    4. Absturz aller Adapter nach Upgrade auf js-controller 5
      Jens77 @Thomas Braun last edited by Jens77
      @thomas-braun Danke.
      Die Postgres-Pakete würden Postgres-16 installieren, ich verwende für Teslamate derzeit Postgres-14, daher werde ich die zurückhalten. Das hat mit meinem iobroker-Problem aber ziemlich sicher nichts zu tun.
      iob diag verlangt noch nach einem nodejs binary, welches seit nodejs 16 nicht mehr existiert (zumindest nicht in den Paketen von nodesource.com).
      *** BASE SYSTEM ***
      Static hostname: raspberry64
      Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
      Kernel: Linux 6.1.19-v8+
      Architecture: arm64
      Model : Raspberry Pi 4 Model B Rev 1.2
      Docker : false
      Virtualization : none
      Kernel : aarch64
      Userland : arm64
      Systemuptime and Load:
      20:11:34 up 49 days, 3:25, 6 users, load average: 2.13, 1.94, 1.47
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      This system needs to be REBOOTED!
      *** Time and Time Zones ***
      Local time: Mon 2023-10-30 20:11:35 CET
      Universal time: Mon 2023-10-30 19:11:35 UTC
      RTC time: n/a
      NTP service: active
      RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal: tty
      Boot Target: multi-user.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 3.8G 1.9G 154M 20M 1.7G 1.7G
      Swap: 3.8G 91M 3.7G
      Total: 7.6G 2.0G 3.9G
           3793 M total memory
           1935 M used memory
           1079 M active memory
           1656 M inactive memory
            154 M free memory
             49 M buffer memory
           1654 M swap cache
           3802 M total swap
             91 M used swap
           3711 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      • hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
      LOAD = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/root ext4 440G 77G 346G 19% /
      devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev
      tmpfs tmpfs 1.9G 224K 1.9G 1% /dev/shm
      tmpfs tmpfs 759M 1.1M 758M 1% /run
      tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
      /dev/sda1 vfat 253M 31M 222M 13% /boot
      tmpfs tmpfs 380M 8.0K 380M 1% /run/user/1000
      [Mon Sep 11 17:46:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:73:2C:88 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=38be9e7a-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): 13 orphan inodes deleted
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): recovery complete
      [Mon Sep 11 17:46:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Sep 11 17:46:05 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Mon Sep 11 17:46:07 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET SOURCE FSTYPE OPTIONS
      / /dev/sda2 ext4 rw,noatime
      `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      17G /var/
      7.7G /var/lib
      4.9G /var/log
      3.2G /var/log/journal/82d4f63990114b27bac41e9b3e9a49f1
      Archived and active journals take up 3.1G in the file system.
      /opt/iobroker/backups:
      603M /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      247M /opt/iobroker/iobroker-data/
      160M /opt/iobroker/iobroker-data/files
      67M /opt/iobroker/iobroker-data/backup-objects
      52M /opt/iobroker/iobroker-data/files/javascript.admin
      34M /opt/iobroker/iobroker-data/files/javascript.admin/static
      21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
      8.3M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js
      7.9M /opt/iobroker/iobroker-data/objects.jsonl
      7.1M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
      6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 277: nodejs: command not found
      /usr/bin/node v18.17.1
      /usr/bin/npm 9.6.7
      /usr/bin/npx 9.6.7
      /usr/bin/corepack 0.18.0
      /home/iobroker/.diag.sh: line 288: nodejs: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
      *** 18.17.1-deb-1nodesource1 500
      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
      100 /var/lib/dpkg/status
      12.22.12~dfsg-1~deb11u4 500
      500 http://deb.debian.org/debian bullseye/main arm64 Packages
      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Core adapters versions
      js-controller: 5.0.12
      admin: 6.12.0
      javascript: 7.1.4
      Adapters from github: 0
      Adapter State
      • system.adapter.admin.0 : admin : raspberry64 - enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
