    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      mading @pingo last edited by
      @pingo AGBs akzeptiert? Loggˋ dich mal auf myvolkswagen ein
      P 2 Replies Last reply Reply Quote 0
        tombox @pingo last edited by
        @pingo kommt drauf an was der loggt sagt
          Mc-Rust last edited by Mc-Rust
          Moin, habe bei meinem Enyaq auch Probleme eine Verbindung mit dem Adpater zu bekommen.
          Hier meine Log:
          code_text
          ```vw-connect.0       2023-10-30 10:29:51.669	error	Restart Adapter in 30min
          vw-connect.0       2023-10-30 10:29:51.669	error	Login Failed
          vw-connect.0       2023-10-30 10:29:51.667	debug	client_id= **entfernt** @apps_vw-
          dilab_com&scope=openid%20mbb%20profile&response_type=code%20id_token%20token&redirect_uri=skodaconnect://oidc.login/&nonce=KRVQgQbmSAUHtAVu4CIjF1+bJIPbt/GJgK1b5mWOW0g&state=5bd0ce6f-3508-4bd2-9364-1cdee01b57ca
          vw-connect.0       2023-10-30 10:29:51.666	error	"default backend - 404"
          vw-connect.0       2023-10-30 10:29:51.666	error	404
          vw-connect.0       2023-10-30 10:29:51.665	error	Failed in first login step
          vw-connect.0       2023-10-30 10:29:51.230	info	Login in with skodae
          vw-connect.0       2023-10-30 10:29:51.203	info	starting. Version 0.2.0 (non-npm: ta2k/ioBroker.vw-connect) in
        /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.5.1, js-
        controller: 5.0.12
          vw-connect.0       2023-10-30 10:29:50.628	debug	Plugin sentry Initialize Plugin (enabled=true)
          vw-connect.0       2023-10-30 10:29:50.534	debug	States connected to redis: 127.0.0.1:9000
          vw-connect.0       2023-10-30 10:29:50.461	debug	States create User PubSub Client
          vw-connect.0       2023-10-30 10:29:50.459	debug	States create System PubSub Client
          vw-connect.0       2023-10-30 10:29:50.439	debug	Redis States: Use Redis connection: 127.0.0.1:9000
          vw-connect.0       2023-10-30 10:29:50.403	debug	Objects connected to redis: 127.0.0.1:9001
          vw-connect.0       2023-10-30 10:29:50.393	debug	Objects client initialize lua scripts
          vw-connect.0       2023-10-30 10:29:50.333	debug	Objects create User PubSub Client
          vw-connect.0       2023-10-30 10:29:50.328	debug	Objects create System PubSub Client
          vw-connect.0       2023-10-30 10:29:50.323	debug	Objects client ready ... initialize now
          vw-connect.0       2023-10-30 10:29:50.280	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
          ? 2 Replies Last reply Reply Quote 0
            A Former User @Mc-Rust last edited by
            @mc-rust sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
            Ich hoffe ihr könnt mir weiter helfen
            Moin,
            ja, Code in Code Tags </> packen, damit man das besser lesen kann und auch sagen welche Version, des Adapters man einsetzt.
            VG
            Bernd
              Mc-Rust @Guest last edited by
              @dp20eic
              Moin, so besser?
              Version ist die neuste!
              vw-connect.0 v0.2.0
                Moin,
                da passt ja irgendwas mit Deinem Login nicht.
                Moin, so besser?
                Jup, siehe oben.
                vw-connect.0 v0.2.0
                Habe ich auch gerade mal installiert, um zu schauen, ob es da vielleicht ein Problem mit gibt, aber funktioniert bei mir einwandfrei.
                VG
                Bernd
                  @dp20eic sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                  Moin,
                  ja, aber Daten sin die gleichen wie in der App und im Onlineportal.....
                  kann es etwas mit der Node und JS Version zu tun haben? Weil glaube, das es seid dem Update darauf war....
                    Moin,
                    Ich betreibe das alles mit Beta Repo. JS-Controller, Admin usw. sind alle auf dem neusten Stand und ich habe kein Login Problem, wobei ich aber VM habe und nicht Skoda.
                    Mach mal Debug aus, denn nach dem fehlerhaften Login, geht er ja auf den Skoda Login und der scheint ja zu funktionieren, nur dann ist das Log zu Ende, um zu sehen, was da evtl. noch kommt.
                    Hast Du auch den korrekten Typ gewählt?
                    VG
                    Bernd
                      @dp20eic
                      ja steht auf Skoda Enyaq.
                      debug auf aus? Also in der Instanzen Einstellung wieder auf INFO statt DEBUG!
                      Bleibt leider alles beim alten.
                        Läuft wieder.
                        habe nun viel geupdatet und und und.....nichts hat geholfen.
                        bin nun von der nodejs v20.5.1 auf version 18.18.2 mit iob nodejs-update runter gegangen und der Adapter
                        hat sich gleich verbunden.
                        Läuft also wieder. Warum das nun so war kann ich nicht sagen.
                        Trotzdem vielen Dank
                          pingo @tombox last edited by
                          @tombox : komischerweise trotz Debugmodus habe ich keine Infos im Log:
                          nur diese Quellen werden geloggt. Grrr:
                            pingo @mading last edited by
                            @mading Hab ich gemacht. Da sehe ich mein Fahrzeug und muss nix bestätigen
                              nodejs v20.5.1
                              Moin,
                              das ist ja auch keine offizielle Version!
                              Dann bitte beim nächsten Mal gleich mit solchen Informationen posten, oder besser gleich den langen Output vom Kommando, hier posten!
