    4. Zigbee Instanz startet nicht mehr
      Thomas Braun Most Active @Tapdance last edited by
      @tapdance
      Und
      iob diag
      sagt nun?
        Tapdance @Thomas Braun last edited by
        @thomas-braun sagte in Zigbee Instanz startet nicht mehr:
        iob diag
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        449M    /var/
        127M    /var/cache
        124M    /var/lib
        120M    /var/cache/apt
        99M     /var/log
        Archived and active journals take up 96.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        355M    /opt/iobroker/iobroker-data/
        255M    /opt/iobroker/iobroker-data/files
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        70M     /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
        7.4M    /opt/iobroker/iobroker-data/states.jsonl
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /home/iobroker/.diag.sh: line 277: nodejs: command not found
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        /home/iobroker/.diag.sh: line 288: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.12
        admin:          6.12.0
        javascript:     7.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
        + instance is alive
        ioBroker-Repositories
        Aktuell       : http://download.iobroker.net/sources-dist-latest.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Stable (default): http://download.iobroker.net/sources-dist.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alarm"        : 3.4.0    , installed 3.3.13 [Updatable]
        Adapter    "backitup"     : 2.8.1    , installed 2.8.1
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "javascript"   : 7.1.4    , installed 7.1.4
        Controller "js-controller": 5.0.12   , installed 5.0.12
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
        Adapter    "socketio"     : 6.5.5    , installed 6.5.5
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "synology"     : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "web"          : 6.1.2    , installed 6.1.2
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "ws"           : 2.5.5    , installed 2.5.5
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        5305
        States:         4677
        W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
        Pending Updates: 148
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14823      538/cupsd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17006      540/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17628      540/iobroker.js-con
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20643      1547/io.sonoff.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15543      578/sshd: /usr/sbin
        tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       18180      1470/io.hm-rpc.0
        tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       19642      1495/io.hm-rpc.1
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22353      2250/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       28225      2650/io.admin.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22979      1944/io.terminal.0
        tcp6       0      0 :::35275                :::*                    LISTEN      1001       23436      2418/io.yahka.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14822      538/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15545      578/sshd: /usr/sbin
        udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19248      1583/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1677       398/avahi-daemon: r
        udp        0      0 0.0.0.0:54757           0.0.0.0:*                           1001       351092     22479/io.broadlink2
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19717      1530/io.shelly.0
        udp        0      0 0.0.0.0:57197           0.0.0.0:*                           1001       377275     22479/io.broadlink2
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1982       480/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16457      587/cups-browsed
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       351089     22479/io.broadlink2
        udp        0      0 0.0.0.0:35694           0.0.0.0:*                           108        1679       398/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        1678       398/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          17476      480/dhcpcd
        udp6       0      0 :::43833                :::*                                108        1680       398/avahi-daemon: r
        2023-10-27 17:52:10.911  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:19.566  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:21.278  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:29.796  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:31.618  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:39.953  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:41.998  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:50.165  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:52:52.359  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:00.319  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:02.699  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:10.506  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:13.092  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:20.642  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:23.456  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:30.807  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:33.826  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:40.960  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:44.212  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:51.213  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:53:54.646  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:54:01.387  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:54:06.526  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:54:11.638  - warn: shelly.0 (1530) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
        2023-10-27 17:54:17.044  - warn: shelly.0 (1530) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
        iob diag has finished.
          Thomas Braun Most Active @Tapdance last edited by Thomas Braun
          @tapdance
          Da fehlt der erste Teil.
          Ist aber eine 32bit-Installation. Bring das in die Gegenwart -> 64Bit Debian 12 'Bookworm' neuinstallieren.
            @thomas-braun aber das steht doch
            Architecture: arm64
            Gibt es für die installation 64Bit Debian 12 'Bookworm' eine Anleitung?
            Muss ich das systems dann komplett neu aufsetzen und eine Sicherung einspielen?
