    3. Off Topic
    4. Proxmox
    5. Proxmox has changed to `Bookworm`
    • Pedder007
      Pedder007 @Guest last edited by Pedder007
      @dp20eic auch moin :-), danke für Deine Rückmeldung.
      Ja den check hatte ich natürlich gemacht, ohne Auffälligkeiten, gerade aktuell nochmal und dabei kommt das heraus:
      (meine Syno (=Backup) schläft um die Zeit noch und die anderen Warnings kommen ja von den Containern, welche ich vor dem Upgrade-Versuch aber alle manuell gestoppt hatte):
      root@proxo:~# pve7to8
      = CHECKING VERSION INFORMATION FOR PVE PACKAGES =
      Checking for package updates..
      PASS: all packages up-to-date
      Checking proxmox-ve package version..
      PASS: proxmox-ve package has version >= 7.4-1
      Checking running kernel version..
      PASS: running kernel '5.15.116-1-pve' is considered suitable for upgrade.
      = CHECKING CLUSTER HEALTH/SETTINGS =
      SKIP: standalone node.
      = CHECKING HYPER-CONVERGED CEPH STATUS =
      SKIP: no hyper-converged ceph setup detected!
      = CHECKING CONFIGURED STORAGES =
      storage 'BackUp-Proxo' is not online
      WARN: storage 'BackUp-Proxo' enabled but not active!
      PASS: storage 'datatransfer' enabled and active.
      PASS: storage 'local' enabled and active.
      PASS: storage 'local-lvm' enabled and active.
      INFO: Checking storage content type configuration..
      PASS: no storage content problems found
      WARN: activating 'BackUp-Proxo' failed - storage 'BackUp-Proxo' is not online
      PASS: no storage re-uses a directory for multiple content types.
      = MISCELLANEOUS CHECKS =
      INFO: Checking common daemon services..
      PASS: systemd unit 'pveproxy.service' is in state 'active'
      PASS: systemd unit 'pvedaemon.service' is in state 'active'
      PASS: systemd unit 'pvescheduler.service' is in state 'active'
      PASS: systemd unit 'pvestatd.service' is in state 'active'
      INFO: Checking for supported & active NTP service..
      PASS: Detected active time synchronisation unit 'chrony.service'
      INFO: Checking for running guests..
      WARN: 5 running guest(s) detected - consider migrating or stopping them.
      INFO: Checking if the local node's hostname 'proxo' is resolvable..
      INFO: Checking if resolved IP is configured on local node..
      PASS: Resolved node IP '192.168.188.100' configured and active on single interface.
      INFO: Check node certificate's RSA key size
      PASS: Certificate 'pve-root-ca.pem' passed Debian Busters (and newer) security level for TLS connections (4096 >= 2048)
      PASS: Certificate 'pve-ssl.pem' passed Debian Busters (and newer) security level for TLS connections (2048 >= 2048)
      INFO: Checking backup retention settings..
      PASS: no backup retention problems found.
      INFO: checking CIFS credential location..
      PASS: no CIFS credentials at outdated location found.
      INFO: Checking permission system changes..
      INFO: Checking custom role IDs for clashes with new 'PVE' namespace..
      PASS: no custom roles defined, so no clash with 'PVE' role ID namespace enforced in Proxmox VE 8
      INFO: Checking if LXCFS is running with FUSE3 library, if already upgraded..
      SKIP: not yet upgraded, no need to check the FUSE library version LXCFS uses
      INFO: Checking node and guest description/note length..
      PASS: All node config descriptions fit in the new limit of 64 KiB
      PASS: All guest config descriptions fit in the new limit of 8 KiB
      INFO: Checking container configs for deprecated lxc.cgroup entries
      PASS: No legacy 'lxc.cgroup' keys found.
      INFO: Checking if the suite for the Debian security repository is correct..
      PASS: found no suite mismatch
      INFO: Checking for existence of NVIDIA vGPU Manager..
      PASS: No NVIDIA vGPU Service found.
      INFO: Checking bootloader configuration...
      SKIP: not yet upgraded, no need to check the presence of systemd-boot
      SKIP: NOTE: Expensive checks, like CT cgroupv2 compat, not performed without '--full' parameter
      = SUMMARY =
      TOTAL:    32
      PASSED:   24
      SKIPPED:  5
      WARNINGS: 3
      FAILURES: 0
      ATTENTION: Please check the output for detailed information!
      Installiert hatte ich das ganze System vor einiger Zeit komplett neu, also nicht auf einem bestehendem Image.