                              iob diag
                              VG
                              Bernd
                                Irgendwas mache ich weiter falsch:
                                Ich habe nun den Adapter deinstalliert und versucht nochmal neu zu installieren.
                                Er wird mir zwar als installiert angezeigt, aber leider nicht in der Liste der Instanzen.
                                Und nun?
                                  Mc-Rust @pingo last edited by
                                  @pingo
                                  Moin,
                                  unter Adapter hinten bei VW Connect auf das + gehen dann wird die Instanz erst installiert....
                                  I P 2 Replies Last reply Reply Quote 0
                                  • I
                                    ioBrokerMike @Mc-Rust last edited by ioBrokerMike
                                    Moin
                                    Habe auch seid heute mit einem ID3 Problem.
                                    App läuft
                                    Neu Angemeldet
                                    Fehler ?
                                    vw-connect.0
                                    2023-10-31 15:33:46.695	error	{"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true,"message":"Not Found"}}
                                    vw-connect.0
                                    2023-10-31 15:33:46.695	error	AxiosError: Request failed with status code 404
                                    vw-connect.0
                                    2023-10-31 15:33:46.460	error	{"error":{"code":4112,"group":2,"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support."}}
                                    vw-connect.0
                                    2023-10-31 15:33:46.460	error	AxiosError: Request failed with status code 404
                                    vw-connect.0
                                    2023-10-31 15:33:45.968	error	{"error":{"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2}}
                                    vw-connect.0
                                    2023-10-31 15:33:45.968	error	AxiosError: Request failed with status code 404
                                    vw-connect.0
                                    2023-10-31 15:33:45.770	error	{"error":{"group":2,"retry":true,"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112}}
                                    vw-connect.0
                                    2023-10-31 15:33:45.769	error	AxiosError: Request failed with status code 404
                                    EDIT : Bin wieder auf 0.0.67 zurück und bis her keine Meldungen mehr.
                                      pingo @Mc-Rust last edited by
                                      @mc-rust OK.
                                      Erst habe ich dies installiert:
                                      dann danach den Adapter mit + (guter Hinweis!)
                                      Er hat weitere keine Verbindung:
                                      und gibt mir keine debug infos im Log
                                      Irgendetwas mache ich noch grundsätzlich falsch 😠
                                        pingo @mading last edited by pingo
                                        @mading
                                        Obwohl ich in der Volkswagen APP alles erlaubt habe, kommt tatsächlich auf der myvolkswagen-Seite dieser Hinweis, wenn ich Ausstattungsdetails klicke:
                                        Nur finde ich dort und in der APP nichts, wo ich die Onlinedienste noch freischalten kann.
                                        In meinem Profil dort ist alles ok und erlaubt.
                                        Das Auto ist mit allem online und auch die APP!
                                        Im Auto ist auch alles erlaubt bzw. aktiviert.
                                        Gibt es da noch etwas, was ich übersehe?
                                          A Former User @pingo last edited by
                                          @pingo sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                          Moin,
                                          etwas schnippisch, geantwortet, ja, warum rufst Du nicht bei VW an und lässt Dir erklären, was da schiefläuft.
                                          Warum soll ich als Privatperson Support aus dem ioBroker Forum für einen Weltkonzern leisten, die bezahlen da Menschen dafür, dass Du sie mit Fragen löcherst 😉
                                          VG
                                          Bernd
                                          • RaspiUser
                                            RaspiUser last edited by RaspiUser
                                            ... immer am 1ten des Monats werden mir div. Daten aus dem Adapter geliefert.
                                            Heute nicht ... dafür habe ich erst jetzt bemerkt, das eh keine DP mehr da sind.
                                            Ich habe den Objekt-Baum gelöscht und den Adapter neu gestartet (er ist grün) und dann bekomme ich diesen Log-Einträge ...
                                            21
                                            Log-Größe: 1.7 KB
                                            Zeit
                                            Nachricht
                                            vw-connect.0
                                            	2023-11-01 11:24:50.345	error	get personal data Failed
                                            vw-connect.0
                                            	2023-11-01 11:24:50.344	error	Error: getaddrinfo ENOTFOUND customer-profile.apps.emea.vwapps.io
                                            vw-connect.0
                                            	2023-11-01 11:24:50.288	info	Login successful
                                            vw-connect.0
                                            	2023-11-01 11:24:48.111	info	Login in with vwv2
                                            vw-connect.0
                                            	2023-11-01 11:24:48.060	info	starting. Version 0.0.67 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.18.2, js-controller: 5.0.12
                                            vw-connect.0
                                            	2023-11-01 11:24:42.354	info	terminating
                                            vw-connect.0
                                            	2023-11-01 11:24:42.009	warn	State "vw-connect.0.info.connection" has no existing object, this might lead to an error in future versions
                                            vw-connect.0
                                            	2023-11-01 11:24:41.851	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            vw-connect.0
                                            	2023-11-01 11:24:41.849	info	terminating
                                            vw-connect.0
                                            	2023-11-01 11:24:41.848	info	cleaned everything up...
                                            vw-connect.0
                                            	2023-11-01 11:24:41.845	info	Got terminate signal TERMINATE_YOURSELF
                                            Was läuft falsch bei mir (oder VW) ?
                                            EDIT:
                                            Ich habe (mußte) vor kurzem auf "Druck" von VW die App gewechselt und mein connect Plus Abo läuft am 06.11. aus ... ist da ein Zusammenhang ?!
                                            EDIT:
                                            ... hab es gefunden ...
                                            @tombox
                                            Da gibt's demnächst bestimmt eine Stable-Version, oder ?
                                            Danke für den Adapter 👏
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1602361