              Tapdance @Tapdance last edited by
              @tapdance ich hatte das so verstanden das folgendes mein Problem ist
              pi@raspberrypi:/etc/apt/sources.list.d $ apt policy udev
              udev:
                Installed: 247.3-7+rpi1+deb11u2
                Candidate: 247.3-7+rpi1+deb11u2
                Version table:
               *** 247.3-7+rpi1+deb11u2 500
                @tapdance sagte in Zigbee Instanz startet nicht mehr:
                Ja. Da gibt es aber keine gescheite Lösung mehr für ein 32Bit-System. Backports würde ich da nicht einspielen.
                Mach es neu:
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                Dann Backup einspielen, fertig.
                  @thomas-braun ok dann versuche ich das mal
                    DANKE das neuaufsetzen hat geklappt. Nach der neuinstallation habe ich als erstes
                    sudo apt-mark hold udev
                    gemacht damit das beschädigte packet garnbicht erst geladen wird dann alles andere aktualisiert und dann die sicherung zurückgespielt.
                    Zigbee stick funktioniert wieder leider habe ich jetzt ein anderes Problem. Meien Visualisierung läuft nicht mehr.
                    Deinstalieren und neu Instalieren habe ich schon versucht. Ich hoffe ihr könnt mir noch mal weiter helfen.
                    Hier das log
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                     Static hostname: raspberrypi
                           Icon name: computer
                              Kernel: Linux 6.1.0-rpi4-rpi-v8
                        Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     10:19:36 up 2 days, 15:24,  4 users,  load average: 0.66, 0.99, 0.89
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Mon 2023-10-30 10:19:36 CET
                               Universal time: Mon 2023-10-30 09:19:36 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    PI
                    /home/PI
                    PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        2.4G        744M         15M        1.0G        1.6G
                    Swap:           104M          0B        104M
                    Total:          4.1G        2.4G        849M
                             3793 M total memory
                             2254 M used memory
                             2348 M active memory
                              397 M inactive memory
                              709 M free memory
                               51 M buffer memory
                              923 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    Filesystem                              Type      Size  Used Avail Use% Mounted on
                    udev                                    devtmpfs  1.6G     0  1.6G   0% /dev
                    tmpfs                                   tmpfs     380M  1.3M  379M   1% /run
                    /dev/mmcblk0p2                          ext4       28G  6.2G   21G  24% /
                    tmpfs                                   tmpfs     1.9G  148K  1.9G   1% /dev/shm
                    tmpfs                                   tmpfs     5.0M   16K  5.0M   1% /run/lock
                    /dev/mmcblk0p1                          vfat      510M   73M  438M  15% /boot/firmware
                    tmpfs                                   tmpfs     380M   36K  380M   1% /run/user/1000
                    //192.168.2.3/all/SI-ioBrocker/Standard cifs       28T   23T  5.7T  80% /opt/iobroker/backups
                    [Fri Oct 27 19:55:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Fri Oct 27 19:55:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Fri Oct 27 19:55:26 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /                       /dev/mmcblk0p2                          ext4        rw,noatime,commit=600
                    |-/run/user/1000/doc    portal                                  fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                    |-/boot/firmware        /dev/mmcblk0p1                          vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    `-/opt/iobroker/backups //192.168.2.3/all/SI-ioBrocker/Standard cifs        rw,relatime,vers=1.0,cache=strict,username=Backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.2.3,soft,unix,posixpaths,serverino,mapposix,acl,rsize=1048576,wsize=1048576,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
                    /var:
                    510M    /var/
                    190M    /var/lib
                    178M    /var/cache
                    171M    /var/cache/apt
                    130M    /var/lib/apt/lists
                    Archived and active journals take up 40.0M in the file system.