      Leider habe ich aber keinen Link mehr dahin, wobei es aber ein offizielles Proxmox Image war und ich danach dann die Quellen nach einem Tutorial auf 'nicht Enterprise' umgehängt hatte. Zu dem Zeitpunkt kannte ich leider noch nicht die Anleitung aus der ioBroker Doku.
      Den Hinweis bzgl.
      Upgrade wants to remove package 'proxmox-ve
      hatte ich auch bereits gefunden und auch schon befolgt:
      root@proxo:~# sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
      root@proxo:~# apt remove linux-image-amd64
      Reading package lists... Done
      Building dependency tree... Done
      Note, selecting 'pve-kernel-5.15' instead of 'linux-image-amd64'
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Danach kommt zwar keine Fehlermeldung mehr, aber es läuft auch kein Update:
      root@proxo:~# apt dist-upgrade
      Calculating upgrade... Done
      root@proxo:~# apt full-upgrade
      Wobei wenn ich jetzt oben lese:
      pve-kernel-5.15
      Bin ich da etwa "unter der Motorhaube" noch auf irgendeiner Alt-Version?
      In der Kopfzeile meines Proxmox steht auf jeden Fall:
      Edit: Jetzt hab ich's wieder. Von hier hatte ich das Image gezogen:
      https://www.proxmox.com/de/proxmox-virtual-environment/erste-schritte
      ... einen bootfähigen USB-Stick erstellt und dann den HP Elitedesk davon gebootet und installiert.
        tobrog @Pedder007 last edited by
        @pedder007 hast du denn das pve repo auch auf bookworm umgestellt?
        Ich habe noch diese Zeile im meiner source.list mit drin
        deb http://download.proxmox.com/debian/pve bookworm pve-no-subscription
        Pedder007 1 Reply Last reply Reply Quote 0
        • Pedder007
          Pedder007 @tobrog last edited by Pedder007
          @tobrog
          die steht bei mir in der:
          /etc/apt/sources.list.d/pve-enterprise.list
          ... ist dort allerdings auskommentiert:
          # deb https://enterprise.proxmox.com/debian/pve bookworm pve-enterprise
          In der GUI sieht das dann so aus:
          Muss ich die Zeile für das Upgrade wieder aktivieren?
          Edit: Ahh Moment, dass ist ja gar nicht die gleiche Zeile - man sollte mal die Augen aufmachen 😉
          Ok ich füge die mal in die 'source.list' ein und versuche es nochmal.
            @pedder007 Wenn du nicht die enterprise version benutzt, brauchst du das no-subscription repo. Klick einfach mal auf hinzufügen bei den repos und wähl dann das no-subscription repo aus.
            Pedder007 2 Replies Last reply Reply Quote 1
            • Pedder007
              @tobrog
              So, jetzt sieht's so aus, wobei ich das selber editieren musste.
              Der 'Add' Button tut's irgendwie nicht.
              Und ich meine so eine Zeile war da auch eigentlich immer drin ... !?
              • Pedder007
                @tobrog tja das wars wohl leider auch nicht:
                apt dist-upgrade` also auch 'apt full-upgrade' erzeugen dasselbe Ergebnis, wie auch schon gestern Abend:
                The following packages were automatically installed and are no longer required:
                  libjs-sencha-touch proxmox-kernel-helper
                Use 'apt autoremove' to remove them.