      • system.adapter.backitup.0 : backitup : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.bydhvs.0 : bydhvs : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.deconz.0 : deconz : raspberry64 - enabled, compact enabled (group 1), port: 80
      • system.adapter.discovery.0 : discovery : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.fritzdect.0 : fritzdect : raspberry64 - enabled, compact enabled (group 1)
        system.adapter.habpanel.0 : habpanel : raspberry64 - enabled
      • system.adapter.influxdb.0 : influxdb : raspberry64 - enabled, compact enabled (group 1), port: 8086
      • system.adapter.iqontrol.0 : iqontrol : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.javascript.0 : javascript : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.mqtt.0 : mqtt : raspberry64 - enabled, compact enabled (group 1), port: 1884, bind: 0.0.0.0
        system.adapter.net-tools.0 : net-tools : raspberry64 - disabled, compact disabled
        system.adapter.netatmo.0 : netatmo : raspberry64 - disabled, compact disabled
      • system.adapter.node-red.0 : node-red : raspberry64 - enabled, compact enabled (group 1), port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0 : openweathermap : raspberry64 - enabled, compact enabled (group 1)
        system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberry64 - disabled, compact enabled (group 1)
      • system.adapter.plenticore.0 : plenticore : raspberry64 - enabled, compact enabled (group 1), port: 80
      • system.adapter.rpi2.0 : rpi2 : raspberry64 - enabled
        system.adapter.smartcontrol.0 : smartcontrol : raspberry64 - disabled, compact enabled (group 1)
      • system.adapter.sonoff.0 : sonoff : raspberry64 - enabled, compact enabled (group 1), port: 1883, bind: 0.0.0.0
      • system.adapter.tesla-motors.0 : tesla-motors : raspberry64 - enabled, compact disabled
      • system.adapter.tr-064.0 : tr-064 : raspberry64 - enabled, compact enabled (group 1)
        system.adapter.weatherunderground.0 : weatherunderground : raspberry64 - enabled, compact enabled (group 1)
      • system.adapter.web.0 : web : raspberry64 - enabled, compact enabled (group 1), port: 8082, bind: 0.0.0.0, run as: admin
      • instance is alive
      ioBroker-Repositories
      stable : http://download.iobroker.net/sources-dist.json
      beta : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter "admin" : 6.12.0 , installed 6.12.0
      Adapter "backitup" : 2.8.1 , installed 2.8.1
      Adapter "bydhvs" : 1.4.0 , installed 1.4.0
      Adapter "deconz" : 1.3.21 , installed 1.3.21
      Adapter "discovery" : 3.1.0 , installed 3.1.0
      Adapter "fritzdect" : 2.3.1 , installed 2.3.1
      Adapter "habpanel" : 0.5.0 , installed 0.5.0
      Adapter "influxdb" : 3.2.0 , installed 3.2.0
      Adapter "iqontrol" : 2.3.0 , installed 2.3.0
      Adapter "jarvis" : 3.1.2 , installed 3.1.2
      Adapter "javascript" : 7.1.4 , installed 7.1.4
      Controller "js-controller": 5.0.12 , installed 5.0.12
      Adapter "mqtt" : 4.1.1 , installed 4.1.1
      Adapter "net-tools" : 0.2.0 , installed 0.2.0
      Adapter "netatmo" : 3.1.0 , installed 3.1.0
      Adapter "node-red" : 4.0.3 , installed 4.0.3
      Adapter "openweathermap": 0.3.9 , installed 0.3.9
      Adapter "panasonic-comfort-cloud": 2.2.4, installed 2.2.4
      Adapter "plenticore" : 2.2.0 , installed 2.2.0
      Adapter "rpi2" : 1.3.2 , installed 1.3.2
      Adapter "simple-api" : 2.7.2 , installed 2.7.2
      Adapter "smartcontrol" : 2.0.1 , installed 2.0.1
      Adapter "socketio" : 6.5.5 , installed 6.5.5
      Adapter "sonoff" : 2.5.3 , installed 2.5.3
      Adapter "synology" : 3.0.0 , installed 3.0.0
      Adapter "tesla-motors" : 1.3.2 , installed 1.3.2
      Adapter "tr-064" : 4.2.18 , installed 4.2.18
      Adapter "weatherunderground": 3.6.0, installed 3.6.0
      Adapter "web" : 6.1.2 , installed 6.1.2
      Adapter "ws" : 2.5.5 , installed 2.5.5
      Objects and States
      Objects: 6466
      States: 5552
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
      Ign:5 http://binaries.erlang-solutions.com/debian stretch InRelease
      Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:7 http://binaries.erlang-solutions.com/debian stretch Release
      Hit:8 https://apt.grafana.com stable InRelease
      Hit:9 https://repos.influxdata.com/debian bullseye InRelease
      Get:10 https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version InRelease [8263 B]
