    3. Einsteigerfragen
    4. Installation
    5. Troubleshooting NodeJS update
      Thomas Braun Most Active @dos1973 last edited by
      @dos1973
      Und war es so grauenvoll wie befürchtet?
        dos1973 @Thomas Braun last edited by dos1973
        nein, deiner Beschreibung gefolgt (1A) und alles lief Perfekt.
          austrogaucho last edited by
          "curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -" hat funktioniert und hat mich von von 16.20.1 (nur) auf 18.7.1 gehoben (18.8.0 ist empfohlen)
          es kam aber folgende Meldung:
                                     SCRIPT DEPRECATION WARNING
            This script, located at https://deb.nodesource.com/setup_X, used to
            install Node.js is deprecated now and will eventually be made inactive.
            Please visit the NodeSource distributions Github and follow the
            instructions to migrate your repo.
            https://github.com/nodesource/distributions
            The NodeSource Node.js Linux distributions GitHub repository contains
            information about which versions of Node.js and which Linux distributions
            are supported and how to install it.
          TO AVOID THIS WAIT MIGRATE THE SCRIPT
          Continuing in 60 seconds (press Ctrl-C to abort) ...
          nach 1min gehts dann weiter mit:
          ## Installing the NodeSource Node.js 18.x repo...
          ## Populating apt-get cache...
          + apt-get update
          OK:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
          OK:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
          OK:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
          OK:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
          OK:5 https://deb.nodesource.com/node_18.x focal InRelease
          ## Confirming "focal" is supported...
          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/focal/Release'
          ## Adding the NodeSource signing key to your keyring...
          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
          ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' > /etc/apt/sources.list.d/nodesource.list
          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x focal main' >> /etc/apt/sources.list.d/nodesource.list
          ## Running `apt-get update` for you...
          + apt-get update
          ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
          ## You may also need development tools to build native addons:
               sudo apt-get install gcc g++ make
          ## To install the Yarn package manager, run:
               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
               sudo apt-get update && sudo apt-get install yarn
          Ich hab dann gemäß der Anleitung mit "sudo apt install -y nodejs" weitergemacht
          dann kam
          Die folgenden NEUEN Pakete werden installiert:
            nodejs
          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 14 nicht aktualisiert.
          Es müssen 28,9 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 188 MB Plattenplatz zusätzlich benutzt.
          Holen:1 https://deb.nodesource.com/node_18.x focal/main amd64 nodejs amd64 18.17.1-deb-1nodesource1 [28,9 MB]
          Es wurden 28,9 MB in 5 s geholt (5.334 kB/s).
          Vormals nicht ausgewähltes Paket nodejs wird gewählt.
          (Lese Datenbank ... 121482 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../nodejs_18.17.1-deb-1nodesource1_amd64.deb ...
          Entpacken von nodejs (18.17.1-deb-1nodesource1) ...
          nodejs (18.17.1-deb-1nodesource1) wird eingerichtet ...
          Trigger für man-db (2.9.1-1) werden verarbeitet ...
          ? wie komm ich nun auf die 18.8.0 ?
            Thomas Braun Most Active @austrogaucho last edited by
            @austrogaucho
            Mit dem Skript aus meiner Signatur.
            Pedder007 1 Reply Last reply Reply Quote 0
            • Pedder007
              Pedder007 @Thomas Braun last edited by Pedder007
              @thomas-braun sagte in Troubleshooting NodeJS update:
              Klasse Script! Hatte 'gefühlt' alle Zustände bzgl. des 18.18.0 er Updates:
              • 1x iOMaster, dediziert auf Raspi4B, mit in Info angezeigtem Update, allerdings keine Anzeige/Update per 'sudo apt update'.
              • 4x vermeintlich gleiche iOSlaves unter Proxmox, allerdings manchmal mit angezeigtem Update in Info und manchmal nicht und dann wiederum manchmal möglichem 'sudo apt update' per Konsole, allerdings auch nicht jeweils gleich bzgl. der in Info angezeigten Updates.
              Also eine bunte Mischung, wobei Ausgangslage überall der letzte Stand mit Node 18.17.1 inkl. passendem NPM war und ich auch im Glauben war, dass ich alle Instanzen immer gleich behandelt hatte.
              Mit dem Script habe ich sie alle 'gerade' bekommen. Danke @thomas-braun
                Happyuser20 last edited by Happyuser20
                Hallo zusammen.
                Ich wollte auf meinem IOB Slave (Raspi 3+) NodeJS von 16 auf 18 updaten.
                Ich fürchte ich habe das Teil komplett abgeschossen. Habe jetzt einen Raspi mit IOB ohne NodeJS.
                Es lässt sich auch das erstellte Backup nicht mehr zurückspielen.