                The following packages will be REMOVED:
                  libgnutlsxx28 libnfsidmap2 libproxmox-acme-perl libproxmox-rs-perl libpve-access-control libpve-cluster-api-perl libpve-cluster-perl libpve-common-perl
                  libpve-guest-common-perl libpve-http-server-perl libpve-rs-perl libpve-storage-perl libpve-u2f-server-perl librados2-perl libsemanage1 lxc-pve proxmox-ve
                  pve-cluster pve-container pve-firewall pve-ha-manager pve-manager qemu-server
                The following NEW packages will be installed:
                  cron-daemon-common dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common dbus-user-session gcc-12-base i965-va-driver intel-media-va-driver
                  libboost-context1.74.0 libboost-filesystem1.74.0 libboost-iostreams1.74.0 libboost-program-options1.74.0 libboost-thread1.74.0 libbpf1 libcbor0.8
                  libdrm-amdgpu1 libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libevent-core-2.1-7 libffi8 libfile-find-rule-perl libflac12 libfmt9 libgprofng0 libicu72
                  libigdgmm12 libldap-2.5-0 libllvm15 libmp3lame0 libmpg123-0 libnfsidmap1 libnumber-compare-perl libpciaccess0 libperl5.36 libproc2-0 libprotobuf32
                  libpython3.11 libpython3.11-minimal libpython3.11-stdlib libsemanage2 libsepol2 libssl3 libsubid4 libsystemd-shared libtext-glob-perl liburcu8 libva-drm2
                  libva2 libvulkan1 libwayland-client0 libx11-xcb1 libxcb-dri2-0 libxcb-dri3-0 libxcb-present0 libxcb-randr0 libxcb-sync1 libxcb-xfixes0 libxshmfence1
                  libz3-4 mesa-va-drivers mesa-vulkan-drivers perl-modules-5.36 python3-distutils python3-lib2to3 python3.11 python3.11-minimal usrmerge util-linux-extra
                  va-driver-all
                The following packages will be upgraded:
                  apparmor apt apt-utils attr base-passwd bash bind9-dnsutils bind9-host bind9-libs binutils binutils-common binutils-x86-64-linux-gnu bridge-utils
                  bsd-mailx bsdextrautils bsdutils btrfs-progs busybox bzip2 ceph-common ceph-fuse chrony cifs-utils coreutils cpio criu cron cstream curl dash dbus
                  debianutils diffutils dirmngr dmeventd dmidecode dmsetup dpkg e2fsprogs ebtables efibootmgr eject faketime fdisk fdutils file findutils fontconfig fuse
                  gdisk genisoimage gettext-base glusterfs-client glusterfs-common gnupg gnupg-l10n gnupg-utils gnutls-bin gpg gpg-agent gpg-wks-client gpg-wks-server
                  gpgconf gpgsm gpgv grep groff-base grub-common grub-efi-amd64-bin grub-pc grub-pc-bin grub2-common gzip hdparm hostname init-system-helpers iproute2 ipset
                  iptables iputils-ping isc-dhcp-client kbd keyutils kmod less libacl1 libanyevent-perl libapparmor1 libapt-pkg-perl libapt-pkg6.0 libarchive13 libargon2-1
                  libasound2 libasound2-data libassuan0 libasyncns0 libattr1 libaudit1 libauthen-pam-perl libavahi-client3 libavahi-common-data libavahi-common3
                  libbabeltrace1 libbinutils libblkid1 libbsd0 libbz2-1.0 libc-bin libc6 libcairo2 libcap-ng0 libcap2 libcap2-bin libcephfs2 libclone-perl
                  libcommon-sense-perl libcrypt-openssl-bignum-perl libcrypt-openssl-random-perl libcrypt-openssl-rsa-perl libcrypt-ssleay-perl libcrypt1 libcryptsetup12
                  libctf0 libcups2 libcurl3-gnutls libcurl4 libdb5.3 libdbus-1-3 libdevmapper-event1.02.1 libdevmapper1.02.1 libdrm2 libdw1 libedit2 libelf1 libevent-2.1-7
                  libext2fs2 libfaketime libfdisk1 libfido2-1 libfilesys-df-perl libfontconfig1 libfreetype6 libfstrm0 libfuse2 libfuse3-3 libgbm1 libgcc-s1 libgcrypt20
                  libgdbm-compat4 libgdbm6 libgfapi0 libgfchangelog0 libgfrpc0 libglib2.0-0 libglusterfs0 libgnutls-dane0 libgnutls30 libgpg-error0 libgssapi-krb5-2
                  libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libharfbuzz0b libhtml-parser-perl libhttp-message-perl libibverbs1 libip4tc2 libip6tc2 libipset13
                  libisns0 libjemalloc2 libjson-c5 libjson-xs-perl libk5crypto3 libkmod2 libknet1 libkrb5-3 libkrb5support0 libksba8 libldb2 libleveldb1d
                  liblinux-inotify2-perl liblocale-gettext-perl liblua5.3-0 liblvm2cmd2.03 liblzma5 libmagic-mgc libmagic1 libmaxminddb0 libmd0 libmount1 libncurses6
                  libncursesw6 libnet-dbus-perl libnet-ssleay-perl libnetaddr-ip-perl libnewt0.52 libnftables1 libnftnl11 libnl-3-200 libnl-route-3-200 libnozzle1 libnspr4