      Hit:11 https://packages.sury.org/php bullseye InRelease
      Hit:12 http://apt.postgresql.org/pub/repos/apt bullseye-pgdg InRelease
      Hit:13 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:14 https://packagecloud.io/timescale/timescaledb/debian bullseye InRelease
      Fetched 8263 B in 6s (1438 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:45293 0.0.0.0:* LISTEN 0 101007442 3558521/containerd
      tcp 0 0 127.0.0.1:4100 0.0.0.0:* LISTEN 1003 100600466 3450285/beam.smp
      tcp 0 0 0.0.0.0:32943 0.0.0.0:* LISTEN 1003 100601531 3450285/beam.smp
      tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 0 100598861 3449771/dnsmasq
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 101006440 3558544/sshd: /usr/
      tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 101006581 3558589/deCONZ
      tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 101007552 3558589/deCONZ
      tcp 0 0 0.0.0.0:4369 0.0.0.0:* LISTEN 1003 100601919 3450336/epmd
      tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 100746363 3486227/iobroker.js
      tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 100745357 3486227/iobroker.js
      tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 110 100596344 3449823/postgres
      tcp 0 0 0.0.0.0:8000 0.0.0.0:* LISTEN 0 59433239 124555/docker-proxy
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 100905151 3527193/iobroker.js
      tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 1001 100905102 3527354/node-red
      tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 1001 100902643 3527193/iobroker.js
      tcp 0 0 172.17.0.1:5432 0.0.0.0:* LISTEN 110 100596345 3449823/postgres
      tcp 0 0 127.0.0.1:2019 0.0.0.0:* LISTEN 998 100555213 3427267/caddy
      tcp6 0 0 :::3000 :::* LISTEN 115 100474205 3407841/grafana
      tcp6 0 0 :::53 :::* LISTEN 0 100598863 3449771/dnsmasq
      tcp6 0 0 :::4101 :::* LISTEN 998 100553324 3427267/caddy
      tcp6 0 0 :::22 :::* LISTEN 0 101006442 3558544/sshd: /usr/
      tcp6 0 0 :::81 :::* LISTEN 998 100553327 3427267/caddy
      tcp6 0 0 :::4369 :::* LISTEN 1003 100601920 3450336/epmd
      tcp6 0 0 :::8082 :::* LISTEN 1001 100905309 3527193/iobroker.js
      tcp6 0 0 :::8081 :::* LISTEN 1001 100903176 3527193/iobroker.js
      tcp6 0 0 :::8086 :::* LISTEN 999 100552823 3426555/influxd
      tcp6 0 0 :::6000 :::* LISTEN 998 100553326 3427267/caddy
      udp 0 0 169.254.39.1:5353 0.0.0.0:* 1001 100905131 3527193/iobroker.js
      udp 0 0 172.17.0.1:5353 0.0.0.0:* 1001 100905130 3527193/iobroker.js
      udp 0 0 192.168.178.54:5353 0.0.0.0:* 1001 100905129 3527193/iobroker.js
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 100595343 3449495/avahi-daemo
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 101006633 3558589/deCONZ
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902803 3527193/iobroker.js
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902801 3527193/iobroker.js
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 100902798 3527193/iobroker.js
      udp 0 0 0.0.0.0:53 0.0.0.0:* 0 100598860 3449771/dnsmasq
      udp 0 0 0.0.0.0:67 0.0.0.0:* 0 100598857 3449771/dnsmasq
      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 100595687 3449541/dhcpcd
      udp 0 0 0.0.0.0:53734 0.0.0.0:* 108 100595345 3449495/avahi-daemo
      udp6 0 0 :::5353 :::* 108 100595344 3449495/avahi-daemo
      udp6 0 0 :::1900 :::* 1001 100902804 3527193/iobroker.js
      udp6 0 0 :::1900 :::* 1001 100902802 3527193/iobroker.js
      udp6 0 0 :::1900 :::* 1001 100902800 3527193/iobroker.js
      udp6 0 0 :::1900 :::* 1001 100902799 3527193/iobroker.js
      udp6 0 0 :::4101 :::* 998 100553325 3427267/caddy
      udp6 0 0 :::53 :::* 0 100598862 3449771/dnsmasq
      udp6 0 0 :::55643 :::* 108 100595346 3449495/avahi-daemo
      udp6 0 0 :::546 :::* 0 100595686 3449541/dhcpcd
      2023-10-30 20:04:50.660 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:05:21.161 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:05:52.873 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:06:26.928 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:07:00.837 - info: influxdb.0 (COMPACT) Store 202 buffered influxDB history points
      2023-10-30 20:07:28.914 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:08:03.707 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:08:12.672 - info: plenticore.0 (COMPACT) Read forecast data before calcMinSoC.