                    1001M   /opt/iobroker/backups/
                    0       /opt/iobroker/backups/redistmp
                    338M    /opt/iobroker/iobroker-data/
                    245M    /opt/iobroker/iobroker-data/files
                    68M     /opt/iobroker/iobroker-data/backup-objects
                    18M     /opt/iobroker/iobroker-data/objects.jsonl
                    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
                    6.5M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /usr/bin/nodejs         v18.18.2
                    /usr/bin/node           v18.18.2
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    /usr/bin/corepack       0.19.0
                    nodejs:
                      Installed: 18.18.2-1nodesource1
                      Candidate: 18.18.2-1nodesource1
                      Version table:
                     *** 18.18.2-1nodesource1 500
                         18.18.1-1nodesource1 500
                         18.18.0-1nodesource1 500
                         18.17.1-1nodesource1 500
                         18.17.0-1nodesource1 500
                         18.16.1-1nodesource1 500
                         18.16.0-1nodesource1 500
                         18.15.0-1nodesource1 500
                         18.14.2-1nodesource1 500
                         18.14.1-1nodesource1 500
                         18.14.0-1nodesource1 500
                         18.13.0+dfsg1-1 500
                         18.13.0-1nodesource1 500
                         18.12.0-1nodesource1 500
                         18.11.0-1nodesource1 500
                         18.10.0-1nodesource1 500
                         18.9.1-1nodesource1 500
                         18.9.0-1nodesource1 500
                         18.8.0-1nodesource1 500
                         18.7.0-1nodesource1 500
                         18.6.0-1nodesource1 500
                         18.5.0-1nodesource1 500
                         18.4.0-1nodesource1 500
                         18.3.0-1nodesource1 500
                         18.2.0-1nodesource1 500
                         18.1.0-1nodesource1 500
                         18.0.0-1nodesource1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.4
                    Adapter State
                      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                    + instance is alive
                    Adapter    "alarm"        : 3.4.0    , installed 3.4.0
                    Objects and States
                    Objects:        5452
                    States:         4811
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       57223      14093/io.sonoff.0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14094      758/sshd: /usr/sbin
                    tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       57088      13999/io.hm-rpc.1
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51636      10767/iobroker.js-c
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52534      10767/iobroker.js-c
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1599726    115468/cupsd
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       59576      14108/io.terminal.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57281      14151/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51722      10795/io.admin.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1599725    115468/cupsd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14096      758/sshd: /usr/sbin
                    tcp6       0      0 :::35749                :::*                    LISTEN      1001       59641      14177/io.yahka.0
                    udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       60517      14127/io.tr-064.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14006      545/avahi-daemon: r
                    udp        0      0 0.0.0.0:60882           0.0.0.0:*                           1001       2089315    150158/io.broadlink
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       59651      14078/io.shelly.0
                    udp        0      0 0.0.0.0:36681           0.0.0.0:*                           1001       2089391    150158/io.broadlink
                    udp        0      0 0.0.0.0:55521           0.0.0.0:*                           1001       673391     10818/io.backitup.0
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1598109    115470/cups-browsed
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       2089312    150158/io.broadlink
                    udp        0      0 0.0.0.0:53948           0.0.0.0:*                           104        14008      545/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                104        14007      545/avahi-daemon: r
                    udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          18107      678/NetworkManager
                    udp6       0      0 :::35810                :::*                                104        14009      545/avahi-daemon: r
                    2023-10-30 10:20:05.154  - info: broadlink2.0 (150158) discover  [ '192.168.2.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:40677
                    2023-10-30 10:20:05.389  - info: broadlink2.0 (150158) Device RM:RMPRO-MOVE315-b1-1a-8d detected: address=192.168.2.169, mac=24:df:a7:b1:1a:8d, typ=RMP, id=0x27a9 devtype=RM3 Pro Plus
                    2023-10-30 10:20:10.388  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                    2023-10-30 10:20:10.389  - info: broadlink2.0 (150158) discover  [ '192.168.2.169' ] from 0.0.0.0:42251
                    2023-10-30 10:20:11.457  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:13.157  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:14.619  - warn: broadlink2.0 (150158) device RM:Broadlink-RM2-aa-80-31 not found, please rescan later again or delete it! It was: 192.168.2.227,80,10002,智能遥控,0,[object Object],b4:43:0d:aa:80:31,RM,RM:Broadlink-RM2-aa-80-31,0x2712,RM2,Broadlink-RM2-aa-80-31,RM:Broadlink-RM2-aa-80-31,26
                    2023-10-30 10:20:14.620  - warn: broadlink2.0 (150158) device RM:RM4-14-80-2b not found, please rescan later again or delete it! It was: 192.168.2.203,80,25278,智能遥控,0,[object Object],a0:43:b0:14:80:2b,RM4,RM:RM4-14-80-2b,0x62be,RM4c,RM4-14-80-2b,RM:RM4-14-80-2b,52078
                    2023-10-30 10:20:15.036  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                    2023-10-30 10:20:15.037  - info: broadlink2.0 (150158) discover  [ '192.168.2.227' ] from 0.0.0.0:51145
                    2023-10-30 10:20:17.248  - info: broadlink2.0 (150158) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
                    2023-10-30 10:20:17.250  - info: broadlink2.0 (150158) discover  [ '192.168.2.203' ] from 0.0.0.0:36681
                    2023-10-30 10:20:19.465  - info: broadlink2.0 (150158) Poll every 30 secods.