                  libnss-systemd libnss3 libnuma1 liboath0 libopeniscsiusr libopts25 libp11-kit0 libpam-modules libpam-modules-bin libpam-systemd libpam0g libpango-1.0-0
                  libpangocairo-1.0-0 libpangoft2-1.0-0 libpcap0.8 libpci3 libpcre2-8-0 libpcre3 libpipeline1 libpopt0 libposix-strptime-perl libpsl5 libpulse0
                  libpython3-stdlib libqb100 librabbitmq4 librados2 libradosstriper1 librbd1 librdkafka1 librdmacm1 libreadline8 librgw2 librrd8 librrds-perl libsasl2-2
                  libselinux1 libsemanage-common libslang2 libslirp0 libsmartcols1 libsmbclient libsndfile1 libspice-server1 libsqlite3-0 libss2 libssh2-1 libstatgrab10
                  libstdc++6 libsystemd0 libtalloc2 libtdb1 libtemplate-perl libterm-readline-gnu-perl libtevent0 libtext-charwidth-perl libtext-iconv-perl libtinfo6
                  libtirpc3 libu2f-server0 libudev1 libunbound8 libunistring2 libunwind8 libuuid-perl libuv1 libvirglrenderer1 libwayland-server0 libwbclient0 libwrap0
                  libx11-6 libxml-libxml-perl libxml-parser-perl libxml2 libxslt1.1 libxtables12 libyaml-libyaml-perl libzstd1 locales login logrotate logsave lsb-base lsof
                  lvm2 man-db mount nano ncurses-base ncurses-bin ncurses-term nfs-common nftables nmap nmap-common open-iscsi openssh-client openssh-server
                  openssh-sftp-server openssl passwd pciutils perl perl-base perl-openssl-defaults pinentry-curses postfix procmail procps psmisc python3 python3-apt
                  python3-ceph-argparse python3-ceph-common python3-cephfs python3-ldb python3-minimal python3-protobuf python3-pycurl python3-rados python3-rbd python3-rgw
                  python3-talloc python3-yaml rpcbind rrdcached rsync rsyslog samba-common samba-libs sed smartmontools smbclient socat sqlite3 ssh strace sudo systemd
                  sysvinit-utils tar tcpdump thin-provisioning-tools time traceroute udev uidmap util-linux vim-common vim-tiny wget whiptail xfsprogs xxd xz-utils zstd
                358 upgraded, 71 newly installed, 23 to remove and 0 not upgraded.
                Need to get 0 B/259 MB of archives.
                After this operation, 303 MB of additional disk space will be used.
                Do you want to continue? [Y/n] Y
                W: (pve-apt-hook) !! WARNING !!
                W: (pve-apt-hook) You are attempting to remove the meta-package 'proxmox-ve'!
                W: (pve-apt-hook)
                W: (pve-apt-hook) If you really want to permanently remove 'proxmox-ve' from your system, run the following command
                W: (pve-apt-hook)       touch '/please-remove-proxmox-ve'
                W: (pve-apt-hook) run apt purge proxmox-ve to remove the meta-package
                W: (pve-apt-hook) and repeat your apt invocation.
                W: (pve-apt-hook)
                W: (pve-apt-hook) If you are unsure why 'proxmox-ve' would be removed, please verify
                W: (pve-apt-hook)       - your APT repository settings
                W: (pve-apt-hook)       - that you are using 'apt full-upgrade' to upgrade your system
                E: Sub-process /usr/share/proxmox-ve/pve-apt-hook returned an error code (1)
                E: Failure running script /usr/share/proxmox-ve/pve-apt-hook
                • Pedder007
                  Pedder007 @Pedder007 last edited by Pedder007
                  im Reiter 'Updates' stehen die ganzen Pakete auch zur Verfügung.
                  Soll ich darüber mal updaten?
                  Edit: Gerade probiert, die Konsole kommt dann aber mit dem gleichen Abschluss wie oben.
                  Pedder007 T 2 Replies Last reply Reply Quote 0
                  • Pedder007
                    @tobrog und @dp20eic so jetzt ging es endlich.
                    Der entscheidende Hinweis war die fehlende Zeile in der 'sources.list'
                    Ich musste danach allerdings nochmals alle Pfade in der 'sources.list' zurück nach 'bullseye' bringen.
                    Bei einem erneuten 'apt update' kam nun aber nochmal ein Proxmox Update von 'Virtual Environment 7.4.16 'auf 'Virtual Environment 7.4.17' mit, was ich gestern Abend nicht bekommen hatte, wahrscheinlich dann ja wegen der fehlenden Zeile.
                    Danach nochmals alle Schritte des Proxmox Update Tutorials wiederholt und nun steht da:
                    4f1ea12c-2187-4041-ac07-6fc1eae941ab-image.png 🙂
                    1000-Dank für Eure Hinweise!