      2023-10-30 20:08:13.146 - info: plenticore.0 (COMPACT) calcMinSoC for day 1.
      2023-10-30 20:08:13.189 - info: plenticore.0 (COMPACT) calcMinSoC for day 2.
      2023-10-30 20:08:13.189 - info: plenticore.0 (COMPACT) Using forecast of day 2 for MinSoC calculation.
      2023-10-30 20:08:15.354 - info: plenticore.0 (COMPACT) got weather data from met.no with 88 elements.
      2023-10-30 20:08:15.559 - info: plenticore.0 (COMPACT) Requested weather data from kachelmannwetter.com
      2023-10-30 20:08:15.698 - info: plenticore.0 (COMPACT) Requested alternative weather data from kachelmannwetter.com
      2023-10-30 20:08:15.707 - info: plenticore.0 (COMPACT) Got all internal forecast data and made it available to main process.
      2023-10-30 20:08:33.873 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:09:06.688 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:09:37.545 - info: influxdb.0 (COMPACT) Store 202 buffered influxDB history points
      2023-10-30 20:10:12.184 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:10:41.886 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:11:15.880 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:11:47.310 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:12:18.711 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:12:52.500 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      2023-10-30 20:13:22.934 - info: influxdb.0 (COMPACT) Store 201 buffered influxDB history points
      [/s]
      Danke für jede Hilfe!
        Thomas Braun Most Active @Jens77 last edited by
        @jens77 sagte in Absturz aller Adapter nach Upgrade auf js-controller 5:
        Doch, in den aktuellen Versionen ist es drin. Installier das.
          @jens77 >
            @thomas-braun Wie heißt denn das Paket?
            nodejs (v18) ist bereits installiert.
              @jens77
              Das Repo muss umgestellt werden.
              Kannst du per Skript / Kommando machen
              iob nodejs-update
                @thomas-braun Meine beschriebenen iob-Probleme traten schon auf, bevor neu gestartet werden sollte. Ich habe erst als diese Probleme auftraten ein apt upgrade nachgeschoben, wobei (u.a.) ein neuer Kernel installiert wurde, der jetzt den Neustart fordert.
                Ich denke also nicht, dass es daran liegen wird.
                  Nein, aber mach es, damit die Updates auch greifen. Die Meldung kommt nicht aus Jux und Dollerei, die hat schon einen Hintergrund.
                    Das Skript ist lustig:
                    Nothing to do - Your installation is using the correct paths.
                    You are running nodejs v18.17.1. Do you want to install recommended version 18.18.2?
                    Was denn jetzt? 🙂
                    Installing the recommended nodejs version now!
                    /home/iobroker/.nodejs-update.sh: line 331: [: : integer expression expected
                    /home/iobroker/.nodejs-update.sh: line 348: [: : integer expression expected
                    Installing the recommended nodejs version!
                    (Reading database ... 89181 files and directories currently installed.)
                    Preparing to unpack .../nodejs_18.18.2-1nodesource1_arm64.deb ...
                    Detected old npm client, removing...
                    Unpacking nodejs (18.18.2-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                    Setting up nodejs (18.18.2-1nodesource1) ...
                    Gerade probiert - Problem tritt immer noch exakt so auf wie anfangs beschrieben, auch mit Node 18.18.
                      Thomas Braun Most Active @Jens77 last edited by Thomas Braun
                      Was denn jetzt?
                      Die Installations-Pfade sind richtig, an der Stelle ist also nichts zu tun, die Version ist allerdings nicht richtig/die aktuelle.
                      Und genau das wird gemeldet.
                      Also ganz 'unlustig' die richtige Diagnose.
                        @thomas-braun Das stimmt wohl.
                        Der Vollständigkeit halber mache ich jetzt mal einen Neustart, melde mich dann zurück (das kann allerdings etwas dauern). Danke schon mal!
                          @jens77
                          Da hats mal Einschläge im Dateisystem gegeben:
                          Da gibt es mit Sicherheit aber auch ein für Bullseye passendes Repo.