                    2023-10-30 10:20:19.466  - info: broadlink2.0 (150158) broadlink2.0 started and found 1 devices named RM:RMPRO-MOVE315-b1-1a-8d
                    2023-10-30 10:20:19.466  - info: broadlink2.0 (150158) 2 were not found: RM:Broadlink-RM2-aa-80-31, RM:RM4-14-80-2b
                    2023-10-30 10:20:19.467  - info: broadlink2.0 (150158) found macs: 24:df:a7:b1:1a:8d
                    2023-10-30 10:20:21.804  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:23.373  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:32.337  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:33.546  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:42.798  - warn: shelly.0 (14078) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                    2023-10-30 10:20:43.742  - warn: shelly.0 (14078) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                    DANKE für die Unterstützung
                    Thomas Braun 3 Replies Last reply Reply Quote 0
                      gemacht
                      Nein, das Paket muss frei schwimmen, unter Bookworm ist der Fehler nicht mehr vorhanden und deswegen muss das Paket auch nicht auf hold gesetzt werden.
                        @tapdance
                        Die Freigabe für die Backups würde ich nicht mit SMB V1 machen sondern mit der höchstmöglichen Variante.
                          Hast du vor dem Zurückspielen den Adapter Vis 'leer' angelegt?
                            hallo,
                            nein das habe ich nicht. Muss man das? geht das nachträglich noch und dann noch mal zurücksichern?
                            Wie macht man das?
                              Muss man das?
                              Ja, muss man. Ist ein Bug.
                              Wie macht man das?
                              Installier eine alte Version von vis und dann das Backup da nochmal drüber gießen.
                                Ich weiß ist bestimmt eine blöde Frage, aber wo finde ich eine alte Version wo vis? Auf der weboberfläche wird ja nur die aktuelle angezeigt
                                  @tapdance
                                  Da kann man aber auch Vorversionen finden.
                                  Ansonsten:
                                  iobroker upgrade vis@VERSIONSNUMMER
                                  Musst du mal schauen welche geht, das Problem hatten schon viele vor dir.
                                    habe alle probiert die ich finden konnte immer der gleiche fehler.
                                    PI@raspberrypi:~ $ iobroker upgrade vis@1.4.13
                                    Adapter "vis"            is not installed.
                                    PI@raspberrypi:~ $ iobroker upgrade vis@1.4.15
                                    PI@raspberrypi:~ $ iobroker upgrade vis@1.4.16
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.0.0
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.0.8
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.0.10
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.0.129
                                    ^[[API@raspberrypi:~ $ iobroker upgrade vis@2.0.29
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.0.36
                                    PI@raspberrypi:~ $ iobroker upgrade vis@2.1.4
                                    PI@raspberrypi:~ $
                                      danke für den Tipp habe einen Forum Eintrag gefunden der funktioniert hat.
                                      cd /opt/iobroker
                                      npm i iobroker.vis@1.4.6
                                      und anschließendes Update übers WebUI klappt's dann.
                                      Das hast gebracht. Vielen dank für die Unterstützung. Kann man das hier im Forum irgendwo auf gelöst setzen?
                                      619