                    Dann mache ich mich nun mal Schritt für Schritt an die Container 😉
                      tobrog @Pedder007 last edited by tobrog
                      @pedder007 Du hast die non-free Komponenten bei den debian repos nicht mit drin. Evtl liegt es daran.
                      Meine source.list sieht so aus:
                      deb http://ftp.debian.org/debian bookworm main contrib non-free non-free-firmware
                      deb http://ftp.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
                      deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
                      Edit: Unsere posts haben sich zeitlich überschnitten. Super dass es nun doch geklappt hat
                      • Pedder007
                        @tobrog ja 🙂
                        Bei mir sieht das jetzt so aus:
                        root@proxo:/etc/apt# cat sources.list
                        deb http://ftp.de.debian.org/debian bookworm main contrib
                        deb http://ftp.de.debian.org/debian bookworm-updates main contrib
                        # security updates
                        deb http://security.debian.org bookworm-security main contrib
                        Soll ich das jetzt noch ändern? - es scheint ja so ok zu sein!?
                        Es fehlen ja, glaube ich nur die Kommentare, oder?
                          A Former User @Pedder007 last edited by
                          @pedder007 sagte in Proxmox has changed to `Bookworm`:
                          Moin,
                          der Unterschied ist, dass @tobrog sein Proxmox, besser die Debian-Basis, auf die non-free Repositorien angelegt/eingerichtet hat, Du aber auf den Standard!
                          Wenn Du keine Hardware am Start hast, die spezielle Firmware braucht, dann bleib bei Deiner Einstellung, das ist soweit korrekt.
                          VG
                          Bernd
                          • Pedder007
                            @dp20eic ok danke 👍
                            Ich denke ein HP EliteDesk ist jetzt nicht so speziell 🙂
                              Moin,
                              das kannst nur Du beantworten, denn ich habe keine Lust mir die Spezifikationen, der PCs anzuschauen, um zu sehen, ob da ein WLAN, oder Netzwerkchip oder Soundkarte oder USB Treiber oder ... verbaut wurde, die nicht mit Open Source - Treibern funktionieren.
                              Solange, die Festplatten und das Netzwerk und die USB-Ports funktionieren, hast Du da sicherlich kein Bedarf und kannst so weiter machen.
                              VG
                              Bernd
                              Pedder007 1 Reply Last reply Reply Quote 1
                              • Pedder007
                                Hallo zusammen, ich komme da gerade, nachdem nun der Proxmox 'Host' und drei Container (Unifi, Pihole, Grafana/Influx) erfolgreich umgestellt sind, an einer Frage vorbei, wobei ich bei entsprechender Netz-Recherche bisher nicht fündig geworden bin.
                                Im aktuellen Setup greife ich von meinem Raspi4B ioBroker Master per ssh auf meinen Motioneye LXC Container (ioBroker Slave) zu um dort ggf. 1-2 kleine Scripte auszuführen (Umkonfiguration von Motioneye, welche nicht per zugehöriger API geht).
                                Meine Frage: Gibt es in einer Proxmox Instanz evtl. eine andere Möglichkeit (ohne ssh) von einem LXC Container entsprechend auf einen anderen LXC Container zuzugreifen?
                                Ich kann mich erinnern, dass ich mich seiner Zeit mit der ssh Einrichtung doch recht schwer getan hatte und wenn ich meinen Master nun auch in einen Container bringe, muss ich das natürlich komplett neu einrichten.
                                crunchip ? 2 Replies Last reply Reply Quote 0
                                  crunchip Forum Testing Most Active @Pedder007 last edited by
                                  um was genau handelt es sich, bzw was möchtest du genau?
                                    Moin,
                                    kannst Du das mal so beschreiben, dass das jemand auch versteht!
                                    Ich dachte, Du hast
                                    Wo kommt denn jetzt der LX Container mit Motioneye (iobroker Slave) her?
                                    Wie stellst Du Dir das denn vor, aus einer geschlossenen Installation LXC auf eine andere geschlossene Installation LXC zuzugreifen, ohne dass Du Dich authentifizieren musst?
                                    Außer Du installierst alles in einen LX Container oder einer VM.
                                    Ich kenne Deine Installation nicht, aber wieso laufen diese Skripte auf dem Slave, wieso fährst Du überhaupt Mast/erSlave?
                                    Also, am besten mal genau beschreiben, um was es geht, auch, was Du für Probleme hattest, ssh einzurichten, das ist eigentlich nicht allzu schwer!