                @Thomas-Braun Dein Script knackt meine vermurkste Installation auch nicht 😞
                *** nodejs is NOT correctly installed ***
                We found these nodejs versions available for installation:
                nodejs:
                  Installed: (none)
                  Candidate: 18.18.2-1nodesource1
                  Version table:
                     18.18.2-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                Press <y> to continue or any other key to quit
                Fixing your nodejs setup
                *** Deleting  ***
                rm: cannot remove '': No such file or directory
                *** Deleting  ***
                *** Deleting  ***
                Wrong paths have been fixed. Run 'iob diag' or 'iob node-fix' again to check if your installation is fine now
                ./iob_node_update: line 248: node: command not found
                You are running nodejs . Do you want to install latest version from nodejs v.18 branch?
                Trying to fix your installation now. Please be patient.
                Waiting for ioBroker to shut down - Give me a minute...
                *** Removing previous installations of nodejs
                E: Unable to locate package nodejs
                E: Unable to locate package libnode*
                E: Couldn't find any package by glob 'libnode*'
                E: Couldn't find any package by regex 'libnode*'
                E: Unable to locate package node-*
                E: Couldn't find any package by glob 'node-*'
                E: Couldn't find any package by regex 'node-*'
                *** These repos are active on your system:
                Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                Ign:2 http://raspbian.raspberrypi.org/raspbian stretch Release
                Ign:3 http://raspbian.raspberrypi.org/raspbian stretch/main all Packages
                Ign:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
                Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
                Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
                Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
                Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
                Ign:10 http://raspbian.raspberrypi.org/raspbian stretch/non-free all Packages
                Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
                Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
                Ign:13 http://raspbian.raspberrypi.org/raspbian stretch/rpi armhf Packages
                Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
                Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
                Reading package lists... Done
                W: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does not have a Release file.
                N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
                N: See apt-secure(8) manpage for repository creation and user configuration details.
                E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/main/binary-armhf/Packages  404  Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
                E: Some index files failed to download. They have been ignored, or old ones used instead.
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Ign:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                Ign:6 http://raspbian.raspberrypi.org/raspbian stretch/main Translation-en
                Ign:7 http://raspbian.raspberrypi.org/raspbian stretch/contrib all Packages
                Ign:8 http://raspbian.raspberrypi.org/raspbian stretch/contrib armhf Packages
                Ign:9 http://raspbian.raspberrypi.org/raspbian stretch/contrib Translation-en
                Ign:11 http://raspbian.raspberrypi.org/raspbian stretch/non-free armhf Packages
                Ign:12 http://raspbian.raspberrypi.org/raspbian stretch/non-free Translation-en
                Ign:14 http://raspbian.raspberrypi.org/raspbian stretch/rpi all Packages
                Ign:15 http://raspbian.raspberrypi.org/raspbian stretch/rpi Translation-en
                Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                Installing the recommended nodejs version now!
                ./iob_node_update: line 336: [: : integer expression expected
                Exact recommended version unknown, installing a fallback!
                E: Unable to correct problems, you have held broken packages.
                Updating fallback to latest nodejs v18 release
                E: Broken packages
                ./iob_node_update: line 349: node: command not found
                 has been installed! You are using the latest version now!
                ./iob_node_update: line 353: [: : integer expression expected
                Installing the recommended nodejs version!
                E: Broken packages
                We tried our best to fix your nodejs. Please run iob diag again to verify.
                *** RESTARTING ioBroker NOW! ***
                 Please refresh or restart your browser in a few moments.
                Gibt es noch eine Möglichkeit das ding zu retten?
                Danke für eure Hilfe schon mal im voraus.
                  Thomas Braun Most Active @Happyuser20 last edited by
                  @happyuser20
                  Dein 'stretch' ist so tot, das stinkt nicht mal mehr. Installier da zunächst ein lebendes Betriebssystem.
                    Happyuser20 @Thomas Braun last edited by
                    Komplett neu aufsetzten, richtig?
                    Sorry für die doofe Frage.
                      @happyuser20
                      Röchtösch!
                        Dann weis ich schon was ich am Feiertag mache 😉
                          Baki074 last edited by
                          ich habe mit dem Befehl sudo apt install -y nodejs Probleme.
                          Und zwar erhalte ich die Meldung "Fehlschlag beim Holen von...".
                          sudo apt-get update habe ich schon versucht. Hat für die Installation nichts gebracht - derselbe Fehler wird angezeigt.
                          Was genau muss ich machen, damit die Installation klappt?
                          Danke schonmal!
                          pi@phoscon-iob:~ $ sudo apt install -y nodejs
                            nodejs
                          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                          Es müssen 25,9 MB an Archiven heruntergeladen werden.
                          Nach dieser Operation werden 177 MB Plattenplatz zusätzlich benutzt.