                          mcm1957 J 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @Thomas Braun last edited by
                            @Jens77
                            Versuch mal das System OHNE Compact mode zu betreiben. Ich hab im Hinterkopf ein komisches Problem bei einem anderen Adapter das mit Compaq Mode zusammen hängen könnte. War damals nicht mehr reproduzierbar. Ist zwar nur ein Hintergrundgedanke und kann absoluter Blödsinn sein - aber wenn dein Problem ohne Compact Mode nicht auftritt und mit schon, dann mention bitte Foxriver76 damit er sich einklinkt. Dann könnte (BETONUNG könnte) ein Problem mit js-controller 5 und compact Mode existieren.
                            Aber wie geschrieben - ist nur ein Hintergrundgedanke und kann total falsch sein !
                            mcm1957 J 2 Replies Last reply Reply Quote 1
                            • mcm1957
                              mcm1957 @mcm1957 last edited by
                              Und noch was:
                              Wenn da was abstürzt bitte den gesammten Log hier anhängen.
                              Derzeit seh ich nicht wirklich ewas du unter 'stürzt ab' verstehst bzw.w eclhe Fehlermeldungen genau auftreten.
                                @thomas-braun Korrekt, die Dateisystemfehler wurden behoben. (auch offline noch mal)
                                Zum Thema Erlang: damals leider nicht. Das (brauche ich für Teslamate) ist aber auch völlig unabhängig von iobroker.
                                  Aber nicht unabhänigig vom Gesamtsystem.
                                    Jens77 @mcm1957 last edited by
                                    @mcm57 Habe ich versucht. Die 520kb lassen das Forensystem abstürzen, jedes Mal wieder.
                                    Daher habe ich die 100-fachen Wiederholmeldungen rausgekürzt und den Rest hinter Spolier-Tags versteckt.
                                    Aber hier bitte: https://share.rb-hosting.de/s/fkqJWp2RinWCN9S
                                    Da ist das vollständige Log eines Adapter-Neustarts.
                                      @thomas-braun Nein, natürlich nicht. Alles ist verbunden.
                                      Aber man sollte nach Plausibilität priorisieren. Es gibt Dinge, die haben einen wahrscheinlichen Einfluss und Dinge, deren Einfluss ist eher unwahrscheinlich, und Dinge, denen Einfluss zu unterstellen wäre geradezu absurd.
                                      Ansonsten kommt der nächste und fragt nach der Konfiguration unserer Fritzbox, oder was ich zum Abendessen hatte. 🙂
                                        @mcm57 Dann klick mal in meiner Originalmeldung auf die Spoiler-Tags. Da sind die Absturz-logs zitiert.
                                        Oder lad dir das ganze Log herunter, das konnte ich hier nicht posten, siehe Link in der vorigen Nachricht.
                                          @jens77
                                          Schalt den Compact-Mode mal aus.
                                            Jens77 @mcm1957 last edited by Jens77
                                            @mcm57 das habe ich jetzt gemacht. Bisher ist der Fehler nicht wieder aufgetreten, Adapter lassen sich normal neu starten.
                                            Leider braucht ioBroker ohne Compact Mode mit allen Adaptern fast 2GB RAM, da fängt der Raspi irgendwann an zu schwitzen, das ist also keine langfristige Lösung.
                                            @Foxriver76, kannst du hier weiterhelfen? Vielleicht habe ich einen Bug im compact mode des neuen js-controllers gefunden. Danke für jede Hilfe!
                                            Nochmal zusammengefasst: Der Neustart einzelner Adapter (egal welcher, passiert mit allen, immer) lässt seit Update auf js-controller 5 (von 4) und Node 18 (von 14) den ganzen ioBroker abstürzen, weil die "states database" plötzlich für alle Adapter nicht mehr verfügbar ist. Beispiel-Logfile ist oben verlinkt.
                                            apt upgrade inkl. Reboot half nicht, iob upgrade-nodejs half nicht, iob fix half nicht, die Festplatte hat noch genügend Platz frei (>300GB), aber seit Deaktivieren des Compact Modes mit iob compact off scheint das Problem weg. Nur werde ich damit über kurz oder lang ein RAM-Problem auf dem Raspi bekommen, daher würde ich den Compact Mode gerne wieder anschalten, mit js-controller 4.x lief der über Jahre problemlos.
                                            2369