                                    VG
                                    Bernd
                                    MartinP Pedder007 2 Replies Last reply Reply Quote 0
                                    • MartinP
                                      MartinP @Guest last edited by MartinP
                                      So eine "Matroschka - Puppe" aus Proxmox und Containern / Virtuellen Maschinen in allen Schalen eine Debian-Version weiter hochziehen ist ja mit gewissen Risiken verbunden.
                                      Was wären denn die Maßnahmen, hier vorab Risikominimierung zu betreiben?
                                      Was und wie sollte man z. B. Backups ziehen?
                                      Womit sollte man anfangen? Erst Proxmox hochziehen, dann die darunterliegenden Systeme, oder umgekehrt?
                                        A Former User @MartinP last edited by
                                        @martinp sagte in Proxmox has changed to `Bookworm`:
                                        Moin,
                                        keine Ahnung, wie das andere machen, aber ich halte die Basis immer aktuell, heißt, dass ich Proxmox immer als Erstes update, danach die LX Container, bei VMs interessiert das nicht wirklich, denn die haben ja ein vollständiges OS im Bauch, wobei auch da der Host immer aktuell seien sollte.
                                        Bei einer Migration vom Host, steht meist auch, ob es Unverträglichkeiten mit gewissen LXC oder VM gibt, die man zuerst beheben muss, ist aber alles nicht pauschal zu beantworten, denn jede Installation ist zu individuell.
                                        Habe ich z. B. noch alte Debian Buster Installationen oder alte Ubuntu VMs, dann bringe ich die zuerst auf einen aktuellen Stand, damit ich nicht zu weit, zwischen Host und Client auseinander drifte.
                                        Bei Proxmox, ganz klar ein Backup, der VM, des LXC, aus Proxmox heraus machen, bei ioBroker RasPi immer ein Backup mit BackitUp, bei RasPIs mit was weiß ich für Software ein Klon der SD-Karte.
                                        VG
                                        Bernd
                                        • Pedder007
                                          @dp20eic Hallo nochmal, sorry, man wird da mit der Zeit sicher auch etwas betriebsblind, was das eigene Setup angeht 🙂
                                          Also, Motioneye läuft bereits in einem weiteren Container, welcher aber noch nicht auf Bookworm umgestellt ist, deshalb war der in der geklammert Liste der Container oben nicht dabei. Da muss ich bei Motioneye erst noch nachlesen, welche 'Kinken' man da evtl. beachten muss. Es wird mit pip (Python) installiert und da gab es meines Wissens immer Extras zu beachten.
                                          Von meinem aktuellen Master greife ich aber heute, aus einem Blockly-Script, über ssh, auf den Motioneye Container zu um dort zwei Scripte zu starten, welche dann nichts anderes tun als Motioneye zu stoppen, zwei (Konfig-)Files um zu kopieren und danach Motioneye wieder zu starten.
                                          Meine Frage ging nun da hin, ob es bei Proxmox evtl. ein internes 'Bordmittel' gibt, um so einen Zugriff anders als mit ssh zu realisieren. Hintergrund dazu ist, dass ich plane meinen Master dann in einem der nächsten Schritte auch noch von eigener HW (Raspi) in einen eigenen Container zu verschieben.
                                          Grundsätzlich hatte ich vor einer Weile einmal damit angefangen bestimme Applikationen in Slaves auszulagern, um den Raspi zu entlasten und um da bei Updates auch unabhängiger von meiner ioBroker Instanz zu werden. Bei Motioneye war das dann tatsächlich auch eine Performance-Frage.
                                          Wird das nun klarer? 🙂
                                            Moin,
                                            nein, nicht wirklich 🙂
                                            Keine Ahnung, warum Du das tun musst, aber für mich würde das dann so möglich sein
                                            1. das Stoppen/Umkopieren/Starten auf den Motioneye LXC verlagern,
                                              • Cron
                                              • Skript, das läuft und auf ein Event/Trigger wartet, z. B. x ist nicht erreichbar
                                            2. ioBroker Adapter linux-control, ob das einfacher ist als ssh direkt, kann ich nicht beurteilen.
                                            3. die Ursache ermitteln/bekämpfen, warum man Stoppen/Umkopieren/Starten muss
                                            Ich sach mal, nein, das ist ja aus sicherheitstechnischen Gründen nicht gewollt, denn dann brauchte man ja keine User/Passwörter.
                                            VG
                                            Bernd
                                            81.1k
                                            90
                                            14503
