by jahnbes
                              @timowald
                              Kein Problem, ich hatte alles schon mal aufgeschrieben und mit Bildern versehen. Du findest hier im Thread am 28.7.23 unter jahnbes den Eintrag "Einzelraumreinigung".
                              Ich hoffe, es hilft. Wenn nicht, melde Dich bitte.
                              Gruß Bert
                              Einzelraumreinigung
                              eine Einzelraumreinigung vom iobroker, bzw. von der davor geschalteten gui aus, ist möglich:
                              Für die Einzelraumreinigung den gewünschten Raum unter floors auf true und alle anderen auf false setzen.
                              Anschließend [commands.app_segment_clean] auf true setzen. (Geht automatisch nach kurzer Zeit wieder auf false.)
                              Die Reinigung des Raumes beginnt.
                              Meiner Erfahrung nach reicht das noch nicht, sondern es müssen die Namen der Räume über die App (Handy) eingetragen worden sein. Eine Eintragung der Namen nur über den iobroker reicht nicht!
                              [Karten verwalten] -> gewünschte Etage [Bearbeiten] -> [Raum bearbeiten] -> [Name] -> Raum aus der Karte auswählen -> [Zimmertyp auswählen] -> [OK]
                              Ist das erfolgt, erscheint in der Kartendarstellung bei allen Räumen vor deren Bezeichnung auch das Icon und - Heureka - die Einzelraumreinigung funktioniert nun für jeden Raum!
                                DarkDevil @jahnbes last edited by
                                @jahnbes wie hast du die Karte so schick erstellt? Also mit Sofa etc? Meine ist einfach nur bunt 😂
                                jahnbes 2 Replies Last reply Reply Quote 0
                                • jahnbes
                                  jahnbes @DarkDevil last edited by jahnbes
                                  @darkdevil
                                  Hallo, keine Zauberei, sondern der direkte Weg, Screenshot auf dem Handy und als normales Bild zu Rechner, das war es.
                                  Das Sofa usw. reinzubringen, funktioniert zuvor in der roborock-App auf dem Handy.
                                  Viele Grüße, Bert.
                                    TimoWald @jahnbes last edited by TimoWald
                                    @jahnbes Hallo, habe mir jetzt mal HABPanel installiert. Dürfte ich deine Visu für den Roboter haben?
                                    Wieso zeigt er mit keine Werte bei life an?
                                    Welchen Befehl nutze ich für Rückkehr zur Ladestation?
                                    • jahnbes
                                      @timowald
                                      Viele Befehle und Rückgabewerte sind im Wiki aufgeführt, mal ausprobieren: Wiki
                                      Für die Rückkehr zur Ladestation setze [commands.app_charge] auf "true", dann fährt der Roborock los zum Laden.
                                      Ich kann dir gern meine HABPanel-Visu geben, allein, wie mache ich dass? Hast Du da eine Ahnung, was ich Dir schicken muss, ich habe das noch nie gemacht bei HABPanel.
                                      Ich könnte Dir den html-Code der Visu-Seite schicken, allein, das hilft nicht viel, das ist lediglich der html-Code dessen, was Du im Bild siehst, mehr nicht, Alles, was dahinter ist, jeden Befehl z.B. musst Du in HABPanel selbst erstellen. Jedenfalls sehe ich keinen anderen Weg. Das Wichtigste, was ich mir zusammen suchen musste, war, welche Kommandos ich wie ausführen und welche Werte ich wie auslesen musste. Das findest Du im oben erwähnten Wiki, jedenfalls den Teil davon, der mir bekannt ist.
                                        @jahnbes man kann doch das Projekt exportieren bzw. speichern in einer Datei. Oder?
                                        • jahnbes
                                          @darkdevil
                                          Ich habe eben erst bemerkt, dass Du möglicherweise das Einbauen der Möbelbilder meinst. Wenn ja, das geht in der Roborock-App so:
                                          gewünschten Roborock anklicken - rechts oben 3 Punkte anklicken - [Einstellungen] öffnet sich - [Karten verwalten] - auf gewünschter Karte [Bearbeiten] anklicken - [Möbel bearbeiten]
                                          Es erscheint die Karte und eine (kleine) Liste auswählbarer Möbelbilder, eines daraus auf der Karte platzieren, speichern - fertig.
                                          Nett ist, dass der Roborock dann auch im Bild unter dem Sofa verschwindet und Du nur noch mit Glück seinen Schemen siehst...
                                          • jahnbes
                                            @timowald
                                            Die Erstellung der history-Liste habe ich hier im Thread schon mal ausführlich beschrieben, schau mal meinen Eintrag unter jahnbes vom 31. Juli 2023, 15:17 an.
                                            Falls Du die drei Werte aus der Statistik meinst, die sind im Wiki aufgeführt.
                                            Das mit dem Exportieren in eine Datei muss ich erst mal erforschen.
                                            81.1k
                                            916
                                            311694