                          Fehl:1 https://deb.nodesource.com/node_18.x buster/main armhf nodejs armhf 18.17.1-deb-1nodesource1
                            404  Not Found [IP: 172.67.10.205 443]
                          E: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.17.1-deb-1nodesource1_armhf.deb 404  Not Found [IP: 172.67.10.205 443]
                          E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                          pi@phoscon-iob:~ $ sudo apt-get update
                          OK:1 http://phoscon.de/apt/deconz buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          OK:3 http://archive.raspberrypi.org/debian buster InRelease
                          OK:4 https://deb.nodesource.com/node_18.x buster InRelease
                            Thomas Braun Most Active @Baki074 last edited by
                            @baki074
                            Buster ist tot. Muss ersetzt werden.
                            Und das Update von nodejs geht über
                            iob nodejs-update
                            (Ggfls. zuvor iob fix ausführen).
                              Baki074 @Thomas Braun last edited by
                              @thomas-braun Super, hat funktioniert - danke!
                              Blöde Frage: Kann ich Debian 10 easy durch 11 ersetzen bzw. gibt es vielleicht eine Schritt für Schritt Anleitung hierfür?
                                Thomas Braun Most Active @Baki074 last edited by Thomas Braun
                                @baki074
                                https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                Aktuell ist allerdings Debian 12 'Bookworm'.
                                https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                                  marian.t @Thomas Braun last edited by
                                  Habe nach einem Update auf node.js 18.18.2 iobroker bis auf lovelace-UI am laufen.
                                  Lovelace-UI bricht wiederkehrend ab (wird terminated).
                                  Das betrifft sowohl node.js update auf buster als auch eine komplette Neuinstallation von iobroker auf bookworm und einem anderem raspi. Logs und weitere Details unter
                                  https://github.com/ioBroker/ioBroker.lovelace/issues/476.
                                  Hier Logeintrag vom Host:
                                  „States 127.0.0.1:37204 Error from InMemDB: Error: The pattern "typeof window.socketLoadedHandler === 'function' && window.socketLoadedHandler()" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2497:15) at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59) at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14) at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:395:26) at RedisHandler.emit (node:events:517:28) at RedisHandler.emit (node:domain:489:12) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37) at processImmediate (node:internal/timers:476:21)“
                                  Kann ich es korrigieren? Falls ja wo/wie? Oder hilft ein Downgrade von nod.js auf 16.x?
                                  marian-t-web-de created this issue in ioBroker/ioBroker.lovelace
                                  closed Iobroker lovelace-UI permamently crashes under Node.js 18.18.2 #476
                                    Thomas Braun Most Active @marian.t last edited by Thomas Braun
                                    @marian-t sagte in Troubleshooting NodeJS update:
                                    Da nodejs@16 jenseits des EndOfLife ist: Nein.
                                    Poste das mal beim js-controller, könnte auch von dort kommen.
                                      Wednesday13 last edited by
                                      Hi zusammen!
                                      ich komme mit meinem längst fälligen Update auch nicht weiter... folgende Fehlermeldung wird mir ausgeworfen:
                                      pi@raspberrypi3iOb:~ $ curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                      • apt-get update
                                        Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                        OK:2 https://deb.nodesource.com/node_14.x buster InRelease
                                        Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                        E: Für das Depot »http://archive.raspberrypi.org/debian buster InRelease« wurde der »Suite«-Wert von »testing« in »o ldoldstable« geändert.
                                        N: Sie müssen dies explizit bestätigen, bevor Aktualisierungen von diesem Depot angewendet werden können. Lesen Sie die apt-secure(8)-Handbuchseite, wenn Sie weitere Informationen benötigen.
                                        E: Für das Depot »http://raspbian.raspberrypi.org/raspbian buster InRelease« wurde der »Suite«-Wert von »stable« in »oldoldstable« geändert.
                                        Error executing command, exiting
                                      könnt ihr mir sagen wie ich jetzt weiterkomme?
                                      Danke euch!
                                      DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                                      • DJMarc75
                                        DJMarc75 @Wednesday13 last edited by DJMarc75
                                        @wednesday13 sagte in Troubleshooting NodeJS update:
                                        zu erst solltest Du den uns unbekannten Übersetzer ausschalten. Linux ist und bleibt englisch 😉
                                        Zweitens bitte alles an Text hier in Codetags einbinden.
                                        Das ist oben der </> Button.
                                          Thomas Braun Most Active @Wednesday13 last edited by Thomas Braun
                                          Mit dem Kommando
                                          iob nodejs-update
                                          Dein buster ist aber tot. Installier da was lebendiges. Und mach regelmäßig Updates...
                                          Kann ja nicht sein, dass dein Suite von 'stable' auf 'oldoldstable' springt. Dann hast du ja nie was gemacht...
                                            Wednesday13 @Thomas Braun last edited by
                                            @thomas-braun Danke dir für die Antwort. Ich bin absolut froh, dass ich das Dingen so zum laufen bekommen habe vor einiger Zeit. 🙄 Bin da absolut kein Profi drin. Kannst du mir das genauer erklären was ich machen muss?
                                            nodejs 18 nodejs update
                                            60
                                            504
                                            143318
